    wipy2.0i2cpycompythonsaving data
    100 Posts 2 Posters 28.4k Views 2 Watching
      robert-hh @VFlorio94
      @vflorio94 Actually I have no clue what's happening and what was done.
      • V Offline
        VFlorio94 @robert-hh
        @robert-hh but the message in the second line what means? when I upload file is necessary a safe booting? and here it isn't in safe booting
          @vflorio94 I do not know what pymakr is doing. It can force a sfae boot via Ctrl-F, but that has to be configured somewhere in pymakr.
          • V Offline
            @robert-hh can be something in project settings? but I didn't modify it
              @vflorio94 Looks like the seeting of "safe_boot_on_upload": false
              • V Offline
                @robert-hh yes, i see it, but i don't know if I can modify it and if i have to upload also this pymakr.conf ?
                  @vflorio94 pymakr.conf is local file on your PC, configuring pymakr. Why should you not be able to modify it. You may have to restart Atom after that.
                  • V Offline
                    @robert-hh Hi, I need to ask you one more time. Do you know if there is a way to save on micro SD not only file.txt but also file.py?
                    thank you!!
                      @vflorio94 A python script is a text file, just with the extension .py. You can start that from sd card with two methods:
                      a) change the active directory to the card before import
                      mount the card
                      os.chdir("/sd")
                      import file
                      b) change the system path.
                      If you
                      import sys
                      print(sys.path)
                      you get something like ['', '/flash', '/flash/lib'], which is the list of places where the python scripts are looked for. '' is the actual directory. You can add "/sd" to that path with:
                      sys.path.append("/sd")
                      you can also directly set sys.path to the list of places.
                      • V Offline
                        @robert-hh I try to update my main.py and my lib.py on sd card but I can't understand where i have to put the command that you wrote.
                          @vflorio94 You have to put that in boot.py or main.py in flash, because that is executed in first place.
                          • V Offline
                            @robert-hh thank you, I do it.
                            another question, if I read data from a file.txt and I want to reuse this data, what is the way to import and/or assign them to a local variable?
                            thank you
                              @vflorio94 To read the data from a file, you could read it all in once, assumign f is the opened file, with:
                              text = f.readlines()
                              then text is a list of strings. That however will use a lot for RAM. You can also read line by line with:
                              for line in f:
                              # line is one line to be processed
                              • V Offline
                                @robert-hh YEs, but i have a file.txt with this content
                                [169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5, 169.5]  [0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.1875, 0.125, 0.1875]       [-177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.5625, -177.625, -177.5625]
                                I want to iterate data by data in this file and compare them with other value trough control 'if'.
                                for example I want to use data in the first square brackets and step by step compare them with other numeric value, do you know a way to do this?
                                I am not able to convert them in numeric value and compare them one by one, I know that i have to use a 'for' to pass all the value but I am not succeded.
                                  @vflorio94 Can you create the file in a different format, like having one line for each set of data in brackets?
                                    @vflorio94 You can do something like:
                                    f = open("file.txt", "r")
                                    line = f.read()
                                    f.close()
                                    # now you have the full test in one string
                                    list = line.split("[")
                                    # now you have a list of three strings, and an empty one
                                    # remove the empty ones
                                    for index, item in enumerate(list):
                                        if len(item) == 0:
                                            del list[index]
                                    # convert to numeric value
                                        item = item.strip("] ").split(",")
                                        # now item is a list of numeric strings
                                        for i, el in enumerate(item):
                                            item[i] = float(el)
                                        list[index] = item
                                        # now list is a list of lists with numeric values
                                        # indexing by list[i][j]
                                    • V Offline
                                      @robert-hh yes, i'll create a file in which I put one set of data in brackets in a line, then there is a way to extract a single data and do a control on it and then pass to the data in the next position?
                                        @vflorio94 In my previous post I showed a code snippet, if all data is in one line. If each bracket is in a separate line, then the code snippet is much simpler.
                                        f = open("file1.txt", "r")
                                        list = f.readlines()
                                        f.close()
                                        # now you have a list of one string per line
                                            item = item.strip("[]\n ").split(",")
                                                item[i] = float(el)
                                            list[index] = item
                                            # now list is a list of lists wirth numeric values
                                        V 2 Replies Last reply Reply Quote 0
                                        • V Offline
                                          @robert-hh Thank you, I didn't see your comment before. At the end I am succeded in a similar way, now i'll try also yours
                                          thank you very much
                                            @vflorio94 Shortened version, not easy to read:
                                            with open("file.txt", "r") as f:
                                                    list[index] = [float(el) for el in item.strip("[]\n ").split(",")]
                                                    # accessible with list[i][j]
                                            • 5
                                            • 4 / 5
