    Firmware Release v1.20.1
    firmware
    68 Posts 18 Posters 11.4k Views 19 Watching
    • rcolisteteR Offline
      rcolistete
      Please update the links for all Pycom devices in :
      https://docs.pycom.io/advance/downgrade/
      to include the version 1.20.1 for manual firmware download.
      rcolisteteR 1 Reply Last reply Reply Quote 0
        Clemens @robert-hh
        One software is after the repeated firmware update with the checked option erase filesystem now running. The second one outputs still the same error.
          berni
          After upgrading to 1.20.1, I started having crashes when setting up the frequencies for the Nano-Gateway code:
          Guru Meditation Error: Core  1 panic'ed (Cache disabled but cached memory region accessed)
          Guru Meditation Error: Core  1 panic'ed (IllegalInstruction). Exception was unhandled.
          Memory dump at 0x40201f50: bad00bad bad00bad bad00bad
          This happens somehow randomly, after a few cycles of deep sleep/transmission, but even the Watchdog timer becomes useless.
          Then I downgraded to 1.20.rc13. Now, the code doesn't work and stops in this line:
          >>> from network import LoRa
          >>> lora = LoRa(mode=LoRa.LORAWAN)
          >>> lora.nvram_erase()
          >>> lora.nvram_save()
          Is there any way to go back to 1.20.rc13 and have these function working again? I suspect there must be some low level changes on the LoRa radio.
          I robert-hhR O 3 Replies Last reply Reply Quote 0
          • I Offline
            iwahdan @berni
            Hello @berni , Thanks for reporting that issue, we will work on reproducing it, meanwhile regarding the exception you get when downgrading to rc13 , this should be due to the new formatting mechanism of NVS introduced in IDF_v3.2 (1.20.1) , so when you downgrade the FW to previous version of IDF, NVS might not be initialise successfully, to solve this issue you can erase the device and flash the Firmware again.
            Wahdan
              robert-hh @berni
              @berni @iwahdan Setting the frequency and/or removing channels is a topic which anyhow does not seem to work. I have to look at it. Even when I set in the abp_node.py sample code the device to use a single frequency only, it transmits at the three default frequencies. That was different once.
              • O Offline
                oligauc @berni
                @berni Using a terminal / command prompt, please can you go to the pycom firmware updater folder (e.g "C:\Program Files (x86)\Pycom\Pycom Firmware Update" in windows) and type the following command:
                pycom-fwtool-cli.exe -p "your com port" erase_all
                After erasing please re-flash your device.
                Please let us know how it goes, Thanks
                • O Offline
                  oligauc @robert-hh
                  @robert-hh We carried out some tests with the abp node / RAK gateway in the EU region. If you add 3 channels with the same frequency and remove the others, it will send at 1 frequency.
                  If you do not add / remove channels manually, then the node uses frequency hopping.
                    robert-hh @oligauc
                    @oligauc I think i did that in my code, which is the abp_node example. I'll repeat it.
                      robert-hh @oligauc
                      @oligauc I just verified that, after a clean erase & upload. Then only one frequency is used. There may have been a modified set-up. I purchased a SDR recently, which allows to see the frequencies used. It's interesting to see all the different activities in the 868 band.
                        robert-hh @oligauc
                        @oligauc I tried another device, a LoPy now, and that one was completely messy. After setting a Lora parameter wrong, I could not change that any more. Only erasing flash and re-installing the firmware made it working again. Besides that, below is a nice picture showing how a message with DR=0 looks in the waterfall diagram.
                          berni @oligauc
                          Thank you @oligauc!
                          This fixed the issue with lora.nvram_erase(). Also, I was having troubles deleting the flash from the pycom firmware upgrade software (it will time out if I select that option, working fine if I just upgrade the FW).
                          I have observed that having pybytes active and doing my own LoRa OTTA (saving on nvram after joining the network) caused that the join flag was deleted and never connected again. I have disabled the pybytes in the pybytes_config.jsonfile adding {"pybytes_autostart": false} and that fixed the issue.
                          I have been running the program on v1.20.1.r1 without pybytes and haven't had any Guru Meditation errors for a while. I'll keep trying...
                            cmisztur @robert-hh
                            @robert-hh said in Firmware Release v1.20.1:
                            I build the image myself
                            Right.
                            pyexec_frozen_module("_main.py");
                              robert-hh @cmisztur
                              @cmisztur It's not that _main.py or _boot.py are executed, it's what is frozen into the image as _boot.py or _main.py.
                                serafimsaudade
                                I'm getting this error when compiling.
                                I clone the repo and try to compile.
                                  robert-hh @serafimsaudade
                                  @serafimsaudade IOt may be a problem with the pycom esp-idf.
                                  in the folder pycom-esp-idf, execute the command:
                                  git checkout idf_v3.2
                                  git submodule sync
                                  git submodule update --init
                                  Also, in you pycom esp32 source directory, issue the commands:
                                  git checkout Dev
                                  git submodule sync
                                  Then, a
                                  make BOARD=WIPY clean
                                  make BOARD=WIPY
                                    serafimsaudade @robert-hh
                                    @robert-hh Tks for the tip.
                                    That was the idf submodules.
                                    problem solve. :)
                                      serafimsaudade
                                      Hi again,
                                      I'm trying to connect gpy to wireless, but when I do wlan.scan() get this error:
                                      wlan = WLAN(mode=WLAN.STA_AP,ssid="teste", auth=(WLAN.WPA2, 'pass'))
                                      nets = wlan.scan()
                                      OSError: Scan operation Failed!
                                      This work on others fw version.
                                      robert-hhR A 2 Replies Last reply Reply Quote 0
                                        @serafimsaudade The following sequence works for me:
                                        from network import WLAN
                                        wlan = WLAN(WLAN.STA_AP)
                                        wlan.scan()
                                        S robert-hhR 2 Replies Last reply Reply Quote 0
                                          @robert-hh but I need to set a custom ssid and password.
                                            robert-hh @robert-hh
                                            @robert-hh This sequence works too, after setting the password to a length of 8 min.:
                                            wlan=WLAN(mode=WLAN.STA_AP, ssid="teste", auth=(WLAN.WPA2, 'passpass'))
                                            wlan.scan()
                                            Pycom MicroPython 1.20.1.r1 [d4b4717] on 2019-10-09; LoPy4 with ESP32
                                            I do not expect that the GPY is different with respect to WiFi.
                                            • 2 / 4
