    GPY full flash erase
    45 Posts 7 Posters 5.1k Views 7 Watching
    • K Offline
      kjm @robert-hh
      @robert-hh I don't think I'm smart enough to roll my own firmware. When I run the latest Windows pycom firmware updater it starts by telling me the latest firmware is 1.16.1 but then later it says it downloaded & used 1.20.1.r1 I assume that's the Oct 5th pybytes-master in your list, with no adhoc wifi? How is this different from Oct7th Release/v1.20?
      • K Offline
        kjm @robert-hh
        • K Offline
          kjm @robert-hh
          @robert-hh said in GPY full flash erase:
          @kjm I tested this short script, and it sets up the AP. Note, that you can set ssid, password, and IP address as you like. The DNS settings are more or less useless.
          Is this a way to setup an adhoc wifi that I can turn on/off with import pycom, machine; pycom.wifi_on_boot(1); machine.reset() ?
            robert-hh @kjm
            @kjm 1.16.1 is the version of the firmware updater itself. Whereas 1.20.1r1 is the latest revision of the firmware for the PyCom modules. Both the Dev and Release/ v1.20 have the revision number 1.20.1.r1, the differ in the pybytes revision. Dev shows pybytes 1.2.0, Release/v1.20 shows pybytes 1.1.3. The branch pybytes-master has the firmware revision 1.18.3. That's all in the file pycom_version.h in the repository.
            b.t.w.: I build my firmware w/o pybytes support.
              robert-hh @kjm
              @kjm said in GPY full flash erase:
              No. This little script will turn on an AP, configured to your needs, if you put it into boot.py or main.py
              • K Offline
                kjm @robert-hh
                Do you know if there is flavour of LittleFS firmware that still has adhoc wifi? If so could I download it with the pycom updater with the 'legacy' option?
                  robert-hh @kjm
                  @kjm LittleFS came with version 1.20.
                  I just made a test about ad-hoc AP and firmware variants:
                  • 1.20.1r1 without pybyte: ad-hoc AP comes
                  • 1.20.1r1 with pybytes: no ad-hoc AP
                  So it is the by pybytes option which chooses another way. Some Information may be found at https://docs.pycom.io/smart. That all looks for me like an endless source of trouble, because so many instances are involved: - your PC, Pycom servers & services, a smart phone IOS only(!) app, local access points, the Pycom devices, ... And if any of that fails, the process fails.
                  BUT: at least I found a bypass, that worked on my device. If you copy a file named "pybytes_config.json" with the content below to your device, pybytes will not start and the ad-hoc AP comes up.
                  {"wifi": {"ssid": "", "password": ""},
                           "wlan_antenna": 0,
                           "dump_ca": "FALSE",
                           "cfg_msg": "NULL",
                           "server": "",
                           "ssl": "FALSE",
                           "lte": {"apn": "NULL", "cid": 1, "reset": "FALSE", "carrier": "NULL", "band": "NULL", "type": "NULL"},
                           "device_id": "",
                           "network_preferences": [],
                           "ota_server": {"port": 443, "domain": "software.pycom.io"},
                           "pybytes_autostart": "FALSE",
                           "username": "",
                  Note: These are double quotes in the text. Strange also, that with pybytes Ctrl-D for soft reset does not work any more.
                    robert-hh @kjm
                    @kjm The json script for disabling pybytes can be shorter. This single line in the file /flash/pybytes_config.json is sufficient:
                    {"pybytes_autostart": false}
                    • K Offline
                      kjm @robert-hh
                      I don't have the skills set to find & edit /flash/pybytes_config.json, Atom doesn't show it. It took me most of a day just to figure out how to do the full flash erase using the CLI! Can you not link me to the 1.20.1r.1 without pybyte firmware & I could download it with the pycom firmware downloader as legacy?
                        robert-hh @kjm
                        @kjm You can simple create that file locally and copy it to your device, either using atom or adafruit ampy. With ampy call:
                        ampy -p <your_com_port> put pybytes_config.json
                        /flash is the default directory of the GPY file system, with e.g. boot.py and main.py.
                        Edit: I can compile later today a non-pybytes GPY image and send the link.
                          robert-hh @kjm
                          @kjm There is a GPY package here: https://github.com/robert-hh/Shared-Stuff
                          K A 2 Replies Last reply Reply Quote 0
                          • K Offline
                            kjm @robert-hh
                            Yeah I know what \flash is, but my 1.20.1.r1 does not have that file,
                            ['boot.py', 'cert', 'lib', 'main.py', 'sys']
                            So there is no 1.20.1r1 without pybyte firmware?
                            • K Offline
                              kjm @robert-hh
                              Much obliged I'll give it a try. As a matter of interest, does compiling your own firmware let you modify micropython? For example are you able to change the default 20s timeout micropython has for most OSErrors?
                                robert-hh @kjm
                                @kjm Most of the source code is available. There are only a few binary blobs for specific drivers. The espressif RTOS source is also provided. So yes, in theory you can change everything. But it is quite a pack of software. I do not agree that most OSErrors have a 20 s timeout. Only those which by its semantics require waiting, like the ones dedicated to communication.
                                  andreas @robert-hh
                                  Thanks, @robert-hh. We took a bunch of your builds scattered around the forum and gave them a canonical home on our page for Inofficial firmware images for Pycom devices in order to be able to find them back easier.
                                  We hope that you and all others are fine with that.
                                  To whom that may concern:
                                  I've tried to reflect the copyright and license terms of Pycom as good as possible, please let me know if I missed something relevant.
                                  True. Thanks to all software authors for your hard work on that!
                                    robert-hh @andreas
                                    @andreas My build typicall include some utility scripts in frozen bytecode:
                                    • mount.py - Mount the SD card
                                    • pye_mp.py - A file editor which runs on the Pyxx device. Typically imported as from pye_mp import pye. Then you can type: pye("filename"). For the documentation look here: https://github.com/robert-hh/Micropython-Editor
                                    • uping.py - a ping utility
                                    • upysh.py - a small set of unix like commands, typically imported as from uping import *
                                      andreas
                                      @robert-hh I've updated the documentation accordingly [1]. Thanks a bunch and keep up the spirit.
                                      [1] https://packages.hiveeyes.org/hiveeyes/foss/pycom/#robert-hh
                                      P.S.: We might really want to divert that discussion into another thread ;]. Nevertheless, thanks for bringing us to these topics, finally making me build a humble hut for community-based firmware images.
                                      • K Offline
                                        kjm @robert-hh
                                        You're right the 20s wait when a DNS lookup fails at getaddrinfo in urequests really bugs me. In reality if a DNS server hasn't replied in a tenth of that time it's not going to. I'd kill to be able to tweak that value.
                                          andreas
                                          Now we are really getting things mixed up within this conversation.
                                          Let's divert that to the thread where you already started this topic [1], right?
                                          [1] https://forum.pycom.io/topic/4932/urequests-timeouts
                                          • K Offline
                                            kjm @robert-hh
                                            Confirming adhoc wifi working in your 1.20.1.r1 firmware Robert. How do I use your utilities? For example what would I type in the Atom console to try uping? Is there a way to see the full extent of the flash memory in Atom/Filezilla? Do I need a new windows or unix program to see deeper into the gpy flash?
                                            • 2 / 3
