    New Stable release v1.18.1
    firmwarelte
    21 Posts 8 Posters 5.2k Views 10 Watching
    • I Offline
      IOAg @iwahdan
      Hi @iwahdan, my modem is not bricked. I am trying to update to latest firmware because there is an connectivity issue in Australia usingLTE CAT M1 with Telstra. Should I follow follow another process? Thanks.
      • I Offline
        iwahdan @IOAg
        ok, thanks @IOAg , I am looking in to that error you had and will update you Asap
        Wahdan
        • E Offline
          EinarJ
          I am getting this error when trying to upgrade the modem:
          import sqnsupgrade
          sqnsupgrade.run('/sd/NB1-37781.dup','/sd/updater.elf')
          AttributeError: 'module' object has no attribute 'run'
          The FiPy is upgraded to the latest FW with the updating tool. Formatted the SD card, mounted it and transferred the files as described. Got the latest version of the sqnsupgrade from GitHub and transferred it to the FiPy.
          • I Offline
            iwahdan @EinarJ
            Hi @einarj, you don't need to transfer scripts fro GitHub to the Fipy, these scripts are already embedded in the Firmware (v1.18.1) as frozen code
            Wahdan
            E 1 Reply Last reply Reply Quote 1
            • E Offline
              EinarJ @iwahdan
              Hi @iwahdan ,
              It seems the firmware updating tool only upgrades the FiPy to 1.18.0.r1
              Tool version is 1.15.1
              BR.
              Einar
              • I Offline
                iwahdan @EinarJ
                Hi @einarj, could you update to version 1.15.2 https://forum.pycom.io/topic/3454/new-development-firmware-updater-1-15-2-b1
                Wahdan
                • E Offline
                  EinarJ @iwahdan
                  Thanks @iwahdan ,
                  Managed to upgrade it to 1.18.1 - but I get the same error as mentioned from others:
                  import sqnsupgrade
                  File "sqnsupgrade.py", line 538, in run
                  File "sqnsupgrade.py", line 168, in detect_modem_state
                  File "sqnsupgrade.py", line 89, in return_code
                  AttributeError: 'NoneType' object has no attribute 'decode'
                    peterv
                    Hi @iwahdan,
                    Looks like the delay is not long enough:
                    >>> from sqnsupgrade import sqnsupgrade
                    >>> sqnup = sqnsupgrade()
                    >>> sqnup.detect_modem_state()
                    >>> sqnup.detect_modem_state(initial_delay=8)
                    • I Offline
                      iwahdan @peterv
                      @peterv , I do acknowledge now that this error happens with some modules , not all of them, we are working on doing a fix for that.
                      Wahdan
                        apallo @EinarJ
                          apallo
                            tuftec @iwahdan
                            Hi @iwahdan, My LoPy is brand new. Never been used.
                            Peter.
                              robert-hh @iwahdan
                              @iwahdan The new release excludes own files in the frozen directory to be included into the build. At the moment they have to be places in one of the subdirectories, Base or Common. Maybe the build script is changed again, or an additional subdirectory is defined for user code, like Custom (?).
                              Edit: The script to be changed is py/mkrules.mk.
                              Edit2: I do not understand the need to change the makefile, because files in subdirectories have always been included into the build.
                              • I Offline
                                iwahdan @robert-hh
                                @robert-hh , yes since the frozen folder structure has been changed py/mkrules.mk had to be updated, your proposal sounds very good , I'll consider it in the new release which I believe will not be far away, for now as you mentioned you can place your scripts in either the Base or Common folder .
                                we have gone with this structure as we are planning to merge the Pybytes firmware into the Base Firmware Build Environment , so Scripts in Common would be included in both Base and PyBytes Builds but PyBytes builds would include Common and other scripts in a new Folder , will be called Pybytes... and LTE with Only FIPY and GPY.
                                Hope that explains it.
                                Wahdan
                                • I Offline
                                  iwahdan
                                  A new firmware v1.18.1.r1 has been released for fixing the issue encountered during modem state detection
                                  Wahdan
                                    robert-hh @iwahdan
                                    @iwahdan OK. I adapted my mkrules.py script already to include files from a 'Custom' folder.
                                      Prx
                                      More simple procedure on Linux :
                                      start from the Linux menu "Pycom Firmware tool", quote "include dev releases"
                                      then just choice /dev/ttyACM0 in High transfert mode
                                      the firmware is flashed in 1.18.1.r1
                                      Wrote 1.19 MiB from sipy.bin in 1 minute and 13.88 seconds
