    Pysense firmware?
    otherlopy
    5 Posts 3 Posters 1.5k Views 3 Watching
      JuanMa
      Is Pysense firmware going to be released in the near future? It is a little frustrating to work with a black box. I think Pycom should release it the same way the development board firmware was released. It makes no sense the contrary.
      JuanMa
      • sebS Offline
        seb
        Open sourcing the Pysense/Pytrack firmware is something we are looking into but I am afraid I cannot provide an exact timeline. If there are any missing features that you require I can pass this on to the team.
          JuanMa
          Thanks for the answer.
          The only bug I have notticed is related with the wake_reason after py.go_to_sleep(). In this code:
          if py.get_wake_reason() == WAKE_REASON_TIMER:
              # some code
          elsif py.get_wake_reason() == WAKE_REASON_PUSH_BUTTON
              #some code
          else
              #some code
          If the Lopy is reset inside deepsleep, the WAKE_REASON will be WAKE_REASON_TIMER. Am I doing something wrong? Should it not be a POWER_ON_RESET?
          Same happen if Lopy is reset inside the elsif code (WAKE_REASON_PUSH_BUTTON), but this time the wake reason is PUSH_BUTTON.
          Thanks again,
          JuanMa
          • catalinC Offline
            catalin @JuanMa
            Hi @juanma,
            Thanks for pointing out these scenarios, they have to be verified.
            The WAKE_REASON_PUSH_BUTTON is returned if Pysense Reset button is pressed.
            Another note is that after py.go_to_sleep(), the next python code is not executed; at wakeup, the micropython is reset.
            Catalin,
              JuanMa
              Thanks very much. From my experience, it is like if some flag is not reset when you press the reset button or you call machine.reset().
