    Not getting Sensor Readings in Pysense with FiPy Module
    fipyraspberry pipysensemicorpython
    79 Posts 6 Posters 28.0k Views 6 Watching
      Archana Kadam @livius
      @livius
      recv_pkg_len = recv_pkg[1] is this declaration correct in gateway code.
        jcaron @Archana Kadam
        @archana-kadam Please share the actual code you are using, no sense trying to guess what you have in your code. In the gateway code as posted in the docs, I don't think it's possible to get that error on that line with the test just before it...
        Please make sure your code is properly formatted when you post it (add ``` on a line before and after the code).
          Archana Kadam @jcaron
          @jcaron
          I am attaching the file of gateway and node code please go through the file and please check update me as soon as possible. Your help will be appreciable.1_1522300805718_Node.py 0_1522300805717_Gateway.py
            @jcaron
            We tried the gateway code and node code provided in the documentation, we connected one gateway and one node. The communication between two boards has been created but we are enable to fetch the device number,package etc. So please update for this solution.
            Thank you
              Archana Kadam @Archana Kadam
              @jcaron
              Please update to soon. Your help will be appreciable.
              Thank You
                Archana Kadam
                Please reply as soon as possible, waiting for your solution. Your help will be appreciable.
                Thank you
                  Archana Kadam
                  @administrators
                  Which type of LoRa module your are using in pycom board. Can you please share us the schematic of Fipy development module.
                  Thank you
                    smbunn
                    Have you had a look at my forum thread?
                    https://forum.pycom.io/topic/2908/creating-a-json-structure-for-pysense/9
                    This has me reading all PySense values, packing them into a bytearray for LoRa transmission and the unpacking them at the other end with some simple JavaScript on a Node-red environment.
                      Archana Kadam
                      @administrators
                      I have inserted a sim in a fipy board, now we are not able to connect to the internet of the inserted sim. Please explain the procedure to connect to inserted sim
                      Thank you
                        jmarcelino @Archana Kadam
                        @archana-kadam
                        The FiPy only supports Cat M1 and NB-IoT networks. Which one are you using?
                          Archana Kadam @jmarcelino
                          @jmarcelino
                          Cat M1 we are using
                            Archana Kadam
                            @administrators
                            We are trying to send data from fipy to sever using urequests, but getting an error. We are running code in atom.
                            import urequests
                            response = urequests.get("http://localhost/server.php?data="+msg)
                            response.close()
                            Error Message:
                            File "<stdin>", line 12, in <module>
                            ImportError: no module named 'urequests'
                              @archana-kadam
                              Which operator are you using and which country for Cat M1?
                              Also can you please split your questions into separate topics (LoRa nano-gateways issues, LTE issues, sensor reading issues,..) , it's becoming impossible to understand what is working or not for you.
                              For example is the post below about using the LTE connection or WiFi?
                              If you can ask these questions on separate topics it would be easier for us to understand and help you. Thanks.
                                @jmarcelino
                                We are using INDIA for Cat M1
                                Thank you
                                  @archana-kadam
                                  There is no live Cat M1 network in India. Are you working on a closed trial with a mobile operator? If so we'll need more details (carrier name, frequency, APN) to support it.
                                    @jmarcelino
                                    As u say there is no live Cat M1 network in India. Means we cannot use built LTE option available in fipy board from India. So what is other option to use the LTE from India.
                                    Thank you
                                      @jmarcelino
                                      As u say there is no live Cat M1 network in India. Then how we can use normal LTE from fipy board. Please help us as soon as possible your help will be appreciable.
                                      Thank You
                                        @archana-kadam
                                        It's not possible to use regular LTE on the FiPy, it's an LTE-M modem. You need to have LTE-M or NB-IoT from the operator.
                                          @jmarcelino
                                          Is there any solution to connect LTE,Wifi and LoRa normally of fipy board.
                                            @archana-kadam
                                            Normal LTE no.. unless you use a WiFi-LTE router (MiFi) or external LTE modem.
                                            • 4 / 4
