    GPY full flash erase
    45 Posts 7 Posters 4.6k Views 7 Watching
      robert-hh @kjm
      @kjm Looking at the source code I can see, that the WiFi settings for boot are now taken from a flash configuration data set. I did not dig further about how this data is set. The intention may be to set that in the pybytes configuration dashboard. Since my devices start that AP with software implementing that property, and these have been erased, It may be that the default is: start the AP.
      • K Offline
        kjm @robert-hh
        @robert-hh I'm still confused. Am I right in thinking there are two 1.20.1.r1 firmwares now? The pybytes version (which has no adhoc wifi) that the pycom updater will install and your version that I have to assemble on a linux machine before I can install it?
          andreas
          @kjm Anyone can build firmware images from the sources. Pycom is obviously featuring their offical firmware builds stronger with respect to features of their product platform while we are aiming to freeze our foundation modules into different builds in order to brew customized firmware images better fitting the requirements of our community.
            robert-hh @kjm
            @kjm As @andreas told, the firmware builds I make are not that special. They include only my favorite scripts as frozen bytecode, and I have tailored the build scripts to support my build environment. Sometimes I try special variants, like a version the supports Lora EU433, or an option to invert UART, .....,
            It is not explained by PyCom, which of the various branches in the PyCom repository is the recent "official" one. By convention, it should be 'master'. But the actual development seems to happen at Dev (tagged as default), which seems to include the pybytes code. But there is also a branch called 'pybytes-master'.
            Edit: This is the list of actual branches with their most recent update times:
            Dev (default)           Oct 30, 2019
            Release/v1.20           Oct 7, 2019
            pybytes-master          Oct 5, 2019
            OTA_1_20_Prep/master    Sep 15, 2019
            fw_fixes                Sep 10, 2019
            release-candidate       Aug 22, 2019
            Release/v1.18           May 15, 2019
            master                  May 14, 2019
            bug_fixes               Apr 15, 2019
            pypic_pid_fix           Mar 1, 2019
            development             Nov 12, 2018
            spi_bitorder            Nov 7, 2017
            • K Offline
              kjm @robert-hh
              @robert-hh I don't think I'm smart enough to roll my own firmware. When I run the latest Windows pycom firmware updater it starts by telling me the latest firmware is 1.16.1 but then later it says it downloaded & used 1.20.1.r1 I assume that's the Oct 5th pybytes-master in your list, with no adhoc wifi? How is this different from Oct7th Release/v1.20?
              • K Offline
                kjm @robert-hh
                • K Offline
                  kjm @robert-hh
                  @robert-hh said in GPY full flash erase:
                  @kjm I tested this short script, and it sets up the AP. Note, that you can set ssid, password, and IP address as you like. The DNS settings are more or less useless.
                  Is this a way to setup an adhoc wifi that I can turn on/off with import pycom, machine; pycom.wifi_on_boot(1); machine.reset() ?
                    robert-hh @kjm
                    @kjm 1.16.1 is the version of the firmware updater itself. Whereas 1.20.1r1 is the latest revision of the firmware for the PyCom modules. Both the Dev and Release/ v1.20 have the revision number 1.20.1.r1, the differ in the pybytes revision. Dev shows pybytes 1.2.0, Release/v1.20 shows pybytes 1.1.3. The branch pybytes-master has the firmware revision 1.18.3. That's all in the file pycom_version.h in the repository.
                    b.t.w.: I build my firmware w/o pybytes support.
                      robert-hh @kjm
                      @kjm said in GPY full flash erase:
                      No. This little script will turn on an AP, configured to your needs, if you put it into boot.py or main.py
                      • K Offline
                        kjm @robert-hh
                        Do you know if there is flavour of LittleFS firmware that still has adhoc wifi? If so could I download it with the pycom updater with the 'legacy' option?
                          robert-hh @kjm
                          @kjm LittleFS came with version 1.20.
                          I just made a test about ad-hoc AP and firmware variants:
                          • 1.20.1r1 without pybyte: ad-hoc AP comes
                          • 1.20.1r1 with pybytes: no ad-hoc AP
                          So it is the by pybytes option which chooses another way. Some Information may be found at https://docs.pycom.io/smart. That all looks for me like an endless source of trouble, because so many instances are involved: - your PC, Pycom servers & services, a smart phone IOS only(!) app, local access points, the Pycom devices, ... And if any of that fails, the process fails.
                          BUT: at least I found a bypass, that worked on my device. If you copy a file named "pybytes_config.json" with the content below to your device, pybytes will not start and the ad-hoc AP comes up.
                          {"wifi": {"ssid": "", "password": ""},
                                   "wlan_antenna": 0,
                                   "dump_ca": "FALSE",
                                   "cfg_msg": "NULL",
                                   "server": "",
                                   "ssl": "FALSE",
                                   "lte": {"apn": "NULL", "cid": 1, "reset": "FALSE", "carrier": "NULL", "band": "NULL", "type": "NULL"},
                                   "device_id": "",
                                   "network_preferences": [],
                                   "ota_server": {"port": 443, "domain": "software.pycom.io"},
                                   "pybytes_autostart": "FALSE",
                                   "username": "",
                          Note: These are double quotes in the text. Strange also, that with pybytes Ctrl-D for soft reset does not work any more.
                            robert-hh @kjm
                            @kjm The json script for disabling pybytes can be shorter. This single line in the file /flash/pybytes_config.json is sufficient:
                            {"pybytes_autostart": false}
                            • K Offline
                              kjm @robert-hh
                              I don't have the skills set to find & edit /flash/pybytes_config.json, Atom doesn't show it. It took me most of a day just to figure out how to do the full flash erase using the CLI! Can you not link me to the 1.20.1r.1 without pybyte firmware & I could download it with the pycom firmware downloader as legacy?
                                robert-hh @kjm
                                @kjm You can simple create that file locally and copy it to your device, either using atom or adafruit ampy. With ampy call:
                                ampy -p <your_com_port> put pybytes_config.json
                                /flash is the default directory of the GPY file system, with e.g. boot.py and main.py.
                                Edit: I can compile later today a non-pybytes GPY image and send the link.
                                  robert-hh @kjm
                                  @kjm There is a GPY package here: https://github.com/robert-hh/Shared-Stuff
                                  K A 2 Replies Last reply Reply Quote 0
                                  • K Offline
                                    kjm @robert-hh
                                    Yeah I know what \flash is, but my 1.20.1.r1 does not have that file,
                                    ['boot.py', 'cert', 'lib', 'main.py', 'sys']
                                    So there is no 1.20.1r1 without pybyte firmware?
                                    • K Offline
                                      kjm @robert-hh
                                      Much obliged I'll give it a try. As a matter of interest, does compiling your own firmware let you modify micropython? For example are you able to change the default 20s timeout micropython has for most OSErrors?
                                        robert-hh @kjm
                                        @kjm Most of the source code is available. There are only a few binary blobs for specific drivers. The espressif RTOS source is also provided. So yes, in theory you can change everything. But it is quite a pack of software. I do not agree that most OSErrors have a 20 s timeout. Only those which by its semantics require waiting, like the ones dedicated to communication.
                                          andreas @robert-hh
                                          Thanks, @robert-hh. We took a bunch of your builds scattered around the forum and gave them a canonical home on our page for Inofficial firmware images for Pycom devices in order to be able to find them back easier.
                                          We hope that you and all others are fine with that.
                                          To whom that may concern:
                                          I've tried to reflect the copyright and license terms of Pycom as good as possible, please let me know if I missed something relevant.
                                          True. Thanks to all software authors for your hard work on that!
                                            robert-hh @andreas
                                            @andreas My build typicall include some utility scripts in frozen bytecode:
                                            • mount.py - Mount the SD card
                                            • pye_mp.py - A file editor which runs on the Pyxx device. Typically imported as from pye_mp import pye. Then you can type: pye("filename"). For the documentation look here: https://github.com/robert-hh/Micropython-Editor
                                            • uping.py - a ping utility
                                            • upysh.py - a small set of unix like commands, typically imported as from uping import *
                                            • 2 / 3
