    How to update script on 100 boards
    lopyloracodefirmware updatefirmware
    8 Posts 4 Posters 2.0k Views 4 Watching
      gruia.nichita
      For example I have 100 LoPy, they seted in one building and I need to update code on all boards? The building is covered LoRa and all devices use this network. How I can solve this?
        this.wiederkehr
        While it might be technically possible to use lora to distribute an upgrade it seems not to be useful. Lora at most has a bandwith of 50000 bit/s and there are regulatory requirements about the on-air-time of a device which is very limited (I think it usually is 1%). This means you are better of distributing firmware upgrades using wifi (if you have the chance). This is also the "supported" method by pycom, see here:
        https://docs.pycom.io/chapter/tutorials/all/ota.html
        If lora really is the only connection you have, you'd have to define your one protocol (which will be hard, think security, authentication, mac ...). lorawan for this purpose is not feasible due to the short payload size of maximum 250 symbols.
        G 2 Replies Last reply Reply Quote 2
          crumble @gruia.nichita
          @gruia-nichita said in How to update script on 100 boards:
          You can send a message over LoRa. The LoPys than build up a WiFi connection over which you can send the updates. If your building has a good WiFi coverage you will reach most of the LoPys. If they send you success messages and you maped the locations well, you need to go only to some and start the update process with a mobile access point again.
            gruia.nichita @this.wiederkehr
              @this-wiederkehr Today I tried to apply this method, but appeared some errors. I configured file with info about WiFi and IP, app_eui, app_key like in my TTN app.
              T sebS 2 Replies Last reply Reply Quote 0
                this.wiederkehr @gruia.nichita
                @gruia-nichita: Sorry, I can't provide support for that. Ask pycom directly ...
                • sebS Offline
                  seb @gruia.nichita
                  @gruia-nichita Are you also running the provided server software to provide the update files?
                    gruia.nichita @seb
                    @seb It's my bad. I have missed that service was listening just on localhost, that's why I was not able to receive any file.
