    Lopy with pytrack, how connect/use GPS?
    gpslopypytrack
    76 Posts 5 Posters 35.6k Views 5 Watching
      crumble @zceld
      @zceld LoRa is like a radio in citizen band. Anyone can send messages around and all have to listen to them. So you may receive data from other devices as well.
      Too solve your specific problem you shall set in your receiver blocking to true. This will wait until you reveived a message. If it is false it will not wait to receive a message in line `data = s.recv(64)
      So it will continue with an empty string, because it has not received a message.
      Setting blocking mode to false is useful, if you want to run your loop until you received a certain message. Setting it to true is useful if you want to start the loop after you received a message.
      If you have only nonblocking calls and you want to wait for a message, you have to call it in a loop until something receives. This will need a lot of battery power.
      If you want to run a loop until you receive a certain message and you have only blocking calls, you have to use multi threading to solve this problem. This will not consume much battery power, but it makes your code more complex.
        livius @zceld
        @zceld said in Lopy with pytrack, how connect/use GPS?:
        Thank you very much for the recommendation but using 'microGPS' gives me a lack of memory again.
        When and where do you create microGPS object instance?
        • Z Offline
          zceld @crumble
          @crumble
          I am very interested in what you say, because what really interests me is that the Lora system is in a listening mode until I receive a message, when we receive a message we can do something specific.
          So a possible solution would be changing s.setblocking (True) like this?:
          from network import LoRa
          lora = LoRa(mode=LoRa.LORA)
                s.setblocking(True)
                data = s.recv(64)
                print(data)
          • Z Offline
            zceld @livius
            @livius
            Well no, I just ran microGPS as if it were the main. So you want to say that microGPS is a library and that to give me the coordinates I should develop a code like this one but with the library 'microGPS'?
            Example code:
            import math
            import network
            import utime
            from machine import RTC
            from machine import SD
            from machine import Timer
            from L76GNSS import L76GNSS
            from pytrack import Pytrack
            #send with LoRa:
            # setup as a station
            import gc
            gc.enable()
            # setup rtc
            rtc = machine.RTC()
            rtc.ntp_sync("pool.ntp.org")
            utime.sleep_ms(750)
            utime.timezone(7200)
            py = Pytrack()
            l76 = L76GNSS(py, timeout=30)
            chrono = Timer.Chrono()
            chrono.start()
            while (True):
                coord = l76.coordinates()
              crumble @zceld
              Yes. You need to set it only once outside the loop:
              s.setblocking(True)
                 data = s.recv(64)
                 print(data)
              • Z Offline
                zceld @crumble
                @crumble
                Great! thank you very much. Now I just need to be able to connect via Wi-Fi directly to Lopy, I do not know what the password is:
                  crumble @zceld
                  @zceld
                  here you will find the passowrd
                  https://docs.pycom.io/chapter/toolsandfeatures/repl/telnet.html
                  • Z Offline
                    zceld
                    good morning everyone
                    I already have a question in the ink, I've been looking and I have not seen anything clear about the plate. Therefore I take my post of doubts.
                    Someone could explain to me what changes if you have write the function:
                    #or
                    s.setblocking (False)
                    Thanks, greetings in advance!
                    By the way, I already managed to connect via wifi @crumble
                    • Z Offline
                      zceld
                      On the other hand, I have the insecurity that I never know how long it will take to find GPS the pytrack ... sometimes they connect in 2 minutes, other times in 15 and then cases like today that I have been without signal for the whole afternoon...
                      Code:
                      import math
                      import network
                      import utime
                      #send with LoRa:
                      import gc
                      gc.enable()
                      # setup rtc
                      rtc = machine.RTC()
                      utime.sleep_ms(750)
                      py = Pytrack()
                      chrono.start()
                      while (True):
                      Result:
                        crumble @zceld
                        @zceld You are inside a building, right? In this case you are lucky, that you receive enough signals. So bad weather conditions, more people in the floors above you, other radio signals, other set of satalites visible for your device, will influence, if you get a signal.
                        Without an external antenna you have to ways to solve this problem.
                        1. Move the device to a place with better signal quality
                        2. Add a layer to your program, so you can choose between real sensor data and test data.
                        Or try a soft reboot (ctrl-d). The last time I tested it, the GPS chip got a fix after reboot. Maybe it was only a coincidence ;)
                        • Z Offline
                          zceld @crumble
                          @crumble
                          If in it is quite unlikely to get a good signal inside a building, in fact with the smartphone many times it is not able to catch coverage. But since the LoPy with the Pytrack has always ended up taking me, it was strange to me that today I do not.
                          I tried the ctrl + d but it has not had an effect. Thank you very much for the info.
                          On the subject of :
                          #or
                          would you explain to me how it works?
                          I have done these tests but they do not convince me:
                          while (True):
                              s.setblocking(True)
                              x = "hi-"+str(j)+"-"+"12345678Z-"+str(coord[0]) + "-"+str(coord[1])
                              p = str(coord[0])
                              if p =='None':
                                  pycom.rgbled(0x7f0000)
                                  time.sleep(0.5)
                                  pycom.heartbeat(False)
                                  print("Buscando -",nintentos)
                                  nintentos+=1
                                  s.send(x)
                                  pycom.rgbled(0xfffe02)
                                  time.sleep(0.1)
                                  print(x)
                                  j+=1
                                  time.sleep(20) #Pausa entre toma de coordenadas.
                              alertas=[]
                              s.setblocking(False)
                              data = s.recv(64)
                              time.sleep(3)
                              ide =data.decode("utf-8")
                              ide = ide.split('-')
                              if ide[0] == 'alerta':
                                  for x in range (1,3):
                                      pycom.rgbled(0xC011EB)#Lila
                                      time.sleep(0.1)
                                      time.sleep(0.1)
                                  if ide[1] not in alertas:
                                      alertas.append(ide[1])
                                          pycom.rgbled(0x0007F)#Azul
                                          time.sleep(1)
                                          time.sleep(0.1)
                          The idea of operation is that every 20 seconds approximately, make one get the GPS position and send it by LoRa.
                          time.sleep(20)
                          Done that you hear if you are sending a message then I put s.setblocking (False) that I understand that in this mode will listen for 3 seconds:
                              alertas=[]
                              data = s.recv(64)
                              time.sleep(3)
                          Surely you have a better approach to programming or a different method, and that is what I have been able to do with what I think each command s.setblocking () does
                            crumble @zceld
                            @zceld
                            If you have something like
                                result = s.recv(256)
                                print(result)
                            and you run it in setblocking(True) mode, the program will wait on the line result = s.resv(256) until it received a message and will then continue. So result will always contains someting you received from the aether. Either from your LoPy or another device. So you shall not forget to check the content before controling some other hardware like servos, etc.
                            if you run the same loop with setblocking(False) it will not wait. It will directly go to the next line. So you will most of the time get your empty lines, because no one has send someting.
                            You can use this for easy control your program. If you want to open a door when someone sends a message you will use setblocking(True)
                            s.setblocking(True)
                                if result.equals('Open door'):
                                     OpenTheDoor()
                            If you use this with setblocking(False) it will not be that dangerous, because the if guards the door unless someone sends the right message. But it will use a lot of power, because it will run the loop without any pause. This can be really bad, if you run your device by battery. So you may have to charge your device every day instead of once a week,
                            If you want to stop something when someone sends you a stop message you would to something like this:
                            stopMessage = ''
                            while stopMessage != 'stop'
                                toggleLED()
                                stopMessage = s.recv(256)
                            setblocking(True) would be a bad idea, becaus the recv call would wait until someone sends a message. So your LED would change only its state when someone is sending a messages. With setblocking(False) you will see it blinking until someone sends the right message.
                            • Z Offline
                              zceld @crumble
                              @crumble
                              Thank you very much! , very kind, you got me out of doubt.
                              There would be a way to program it to stay listening in mode:
                              x = "no messages"
                              s.setblocking (true)
                              data = s.recv (256)
                              time.sleep (20)
                              if data! = ''
                                  print (data)
                              else
                                  s.send (x)
                              In plan, be listening if there is any message for 20 seconds. but at the end of this time, make another function and then listen again.
                                crumble @zceld
                                @zceld
                                this code will wait infinite for a message and wait additional 20 (milli?)seconds. If you want to use blocking sockets, you have to set the timeout for a socket. I never used them by myself. Browse in the documentation for:
                                socket.settimeout(value)
                                Or you use it as nonblocking and use the receive together with the sleep in a loop.
                                • Z Offline
                                  zceld @crumble
                                  @crumble
                                  On the subject server, I had this code that I would say that I used to run and be able to access Lopy via Filezilla FTP but today it does not work for me.
                                  There may be something I'm missing or what can it be?
                                  import network
                                  from network import WLAN
                                  wlan.init(mode=WLAN.AP, ssid='Gateway', auth=(WLAN.WPA2,'witeklab@2018'), channel=7, antenna=WLAN.INT_ANT)
                                  • Z Offline
                                    zceld @zceld
                                    @crumble @livius @seb
                                    Recommendation of the process to be programmed (I am noob):
                                    Ok, I explain the situation. With the chip Lopy and Pytrack I pick up the gps position of a vehicle and send it through LoRa to another board located at home that collects the data by LoRa and saves it to me in a file.txt.
                                    From the board at home I have activated server mode to connect by FTP and download the file.txt that is accumulating positions and that I download on my computer and from a file.php that saves the data in an array to track .
                                    So I know how to do it like that, but it's a tedious job to have to connect, download the file. the ideal idea would be to automate it but I can not think of how.
                                    I do not know if I could program by php / JavaScript or any language that will connect to the FTP of the Lopy every 'x' time and download and read the file atomically or vice versa that Lopy will send an IP of the network that connects this file every some time.
                                    What do you recommend or what options can I take to automate the process?
                                    Thank you very much as always you are fantastic !.
                                      livius @zceld
                                      @zceld
                                      Recomendation is that lopy connect to your server and send data to it
                                      • Z Offline
                                        zceld @livius
                                        @livius
                                        Hello again! What's going on? I upload the thread to ask some questions.
                                        Can I assign an ip address in server mode?
                                        I have this configuration / programming to put in server mode:
                                        import network
                                        wlan.init(mode=WLAN.AP, ssid='Gateway3', auth=(WLAN.WPA2,'witeklab@2018'), channel=7,
                                        from network import Server
                                        server = Server(login=('micro', 'python'), timeout=600)
                                        server.timeout(300)
                                        server.timeout()
                                        server.isrunning()
                                        The documentation that I have looked at is this but I have not found the ip theme:
                                        https://docs.pycom.io/chapter/firmwareapi/pycom/network/server.html
                                        I also take the opportunity to ask another question and it is: When I connect the lopy it automatically creates a wifi network to connect to it but with an SSID I guess random. In what loop file is this process? Can this operation be canceled? where are the initial programming that makes the default lopy and if it can be modified?
                                        The reasons for knowing this is because I do not want to start the Wi-Fi automatically in some Lopy apart from that I would like to know what other things it executes or puts in on mode independently.
                                        Thank you for your answers! I wait impatiently!
                                          livius @zceld
                                          @zceld
                                          IP can you set in the wifi configuration
                                          look for Assigning a Static IP Address at Boot Up in documentation
                                          https://docs.pycom.io/chapter/tutorials/all/wlan.html
                                          you can disable wifi by
                                          wlan.deinit()
                                          or permanently - it does not start automaticaly at board boot - call this once it is stored in nvs
                                          pycom.wifi_on_boot(False)
                                          if you disable it permanently you have full control when and with which ssid it start
                                          • Z Offline
                                            zceld
                                            Hello again! I have a new problem and I do not know why it may be, I have been reading several that have published similar things but I do not see what happens to me, so I will try to reflotar my thread of questions ..
                                            Vereís wanted to edit the main.py file that had lopy running every time I plugged it. Therefore I take the board I connect it to the pc I open the IDE atom> get serial ports, I copy the path where it has been connected. I go to global settings to indicate which port to connect to and give the connect button.
                                            Up to here are the usual steps that had always worked for me. Well when I connect I see that it is in the loop of the main.py file when it is like this to stop it, it always stops cntrl + c and it stops. This time there was no way to connect to Filezilla and I deleted the main.py file and at least I managed to connect again with LoPy in this case just enough to run os.mkfs ('/ flash') to see if it gave me back control with lopy.
                                            Well now it does not let me connect by the IDE Atom I do not know what happened ... I can only connect by example with putty by telnet ..
                                            Do you know what I can do or what is due?
                                            • 4 / 4
