    New Stable release v1.18.1
    firmwarelte
    21 Posts 8 Posters 4.9k Views 10 Watching
    • E Offline
      EinarJ @iwahdan
      Hi @iwahdan ,
      It seems the firmware updating tool only upgrades the FiPy to 1.18.0.r1
      Tool version is 1.15.1
      BR.
      Einar
      • I Offline
        iwahdan @EinarJ
        Hi @einarj, could you update to version 1.15.2 https://forum.pycom.io/topic/3454/new-development-firmware-updater-1-15-2-b1
        Wahdan
        • E Offline
          EinarJ @iwahdan
          Thanks @iwahdan ,
          Managed to upgrade it to 1.18.1 - but I get the same error as mentioned from others:
          import sqnsupgrade
          sqnsupgrade.run('/sd/NB1-37781.dup','/sd/updater.elf')
          File "sqnsupgrade.py", line 538, in run
          File "sqnsupgrade.py", line 168, in detect_modem_state
          File "sqnsupgrade.py", line 89, in return_code
          AttributeError: 'NoneType' object has no attribute 'decode'
            peterv
            Hi @iwahdan,
            Looks like the delay is not long enough:
            >>> from sqnsupgrade import sqnsupgrade
            >>> sqnup = sqnsupgrade()
            >>> sqnup.detect_modem_state()
            >>> sqnup.detect_modem_state(initial_delay=8)
            • I Offline
              iwahdan @peterv
              @peterv , I do acknowledge now that this error happens with some modules , not all of them, we are working on doing a fix for that.
              Wahdan
                apallo @EinarJ
                  apallo
                    tuftec @iwahdan
                    Hi @iwahdan, My LoPy is brand new. Never been used.
                    Peter.
                      robert-hh @iwahdan
                      @iwahdan The new release excludes own files in the frozen directory to be included into the build. At the moment they have to be places in one of the subdirectories, Base or Common. Maybe the build script is changed again, or an additional subdirectory is defined for user code, like Custom (?).
                      Edit: The script to be changed is py/mkrules.mk.
                      Edit2: I do not understand the need to change the makefile, because files in subdirectories have always been included into the build.
                      • I Offline
                        iwahdan @robert-hh
                        @robert-hh , yes since the frozen folder structure has been changed py/mkrules.mk had to be updated, your proposal sounds very good , I'll consider it in the new release which I believe will not be far away, for now as you mentioned you can place your scripts in either the Base or Common folder .
                        we have gone with this structure as we are planning to merge the Pybytes firmware into the Base Firmware Build Environment , so Scripts in Common would be included in both Base and PyBytes Builds but PyBytes builds would include Common and other scripts in a new Folder , will be called Pybytes... and LTE with Only FIPY and GPY.
                        Hope that explains it.
                        Wahdan
                        • I Offline
                          iwahdan
                          A new firmware v1.18.1.r1 has been released for fixing the issue encountered during modem state detection
                          Wahdan
                            robert-hh @iwahdan
                            @iwahdan OK. I adapted my mkrules.py script already to include files from a 'Custom' folder.
                              Prx
                              More simple procedure on Linux :
                              start from the Linux menu "Pycom Firmware tool", quote "include dev releases"
                              then just choice /dev/ttyACM0 in High transfert mode
                              the firmware is flashed in 1.18.1.r1
                              Wrote 1.19 MiB from sipy.bin in 1 minute and 13.88 seconds
