    New firmware release v1.18.0
    firmware
    24 Posts 13 Posters 4.8k Views 13 Watching
    • I Offline
      iwahdan
      Hi @charly86 , I'll look in to adding your PR in the coming development releases
      Wahdan
      Charly86C 1 Reply Last reply Reply Quote 0
      • Charly86C Offline
        Charly86 @iwahdan
        @iwahdan Nice, but that's not my PR so I don't want to get any credit for it ;-)
          Marike
          I used the Pycom Firmware Updater to update my FiPy from v1.17.3.b1. The Updater says the latest available is 1.15 but when I proceed to the update, it detects the 1.18 stable is available and uses that.
          Issues I've encountered:
          • It takes longer after a RESET to connect to the FiPy REPL shell.
          • It appears the first call to lte.attach() always fails with an error. No error on retry but. . .
          • Connecting to LTE does not succeed (fails to attach). So far, I have tried waiting up to 10 minutes. It previously would attach and connect within 10s.
          X 2 Replies Last reply Reply Quote 0
          • X Offline
            Xykon administrators @Marike
            @marike 1.15.0 is the latest firmware updater tool version, while 1.18.0 is the latest firmware version being flashed onto the device.
            The firmware team will look at the issues raised and provide an update as soon as possible.
            If you wish to downgrade please follow these instructions.
            Christian Ehlers
            • X Offline
              @marike Two quick questions: Did you upgrade the firmware of your modem? If yes which firmware are you currently using?
              Which provider (or test system) are you using for LTE-M connectivity?
              Christian Ehlers
                jbthompson @Xykon
                @xykon Recently loaded 1.18.0 onto WiPy2.0 OEM module and having some less than optimal i2c performance.
                Issues:
                1. Doest the new i2c firmware supports i2c clock stretching? I'm communicating with a bno055 imu (that uses clock stretching) and am getting I2C hangs.
                  Currently the i2c hangs after I enable the bno055 and do a scan (which returns the address at least once before hanging).
                I have 4.7K pullups for SDA / SCL on my board that is interacting with the WiPy2.0 OEM.
                Setup:
                Talking to fuel gauge and IMU.
                Scan hangs after second attempt....
                >> from machine import I2C, Pin
                >> bno055_rst = Pin('P23', mode=Pin.OPEN_DRAIN)        # imu reset
                >> bno055_rst.value(1)         #enable imu
                >> i2c = I2C(0, I2C.MASTER)
                >> i2c.scan()
                >> [40, 85]     #success, i2c address for the bno055, bq27441
                >>i2s.scan()
                ... hangs forever, need to hard reset the wipy2.0 OEM
                Note: No hang if I disable the imu by pulling p23 low.
                Thank you!
                  Marike @Xykon
                  @xykon
                  I'm using Verizon (US) for LTE-M. The firmware for the modem was upgraded last week:
                  UE5.0.0.0c
                  LR5.1.1.0-33988
                  It looks like there is something broken with the AT commands. The response to lte.send_at_cmd('X') where X is anything is the same, whether X is valid or not:
                  >>> lte.send_at_cmd('AT+CEREG?')
                  >>> lte.send_at_cmd('AT+COPS?')
                  >>> lte.send_at_cmd('FAKE_COMMAND')
                  • bmarkusB Offline
                    bmarkus
                    Updater updates my LoPy to 1.17.5.b6 but not 1.18.0
                    • X Offline
                      Xykon administrators @bmarkus
                      @bmarkus This is the stable firmware. We haven't released a new Pybytes version yet.
                      Christian Ehlers
                      • bmarkusB Offline
                        bmarkus @Xykon
                        @xykon said in New firmware release v1.18.0:
                        I'm not using pybytes and do not want to have it, just want to update to an ordinary 1.18.0 In the updater all options, like beta versions, pybytes, forced region setting, etc. unselected. Why can't update to 1.18.0?
                        • X Offline
                          @bmarkus Are you using the latest stable firmware updater? Did you change the Type to stable in the Communications window?
                          Christian Ehlers
                          • bmarkusB Offline
                            bmarkus @Xykon
                            @xykon Thanks, setting Type to stable solved the problem, update to 1.18.0 was successful. Would be god to change default from pybytes to stable :(
                            X 1 Reply Last reply Reply Quote 3
                            • X Offline
                              @bmarkus I can't change the default but the next firmware updater release will remember your choice.
                              Christian Ehlers
                              • X Offline
                                Please note that as per the update above, we have reverted the master branch of pycom-esp-idf back to the correct commit needed to build the stable firmware.
                                We have also created a new branch idf-dev which contains all the updates previously pushed to master. The source code for the pycom-micropython-sigfox development release will be published some time next week.
                                Christian Ehlers
                                  danielm
                                  Please take a look at this thread:
                                  https://forum.pycom.io/topic/3377/fw-1-18-0-increased-boot-time-power-consumption
                                    shivankgarg98
                                    What is LORAWAN MAC version of lopy4 after this firmware update?
                                      Aubreychen @Charly86
                                      @charly86 said in New firmware release v1.18.0:
                                      cardgenerator
                                      Are you still facing this issue?
                                      • I Offline
                                        Isabell gracia Banned
                                        • Z Offline
                                          Zekai Sen Banned
                                            monika Hoenig Banned @Aubreychen
