    Multitech conduit and Lopy "Not joined yet"
    lopymultitechconduitfailureconnect
    22 Posts 5 Posters 6.9k Views 5 Watching
      jmarcelino @MOnsteroz
      @monsteroz
      Ok some problems...
      In the AU915 region need to restrict the LoPy to what your gateway is set to:
      Frequency Sub-Band 4
      Because as configured the LoPy expects to use all valid 72 channels. However most real world gateways are limited to only 8 channels, hence the full channel map is partitioned into subbands.
      So add a function like this
      def select_subband_au915(lora, subband):
          if (type(subband) is int):
              if ((subband<1) or (subband>8)):
                  raise ValueError("subband out of range (1-8)")
              raise TypeError("subband must be 1-8")
          for channel in range(0, 64):
              lora.remove_channel(channel)
          for channel in range((subband-1)*8, ((subband-1)*8)+8):
              lora.add_channel(channel, frequency=915200000+channel*200000, dr_min=0, dr_max=5)
      the call select_subband_au915(lora, 4) to remove all channels which don't belong to sub-band 4 after initialising your LoRa object (and before joining)
        MOnsteroz @jcaron
        @jcaron
        The Lopy and Lopy4 just does not exit the loop and says "not joined yet."
          MOnsteroz @jmarcelino
          @jmarcelino Hi,
          If I lock it to sub band 4 it seems to just hang
          # Europe = LoRa.EU868
          # United States = LoRa.US915
          lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AU915)
          # create an ABP authentication params
          If I add the below I get the same 'Not joined yet" message
          app_eui = binascii.unhexlify('1122334455667788')
          app_key = binascii.unhexlify('11112222333344445555666677778888')
          # Join the network
          #lora.join(activation=LoRa.OTAA, auth=(app_eui, app_key), timeout=600)
            Thanks @monsteroz
            I'm not an expert on Multitech but I think your "Join Delay" isn't according to the specification.
            That should be 5 (seconds) as Robert already pointed out. Did you change it already?
            Do keep the sub channel selection code. That's also necessary, but not sufficient.
              @jmarcelino
              I did not change the Join Delay but I have now changed it to 5 seconds with no change
              thanks
              Sean
                MOnsteroz
                Hi guys,
                I reset to factory setting on the conduit and just added ID nd Key .. still no luck with the lopy..
                Sean
                  @monsteroz
                  Can you post what are you current gateway settings please?
                  M 2 Replies Last reply Reply Quote 0
                    @jmarcelino
                    Hi I have been changing settings to try and make it work but here is what it is at the moment. I have changed to FSB 2 in case I want to use the TTN in the future.
                    Cheers
                      @jmarcelino
                      Hi I was trying the code on Leo Gaggl's blog page .
                      Cheers
                      Sean
                        bnjroos
                        • 2 / 2
