    Pytrack firmware update
    pytrackfirmware updatedfu-utilubuntu
    10 Posts 5 Posters 2.1k Views 6 Watching
      jeko
      Hi Pycomers !
      I am trying to upgrade my (newly) Pytrack firmware.
      I followed the procedure as described here.
      Here is what I get :
      $ sudo dfu-util -D pytrack_0.0.8.dfu
      dfu-util 0.8
      Copyright 2010-2014 Tormod Volden and Stefan Schmidt
      Please report bugs to dfu-util@lists.gnumonks.org
      Match product ID from file: f014
      ID 04d8:f014
      Determining device status: state = dfuIDLE, status = 0
      dfu-util: WARNING: Runtime device already in DFU state ?!?
      Claiming USB DFU Interface...
      Setting Alternate Setting #0 ...
      dfuIDLE, continuing
      DFU mode device DFU version 0100
      Device returned transfer size 64
      Copying data from PC to DFU device
      Download	[======================== ]  96%        15808 bytesdfu-util: Error sending completion packet
      The timing seems hard to catch with button pressure/release.
        jeko
        Oh boy I did it ! Sounds like the timing is crucial and has to be determined experimentally haha ! Lets move on.
          robert-hh @jeko
          @jeko I agree that this workflow is most unfriendly and curse prone:
          a) Remove the device from USB
          b) Push the button
          c) Plug in the device while the button is pushed
          d) Release the button
          e) Start the sudo DFU-util .... command within 6-7 seconds
          Even if you came to that point, your busted, because sudo asks for the password (better if so), and once you entered it, the e) time windwow is closed. So start over at a), and if you're fast enough, the sudo password is still valid.
          And: for me, the "make flash" command with the new expansion board does not work at all. Not only that it needs Python3, it does not switch the PIC to firmwareload mode. So I go back to the P2->GND method, or us my hand-assembled board with the espressif reset circuitry.
          • danD Offline
            dan
            Hi @jeko and @robert-hh, it might take a few tries, I'm glad you managed to do it. You don't need to run it with sudo, it should work without it
              robert-hh @dan
              @dan If I run it w/o sudo, I got the message:
              dfu-util: Cannot open DFU device 04d8:f014
              So I added a udev rule in a file called /etc/udev/rules.d/77-pycom.rules with the content:
              # Attribute for Pytrack PIC
              ATTRS{idVendor}=="04d8", ATTRS{idProduct}=="f014", MODE="0666"
              Just giving read/write access to everyone. Could be more specific.
              • danD Offline
                dan @robert-hh
                @robert-hh which OS are you using? I'll look into this when I have some time
                  robert-hh @dan
                  @dan debian 8. But, as said below, it works now without sudo.
                    pwest @robert-hh
                    This solved my problem. Evidently my problem was that I was following the directions at https://docs.pycom.io/chapter/pytrackpysense/installation/firmware.html where the instructions for step e) are to run:
                    $ dfu-util -D pytrack_0.0.8.dfu
                    no mention of the sudo part... With sudo, it worked first try!
                    -Phil
                    • danD Offline
                      dan @pwest
                      Hi @pwest, I've added it to our documentation to avoid further confusion.
                      • kodarnK Offline
                        kodarn
                        I came across this "bytesdfu-util: Error sending completion packet" error today when attempting to upgrade a Pycom Expansionboard 3.1 connected to an Ubuntu 18.04 LTS.
                        Running ls -la /dev showed that the serialport had restricted access, so a quick fix was:
                        sudoedit /etc/udev/rules.d/50-myusb.rules
                        and insert the following:
                        KERNEL=="ttyUSB[0-9]*",MODE="0666"
                        KERNEL=="ttyACM[0-9]*",MODE="0666"
                        then
                        sudo reboot
                        After rebooting the firmware upgrade worked great (holding the s1 button when connecting the USB-cable; releasing s1 after one second; then running dfu-util within a few seconds).
                        sudo su -
                        dfu-util -D /home/user/Download/expansion31_0.0.11.dfu
