    Firmware release 1.0.0.b2
    38 Posts 10 Posters 15.2k Views 10 Watching
      crc16 @Xykon
      @Xykon
      it worked ! Thank you.
        daniel @rskoniec
        @rskoniec
        To make it work you have to do:
        import network
        You have only imported the network module, therefore WLAN.STA cannot be resolved.
          rskoniec @daniel
          @daniel Thank you. My mistake. But the same mistake is in the docs https://docs.pycom.io/pycom_esp32/library/network.WLAN.html so it should be corrected.
          • X Offline
            Xykon administrators @livius
            @livius said in Firmware release 1.0.0.b2:
            @Xykon where it is downloaded?
            The dialog based updater downloads to ${TEMP_DIR}/tmpfile I haven't checked the gui based updater. The update binary is deleted after it is flashed.
            You can download the firmware packages directly without the updater:
            # You can use wget -qO- instead of curl -sL
            #For WiPy2:
            curl -sL "https://software.pycom.io/findupgrade?key=wipy.wipy%20with%20esp32&redirect=false&type=all"
            #For LoPy 868:
            curl -sL "https://software.pycom.io/findupgrade?key=lopy.lopy%20with%20esp32.868&redirect=false&type=all"
            #For LoPy 915:
            curl -sL "https://software.pycom.io/findupgrade?key=lopy.lopy%20with%20esp32.915&redirect=false&type=all"
            You should get an output similar to this:
            {"key":"lopy.lopy with esp32.868","file":"https://software.pycom.io/downloads/1.0.0.b2-LoPy_868.tar.gz","version":"1.0.0.b2","intVersion":67108994,"hash":"7fbe262192c713e01e7e049de93d522ed38c71e4"}
            The "file" attribute shows the direct link to the firmware binary files. You can then download the file with wget "https://software.pycom.io/downloads/1.0.0.b2-LoPy_868.tar.gz" and use bin/updater.py -t 1.0.0.b2-LoPy_868.tar.gz -p /dev/ttyUSB0
            Christian Ehlers
              RSK
              @daniel
              ble.scan() is failing with new firmware release 1.0.0.b2.
              This is due to some unhandled exception:
              ![0_1482380689788_upload-1e8e28d9-8ddb-423f-b392-ae0dc3775813](Uploading 100%)
              Firmware version showed as:
              ![0_1482380777620_upload-c68b6d2d-2c3b-4cf3-8ece-ed3c129c3e0c](Uploading 100%)
              Thanks & Regards,
              Satish Kumar. R.
                rcomeau Pybytes Beta
                I am have a completely different problem with the updater on windows 10. When I try to run it, it just hangs. I can't even close the file window.
                  I don't know what firmware version I am running, because I can't run the updater. But when I do a:
                  machine.reset(), I get a traceback error saying:
                  File "boot.py" line 11 in <module>
                  Attribute error: "module" object has no attribute 'SOFT_RESET'
                    daniel @rcomeau
                    @rcomeau I'm sorry to hear about your issues and thanks for the report regarding Windows 10. We'll test it and provide a fix asap.
                    It looks like you are running an old firmware. In order to get your firmware version try:
                    print(os.uname().release)
                      daniel @RSK
                      @RSK please update to 1.0.1.b1 :-)
                        daniel @rskoniec
                        @rskoniec thanks. I'll correct that immediately.
                        • 2 / 2
