    Not getting Sensor Readings in Pysense with FiPy Module
    fipyraspberry pipysensemicorpython
    79 Posts 6 Posters 28.0k Views 6 Watching
      jcaron @Archana Kadam
      @archana-kadam are you sure you correctly re-uploaded the modified file?
        Archana Kadam @jcaron
        @jcaron
        Yes i re-uploaded the modified file.
        Earlier it was #your_data = "Hello"
          livius @Archana Kadam
          @archana-kadam
          Quite impossible on line 15 where you store text (connect to your device by ftp and look like your file really is)
          but do you have host 192.168.0.109 and especially do you have something which listen on that host on port 2345?
            Archana Kadam @livius
            @livius
            Here is code which im using to connect to the server.
            from network import WLAN
            wlan = WLAN(mode=WLAN.STA)
            # wlan.ifconfig(config=('192.168.0.105', '255.255.255.0', '192.168.0.1', '192.168.0.1')) - you can ommit this line if you need to connect by DHCP
            wlan.connect(ssid='ssid...', auth=(WLAN.WPA2, 'passs...'), timeout=30000)
            while not wlan.isconnected():
            	machine.idle()
            if wlan.isconnected():
            	s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
            	s.connect(socket.getaddrinfo('192.168.0.109', 80)[0][-1]) #IP of your computer(192.168.0.109) in the same network as your Fipy and port(80) of socket in listen mode on your computer
            	s.send("your_data")
            Yes i have the same IP address and the port is 80. By using the same code im getting an error is
            File "<stdin>", line 15, in <module>
            OSError: -1
              @archana-kadam said in Not getting Sensor Readings in Pysense with FiPy Module:
              strange because line 15 is just comment line
              add this lines before socket connect
              print(str(socket.getaddrinfo('192.168.0.109', 80)))
              print(str(socket.getaddrinfo('192.168.0.109', 80)[0][-1]))
              and put result here
                @livius said in Not getting Sensor Readings in Pysense with FiPy Module:
                wlan.ifconfig(config=('192.168.0.109', '255.255.255.0', '192.168.0.1', '192.168.0.1')) - you can ommit this line if you need to connect by DHCP
                wlan.connect(ssid=‘SK@unifi’, auth=(WLAN.WPA2, '********'), timeout=30000)
                machine.idle()
                print(str(socket.getaddrinfo('192.168.0.109', 80)[0][-1])) #IP of your computer(192.168.0.109) in the same network as your Fipy and port(80) of socket in listen mode on your computer
                s.send("your_data")
                Here is and code and we are getting the same errors i,e
                File "<stdin>", line 14
                IndentationError: unindent does not match any outer indentation level
                MicroPython v1.8.6-849-055728a on 2018-02-13; FiPy with ESP32
                  check if you do not mix indentation as tab and space
                  PS. use forum formating http://commonmark.org/help/ e.g. triple ``` around the code
                    @livius
                    We are trying to run the LoRa Nano Gateway code provided in the pycom documentation. We are using three PC's and three fipy boards. In one pc we are running the Gateway.py , second we are running Node.py and in third pc we are running the RawLora.py codes. But we are getting an error in Gateway.py code in Line 26 i,e buffer too small. Is the procedure we are doing is correct? Please reply us soon as possible.
                    Thank You
                      @livius
                      We are trying to run the LoRa Nano Gateway code provided in the pycom documentation. We are using three PC's and three fipy boards. In one pc we are running the Gateway.py , second we are running Node.py and in third pc we are running the RawLora.py codes. But we are getting an error in Gateway.py code in Line 26 i,e buffer too small. Is the procedure we are doing is correct? Please reply us soon as possible. Its urgent
                      Thank You
                        @archana-kadam
                        WIthout the code i can only gues that you try to send to big data throught Lora. It is very limited. Check how much data is really sending.
                          @livius
                          I used the codes from provided pycom documentation. Here are the links of the code
                          https://docs.pycom.io/chapter/tutorials/lora/lora-mac-nano-gateway.html
                          https://docs.pycom.io/chapter/tutorials/lora/lora-mac.html
                            @archana-kadam
                            in documentation gateway line 26 is empty...
                            You have some modification which i do no see ;-)
                              @livius
                              recv_pkg_len = recv_pkg[1] is this declaration correct in gateway code.
                                @archana-kadam Please share the actual code you are using, no sense trying to guess what you have in your code. In the gateway code as posted in the docs, I don't think it's possible to get that error on that line with the test just before it...
                                Please make sure your code is properly formatted when you post it (add ``` on a line before and after the code).
                                  @jcaron
                                  I am attaching the file of gateway and node code please go through the file and please check update me as soon as possible. Your help will be appreciable.1_1522300805718_Node.py 0_1522300805717_Gateway.py
                                    @jcaron
                                    We tried the gateway code and node code provided in the documentation, we connected one gateway and one node. The communication between two boards has been created but we are enable to fetch the device number,package etc. So please update for this solution.
                                    Thank you
                                      Archana Kadam @Archana Kadam
                                      @jcaron
                                      Please update to soon. Your help will be appreciable.
                                      Thank You
                                        Archana Kadam
                                        Please reply as soon as possible, waiting for your solution. Your help will be appreciable.
                                        Thank you
                                          Archana Kadam
                                          @administrators
                                          Which type of LoRa module your are using in pycom board. Can you please share us the schematic of Fipy development module.
                                          Thank you
                                            smbunn
                                            Have you had a look at my forum thread?
                                            https://forum.pycom.io/topic/2908/creating-a-json-structure-for-pysense/9
                                            This has me reading all PySense values, packing them into a bytearray for LoRa transmission and the unpacking them at the other end with some simple JavaScript on a Node-red environment.
                                            • 3 / 4
