    GPy with Hologram.io SIM
    hologram.io
    100 Posts 10 Posters 42.8k Views 12 Watching
      jmarcelino @tlanier
      @tlanier
      I'm really not sure about Hologram with our modules in the US, but lets do the basic checks first:
      • Have you connected the LTE antenna to the correct port - for the GPy should be next to LED
      • Have you waited enough time? - sometimes it can take up to 45 seconds to attach
      • Maybe reception isn't very good in your area - Cat M1 coverage is still limited. Try elsewhere or ideally outside.
        tlanier @jmarcelino
        @jmarcelino
        Hologram tech support indicates that their SIM card should work with Verizon and AT&T with your GPy device. They've indicated that they have a GPy and will try the test at their site.
        Yes, the LTE antenna is connected to the correct port.
        Yes, I've waited many minutes at 3 indoor locations (work and home) and 1 outdoor location with no successful attach to tower.
        A cell phone shows the Verizon signal strength to be 3 bars.
        Any other ideas of what I can try?
        Are there any modem commands that would help understand what is taking place?
        • ChrisGammellC Offline
          ChrisGammell
          Hey Jose,
          I've been testing it on a GPy, FiPy I have here. Is there an exhaustive list of the AT command set available anywhere? I'm also tracking my progress of troubleshooting on our forum where @tlanier also posted: https://community.hologram.io/t/pycom-gpy/1664
            jmarcelino @tlanier
            Ok thanks @tlanier
            Can you try replacing your LTE attach code with:
            lte = LTE()
            send_at_cmd_pretty('AT+CPIN?')
            send_at_cmd_pretty('AT+CGDCONT=1,"IP","hologram"')
            send_at_cmd_pretty('AT+CFUN=0')
            send_at_cmd_pretty('AT+CEREG=2')
            send_at_cmd_pretty('AT!="clearscanconfig"')
            send_at_cmd_pretty('AT!="RRC::addscanfreq band=4 dl-earfcn=2175"')
            send_at_cmd_pretty('AT!="RRC::addscanfreq band=12 dl-earfcn=5095"')
            send_at_cmd_pretty('AT!="RRC::addscanfreq band=13 dl-earfcn=5230"')
            send_at_cmd_pretty('AT+CFUN=1')
            while not lte.isattached():
                time.sleep(1)
                send_at_cmd_pretty('AT!="showphy"')
                send_at_cmd_pretty('AT!="fsm"')
                send_at_cmd_pretty('AT+CEREG?')
            This will produce a lot of debug output
            ChrisGammellC T 2 Replies Last reply Reply Quote 0
              jmarcelino @ChrisGammell
              Thanks @chrisgammell !
              The only AT command guide we can publish is this: https://docs.pycom.io/chapter/datasheets/downloads/Monarch_4G-EZ_LR5110_ATCommands_ReferenceManual_Rev3_NOCONFIDENTIAL.pdf
              But really that should be enough, Sequans doesn't share the special AT!= commands even with us other than to solve particular problems.
                ChrisGammell @jmarcelino
                @jmarcelino said in GPy with Hologram.io SIM:
                AT+CEREG?')
                Here's mine:
                DL SYNCHRO STATISTICS
                    Synchro state                         : CELL SEARCH
                    PPU SIB1 ACQ watchdog                 : 1
                    Frequency Hypothesis RF  (Hz)         : -4000
                    RSRP (dBm)                            : -21474836.00
                    RSRQ  (dB)                            : -22.71
                    Channel estimation state (Cell-spec.) : LOW CINR
                    Channel estimation state (UE-spec.)   : LOW CINR
                    Channel estimation state (MBSFN)      : LOW CINR
                    Channel estimation CINR               : 0.00
                    Channel length                        : SHORT
                  AGC
                    AGC RX gain (dB)                      : 52.76
                    RX PSD BO (dBFs)                      : -21.92
                    RX PSD (dBm)                          : -93.92
                    Noise level RS (dBm)                  : -123.92
                    Digital gain (dB)                     : 12.24
                    CINR RS (dB)                          : -9.76
                  NARROWBANDS
                    Last DL NB                            : Central
                    Last UL NB                            : 0
                  AFC
                    Frequency offset RF  (Hz)             : 0
                    Frequency offset BB  (Hz)             : 0
                  PBCH
                    MIB received quantity                 : 573
                    MIB timeout quantity                  : 0
                OK
                SYSTEM FSM
                    | RRC TOP FSM              |SCANNING            |
                    | RRC SEARCH FSM           |WAIT_CELL_ID        |
                    | RRC ACTIVE FSM           |NULL                |
                    | PMM PLMN FSM             |NORM_WAITCELL       |
                    | EMM MAIN FSM             |REGISTERED          |
                    | EMM AUTH FSM             |KASME_DEFINED       |
                    | EMM CONN FSM             |EMM_IDLE            |
                    | ESM BEARER FSM           |BEARER_ACTIVE       |
                OK
                +CEREG: 2,4
                OK
                    Frequency Hypothesis RF  (Hz)         : -2000
                    RSRQ  (dB)                            : -22.71
                  AGC
                    AGC RX gain (dB)                      : 25.26
                    Digital gain (dB)                     : 4.74
                  NARROWBANDS
                    Last UL NB                            : 0
                  AFC
                  PBCH
                OK
                SYSTEM FSM
                OK
                +CEREG: 2,4
                OK
                  ChrisGammell
                  Also I'm still getting 99,99 for AT+CSQ
                  Yes, I double checked, the antenna is plugged into the correct ports :-D
                  @tlanier, did you check that command on yours?
                    tlanier @ChrisGammell
                    @chrisgammell
                    Yes, I'm also getting +CSQ: 99,99
                      Can you try this instead please:
                      send_at_cmd_pretty('AT+SQNCTM="verizon"')
                      send_at_cmd_pretty('AT!="showinit"')
                          time.sleep(1)
                      The AT+SQNCTM="verizon"' setups up some other parameters for Verizon including scanning the correct bands. These should be reflected in the new debug command AT!="showinit" after CFUN=1
                        tlanier @jmarcelino
                        @jmarcelino
                        Notice the first command (AT+CPIN?) generates an error.
                        CAT M1 Test - V0.1
                        ERROR
                        OK
                        OK
                        OK
                        OK
                        OK
                        OK
                        OK
                        OK
                            Synchro state                         : OFF
                            PPU SIB1 ACQ watchdog                 : 0
                            Frequency Hypothesis RF  (Hz)         : 0
                            RSRQ  (dB)                            : -12.36
                          AGC
                            AGC RX gain (dB)                      : 44.55
                            RX PSD BO (dBFs)                      : -21.15
                            RX PSD (dBm)                          : -85.50
                            Noise level RS (dBm)                  : -87.44
                            Digital gain (dB)                     : 6.48
                            CINR RS (dB)                          : 3.73
                          NARROWBANDS
                            Last UL NB                            : 0
                          AFC
                            Frequency offset RF  (Hz)             : -359
                          PBCH
                            MIB received quantity                 : 1778
                        OK
                        SYSTEM FSM
                            | RRC TOP FSM              |STOPPED             |
                            | RRC SEARCH FSM           |NULL                |
                            | PMM PLMN FSM             |NULL                |
                            | HP USIM FSM              |NULL                |
                            | HP CAT FSM               |NULL                |
                        OK
                        +CEREG: 2,0
                        OK
                            Synchro state                         : OFF
                            RSRQ  (dB)                            : -12.36
                          AGC
                            CINR RS (dB)                          : 3.73
                          NARROWBANDS
                            Last UL NB                            : 0
                          AFC
                          PBCH
                        OK
                        SYSTEM FSM
                            | HP USIM FSM              |NULL                |
                            | HP CAT FSM               |NULL                |
                        OK
                        +CEREG: 2,0
                        OK
                          tlanier @jmarcelino
                          @jmarcelino
                          CAT M1 Test - V0.1
                          OK
                          OK
                          OK
                          OK
                          OK
                          -- Scan options -------------------------------------------
                          | . Init Stored info use     : true
                          | . Init MRU freq use        : true
                          | . Init REG freq use        : false
                          | . Init FastScan use        : true
                          | . Init iterative band scan : false
                          | . Init scan batch of freq  : false
                          | . Init hybrid 1 mode       : false
                          | . Init optim SIB rx        : true
                          | . Forced freq              : false
                          | . MRU cell use             : true
                          -- Scan Command config ----------------------------------------------------
                          | id | type  | object                                                     |
                          | 1  | BAND  | (id:1) 4,13                                                |
                          | 2  | DELAY | 5000 msec                                                  |
                          | 3  | LOOP  | jump to cmd:1, dur:5000ms                                  |
                          OK
                              Synchro state                         : IDLE
                              RSRQ  (dB)                            : -12.79
                            AGC
                              RX PSD BO (dBFs)                      : -21.06
                              RX PSD (dBm)                          : -85.55
                              Noise level RS (dBm)                  : -86.52
                              Digital gain (dB)                     : 6.53
                              CINR RS (dB)                          : 2.09
                            NARROWBANDS
                              Last UL NB                            : 0
                            AFC
                            PBCH
                              MIB received quantity                 : 83
                          OK
                          SYSTEM FSM
                              | HP USIM FSM              |NULL                |
                              | HP CAT FSM               |NULL                |
                          OK
                          +CEREG: 2,0
                          OK
                              RSRQ  (dB)                            : -12.79
                            AGC
                              CINR RS (dB)                          : 2.09
                            NARROWBANDS
                              Last UL NB                            : 0
                            AFC
                            PBCH
                          OK
                          SYSTEM FSM
                              | HP USIM FSM              |NULL                |
                              | HP CAT FSM               |NULL                |
                          OK
                          +CEREG: 2,0
                            jmarcelino @tlanier
                            @tlanier said in GPy with Hologram.io SIM:
                            Can you leave it for a minute or so please. You should see this changing to SCANNING but it's not immediate, it's done in cycles. Thanks.
                              ChrisGammell
                              Looks like mine just needed to cycle a few more times as well, just got this:
                              +CEREG: 2,5,"CC14","031D4803",7
                                @chrisgammell
                                That's great! 2,5 is what we want for Hologram (5 means attached as roaming)
                                So does the while not lte.isattached(): loop finish correctly then and move to the connection step - which means PPP is established?
                                lte.connect()
                                while not lte.isconnected():
                                    time.sleep(1)
                                print("Connected!")
                                ChrisGammellC 1 Reply Last reply Reply Quote 0
                                  tlanier @jmarcelino
                                  @jmarcelino
                                  Mine has been running for about 10 minutes returning:
                                  +CEREG: 2,0
                                  My cell phone uses Verizon and it shows a strong 3 bar signal.
                                  I'm going to try powering down and back up to see if that will help.
                                  T J 2 Replies Last reply Reply Quote 0
                                    tlanier @tlanier
                                    @tlanier
                                    After power off/on I'm now getting +CEREG: 2,4
                                    It never gets the 2,5 you mentioned after 10 mins.
                                    Synchro state                         : MIB DETECT
                                    Frequency Hypothesis RF  (Hz)         : -1000
                                    RSRQ  (dB)                            : -25.99
                                    AGC
                                    AGC RX gain (dB) : 54.90
                                    RX PSD BO (dBFs) : -21.71
                                    RX PSD (dBm) : -95.99
                                    Noise level RS (dBm) : -124.46
                                    Digital gain (dB) : 6.62
                                    CINR RS (dB) : -16.11
                                    NARROWBANDS
                                    Last UL NB : 0
                                    AFC
                                    Frequency offset RF (Hz) : 47
                                    PBCH
                                    MIB received quantity : 1394
                                    OK
                                    SYSTEM FSM
                                    | PMM PLMN FSM             |ANY_WAITCELL        |
                                    | HP USIM FSM              |ABSENT              |
                                    | HP CAT FSM               |NULL                |
                                    OK
                                    +CEREG: 2,4
                                    OK
                                    RSRQ  (dB)                            : -25.99
                                    AGC
                                    AGC RX gain (dB) : 54.87
                                    RX PSD BO (dBFs) : -21.44
                                    RX PSD (dBm) : -96.46
                                    Noise level RS (dBm) : -126.46
                                    Digital gain (dB) : 10.13
                                    NARROWBANDS
                                    Last UL NB : 0
                                    AFC
                                    Frequency offset RF (Hz) : 70
                                    PBCH
                                    MIB received quantity : 1422
                                    OK
                                    SYSTEM FSM
                                    | RRC TOP FSM              |SYNCING             |
                                    | RRC SEARCH FSM           |WAIT_SYNC           |
                                    | HP CAT FSM               |NULL                |
                                    OK
                                    +CEREG: 2,4
                                    OK
                                    RSRQ  (dB)                            : -25.99
                                    AGC
                                    RX PSD BO (dBFs) : -21.78
                                    RX PSD (dBm) : -98.39
                                    Digital gain (dB) : 9.05
                                    NARROWBANDS
                                    Last UL NB : 0
                                    AFC
                                    Frequency offset RF (Hz) : 43
                                    PBCH
                                    MIB received quantity : 1429
                                    OK
                                    SYSTEM FSM
                                    | RRC TOP FSM              |INITIAL             |
                                    | RRC SEARCH FSM           |INITIAL             |
                                    | PMM PLMN FSM             |PARKING             |
                                    | HP CAT FSM               |NULL                |
                                    OK
                                    +CEREG: 2,4
                                    OK
                                    RSRQ  (dB)                            : -25.99
                                    AGC
                                    NARROWBANDS
                                    Last UL NB : 0
                                    AFC
                                    PBCH
                                    OK
                                    SYSTEM FSM
                                    | HP CAT FSM               |NULL                |
                                    OK
                                    +CEREG: 2,4
                                    OK
                                    RSRQ  (dB)                            : -25.99
                                    AGC
                                    NARROWBANDS
                                    Last UL NB : 0
                                    AFC
                                    PBCH
                                    OK
                                    SYSTEM FSM
                                    | HP CAT FSM               |NULL                |
                                    OK
                                    +CEREG: 2,4
                                      jmarcelino @tlanier
                                      @tlanier
                                      Maybe Cat M1 coverage in your area just isn’t very good yet, Verizon only uses one band (band 13) for Cat M1 while on mobile phones they support more.
                                        tlanier @jmarcelino
                                        @tlanier
                                        Do you know if Verizon publishes a coverage map for CAT-M1?
                                        Maybe I should try taking the device to a larger city (Newnan or Atlanta) to see if it works there.
                                        This is what it displays at the start of the test:
                                        CAT M1 Test - V0.1
                                        OK
                                        OK
                                        OK
                                        OK
                                        OK
                                        OK
                                          @jmarcelino no, it still doesn't attach, unfortunately
                                          >>> lte.attach()
                                          >>> lte.connect()
                                          OSError: modem not attached
                                          Don't want to usurp the other issues that @tlanier is having, but curious to understand why the other steps are necessary. Were those necessary with a Verizon SIM?
                                            Hi @chrisgammell ,
                                            Can you try again without calling lte.attach() please?
                                            I'm trying to avoid any wrong/missing assumptions lte.attach() is doing so the code I posted should replace that entire step, if you call lte.attach() again after that you'll effectively undo the parameters we set via custom AT commands and ask the modem to reattach with the problem settings.
                                            If you see "+CEREG: 2,5,... this means the modem is attached and lte.isattached() should return true (even if you didn't use lte.attach()...)
                                            It should then be ready to connect (start the PPP session) via lte.connect()
                                            Being certified by Verizon means we must include a specific configuration for them inside the modem - it's what CID=3 does - which sets everything correctly for them including APN, bands and a lot of other stuff they require... this was done in tight collaboration with them by the modem manufacturer so we don't need these manual configuration steps.
                                            • 5
                                            • 1 / 5
