    Not getting Sensor Readings in Pysense with FiPy Module
    fipyraspberry pipysensemicorpython
    79 Posts 6 Posters 28.0k Views 6 Watching
      Archana Kadam @livius
      @livius
      host = '127.0.0.1'
      port = 80 # The same port as used by the server
      s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
      s.connect((host, port))
      s.send('Hello, world')
      data = s.recv(1024)
      s.close()
      print('Received', repr(data))
      Here is code to connect to server,but we are enable to connect
        @livius
        from network import WLAN
        configure the WLAN subsystem in station mode (the default is AP)
        wlan = WLAN(mode=WLAN.STA)
        go for fixed IP settings (IP, Subnet, Gateway, DNS)
        wlan.ifconfig(config=('192.168.0.107', '255.255.255.0', '192.168.0.1', '192.168.0.1'))
        wlan.scan() # scan for available networks
        wlan.connect(ssid='mynetwork', auth=(WLAN.WPA2, 'my_network_key'))
        while not wlan.isconnected():
        pass
        print(wlan.ifconfig())
        I tried with code also, but its continuously running but there no output.
          livius @Archana Kadam
          @archana-kadam
          I should start with this question, what is your firmware version?
          os.uname()
            Archana Kadam @Archana Kadam
            @livius
            Is Pybytes a server. Can we send data and store in pybytes
              @livius
              We have latest version of firmware installed 1.17.b
                @archana-kadam
                You can send data to whatever you like, but for pybytes you need account.
                Did you successfully connected to the wifi network?
                  @livius
                  We are running the below code on the FiPy to send data to the server. and we are using FiPy in its default mode i,e Access Point Mode.
                  s = socket.socket()
                  s.connect(socket.getaddrinfo('192.168.0.109', 80)[0][-1])
                  your_data = "Hello"
                  s.send("your_data")
                  Can you send us the one complete example code which sends data from fipy to server. Where a local computer in the same network can be used as server.
                  Thank You
                    @archana-kadam
                    with default mode AP you must connect your computer to Fipy.
                    In mode STA you connect your Fipy to computer (most often through router)
                    After you are connected to the network (local) you can communicate between computer and Fipy.
                    # wlan.ifconfig(config=('192.168.0.105', '255.255.255.0', '192.168.0.1', '192.168.0.1')) - you can ommit this line if you need to connect by DHCP
                    wlan.connect(ssid='mynetwork', auth=(WLAN.WPA2, 'my_network_key'), timeout=30000)
                    	machine.idle()
                    if wlan.isconnected():
                    	s = socket.socket()
                    	s.connect(socket.getaddrinfo('192.168.0.109', 2345)[0][-1]) #IP of your computer(192.168.0.109) in the same network as your Fipy and port(2345) of socket in listen mode on your computer
                    	your_data = "Hello"
                    	s.send("your_data")
                    remember that you must have something listen on incoming traffic on your computer then.
                      @livius
                      We have successfully connected to the server by the given code, but we are getting an error in line number 14, im sending the screenshot please go through the file0_1521551509504_5596a1e4-c670-4266-b053-1b5c3d7b1205-image.png
                        @archana-kadam
                        remove line 13 s = socket.socket()
                        P.S> i have blurred your password on the screenshot
                          @livius
                          I removed line 13 "s = socket.socket()" but also im getting an error in line number 15
                          i,e #your_data = "hello"
                            jcaron @Archana Kadam
                            @archana-kadam and the error is...?
                              Archana Kadam @jcaron
                              @jcaron
                              OSError -1
                                @jcaron
                                I will attach the screenshot and i have highlighted the error line.
                                  @archana-kadam are you sure you correctly re-uploaded the modified file?
                                    @jcaron
                                    Yes i re-uploaded the modified file.
                                    Earlier it was #your_data = "Hello"
                                      @archana-kadam
                                      Quite impossible on line 15 where you store text (connect to your device by ftp and look like your file really is)
                                      but do you have host 192.168.0.109 and especially do you have something which listen on that host on port 2345?
                                        @livius
                                        Here is code which im using to connect to the server.
                                        wlan.connect(ssid='ssid...', auth=(WLAN.WPA2, 'passs...'), timeout=30000)
                                        	machine.idle()
                                        	s.connect(socket.getaddrinfo('192.168.0.109', 80)[0][-1]) #IP of your computer(192.168.0.109) in the same network as your Fipy and port(80) of socket in listen mode on your computer
                                        	s.send("your_data")
                                        Yes i have the same IP address and the port is 80. By using the same code im getting an error is
                                        File "<stdin>", line 15, in <module>
                                        OSError: -1
                                          @archana-kadam said in Not getting Sensor Readings in Pysense with FiPy Module:
                                          strange because line 15 is just comment line
                                          add this lines before socket connect
                                          print(str(socket.getaddrinfo('192.168.0.109', 80)))
                                          print(str(socket.getaddrinfo('192.168.0.109', 80)[0][-1]))
                                          and put result here
                                            @livius said in Not getting Sensor Readings in Pysense with FiPy Module:
                                            wlan.ifconfig(config=('192.168.0.109', '255.255.255.0', '192.168.0.1', '192.168.0.1')) - you can ommit this line if you need to connect by DHCP
                                            wlan.connect(ssid=‘SK@unifi’, auth=(WLAN.WPA2, '********'), timeout=30000)
                                            machine.idle()
                                            print(str(socket.getaddrinfo('192.168.0.109', 80)[0][-1])) #IP of your computer(192.168.0.109) in the same network as your Fipy and port(80) of socket in listen mode on your computer
                                            s.send("your_data")
                                            Here is and code and we are getting the same errors i,e
                                            File "<stdin>", line 14
                                            IndentationError: unindent does not match any outer indentation level
                                            MicroPython v1.8.6-849-055728a on 2018-02-13; FiPy with ESP32
                                            • 3 / 4
