    Not getting Sensor Readings in Pysense with FiPy Module
    fipyraspberry pipysensemicorpython
    79 Posts 6 Posters 30.0k Views 6 Watching
      Archana Kadam @livius
      @livius
      Please explain the procedure of connecting fipy to server and how to send data of fipy to server
        livius @Archana Kadam
        @archana-kadam said in Not getting Sensor Readings in Pysense with FiPy Module:
        How we can know that is connected to Wifi?
        wlan.isconnected()
        but to be really sure - only sending by socket tell this for sure
        How we can connect to both station as well as access point?
        change mode from WLAN.STA in WLAN.STA_AP
        simply create socket and send data throught it
        e.g. from memory not tested but something like this should work
        s = socket.socket()
        s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
        s.connect(socket.getaddrinfo('your server ip', your_server_port)[0][-1])
        s.send(your_data)
          @livius
          Can we send data through pybytes ?
          Is a pybytes a server or its just a middleware to send data?
            @livius
            From this above code we are getting an error called OSERORR :-01
            s = socket.socket()
            s.connect(socket.getaddrinfo('192.168.0.109', 80)[0][-1])
            your_data = "Hello"
            s.send("your_data")
              @archana-kadam
              At which line of code?
                @livius
                Line number 6 and 7
                  Line number 6 and 7
                  I do not have your source code ;-)
                  what this lines contain? and why on 6 and 7 - error should be raised only once
                    @livius
                    host = '127.0.0.1'
                    port = 80 # The same port as used by the server
                    s.connect((host, port))
                    s.send('Hello, world')
                    data = s.recv(1024)
                    s.close()
                    print('Received', repr(data))
                    Here is code to connect to server,but we are enable to connect
                      @livius
                      from network import WLAN
                      configure the WLAN subsystem in station mode (the default is AP)
                      wlan = WLAN(mode=WLAN.STA)
                      go for fixed IP settings (IP, Subnet, Gateway, DNS)
                      wlan.ifconfig(config=('192.168.0.107', '255.255.255.0', '192.168.0.1', '192.168.0.1'))
                      wlan.scan() # scan for available networks
                      wlan.connect(ssid='mynetwork', auth=(WLAN.WPA2, 'my_network_key'))
                      while not wlan.isconnected():
                      pass
                      print(wlan.ifconfig())
                      I tried with code also, but its continuously running but there no output.
                        @archana-kadam
                        I should start with this question, what is your firmware version?
                        os.uname()
                          Archana Kadam @Archana Kadam
                          @livius
                          Is Pybytes a server. Can we send data and store in pybytes
                            @livius
                            We have latest version of firmware installed 1.17.b
                              @archana-kadam
                              You can send data to whatever you like, but for pybytes you need account.
                              Did you successfully connected to the wifi network?
                                @livius
                                We are running the below code on the FiPy to send data to the server. and we are using FiPy in its default mode i,e Access Point Mode.
                                s = socket.socket()
                                your_data = "Hello"
                                s.send("your_data")
                                Can you send us the one complete example code which sends data from fipy to server. Where a local computer in the same network can be used as server.
                                Thank You
                                  @archana-kadam
                                  with default mode AP you must connect your computer to Fipy.
                                  In mode STA you connect your Fipy to computer (most often through router)
                                  After you are connected to the network (local) you can communicate between computer and Fipy.
                                  # wlan.ifconfig(config=('192.168.0.105', '255.255.255.0', '192.168.0.1', '192.168.0.1')) - you can ommit this line if you need to connect by DHCP
                                  wlan.connect(ssid='mynetwork', auth=(WLAN.WPA2, 'my_network_key'), timeout=30000)
                                  	machine.idle()
                                  if wlan.isconnected():
                                  	s = socket.socket()
                                  	s.connect(socket.getaddrinfo('192.168.0.109', 2345)[0][-1]) #IP of your computer(192.168.0.109) in the same network as your Fipy and port(2345) of socket in listen mode on your computer
                                  	your_data = "Hello"
                                  	s.send("your_data")
                                  remember that you must have something listen on incoming traffic on your computer then.
                                    @livius
                                    We have successfully connected to the server by the given code, but we are getting an error in line number 14, im sending the screenshot please go through the file0_1521551509504_5596a1e4-c670-4266-b053-1b5c3d7b1205-image.png
                                      @archana-kadam
                                      remove line 13 s = socket.socket()
                                      P.S> i have blurred your password on the screenshot
                                        @livius
                                        I removed line 13 "s = socket.socket()" but also im getting an error in line number 15
                                        i,e #your_data = "hello"
                                          jcaron @Archana Kadam
                                          @archana-kadam and the error is...?
                                            Archana Kadam @jcaron
                                            @jcaron
                                            OSError -1
                                            • 2 / 4
