    Lost PyMakr in VSCode
    vscode pymakr
    40 Posts 10 Posters 6.4k Views 10 Watching
      ChangedDaily @Ralph
      • K Offline
        kgunnar
        I'm also having this issue. I was just using pymakr yesterday but today when I opened up VS Code today, it was nowhere to be found. Ctrl+Shift+C responds with "command 'pymakr.connect' not found". I don't recall my VS Code updating between then and now but I just checked my VS Code version:
        Version: 1.31.0
        Commit: 7c66f58312b48ed8ca4e387ebd9ffe9605332caa
        Date: 2019-02-06T08:51:24.856Z
        Electron: 3.1.2
        Chrome: 66.0.3359.181
        Node.js: 10.2.0
        V8: 6.6.346.32
        OS: Linux x64 4.15.0-45-generic
        So it did update. I switched updating to manual but I can't use pymakr at the moment... is a fix imminent or do I need to take other steps to try and get back to work again? Is this strictly an issue with the serialport library? I also use PlatformIO with VS Code rather extensively and have never had issues connecting to serial or otherwise when VS Code has updated.
          ChangedDaily @Ralph
          @ralph Looks like you've got a job on your hands keeping up there! I hope you can update the plugin because despite me setting VS Code not to update (I was pretty sure I had) it did, so when I came to start on this tonight of course no Pymakr extension. Had to rollback VS Code again.
            Paul Thornton @kgunnar
            @kgunnar Ralph is busy working on the fix now. Hopefully, it won't be much longer. I believe others have confirmed manually rolling back and installing VSCode 1.30 is a temp fix. but VScode seems to ignore its option telling it to not auto update at times so you may lose it again.
              combaindeft @Paul Thornton
              @paul-thornton said in Lost PyMakr in VSCode:
              Jupp.
              • A) 1st make sure to disable auto-update ... or it'll sneak it in again :-)
              In setting, search for: update.channel ... and Choose None or Manual
              • B) You can download (rollback) here: https://code.visualstudio.com/updates/v1_30
                curtis.hendrix @combaindeft
                @combaindeft Just a side note: make sure to change the update.channel setting before uninstalling 1.31. I got burned after installing 3.10, since the updater runs before the settings get saved. So 3.10 saw the old update.channel setting, so it updated to 1.31.
                  combaindeft @curtis.hendrix
                  @curtis-hendrix Yeah 🤓 *fixed-post*
                    Ralph
                    v1.0.6 has just been released to fix these issues. Let me know if any of you are still facing any after updating.
                      Martinnn @Ralph
                      @ralph 1.0.6 just installed, is broken (no command bar, no connection) in VSCode 1.30
                        Ralph @Martinnn
                        @martinnn Make sure you run vscode 1.31. The precompiled serialport lib's are now rebuild for that version specifically.
                          Martinnn @Ralph
                          @ralph OK, updated VSCode the second time today. Works with pymakr 1.0.6.
                            Ralph @Martinnn
                            @martinnn Good to hear!
                            Also, sorry for the delay on this new version guys. We'll have to work on our rebuild process a bit to keep pymakr compatible with vscode.
                              jand @Ralph
                              @ralph: Today I suddenly couldn't connect anymore to the extension board (3.1) with a lopy4 through the COM13 port I always use. Next I even lost Pymakr completely in VSCode.
                              Reading the posts in this topic, I realized I needed to upgrade VSCode to the latest version, which I did. I now have:
                              Version: 1.31.1 (system setup)
                              Commit: 1b8e8302e405050205e69b59abb3559592bb9e60
                              Date: 2019-02-12T02:20:54.427Z
                              Electron: 3.1.2
                              Node.js: 10.2.0
                              V8: 6.6.346.32
                              OS: Windows_NT x64 6.1.7601
                              And I have Pymakr 1.0.6.
                              But I cannot connect to the lopy4 anymore: > Failed to connect (Error: Port is not open). Click here to try again.
                              The VSCode command 'List serial ports' yields the following:
                              Found 2 serialports
                              COM5 (Dell) (copied to clipboard)
                              COM3 (Dell)
                              But I cannot connect to the lopy4. It doesn't work with COM5, not with COM3, and not with COM13.
                              When I connect through COM5, the console starts producing a continuous stream like this:
                              $GPGGA,,,,,,0,00,0.5,,M,,,,*00
                              $GPGSV,1,1,00,,,,,,,,,,,,,,,,79
                              $GPGLL,,,,,235944.000,V,N
                              77
                              $GPGGA,,,,,,0,0,,,M,,,,*1B
                              $GPGSA,A,1,,,,,,,,,,,,,,,*1E
                              $GPGST,235944.000,,,,0,,,74
                              $GPRMC,235944.000,V,,,,,,,,,,N
                              40
                              $GPGLL,,,,,235946.000,V,N
                              75
                              etc.....
                              What to do?
                              R robert-hhR 2 Replies Last reply Reply Quote 0
                                Ralph @jand
                                Hi @jand, looks like your device is not detected by the driver anymore. If it would be, it would definitely show up in the 'list serial ports' list. Did you restart your computer and try again? Happens on my mac sometimes if you unplug the device when it's connected, it doesn't show up again until you reboot.
                                I don't know what COM5 has attached, but that doesn't look like something any Pycom device would output :) Perhaps @iwahdan can confirm that.
                                C P J 3 Replies Last reply Reply Quote 0
                                  robert-hh @jand
                                  @jand said in Lost PyMakr in VSCode:
                                  $GPGLL,,,,,235944.000,V,N77
                                  $GPRMC,235944.000,V,,,,,,,,,,N40
                                  $GPGLL,,,,,235946.000,V,N75
                                  These look like sequences from a GPS module. Do you by change have one attached?
                                    crumble @Ralph
                                    @ralph said in Lost PyMakr in VSCode:
                                    This is the output of NMEA GPS sentences. Can be a pytrack ;)
                                    @jand If VSCode works like Atom, click in the window of the output and hit ctrl-c a couple of times. This shall bring you into the REPL.
                                    There may be a setting which hits the break key as soon the pytrack is connected.
                                    PS: Your sentences show a lot of garbage. Check the way you read them. It seems that you drop a lot of chars and mix up multiple sentences.
                                      Paul Thornton @Ralph
                                        jand @robert-hh
                                        @robert-hh No, I do not have a GPS module attached. Just an expansion board 3.1 with a Lopy4.
                                          jand @Ralph
                                          @ralph I did restart the computer, but that does not change anything. Connecting to the Lopy from VS Code through the wifi still works. But through USB doesn't.
                                          Desperate to understand the problem, I now installed VS code with the pymakr extension (1.0.6) on a brand new laptop. VS code then shows the following configuration:
                                          Electron: 3.1.2
                                          Node.js: 10.2.0
                                          V8: 6.6.346.32
                                          OS: Windows_NT x64 10.0.17134
                                          But here again I cannot connect through usb. The symptoms are now different. Pymakr lists the following serial devices:
                                          Found 1 serialport
                                          COM3 (Microsoft) (copied to clipboard)
                                          But when setting the address to COM3 in the global settings, and then connecting does not give any response: no command prompt signalling a connection, and even no error message. No response at all!.
                                          I should give up and try atom instead? It is not the first time that pymakr stopped working after a VS code update.
                                            Paul Thornton @jand
                                            @jand do you have autoconnect set to true in the global config? Try turning it to false if so. Had a similar issue to this resolved by that.
