    LiPo battery connector?
    14 Posts 8 Posters 8.7k Views 8 Watching
      Batilan @abilio
      @abilio As this is the part number of the connector that you are using on the extension board I guess you would need somethng like XHP-2 housing for crimp contact and a 22AWG crimp contact if you want to replace any non-matching connector? However it is a lot easier to get a LiPo with the right connector off course.
      Currently the Pycom site mentions JST-style connector at several places. I guess it would be better to refer to the specific type of connector as is mentioned at this topic to prevent confusion. As JST is just the name of a company (Japan Solderless Terminals) that produces a lot of different connector types. The JST type connectors that are often used on RC products typically differ from the connectors as often used on PCB products.
      • X Offline
        Xykon administrators
        Thanks everyone for your comments. I found a matching cable from Sparkfun in in one of my many cable boxes and soldered it it the battery so I'm set for now. When I need additional batteries I'll be more careful to make sure I get the right connectors.
        Christian Ehlers
          gertjanvanhethof Pybytes Beta @Xykon
          @Xykon
          Can you please share the details of this matching cable?
          Can you also share which LiPo you bought?
          And finally, which LiPo charger are you using
          Thxs in advance!
          R X 2 Replies Last reply Reply Quote 0
            rskoniec @gertjanvanhethof
            @gertjanvanhethof Maybe my info would be also helpful.
            • Cable - https://botland.com.pl/szukaj?controller=search&orderby=position&orderway=desc&search_query=ADA-06563&submit_search=
            • Battery - https://botland.com.pl/szukaj?controller=search&orderby=position&orderway=desc&search_query=AKU-06052&submit_search=
            • Charger - I'm using built-in on Expansion Board
            Links to the store are in polish language (sorry, no english version), but maybe photos and numbers would be useful. ;o)
            G 1 Reply Last reply Reply Quote 1
              gertjanvanhethof Pybytes Beta @rskoniec
              @rskoniec Thxs! This is helping me further on this. Why does Pycom not give details about this? Or delivering one?
                gertjanvanhethof Pybytes Beta @gertjanvanhethof
                I have brought one from SODAQ now.
                http://shop.sodaq.com/nl/lithium-ion-polymeer-batterij-12ah-21158912.html
                Sorry it's Dutch :-)
                • X Offline
                  Xykon administrators @gertjanvanhethof
                  @gertjanvanhethof said in LiPo battery connector?:
                  https://www.sparkfun.com/products/9914 I had it in my big box of cables.
                  See the link in my original post at the top
                  Expansion board that came with the LoPy.
                  Christian Ehlers
                  • W Offline
                    wierni
                    Gert jan, thanks for the link.
                    I have several Blade micro helies, and i didnt knew the name.
                    The lipo connector is the type 'mcpx' JST PH2.0.
                    Got some from old worn down batteries.
                    Beware the ploarity!
                    With regards,
                    Niek
                      Rachelsimida @gertjanvanhethof
                      @gertjanvanhethof Hi, I want to know when you bought this battery, the connector was together with the battery?
                        johncass Pycom Ambassadors
                        I just received a 2000mah and a 3000mah from Pimoroni in the UK. Great quality and not from China so they were here in 2 days.
                        https://shop.pimoroni.com/products/lipo-battery-pack?variant=12704945864787
