    Not getting Sensor Readings in Pysense with FiPy Module
    fipyraspberry pipysensemicorpython
    79 Posts 6 Posters 30.0k Views 6 Watching
      jmarcelino @Archana Kadam
      @archana-kadam
      The FiPy only supports Cat M1 and NB-IoT networks. Which one are you using?
        Archana Kadam @jmarcelino
        @jmarcelino
        Cat M1 we are using
          Archana Kadam
          @administrators
          We are trying to send data from fipy to sever using urequests, but getting an error. We are running code in atom.
          import urequests
          response = urequests.get("http://localhost/server.php?data="+msg)
          response.close()
          Error Message:
          File "<stdin>", line 12, in <module>
          ImportError: no module named 'urequests'
            @archana-kadam
            Which operator are you using and which country for Cat M1?
            Also can you please split your questions into separate topics (LoRa nano-gateways issues, LTE issues, sensor reading issues,..) , it's becoming impossible to understand what is working or not for you.
            For example is the post below about using the LTE connection or WiFi?
            If you can ask these questions on separate topics it would be easier for us to understand and help you. Thanks.
              @jmarcelino
              We are using INDIA for Cat M1
              Thank you
                @archana-kadam
                There is no live Cat M1 network in India. Are you working on a closed trial with a mobile operator? If so we'll need more details (carrier name, frequency, APN) to support it.
                  @jmarcelino
                  As u say there is no live Cat M1 network in India. Means we cannot use built LTE option available in fipy board from India. So what is other option to use the LTE from India.
                  Thank you
                    Archana Kadam @Archana Kadam
                    @jmarcelino
                    As u say there is no live Cat M1 network in India. Then how we can use normal LTE from fipy board. Please help us as soon as possible your help will be appreciable.
                    Thank You
                      @archana-kadam
                      It's not possible to use regular LTE on the FiPy, it's an LTE-M modem. You need to have LTE-M or NB-IoT from the operator.
                        @jmarcelino
                        Is there any solution to connect LTE,Wifi and LoRa normally of fipy board.
                          @archana-kadam
                          Normal LTE no.. unless you use a WiFi-LTE router (MiFi) or external LTE modem.
                          • 4 / 4
