New firmware release v1.18.0
 Hello everyone, We have released a new stable firmware v1.18.0 This fixes the following issues: -
esp32: Fix hang in AS923 due to incorrect timer behaviour.
esp32: Improve LTE stability. Forbid sending AT commands while in connected (data mode) state
lib/lora: Fix manual channel add for US915 and AU915 regions.
esp32: Add hidden SSID option. Enable websockets.
esp32: If state is already PPP, don't change it to ATTACHED.
esp32: Improve the robustness of lte.connect() when resuming a previous session.
mpy: Show Pycom version alongside Micropython core version
 Update: As it was causing more confusion than anticipated, we have reverted the master branch of pycom-esp-idf back to the correct commit to build the stable version! We will announce the new development version in the Beta Announcements & Development News sub-forum so if you're interested in trying out the latest new features I suggest you subscribe to get new topic notifications.
 The new development firmware will contain a new Micropython core, new filesystem and has been updated to use the latest esp32 IDF.Please let us know if you encounter any issues
 @charly86 said in New firmware release v1.18.0: @iwahdan Nice, but that's not my PR so I don't want to get any credit for it ;-) Are you still facing this issue? @charly86 said in New firmware release v1.18.0: @iwahdan Nice, but that's not my PR so I don't want to get any credit for it ;-)
 What is LORAWAN MAC version of lopy4 after this firmware update?
 Please take a look at this thread:
 https://forum.pycom.io/topic/3377/fw-1-18-0-increased-boot-time-power-consumption
 Please note that as per the update above, we have reverted the master branch of pycom-esp-idf back to the correct commit needed to build the stable firmware. We have also created a new branch idf-dev which contains all the updates previously pushed to master. The source code for the pycom-micropython-sigfox development release will be published some time next week.
 @bmarkus I can't change the default but the next firmware updater release will remember your choice.
 @xykon Thanks, setting Type to stable solved the problem, update to 1.18.0 was successful. Would be god to change default from pybytes to stable :(
 @bmarkus Are you using the latest stable firmware updater? Did you change the Type to stable in the Communications window?
 @xykon said in New firmware release v1.18.0: @bmarkus This is the stable firmware. We haven't released a new Pybytes version yet. I'm not using pybytes and do not want to have it, just want to update to an ordinary 1.18.0 In the updater all options, like beta versions, pybytes, forced region setting, etc. unselected. Why can't update to 1.18.0?
 Updater updates my LoPy to 1.17.5.b6 but not 1.18.0
 I'm using Verizon (US) for LTE-M. The firmware for the modem was upgraded last week: UE5.0.0.0c LR5.1.1.0-33988It looks like there is something broken with the AT commands. The response to lte.send_at_cmd('X')where X is anything is the same, whether X is valid or not:>>> lte.send_at_cmd('AT+CEREG?') '' >>> lte.send_at_cmd('AT+COPS?') '' >>> lte.send_at_cmd('FAKE_COMMAND') ''
 @xykon Recently loaded 1.18.0 onto WiPy2.0 OEM module and having some less than optimal i2c performance.
 Issues:- Doest the new i2c firmware supports i2c clock stretching? I'm communicating with a bno055 imu (that uses clock stretching) and am getting I2C hangs.
 Currently the i2c hangs after I enable the bno055 and do a scan (which returns the address at least once before hanging).
 I have 4.7K pullups for SDA / SCL on my board that is interacting with the WiPy2.0 OEM.
 Setup:
 Talking to fuel gauge and IMU.
 Scan hangs after second attempt....>> from machine import I2C, Pin >> >> bno055_rst = Pin('P23', mode=Pin.OPEN_DRAIN) # imu reset >> bno055_rst.value(1) #enable imu >> >> i2c = I2C(0, I2C.MASTER) >> >> i2c.scan() >> [40, 85] #success, i2c address for the bno055, bq27441 >> >>i2s.scan() ... hangs forever, need to hard reset the wipy2.0 OEM Note: No hang if I disable the imu by pulling p23 low.Thank you!
 @marike Two quick questions: Did you upgrade the firmware of your modem? If yes which firmware are you currently using? Which provider (or test system) are you using for LTE-M connectivity?
 @marike 1.15.0 is the latest firmware updater tool version, while 1.18.0 is the latest firmware version being flashed onto the device. The firmware team will look at the issues raised and provide an update as soon as possible. If you wish to downgrade please follow these instructions.
