    Telstra LTE Cat-M Working on FiPy .... Just..
    fipyltecat-m1lte-mtelstra
    26 Posts 8 Posters 10.1k Views 8 Watching
      Hello everyone,
      Apologies for the delays here. We have a session with the Telstra team this week to sort this out with their help. We'll update everyone after that.
      • I Offline
        IOAg @daniel
        @daniel i have been able to connect consistently to LTE Telstra using below band settings:
        lte.send_at_cmd('AT!="addscanfreq band=28 dl-earfcn=9410"')
        In comparaison, latest firmware v 1.17.2.b1 is not working when I calling attach(band=28); Do you mind checking with telstra about your earfcn parameter?
        John BairdJ 1 Reply Last reply Reply Quote 0
          @ioag said in Telstra LTE Cat-M Working on FiPy .... Just..:
          9410
          That's interesting... I'll ask Telstra. How did you come up with the value of 9410? The central value should be 9435 according to the specs...
          • I Offline
            IOAg @daniel
            @daniel Telstra staff gave me this value to try, worked first go :)
              robert-hh @timh
              @timh The Pycom firmware times out 10 seconds after sending a command. "AT+COPS=?" takes longer to respond. I've seen that by hooking on a pair UART/USB bridges to the link between the ESP32 and the Sequans modem. I just wanted to see what's going on there.
              • John BairdJ Offline
                John Baird @IOAg
                @ioag Any chance you could share your Telstra connect code? I must be doing something wrong...
                Does anyone have an update on the stability issues?
                • 2 / 2
