    Set Cellular Access Point Name (APN)
    ltegpyfipycellular
    51 Posts 14 Posters 23.2k Views 15 Watching
      brotherdust @bbel91
      @bbel91 You'll need to set up a development environment. See https://github.com/pycom/pycom-micropython-sigfox#the-esp32-version for instructions. Follow them carefully! When are you able to compile and flash the firmware from the unmodified source, you'll be ready for modifying the code to enable GSM_DEBUG and LTE roaming features (if that's what you want to do). I STRONGLY suggest getting comfortable with Git before you start modifying the source code. I personally use a combination of Tower and Git CLI commands.
      It's possible to directly access the Sequans modem over UART if you have the expansion board; once you have that setup, you can type AT commands directly to the modem and see what works. See https://forum.pycom.io/topic/2496/gpy-readiness/20 for more info (and a great face-palm moment by yours truly when he forgets to swap the UART pins).
        brotherdust @rskoniec
        @rskoniec said in Set Cellular Access Point Name (APN):
        @michaelhobo I hope everything is OK with your board, because using LoRa/Sigfox/LTE without connecting the antenna is not recommended.
        My understanding is that, with no antenna attached, it could fry the LNA on the modem. It's expecting a particular impedance on the ANT connector. I really hope you didn't fry it. That would be sad and irritating. =( I've fried a REALLY expensive GPS chip this way (ublox LEA-6T); now it's just a paperweight.
          bbel91 @brotherdust
          @brotherdust Thanks a lot for your help.
          As I am on Windows10, I looked for a corresponding environment (msys2).
          I could then follow your procedure but it blocks at "cd mpy-cross ..." because the directory does not exist. Do you have an idea of what it can be?
            livius @bbel91
            @bbel91 said in Set Cellular Access Point Name (APN):
            mpy-cross
            you have it in the pycom-micropython-sigfox/mpy-cross repo
            https://github.com/pycom/pycom-micropython-sigfox/tree/master/mpy-cross
              bbel91 @livius
              @livius Thanks for your answer.
              Yes, of course, I've forgot the essential...
              Now that all seems ok and all the repository installed I get this issue when I "make" in mpy-cros :
              LINK mpy-cross
              build/py/modbuiltins.o:modbuiltins.c:(.rdata$mp_module_builtins_globals_table+0x294): référence indéfinie vers « mp_type_TimeoutError »
              collect2: erreur: ld a retourné 1 code d'état d'exécution
              make: *** [../py/mkrules.mk:133: mpy-cross] Error 1
              Do you know where it can come from ?
                rskoniec @brotherdust
                @brotherdust I would suspect this also.
                @michaelhobo There is a note (below) on the Fipy product description
                  michaelhobo @rskoniec
                  @rskoniec @brotherdust I got my LTE antenna and it's working! At least, I get an IP - I haven't looked at LTE performance, so it's still possible I may have damaged something. I'll make sure to use my backup GPy for any RF-critical benchmarking. Thanks @brotherdust for helping me get started!
                    brotherdust @michaelhobo
                    @michaelhobo you’re welcome and good luck! I fried my FiPy a couple of days ago, so I won’t be much help for now. I’m actually considering going with a different ESP32 board. I’m getting pretty tired of Pycom’s intransigence around releasing actual schematics. If they would, I might have enough info to fix the board, but as it stands, not gonna happen. sigh
                      Sat @benstr
                      @benstr said in Set Cellular Access Point Name (APN):
                      if either have NB
                      Hi Ben, Trying to connect to Telstra's CAT-M1 and NB networks. No luck with that. Could you help? I am in a lab environment in band 28.
                        camdenkrupala
                        @jmarcelino Is there an update on this functionality being added? Thanks!
                          jmarcelino @camdenkrupala
                          @camdenkrupala
                          You can already set an APN manually by doing
                          lte.send_at_cmd('AT+CEREG=2')
                          time.sleep(2)
                          lte.send_at_cmd('AT+CFUN=1')
                          time.sleep(1)
                          lte.send_at_cmd('AT+CGDCONT=1,"IP","YOUR_APN_HERE"')
                          time.sleep(2)
                          while lte.isattached() == False:
                              time.sleep(1)
                          lte.connect()
                          while not lte.isconnected():
                              time.sleep(1)
                          print("connected")
                          • 3 / 3
