GPy with Hologram.io SIM
  • @tlanier
    Maybe Cat M1 coverage in your area just isn’t very good yet, Verizon only uses one band (band 13) for Cat M1 while on mobile phones they support more.
  • @tlanier
    After power off/on I'm now getting +CEREG: 2,4
    It never gets the 2,5 you mentioned after 10 mins.
    DL SYNCHRO STATISTICS
    Synchro state                         : MIB DETECT
    PPU SIB1 ACQ watchdog                 : 0
    Frequency Hypothesis RF  (Hz)         : -1000
    RSRP (dBm)                            : -21474836.00
    RSRQ  (dB)                            : -25.99
    Channel estimation state (Cell-spec.) : LOW CINR
    Channel estimation state (UE-spec.)   : LOW CINR
    Channel estimation state (MBSFN)      : LOW CINR
    Channel estimation CINR               : 0.00
    Channel length                        : SHORT
    AGC
    AGC RX gain (dB) : 54.90
    RX PSD BO (dBFs) : -21.71
    RX PSD (dBm) : -95.99
    Noise level RS (dBm) : -124.46
    Digital gain (dB) : 6.62
    CINR RS (dB) : -16.11
    NARROWBANDS
    Last DL NB : Central
    Last UL NB : 0
    AFC
    Frequency offset RF (Hz) : 47
    Frequency offset BB (Hz) : 0
    PBCH
    MIB received quantity : 1394
    MIB timeout quantity : 0
    OK
    SYSTEM FSM
    | RRC TOP FSM              |SCANNING            |
    | RRC SEARCH FSM           |WAIT_CELL_ID        |
    | RRC ACTIVE FSM           |NULL                |
    | PMM PLMN FSM             |ANY_WAITCELL        |
    | HP USIM FSM              |ABSENT              |
    | HP CAT FSM               |NULL                |
    OK
    +CEREG: 2,4
    OK
    Synchro state                         : CELL SEARCH
    RSRQ  (dB)                            : -25.99
    AGC
    AGC RX gain (dB) : 54.87
    RX PSD BO (dBFs) : -21.44
    RX PSD (dBm) : -96.46
    Noise level RS (dBm) : -126.46
    Digital gain (dB) : 10.13
    NARROWBANDS
    Last UL NB : 0
    AFC
    Frequency offset RF (Hz) : 70
    PBCH
    MIB received quantity : 1422
    OK
    SYSTEM FSM
    | RRC TOP FSM              |SYNCING             |
    | RRC SEARCH FSM           |WAIT_SYNC           |
    | HP CAT FSM               |NULL                |
    OK
    +CEREG: 2,4
    OK
    Synchro state                         : IDLE
    PPU SIB1 ACQ watchdog                 : 1
    RSRQ  (dB)                            : -25.99
    AGC
    RX PSD BO (dBFs) : -21.78
    RX PSD (dBm) : -98.39
    Digital gain (dB) : 9.05
    NARROWBANDS
    Last UL NB : 0
    AFC
    Frequency offset RF (Hz) : 43
    PBCH
    MIB received quantity : 1429
    OK
    SYSTEM FSM
    | RRC TOP FSM              |INITIAL             |
    | RRC SEARCH FSM           |INITIAL             |
    | PMM PLMN FSM             |PARKING             |
    | HP CAT FSM               |NULL                |
    OK
    +CEREG: 2,4
    OK
    RSRQ  (dB)                            : -25.99
    AGC
    NARROWBANDS
    Last UL NB : 0
    AFC
    PBCH
    OK
    SYSTEM FSM
    | HP CAT FSM               |NULL                |
    OK
    +CEREG: 2,4
    OK
    RSRQ  (dB)                            : -25.99
    AGC
    NARROWBANDS
    Last UL NB : 0
    AFC
    PBCH
    OK
    SYSTEM FSM
    | HP CAT FSM               |NULL                |
    OK
    +CEREG: 2,4
  • @jmarcelino
    Mine has been running for about 10 minutes returning:
    +CEREG: 2,0
    My cell phone uses Verizon and it shows a strong 3 bar signal.
    I'm going to try powering down and back up to see if that will help.
  • @chrisgammell
    That's great! 2,5 is what we want for Hologram (5 means attached as roaming)
    So does the while not lte.isattached(): loop finish correctly then and move to the connection step - which means PPP is established?
    lte.connect()
    while not lte.isconnected():
        time.sleep(1)
    print("Connected!")
  • Looks like mine just needed to cycle a few more times as well, just got this:
    +CEREG: 2,5,"CC14","031D4803",7
  • @tlanier said in GPy with Hologram.io SIM:
    RRC TOP FSM |STOPPED
    Can you leave it for a minute or so please. You should see this changing to SCANNING but it's not immediate, it's done in cycles. Thanks.
  • @jmarcelino
    CAT M1 Test - V0.1
    OK
    OK
    OK
    OK
    OK
    -- Scan options -------------------------------------------
    | . Init Stored info use     : true
    | . Init MRU freq use        : true
    | . Init REG freq use        : false
    | . Init FastScan use        : true
    | . Init iterative band scan : false
    | . Init scan batch of freq  : false
    | . Init hybrid 1 mode       : false
    | . Init optim SIB rx        : true
    | . Forced freq              : false
    | . MRU cell use             : true
    -- Scan Command config ----------------------------------------------------
    | id | type  | object                                                     |
    | 1  | BAND  | (id:1) 4,13                                                |
    | 2  | DELAY | 5000 msec                                                  |
    | 3  | LOOP  | jump to cmd:1, dur:5000ms                                  |
    OK
        Frequency Hypothesis RF  (Hz)         : 0
        RSRQ  (dB)                            : -12.79
      AGC
        AGC RX gain (dB)                      : 44.55
        RX PSD BO (dBFs)                      : -21.06
        RX PSD (dBm)                          : -85.55
        Noise level RS (dBm)                  : -86.52
        Digital gain (dB)                     : 6.53
        CINR RS (dB)                          : 2.09
      NARROWBANDS
        Last UL NB                            : 0
      AFC
        Frequency offset RF  (Hz)             : -359
      PBCH
        MIB received quantity                 : 83
    OK
    SYSTEM FSM
        | RRC TOP FSM              |STOPPED             |
        | RRC SEARCH FSM           |NULL                |
        | PMM PLMN FSM             |NULL                |
        | HP USIM FSM              |NULL                |
        | HP CAT FSM               |NULL                |
    OK
    +CEREG: 2,0
    OK
        RSRQ  (dB)                            : -12.79
      AGC
        CINR RS (dB)                          : 2.09
      NARROWBANDS
        Last UL NB                            : 0
      AFC
      PBCH
    OK
    SYSTEM FSM
        | HP USIM FSM              |NULL                |
        | HP CAT FSM               |NULL                |
    OK
    +CEREG: 2,0
  • @jmarcelino
    Notice the first command (AT+CPIN?) generates an error.
    CAT M1 Test - V0.1
    ERROR
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
        Synchro state                         : OFF
        RSRQ  (dB)                            : -12.36
      AGC
        RX PSD BO (dBFs)                      : -21.15
        RX PSD (dBm)                          : -85.50
        Noise level RS (dBm)                  : -87.44
        Digital gain (dB)                     : 6.48
        CINR RS (dB)                          : 3.73
      NARROWBANDS
        Last UL NB                            : 0
      AFC
      PBCH
        MIB received quantity                 : 1778
    OK
    SYSTEM FSM
        | HP USIM FSM              |NULL                |
        | HP CAT FSM               |NULL                |
    OK
    +CEREG: 2,0
    OK
        Synchro state                         : OFF
        RSRQ  (dB)                            : -12.36
      AGC
        CINR RS (dB)                          : 3.73
      NARROWBANDS
        Last UL NB                            : 0
      AFC
      PBCH
    OK
    SYSTEM FSM
        | HP USIM FSM              |NULL                |
        | HP CAT FSM               |NULL                |
    OK
    +CEREG: 2,0
    OK
  • Thanks @chrisgammell
    Can you try this instead please:
    send_at_cmd_pretty('AT+CFUN=0')
    send_at_cmd_pretty('AT+SQNCTM="verizon"')
    send_at_cmd_pretty('AT+CGDCONT=1,"IP","hologram"')
    send_at_cmd_pretty('AT+CEREG=2')
    send_at_cmd_pretty('AT+CFUN=1')
    send_at_cmd_pretty('AT!="showinit"')
        time.sleep(1)
        send_at_cmd_pretty('AT!="showphy"')
        send_at_cmd_pretty('AT!="fsm"')
        send_at_cmd_pretty('AT+CEREG?')
    The AT+SQNCTM="verizon"' setups up some other parameters for Verizon including scanning the correct bands. These should be reflected in the new debug command AT!="showinit" after CFUN=1
  • @chrisgammell
    Yes, I'm also getting +CSQ: 99,99
  • Also I'm still getting 99,99 for AT+CSQ
    Yes, I double checked, the antenna is plugged into the correct ports :-D
    @tlanier, did you check that command on yours?
  • @jmarcelino said in GPy with Hologram.io SIM:
    AT+CEREG?')
    Here's mine:
        Frequency Hypothesis RF  (Hz)         : -4000
        RSRQ  (dB)                            : -22.71
      AGC
        AGC RX gain (dB)                      : 52.76
        RX PSD BO (dBFs)                      : -21.92
        RX PSD (dBm)                          : -93.92
        Noise level RS (dBm)                  : -123.92
        Digital gain (dB)                     : 12.24
        CINR RS (dB)                          : -9.76
      NARROWBANDS
        Last UL NB                            : 0
      AFC
        Frequency offset RF  (Hz)             : 0
      PBCH
        MIB received quantity                 : 573
    OK
    SYSTEM FSM
        | PMM PLMN FSM             |NORM_WAITCELL       |
        | EMM MAIN FSM             |REGISTERED          |
        | EMM AUTH FSM             |KASME_DEFINED       |
        | EMM CONN FSM             |EMM_IDLE            |
        | ESM BEARER FSM           |BEARER_ACTIVE       |
    OK
    +CEREG: 2,4
    OK
        Frequency Hypothesis RF  (Hz)         : -2000
        RSRQ  (dB)                            : -22.71
      AGC
        AGC RX gain (dB)                      : 25.26
        Digital gain (dB)                     : 4.74
      NARROWBANDS
        Last UL NB                            : 0
      AFC
      PBCH
    OK
    SYSTEM FSM
    OK
    +CEREG: 2,4
    OK
  • Thanks @chrisgammell !
    The only AT command guide we can publish is this: https://docs.pycom.io/chapter/datasheets/downloads/Monarch_4G-EZ_LR5110_ATCommands_ReferenceManual_Rev3_NOCONFIDENTIAL.pdf
    But really that should be enough, Sequans doesn't share the special AT!= commands even with us other than to solve particular problems.
  • Ok thanks @tlanier
    Can you try replacing your LTE attach code with:
    lte = LTE()
    send_at_cmd_pretty('AT+CPIN?')
    send_at_cmd_pretty('AT!="clearscanconfig"')
    send_at_cmd_pretty('AT!="RRC::addscanfreq band=4 dl-earfcn=2175"')
    send_at_cmd_pretty('AT!="RRC::addscanfreq band=12 dl-earfcn=5095"')
    send_at_cmd_pretty('AT!="RRC::addscanfreq band=13 dl-earfcn=5230"')
        time.sleep(1)
    This will produce a lot of debug output
  • Hey Jose,
    I've been testing it on a GPy, FiPy I have here. Is there an exhaustive list of the AT command set available anywhere? I'm also tracking my progress of troubleshooting on our forum where @tlanier also posted: https://community.hologram.io/t/pycom-gpy/1664
  • @jmarcelino
    Hologram tech support indicates that their SIM card should work with Verizon and AT&T with your GPy device. They've indicated that they have a GPy and will try the test at their site.
    Yes, the LTE antenna is connected to the correct port.
    Yes, I've waited many minutes at 3 indoor locations (work and home) and 1 outdoor location with no successful attach to tower.
    A cell phone shows the Verizon signal strength to be 3 bars.
    Any other ideas of what I can try?
    Are there any modem commands that would help understand what is taking place?
  • @tlanier
    I'm really not sure about Hologram with our modules in the US, but lets do the basic checks first:
    • Have you connected the LTE antenna to the correct port - for the GPy should be next to LED
    • Have you waited enough time? - sometimes it can take up to 45 seconds to attach
    • Maybe reception isn't very good in your area - Cat M1 coverage is still limited. Try elsewhere or ideally outside.
  • @jmarcelino
    I've modified the program as recommended; still does not attach to the tower.
    Hologram technical support has verified that the SIM should work with the GPy and CAT-M1 connecting to both Verizon and AT&T.
    Any ideas of what I can do to troubleshoot further?
    import ssl
    from network import LTE
    def send_at_cmd_pretty(cmd):
        response = lte.send_at_cmd(cmd).split('\r\n')
        for line in response:
            print(line)
    print("CAT M1 Test - V0.1")
    pycom.heartbeat(False)
    lte = LTE()         # instantiate the LTE object
    lte.attach()        # attach the cellular modem to a base station
    i = 0
        i = i + 1
        print("not attached: {}".format(i))
        if (i % 2 == 0):
            pycom.rgbled(0xFF0000)  # Red
            pycom.rgbled(0x000000)  # off
        time.sleep(0.25)
    lte.connect()       # start a data session and obtain an IP address
    i = 0
        i = i + 1
        print("not connected: {}".format(i))
        if (i % 2 == 0):
            pycom.rgbled(0x00FF00)  # Green
        time.sleep(0.25)
    pycom.rgbled(0x0000FF)  # Blue
    s = socket.socket()
    s = ssl.wrap_socket(s)
    s.connect(socket.getaddrinfo('www.google.com', 443)[0][-1])
    s.send(b"GET / HTTP/1.0\r\n\r\n")
    print(s.recv(4096))
    s.close()
    lte.disconnect()
    lte.dettach()
  • As a first step maybe try:
    lte.send_at_cmd('AT+CGDCONT=1,"IP","hologram"')
    lte.attach()
    to set the APN correctly
  • @tlanier
    I know everything is working with Verizon Cat M1 SIMs but not sure about Hologram.
    Maybe @benstr can test, the stack has had lots of updates since he last posted.
100 out of 100
