Firmware release 1.0.0.b2
Dear all,
We just released a new version that fixes a few bugs. Version 1.0.0.b2 corrects 2 problems found on the previous release:
WiFi scan after a BLE scan would hang indefinitely.
machine.reset() was failing to reboot the board.
Please download the new updater from:
https://www.pycom.io/support/supportdownloads/ and upgrade all our modules. Thanks.
@rskoniec thanks. I'll correct that immediately.
@RSK please update to 1.0.1.b1 :-)
I am have a completely different problem with the updater on windows 10. When I try to run it, it just hangs. I can't even close the file window.
@rcomeau I'm sorry to hear about your issues and thanks for the report regarding Windows 10. We'll test it and provide a fix asap.
Attribute error: "module" object has no attribute 'SOFT_RESET'
It looks like you are running an old firmware. In order to get your firmware version try:
import os print(os.uname().release)
I don't know what firmware version I am running, because I can't run the updater. But when I do a:
machine.reset(), I get a traceback error saying:
File "boot.py" line 11 in <module>
ble.scan() is failing with new firmware release 1.0.0.b2.
This is due to some unhandled exception:
![0_1482380689788_upload-1e8e28d9-8ddb-423f-b392-ae0dc3775813](Uploading 100%)Firmware version showed as:
![0_1482380777620_upload-c68b6d2d-2c3b-4cf3-8ece-ed3c129c3e0c](Uploading 100%)Thanks & Regards,
Satish Kumar. R.
@livius said in Firmware release 1.0.0.b2:
@Xykon where it is downloaded?
The dialog based updater downloads to
${TEMP_DIR}/tmpfile
I haven't checked the gui based updater. The update binary is deleted after it is flashed.You can download the firmware packages directly without the updater:
# You can use wget -qO- instead of curl -sL #For WiPy2: curl -sL "https://software.pycom.io/findupgrade?key=wipy.wipy%20with%20esp32&redirect=false&type=all" #For LoPy 868: curl -sL "https://software.pycom.io/findupgrade?key=lopy.lopy%20with%20esp32.868&redirect=false&type=all" #For LoPy 915: curl -sL "https://software.pycom.io/findupgrade?key=lopy.lopy%20with%20esp32.915&redirect=false&type=all"
You should get an output similar to this:
{"key":"lopy.lopy with esp32.868","file":"https://software.pycom.io/downloads/1.0.0.b2-LoPy_868.tar.gz","version":"1.0.0.b2","intVersion":67108994,"hash":"7fbe262192c713e01e7e049de93d522ed38c71e4"}
The "file" attribute shows the direct link to the firmware binary files. You can then download the file with
wget "https://software.pycom.io/downloads/1.0.0.b2-LoPy_868.tar.gz"
and usebin/updater.py -t 1.0.0.b2-LoPy_868.tar.gz -p /dev/ttyUSB0
@daniel Thank you. My mistake. But the same mistake is in the docs https://docs.pycom.io/pycom_esp32/library/network.WLAN.html so it should be corrected.
To make it work you have to do:
import network wlan = network.WLAN(mode=network.WLAN.STA)
You have only imported the network module, therefore
WLAN.STA
cannot be resolved.Cheers,
@Xykon
it worked ! Thank you.
@crc16 said in Firmware release 1.0.0.b2:
The "firmware" directory is missing in file pycom_update_1.0.0.b2.tar.gz
The firmware file is downloaded automatically. This way you'll always get the latest version of the firmware without having to go to the website and download a new package.
@Xykon we will update this this Thursday, we are cleaning up several things after updating to the latest IDF. Sorry for the delay.
Unless I'm mistaken github.com/pycom/pycom-micropython hasn't yet been updated with this version. The last commit 765f2bc is from 18 days ago. Can you please update the repository?
Yesterday I've noticed that this code is working:
from network import WLAN wlan = WLAN(mode=WLAN.STA)
and this isn't:
import network wlan = network.WLAN(mode=WLAN.STA)
Please check and let me know if I'm alone with this issue. ;o)
@arneme
try once again your upgrade - deselect "fast connection" or something simmillar in updater tool - it help me on one device maybe you got success also@daniel By default this "fast connection" option is checked and first time when I was updating my LoPy I get an error. Second time with this option unchecked update was successful. Can you say a little bit more about this option? Thanx. ;o)
@daniel Here is the error message:
File "lopyupdate.py", line 73, in __do_work self.__done_signal.emit(callback, func(param), param) File "lopyupdate.py", line 97, in get_file_worker timeout=20 File "/usr/lib/python2.7/dist-packages/requests/api.py", line 55, in get return request('get', url, **kwargs) File "/usr/lib/python2.7/dist-packages/requests/api.py", line 44, in request return session.request(method=method, url=url, **kwargs) File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 455, in request resp = self.send(prep, **send_kwargs) File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 558, in send r = adapter.send(request, **kwargs) File "/usr/lib/python2.7/dist-packages/requests/adapters.py", line 385, in send raise SSLError(e) requests.exceptions.SSLError: [Errno 1] _ssl.c:510: error:14077438:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert internal error
Thanks for the update.
I can confirm that WiFiscan
now works after Bluetooth instantiation.Cheers,
M.
