FiPy with NB-IoT sim cards but no signal
Thanks for replying. I've tried the script of you and it returned 1 in both nb-iot and cat-m1.
I have checked the version of Fipy and discovered that it is V1.0r. However, what kind of issue would happen if I use V1.0r? Could it connect to LTE CAT-M1? -
@WalkerYun It is more intersting which EUTRA band are supported, like in my result:
>>> from network import LTE >>> lte=LTE() >>> print(lte.send_at_cmd('AT!="showver"')) SYSTEM VERSION ============== FIRMWARE VERSION Bootloader0 : 5.1.1.0 [39529] Bootloader1* : 6.0.0.0 [41019] Bootloader2 : 6.0.0.0 [41019] NV Info : 1.1,0,0 Software : 6.0.0.0 [41019] by robot-soft at 2018-12-13 21:41:15 UE : 6.0.0.0 COMPONENTS ZSP0 : 1.0.99-3171 ZSP1 : 1.0.98-3170 OK >>> print(lte.send_at_cmd('AT!="setDbgPerm full"')) OK >>> print(lte.send_at_cmd('AT!="showCaps"')) == CAPS config ============================= .Lock UE on SRV band : false .MFBI support : true .TM8 TDD support : false ============================================ == CAPS ==================================== . access stratum: R13 . catM : 1 . nb-IoT : 1 -- EUTRA bands -- . supported : 66/28/26/25/20/19/18/17/14/13/12/8/5/4/3/2/1 . board : 1/2/3/4/5/8/12/13/14/17/18/19/20/25/26/28/66 . admin : . pending admin : -- EUTRA carriers -- . admin : . pending admin : ============================================ OKVersion 1.0r supports only a small setg of EUTRA bands, and if your provider uses these, than the device will not work.
I am facing the same issue. I am in Japan and using Fipy 1.0r with Hologram sim.
The sim works with phone.
How can I know if the supported band work here? @robert-hh, what do you mean by "It should be r1.2. r1.0 Versions have issues and must be replaced." You mean I need to buy a new one or I can ask Pycom to replace it?>>> print(lte.send_at_cmd('AT!="showver"')) SYSTEM VERSION ============== FIRMWARE VERSION Bootloader0 : 5.1.1.0 [33080] Bootloader1* : 5.1.1.0 [38638] Bootloader2 : 5.1.1.0 [39529] NV Info : 1.1,0,0 Software : 5.1.1.0 [39529] by robot-soft at 2018-09-28 16:07:40 UE : 5.0.0.0d COMPONENTS ZSP0 : 1.0.99-13616 ZSP1 : 1.0.99-12355 OK >>> print(lte.send_at_cmd('AT!="setDbgPerm full"')) OK >>> print(lte.send_at_cmd('AT!="showCaps"')) == CAPS config ============================= .Lock UE on SRV band : false .MFBI support : true .TM8 TDD support : false ============================================ == CAPS ==================================== . access stratum: R13 . catM : 1 . nb-IoT : 0 -- EUTRA bands -- . supported : 28/20/13/12/4/3 . board : 3/4/12/13/20/28 . admin : . pending admin : -- EUTRA carriers -- . admin : . pending admin : ============================================ OK -
@naveen your post shows an old modem firmware. You should update that as a first step.
@naveen Looking for the LTE bands used in Japan, it is not likely that a r1.0 device matches. Pycom has a replacement program for these devices. Look at the following link on how to use it. https://forum.pycom.io/topic/3843/important-news-regarding-cat-m1-and-nb-iot-cellular-range.
You need a little patience, because Pycom seems very busy at the moment. Buying a new one, if not from Pycom, may not get you a r1.2 model. Vendors may still have r1.0 devices on stock and sell them in good faith. -
@robert-hh I have updated the firmware. It shows more bands now but still not attaching to the network.
SYSTEM VERSION ============== FIRMWARE VERSION Bootloader0 : 5.1.1.0 [41065] Bootloader1* : 5.1.1.0 [41065] Bootloader2 : 5.1.1.0 [41065] NV Info : 1.1,0,0 Software : 5.1.1.0 [41065] by robot-soft at 2018-12-17 13:03:40 UE : 5.0.0.0d COMPONENTS ZSP0 : 1.0.99-13616 ZSP1 : 1.0.99-12376 == CAPS config ============================= .Lock UE on SRV band : false .MFBI support : true .TM8 TDD support : false ============================================ == CAPS ==================================== . access stratum: R13 . catM : 1 . nb-IoT : 0 -- EUTRA bands -- . supported : 66/28/26/25/20/19/18/17/14/13/12/8/5/4/3/2/1 . board : 1/2/3/4/5/8/12/13/14/17/18/19/20/25/26/28/66 . admin : . pending admin : -- EUTRA carriers -- . admin : . pending admin : ============================================Output:
modem command: AT+CEREG=2 response=['OK'] modem command: AT+CFUN=1 response=['OK'] modem command: AT+CGDCONT=1,"IP","hologram" response=[] attempt to attach cell modem to base station... modem command: ATI response=['+SYSSTART'] modem command: AT+SQNCCID? response=['+SQNCCID: "",""', 'OK'] modem command: AT+CEREG? response=['+CEREG: 2,0', 'OK'] tac=0 modem command: AT+CSQ response=['+CSQ: 99,99', 'OK'] modem command: AT+CEER response=['+CEER: lastEmmCause: NO CAUSE RECEIVED, lastEsmCause: NO CAUSE RECEIVED', 'OK'] -
@naveen That was the case for my r1.0 boards too. I had to replace them by r1.2 boards.
@robert-hh Thanks for your response. Did they send new board or fixed the same one. How long it took to send and get it back? And what was the shipping cost?
@naveen They have sent new boards, and it took ~4 weeks. But at that time they were still searching for the best fix.
@robert-hh @Xykon It took over a month and finally I received a new FiPy r1.2 board. I have tested the CAT-M1 firmware on this board using hologram sim and it was able to connect and send message using Softbank japan CAT-M1 LTE network.
But when I upgraded the firmware with NB-IOT (41019), it is not attaching to any network. The Softbank supports CAT-M1 and NB-IOT both. I am in a good coverage area and it took just 2-3 seconds to attach the CAT-M1 network. What could be the reason? -
@naveen That sounds not good. A few questions:
- which firmware for the FiPy are you using?
- how long did you wait for the attach?
@robert-hh I am using the latest stable v1.18.2.r7 (just updated few hours ago). I waited a minute or so.
@naveen I never tried that with the master branch before. I always used the release-candidate branch. But I loaded now the firmware 1.18.2.r7 from the web site and it works too. As far as I remember, the first attach took like 15 minutes. After that, it is down now to ~10 seconds.
@robert-hh I waited for 25 minutes but still it is not attaching to NB-IOT network. I reverted the firmware to CATM1 again and it works flawlessly. How can I debug the issue?
@naveen No clue. When it did not work for me, I could not get a hand on debugging. I only purchased another LTE NBIoT module to verify, that the service was available and the SIM worked. It did. Module type SIM7020.
