LoPy connects to TheThingsNetwork but payload is empty
Sorry, beginner question…
I am connecting a LoPy to TheThingsNetwork via OTAA. I am sending a integer of the temperature in the payload (which is converted to bytes using the Pycom lora socket object’s send method). The sensor and node all appear to work correctly, however I don't actually know what is being sent by the LoRa radio module.The node’s application on the TTN console shows the device activating, then the uplink occurs a few seconds later.
The Payload in the uplink however shows nothing (actually is reads: 00000000000000000000000000).
Have I forgotten something really obvious? I have already posted this question on TheThingsNetwork forum but I am not sure if this problem may be a LoPy issue.
@philwilkinson For readable data you could also use:
data = "%.2f" % si.temperature()
and use float(recv_data) for back-conversion.
@philwilkinson Since you did no use tohex while sending, fromhex is not needed, unles the tohex is done somewhere else.
Brilliant! thanks @robert-hh for the guidance. I need to study my data types a lot more!
As I thought I should keep a float temperature reading for reasonable accuracy; my code now reads:s = socket.socket(socket.AF_LORA, socket.SOCK_RAW) s.setsockopt(socket.SOL_LORA, socket.SO_DR, 5) s.setblocking(True) raw_data = round((si.temperature()), 2) data = struct.pack('f', raw_data) s.send(data) print('sent ', raw_data, ' to TTN')
I now have to work out how to get the payload back into a readable format using something like
struct.unpack('f', (bytes.fromhex('HEX value in payload')))
@philwilkinson Yes. That's why you get e straing ouf zeroes:
when you convert the float number to an int, you may receive a number like 8. bytes(8) however creates a bytearray of 8 bytes length, each with the value 0.
To convert a number into a bytearray containing this number you can either usrstr(number)
or similar to convert it to an ascii string, or struct.pack(), like:
struct.pack("<i", number)
See https://docs.python.org/3/library/struct.html
results in
I didn't include the whole script as it would get too long...!
s = socket.socket(socket.AF_LORA, socket.SOCK_RAW) # set the LoRaWAN data rate s.setsockopt(socket.SOL_LORA, socket.SO_DR, 5) # make the socket blocking # (waits for the data to be sent and for the 2 receive windows to expire) s.setblocking(True) from pysense import Pysense from SI7006A20 import SI7006A20 py = Pysense() si = SI7006A20(py) data = int(si.temperature()) #converted float to integer s.send(bytes(data)) print('sent data to TTN') # make the socket non-blocking # (because if there's no data received it will block forever...) s.setblocking(False)
@philwilkinson Can you post the code that creates the payload. Pleas enclose code in lines of three backticks (```)
