    Firmware Release v1.20.1
    firmware
    68 Posts 18 Posters 11.4k Views 19 Watching
      robert-hh @berni
      @berni @iwahdan Setting the frequency and/or removing channels is a topic which anyhow does not seem to work. I have to look at it. Even when I set in the abp_node.py sample code the device to use a single frequency only, it transmits at the three default frequencies. That was different once.
      • O Offline
        oligauc @berni
        @berni Using a terminal / command prompt, please can you go to the pycom firmware updater folder (e.g "C:\Program Files (x86)\Pycom\Pycom Firmware Update" in windows) and type the following command:
        pycom-fwtool-cli.exe -p "your com port" erase_all
        After erasing please re-flash your device.
        Please let us know how it goes, Thanks
        • O Offline
          oligauc @robert-hh
          @robert-hh We carried out some tests with the abp node / RAK gateway in the EU region. If you add 3 channels with the same frequency and remove the others, it will send at 1 frequency.
          If you do not add / remove channels manually, then the node uses frequency hopping.
            robert-hh @oligauc
            @oligauc I think i did that in my code, which is the abp_node example. I'll repeat it.
              robert-hh @oligauc
              @oligauc I just verified that, after a clean erase & upload. Then only one frequency is used. There may have been a modified set-up. I purchased a SDR recently, which allows to see the frequencies used. It's interesting to see all the different activities in the 868 band.
                robert-hh @oligauc
                @oligauc I tried another device, a LoPy now, and that one was completely messy. After setting a Lora parameter wrong, I could not change that any more. Only erasing flash and re-installing the firmware made it working again. Besides that, below is a nice picture showing how a message with DR=0 looks in the waterfall diagram.
                  berni @oligauc
                  Thank you @oligauc!
                  This fixed the issue with lora.nvram_erase(). Also, I was having troubles deleting the flash from the pycom firmware upgrade software (it will time out if I select that option, working fine if I just upgrade the FW).
                  I have observed that having pybytes active and doing my own LoRa OTTA (saving on nvram after joining the network) caused that the join flag was deleted and never connected again. I have disabled the pybytes in the pybytes_config.jsonfile adding {"pybytes_autostart": false} and that fixed the issue.
                  I have been running the program on v1.20.1.r1 without pybytes and haven't had any Guru Meditation errors for a while. I'll keep trying...
                    cmisztur @robert-hh
                    @robert-hh said in Firmware Release v1.20.1:
                    I build the image myself
                    Right.
                    pyexec_frozen_module("_main.py");
                      robert-hh @cmisztur
                      @cmisztur It's not that _main.py or _boot.py are executed, it's what is frozen into the image as _boot.py or _main.py.
                        serafimsaudade
                        I'm getting this error when compiling.
                        I clone the repo and try to compile.
                          robert-hh @serafimsaudade
                          @serafimsaudade IOt may be a problem with the pycom esp-idf.
                          in the folder pycom-esp-idf, execute the command:
                          git checkout idf_v3.2
                          git submodule sync
                          git submodule update --init
                          Also, in you pycom esp32 source directory, issue the commands:
                          git checkout Dev
                          git submodule sync
                          Then, a
                          make BOARD=WIPY clean
                          make BOARD=WIPY
                            serafimsaudade @robert-hh
                            @robert-hh Tks for the tip.
                            That was the idf submodules.
                            problem solve. :)
                              serafimsaudade
                              Hi again,
                              I'm trying to connect gpy to wireless, but when I do wlan.scan() get this error:
                              wlan = WLAN(mode=WLAN.STA_AP,ssid="teste", auth=(WLAN.WPA2, 'pass'))
                              nets = wlan.scan()
                              OSError: Scan operation Failed!
                              This work on others fw version.
                              robert-hhR A 2 Replies Last reply Reply Quote 0
                                @serafimsaudade The following sequence works for me:
                                from network import WLAN
                                wlan = WLAN(WLAN.STA_AP)
                                wlan.scan()
                                S robert-hhR 2 Replies Last reply Reply Quote 0
                                  @robert-hh but I need to set a custom ssid and password.
                                    robert-hh @robert-hh
                                    @robert-hh This sequence works too, after setting the password to a length of 8 min.:
                                    wlan=WLAN(mode=WLAN.STA_AP, ssid="teste", auth=(WLAN.WPA2, 'passpass'))
                                    wlan.scan()
                                    Pycom MicroPython 1.20.1.r1 [d4b4717] on 2019-10-09; LoPy4 with ESP32
                                    I do not expect that the GPY is different with respect to WiFi.
                                      time.sleep(3)
                                      wlan.scan()
                                      If I put a delay >= 3 seconds, works as espected, strange.
                                        crumble
                                        Running 1.20.1r1 I am impressed of the boot performance.
                                        But in combination with a pytrack there are a lot of i2c errors. I am not amused to figure out new timings which may result in less errors, but will never remove them all.
                                        Additionally I run now into i2c that can only be resolved by cutting the power suply. Would be great, if the PIC has a watchpig function. So I can track down with less efford, if this is caused by the LoPy or the Pytrack.
                                          andreas @berni
                                          Hi there,
                                          @berni said in Firmware Release v1.20.1:
                                          I have disabled the pybytes in the pybytes_config.json file by adding {"pybytes_autostart": false} and that fixed the issue.
                                          We are able to confirm the new firmware obtained from [0] and bundled and flashed to a FiPy device through the process outlined on [1] works flawlessly. Before adding the pybytes_config.json file, we also experienced Guru Meditation errors like outlined above (bad00bad bad00bad bad00bad). We didn't even use LoRa, just WiFi.
                                          @crumble said in Firmware Release v1.20.1:
                                          We are running the Terkin Datalogger [2] and are also very happy about the performance improvements through the efficiency gains of the new mpy file format shipped with MicroPython 1.11 [3] when loading the py/mpy files into memory. On MicroPython 1.9.4, this took about 30(!) seconds and now we are down to 5 seconds [4].
                                          Thanks to all people involved in this release, turtles all the way down to the MicroPython core maintainers - you know who you are!
                                          With kind regards,
                                          Andreas.
                                          [0] https://github.com/pycom/pycom-micropython-sigfox/releases/tag/v1.20.1.r1
                                          [1] https://forum.pycom.io/topic/4518/firmware-update-elf-vs-tar/13
                                          [2] https://github.com/hiveeyes/hiveeyes-micropython-firmware
                                          [3] https://github.com/micropython/micropython/releases/tag/v1.11
                                          [4] https://community.hiveeyes.org/t/micropython-module-freezing/2445/10
                                            t0000899
                                            Wlan connection has turned to really unreliable in 1.20 version. In 1.18 connection was instant and never disconnected but in the 1.20 version wlan.connect(...) timeout most of the time and if connection is made it disconnects randomly.
                                            If connection get broken wlan.ifconfig() show (0.0.0.0,0.0.0.0,0.0.0.0,0.0.0.0).
                                            Pycom MicroPython 1.20.1.r1 [v1.11-3138a13] on 2019-10-08; LoPy4 with ESP32
                                            Pybytes Version: 1.1.3
                                            Smart config auto-start is disabled.
                                            Sometimes during FTP transfer there is an unhandled exception and flash memory is formatted:
                                            Memory dump at 0x4020234c: bad00bad bad00bad bad00bad
                                            Guru Meditation Error: Core  0 panic'ed (IllegalInstruction). Exception was unhandled.
                                            From my boot.py file:
                                            if useWlan == True:
                                            	print('Configure WLAN')
                                            	wlan = WLAN(mode=WLAN.STA, power_save=True)
                                            	wlan.ifconfig(config='dhcp')
                                            	wlan.connect(AP_name, auth=(WLAN.WPA2, AP_password), timeout=30000)
                                            	del AP_name
                                            	del AP_password
                                            A 2 Replies Last reply Reply Quote 2
                                            • 2 / 4
