    Guru Meditation Error
    58 Posts 7 Posters 2.3k Views 7 Watching
      andreas @sita
      Dear @sita,
      just a short question: Have you been able to run your MicroPython program successfully with LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel until the Guru Meditation error happened again? I am asking because it looked like you had other problems with this the other day.
      With kind regards,
      Andreas.
        sita @andreas
        Hello @andreas,
        The other problems are still there, for temporarily i am running [1] in cmd so that error not coming.
        [1]pycom-fwtool-cli.exe --verbose --port COM12 erase_all
          andreas @sita
          Thanks. So, to make sure we are on the same page...
          • Invoking erase_all once before uploading a new firmware image is considered good practice. Thanks for letting me know.
          • After that, you are able to invoke your MicroPython program using the LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel firmware?
          • However, Guru Meditation errors still occur?
          Now, are you able to submit another core dump when running this firmware build? I have saved a local copy of lopy4-0.8.0-vanilla-squirrel.elf on my workstation in order to decode core dumps produced by this build.
            sita @andreas
            @andreas Now i got an issue with the atom editor :( :(
            i have updated the ATOM editor evening and now i it is not showing REPL console. I will check with this and send you the core dump (LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel).
              peterp
              @sita can you try again with 1.20.2.rc3
              @pigamonte same advice to you, but in case it doesn't solve it for you, I suggest to open your own thread. Otherwise we end up mixing different issues. Just because it shows a Guru Meditation Error, doesn't necessarily mean the issues are related.
                sita @peterp
                Hello @peterp,
                I have tried with new firmware version (1.20.2.rc3) but same error is coming again. I will open new thread to avoid mixing of different issues.
                Thanks & Have a nice day
                  andreas @sita
                  Dear @sita,
                  @sita said in Guru Meditation Error:
                  Either with the original Pycom's 1.20.2.rc3 and/or with the corresponding/updated LoPy4-1.20.2.rc3-0.8.0-vanilla-squirrel.tar.gz, I will be happy to receive respective core dumps. I have now kept the definitive .elf files around for decoding the core dumps appropriately.
                  Thanks and with kind regards,
                  Andreas.
                    sita @andreas
                    Hello @andreas ,
                    This is the core dump of the updated LoPy4-1.20.2.rc3-0.8.0-vanilla-squirrel.tar.gz
                    Guru Meditation Error: Core  1 panic'ed (IllegalInstruction). Exception was unhandled.
                    Memory dump at 0x4010abc8: 10180108 00000044 00000000
                    Core 1 register dump:
                    PC      : 0x4010abcf  PS      : 0x00060130  A0      : 0x801024b3  A1      : 0x3ffd8280
                    A2      : 0x3ffc93fc  A3      : 0x00000000  A4      : 0x3f94ef00  A5      : 0xffffff30
                    A6      : 0x3f9502b3  A7      : 0x00007e00  A8      : 0x40109f79  A9      : 0x3ffd8260
                    A10     : 0x3f40eed0  A11     : 0x00000000  A12     : 0x3f94ef04  A13     : 0x3f94ef08
                    A14     : 0x00000048  A15     : 0x400ff4ea  SAR     : 0x0000001e  EXCCAUSE: 0x00000000
                    EXCVADDR: 0x00000000  LBEG    : 0x40094de0  LEND    : 0x40094dfc  LCOUNT  : 0xffffffff
                    Backtrace: 0x4010abcf:0x3ffd8280 0x401024b0:0x3ffd8320 0x400fe7c1:0x3ffd8350 0x400fe7ee:0x3ffd8370 0x400e208d:0x3ffd8390 0x400e231d:0x3ffd8430 0x400e0d81:0x3ffd8450
                    0DgAAAEAAAARAAAAbAEAAA==
                    9EX8P8CB/T98hv0/
                    AIH9PxCG/T/ztQIADEP8PwxD/D/0Rfw/BEP8Pw4AAAC4N/4/uDf+P/RF/D8AAAAA
                    CwAAAIBW/T9NaWNyb1B5AAAAAAAAAAAAAQAAAHyG/T8AAAAAIAsGAAsAAAABAAAA
                    +DT7P/yT/D8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                    l4dAPwAAAAD4WwlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAA==
                    oCMQgM+rEEAwAQYAsyQQgICC/T/8k/w/AAAAAADvlD8w////swKVPwB+AAB5nxBA
                    YIL9P9DuQD8AAAAABO+UPwjvlD9IAAAA6vQPQB4AAAAAAAAAAAAAAOBNCUD8TQlA
                    /////wTvlD8I75Q/gDYIQLRp+j8AAAAAAAAAAAEAAAD//z+zAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAATvlD8I75Q/SAAAAOr0D0DE5w+AIIP9P1CU/D9QlPw/
                    kIP9PwMAAACzJBCAgIL9PwgAAABQ75Q/TO+UP0TvlD8AAAAAEwAAACsBAAAgAAAA
                    5DYIQFsjDkDE5w+AIIP9P1CU/D9QlPw/TpoQgMyKCUAIAAAARO+UPwAAAAATAAAA
                    AAAAAPDulD9Q75Q/TO+UPwAAAAAAAAAAAAAAAAAAAAAE75Q/MP////cDlT8CAAAA
                    8ecPgFCD/T9g7ZQ/AAAAAAAAAAAAAAAAAwAAACMABgDw7pQ/AAAAAEwAAAAgg/0/
                    kCAOgHCD/T9g7ZQ/AAAAAAAAAAAAAAAAAQAAAAAAAAAgIw6AkIP9P2DtlD8gAAAA
                    AAAAAAAAAAAAAAAAKPCUP4QNDoAwhP0/pu2UP2YDAAAAAAAAAAAAACAjDoCQg/0/
                    DE/8PwAAAAAgAAAAEDNBPwgzQT8IAAAAsg0OgCCE/T+PM0E/ZgMAAIQNDoAwhP0/
                    pu2UP2YDAAAMIA6AvACVP6D+lD8BAAAAZ0FJTgAIAAAIAAAAcDNBP3juAAABAAAA
                    IAAAAKbtlD/D7gAAAQAAACAAAAAQM0E/CDNBPwgAAAAAAAAAUIT9PwYWAAABAAAA
                    mDH+PwAAAAABAAAAAAAAAAAAAAAQhv0/AAAAAAAAAAABAAAApaWlpaWlpaWlpaWl
                    AAAAAAAAAaXoAAAA6QAAAAEAAAAABAAA+P8f0AAAAAD//////////6WlpaWlpaWl
                    AQAIAAAAAAClpaWlpaWlpaWlpaWlpaWlpaWlpQAAAADIXEA/paWlpaWlpaWlpaWl
                    paWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWl
                    5DYIQPQIDkAwAAUAAAAAABCG/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAAAAACQmxkA
                    AAAAAP/////////////////////7O9mUAAAAAAAAAAAAAAAAAPAfAFCE/T8AAAAA
                    AAAoAAAAAAAAAAAAAAAAAM0XQD+sR/w/AAAAAFUXQD8AAAAAAAAAAAAAAAAAAAAA
                    AQAAAAAAAAAchv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAA
                    ZP39P6Ak/T+UJv0/
                    oCT9PzAm/T/ztQIAqEL8P6hC/D9k/f0/oEL8PxMAAAB8/f0/AAAAAGT9/T8AAAAA
                    BgAAAJgW/T9Mb1JhAAAAAAAAAAAAUFkAAQAAAJQm/T8AAAAAIQAGAAYAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAP79Pw==
                    5DYIQE53CUAwCwYAjDMRgGAl/T/ztQIAQN37Pxgh/j8AAAAAAAAAAAAAAABOdwmA
                    QCX9PwEAAADztQIAZP39PwEAAAD+AAAAEAAAAA4AAACLAAYAq6sAAE4+CUBZPglA
                    AAAAAOQ4CEABAAAAzIoJQNQJ+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAIBB/D8BAAAA/gAAAAEAAAAAAAAAgCX9P8SZ/D9Ymvw/
                    3GL7P/////8AAAACzGL7PwAAAAAwJv0/AAAAAAAAAAAIAAAAAAAAAAAAAAABAAAA
                    AAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAAAAAAMyKCUDUCfo/AAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAABKFhQoAAAAAAAAAAAAAAADMNkE/eAT8P1ia/D+V////
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPCb9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAA=
                    HLP7PyCx/T+Isv0/
                    ILH9PyCy/T/ztQIAlEL8P5RC/D8cs/s/jEL8PxQAAAAwOv4/MDr+Pxyz+z8AAAAA
                    BQAAAIyi/T9TZXJ2ZXJzAAAAAAAAAAAAAQAAAIiy/T8AAAAAIQAGAAUAAAAAAAAA
                    9H/7PwAAAAAAAAAAAAAAAAsAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
                    5DYIQE53CUAwCwYAyA4OgOCx/T/ztQIAQN37PwsAAAAA/wAAAAD/AAAAAP9OdwmA
                    wLH9PwEAAADztQIAHLP7PwEAAAD+AAAAIwAGAAAAAADEVg+AoLH9P+BNCUD8TQlA
                    /////+Q4CEABAAAAzIoJQMSV+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAsv0/MPj7PwAAAAAAAAAAALL9PwAAAAAAAAAA
                    AgAAAAD/AAAAAP8AAAAA/wAAAAAgsv0/AAAAAAAAAAAAAAAAAQAAAGpK/D8AAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALLL9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                    QLn7P6C3+z84ufs/
                    oLf7P9C4+z9Tlb0vvL77PzBC/D9Aufs/KEL8PxkAAAC8SVUVuUNvUUC5+z8AAAAA
                    AAAAADy1+z9JRExFMABG0Bmj0zv92E4AAAAAADi5+z8AAAAAIwAGAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEXqHw==
                    5DYIQLZoIUAwDwYAdmgXgGC4+z8AAAAAAAAAAAAAAACQt/s/AwAAACMABgD4kfw/
                    AAAAAPyxAgAAAAAAAAAAAAkAAAAAgAAA//8AgAoAAACguPs/AAAAANDYDkAT2Q5A
                    AAAAAOQ4CEAJAAAAzIoJQHSc+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAPPr8P8yKCUAseQmAgLj7PyAAAAABAAAA
                    //8/swAAAAAAAAAAAAAAAAAAAACguPs/AAAAALhB/D8AAAAAPPr8PxxE/D8AAAAA
                    AAAAANC4+z8AAAAAAAAAAEDd+z8AAAAAAAAAAAAAAAAAAAAAAQAAAAQAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3Lj7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                    tL77PxC9+z+svvs/
                    EL37P0C++z/MtOISMEL8P0i5+z+0vvs/KEL8PxkAAACFM0nahGdmZbS++z8AAAAA
                    AAAAALC6+z9JRExFMQDLX/9qno4QORUAAQAAAKy++z8AAAAAIwAGAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAI8mOg==
                    5DYIQLZoIUAwCQYAdmgXgNC9+z8AAAAAMEL8P4XGAgCoBfw/K6oCACMABgAjAAYA
                    /////5BB/D8wQvw/6M8CAKgF/D81rwIAIwAGAAAAAADQvfs/AAAAAAAAAAAAAAAA
                    AAAAAOQ4CECoBfw/zIoJQOSh+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAseQmA8L37PyAAAAABAAAA
                    //8/swAAAAAAAAAAAAAAAAAAAAAQvvs/AAAAALhB/D8gAAAAPPr8PyBE/D8AAAAA
                    AAAAAEC++z8AAAAAAAAAAEDd+z8AAAAAAAAAAAAAAAABAAAAAQAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAATL77PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                    tJ/7P9Ct+z/Er/s/
                    0K37P2Cv+z8xtgIAHEL8PxxC/T+0n/s/FEL8PwcAAAAIn/s/CJ/7P7Sf+z8An/s/
                    EgAAAMih+z90aVQAcEH8P7x9+z/EffsAAAAAAMSv+z8AAAAAIQAGABIAAAAAAAAA
                    5DYIQLBmCUAwDwYAaf8YgJCu+z/cnvs/MK/7Pyif+z8AAAAAMJ/7PwAAAACwZgmA
                    cK77PwAAAABiAAAAQN37PxxE/D/+AAAAAAAAABAAAAABAAAA/gAAAPHrGED66xhA
                    AAAAAOQ4CEAcRPw/zIoJQAST+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAEQ2GICgrvs/cAtCP6Cu+z//NxiA0K77P/////8wr/s/
                    AAAAAM+1AgBkAAAAUDcYQGIAAACQrvs//gAAAAAAAABIOBiA4K77P7wMQj+YAJQ/
                    rwEYgACv+z88+/w/MK/7P68BGIAAr/s/PPv8PzCv+z9iAAAA/////8+1AgAAAAAA
                    AAAAADCv+z88ZxhAAAAAAFA3GEC8DEI/PGcYQAAAAACo//w/qP/8P6T//D+k//w/
                    AAAAAGCv+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAbK/7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                    FEL9PwBA/T8MQv0/
                    AED9P6BB/T/0tQIAvJ/7PxxC/D8UQv0/FEL8PxMAAAAAAAAAAAAAABRC/T8AAAAA
                    BgAAABA0/T9TaWdmb3gAQLDKH0AwAAUAAAAAAAxC/T8AAAAAIQAGAAYAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKWlpQ==
                    5DYIQE53CUAwAQYAysofgMBA/T/0tQIAQN37PyD//T8AAAAAAAAAAAAAAABOdwmA
                    oED9PwAAAAD0tQIAFEL9PwEAAAD+AAAAIwAGABEAAABEJfo/AAAAAAAAAAAAAAAA
                    AAAAAOQ4CEABAAAAzIoJQEQl+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAA4ED9P9gU/T/UFP0/
                    IP/9PwAAAAAAAAAAAAAAAAAAAACgQf0/AAAAAAAAAADkNghAsMofQDAABQAAAAAA
                    oEH9PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                    RCX6PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                    FwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKxB/T8AAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
                    IMv7P8DJ+z8Yy/s/
                    wMn7P7DK+z8AAAAACEL8PwhC/D8gy/s/AEL8Pw8AAABQwPs/UMD7PyDL+z9IwPs/
                    CgAAABzB+z9UbXIgU3ZjAA5cTdTiH3QAAAAAABjL+z8AAAAAIQAGAAoAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMCU9g==
                    5DYIQGGICUAwAAYAAAAAAIDK+z8AAAAAAAAAAAAAAAAsRPw/JET8PwEAAABhiAmA
                    YMr7PwAAAABA3fs/gEH8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                    AAAAAOQ4CEAAAAAAzIoJQFSu+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAFSu+D8AAAAAAAAAAAAAAAAAAAAAsMr7PwAAAAAAAAAA
                    AAAAAAAAAAC8yvs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                    AAAAAAAAAAA=
                    7MP9P1DC/T/kw/0/
                    UML9P4DD/T/JRKlVCMr9P7Sx+z/sw/0/pEH8PxQAAABziUhuF1Dt2OzD/T8AAAAA
                    BQAAAOiz/T9Tb2NrZXQgT3BlcmF0aW8AAQAAAOTD/T8AAAAAIQAGAAUAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAACNJw==
                    5DYIQPC/AEAwAAYAWnIJgBDD/T8AAAAAIwAGACAABgDQg/0/VQAAAPCh/T///z+z
                    q6sAAOzc+z8jAAYA7MP9PwEAAAD+AAAAAAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                    AAAAAOQ4CEABAAAAzIoJQCSn+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACigwmAIMP9P0Dd+z8GAAAA
                    3moOgEDD/T8BAAAAIET8P+zD/T8BAAAA/gAAALCd+z8AAAAAYMP9PwAAAAAAAAAA
                    HET8P0Dd+z+QQfw/lEL8PwAAAACAw/0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjMP9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                    AMr9P1Dp/T9s6/0/
                    UOn9PwDr/T8Ayv0/OHz7P/TD/T8Ayv0/pEH8Pw4AAAC8sv0/vLL9PwDK/T+0sv0/
                    CwAAAHDL/T9JUlFzAAAAAAAAAAAASYIAAQAAAGzr/T8AAAAAIQAGAAsAAAAAAAAA
                    AAAAAJzq/T8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApv6CQ==
                    5DYIQLBmCUAwBQYASEsPgBDq/T+Qsv0/sOr9P9yy/T8AAAAA5LL9PwAAAACwZgmA
                    8On9PwEAAAD/////QN37PxxE/D/+AAAAAAAAAAAAAABQ6v0/sJX8PwAAAAAAAAAA
                    AAAAAOQ4CEAcRPw/zIoJQKTO+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAAQAAAMyKCUB8FA6AUOr9P4CS/D+w6v0/
                    AAAAAFQAAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAAAAAAAAAQAAAHSS/D8wAPw/
                    AAAAAODq/T90kvw/AAAAAADr/T8AAAAAAAAAAAAAAAAAAAAAdJL8PwAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACw6v0/
                    ABwAAFCU/D9QlPw/AAAAAKTO+j8AAAAAAAAAAAAAAABQlPw/CgAAAJBB/D8MQ/w/
                    AAAAAADr/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAM6/0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAA
                    MHz7P7Cc+z84nvs/
                    sJz7P9Cd+z8sCBnhmNn7PwjK/T8wfPs/pEH8PwEAAAAEfPs/BHz7PzB8+z/8e/s/
                    GAAAADya+z9pcGMxAH0Q8VnobXH5p5QAAQAAADie+z8AAAAAIQAGABgAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKE5jA==
                    5DYIQLBmCUAwBwYAlDQIgHCd+z/Ye/s/AAAAACR8+z8AAAAA2Hv7PwAAAACwZgmA
                    UJ37PwEAAAD/////QN37PxxE/D/+AAAAIAMGABwAAAD//z+zAAAAAAAAAAAAAAAA
                    AAAAAOQ4CEAcRPw/zIoJQHSB+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAADB8+z8BAAAA/gAAACMABgAAAAAAsJ37PzhB/D8AAAAA
                    AAAAAGQEAAD+AAAAIAMGAP////8AAAAAOEH8PyRB/D8Advs/AAAAAAEAAAAAAAAA
                    AAAAANCd+z8AAAAAAAAAALh+CEABAAAAAAAAAAAAAAB9FAiAgH3+PwABAADoDQBA
                    AAAAAAAAAADcnfs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                    AAAAAAAAAAA=
                    kNn7P9CQ/T+Akv0/
                    0JD9PyCS/T8L+VfXqDL9Pzh8+z+Q2fs/pEH8PwUAAABk0/s/ZNP7P5DZ+z9c0/s/
                    FAAAAISG/T9ldmVudFRhc2sADM8yC4kAAAAAAICS/T8AAAAAIQAGABQAAAAAAAAA
                    KDX7PwAAAAAAAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHiJeQ==
                    5DYIQLBmCUAwAgYALGkXgJCR/T840/s/0JH9P4TT+z8AAAAAjNP7PwAAAACwZgmA
                    cJH9PwAAAAD/////QN37PxxE/D/+AAAAIAAGAAAAAABwkf0/fJH9P+BNCUD8TQlA
                    /////+Q4CEAcRPw/zIoJQMR1+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAMCoBAH///8AwKgEATxxv4cAAAAA0JH9P4z6/D8AAAAA
                    AAAAAL0EAAD+AAAAIAAGAP/////Qkf0/jPr8PwAAAACE0/s/AAAAAFzZ+z8BAAAA
                    AAAAACCS/T8AAAAAAAAAAA4AAAACAAAAfML8PwEAAAAIBvw//gAAAAEAAAAbchOA
                    8EH7PwAAAAAAAAAAcQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAskv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                    oDL9P9Aw/T+YMv0/
                    0DD9PzAy/T8AAAAAcHr7P5jZ+z+gMv0/pEH8PxEAAAB4Yvs/eGL7P6Ay/T9wYvs/
                    CAAAAJwm/T9Mb1JhX1RpbWVyX2NhbGwAAQAAAJgy/T8AAAAAIQAGAAgAAAAAAAAA
                    5DYIQPC/AEAwAAYAWnIJgJAx/T8AAAAAIwAGACAABgABAAAA/gAAAAAAQAD//z+z
                    q6sAAEDd+z//////IAoGAIDslD8AAP8AAAAA/wAAAAClpaWlpaWlpQAAAAAAAAAA
                    AAAAAOQ4CECA7JQ/zIoJQNQV+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAP////+nZgmAoDH9P5hi+z//////
                    mB4RgMAx/T9MYvs/ADL9P0Dd+z8cRPw//gAAACMABgAAAAAAADL9P4Cb/D8AAAAA
                    AAAAAIAIAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAACYYvs/AAAAAKBi+z8AAAAA
                    AAAAADAy/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPDL9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                    aHr7P+B4+z9gevs/
                    4Hj7PwB6+z+HrjGXTEP7P6gy/T9oevs/pEH8PwEAAAA4dvs/OHb7P2h6+z8wdvs/
                    GAAAAGR2+z9pcGMwAPHSUYYL2UPLt7EAAAAAAGB6+z8AAAAAIQAGABgAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANj60g==
                    5DYIQLBmCUAwBwYAlDQIgKB5+z8Mdvs/AAAAAFh2+z8AAAAADHb7PwAAAACwZgmA
                    gHn7PwAAAAD/////QN37PxxE/D/+AAAAUQYAAAAAAAAAAAAAAQAAAAAAAAAAAAAA
                    AAAAAOQ4CEAcRPw/zIoJQKRd+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAA4Hn7PzRB/D8AAAAA
                    AAAAADQKAAD+AAAAUQYAAP/////gefs/NEH8PyRB/D8Advs/AAAAAAEAAAAAAAAA
                    AAAAAAB6+z8AAAAAAAAAALh+CEAAAAAAAAAAAAAAAADpEwiAIDz+P4xB/D+PaUA/
                    AAAAAAAAAAAMevs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                    REP7P3BB+z88Q/s/
                    cEH7P9BC+z8TIhymhHL7P3B6+z9EQ/s/pEH8PwIAAAB8Lvs/fC77P0RD+z90Lvs/
                    FwAAAEA1+z93aWZpAL6bfa7+shKU8Z4AAAAAADxD+z8AAAAAIQAGABcAAAABAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANPm3Q==
                    5DYIQLBmCUAwCQYArVwXgDBC+z9QLvs/oEL7P5wu+z8AAAAApC77PwAAAACwZgmA
                    EEL7PwAAAAD/////QN37PxxE/D/+AAAAAAAAAB4AAAD1NBSAUEL7P+BNCUD8TQlA
                    /////+Q4CEAcRPw/zIoJQHQm+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAB41/w/GwAAAAAAAAAZeRWAcEL7P1Au+z+gQvs/
                    AAAAAPK1AgAAAAAAUPr9P/////9wQvs/AAAAABT6/T8JAAAA4Aj8P6AI/D8BAAAA
                    AAAAAJBC+z/YBfw/dAv8P/////+AAAAAxAAAAHAL/D8AAAAA0EL7PwAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAaOb8PxoAAABoCPw/
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3EL7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                    fHL7P+Bw+z90cvs/
                    4HD7PxBy+z+XlaRrrEH8P0xD+z98cvs/pEH8PwMAAABwQPw/cED8P3xy+z9oQPw/
                    FgAAAHhm+z9lc3BfdGltZXIA30u6hkQAAAAAAHRy+z8AAAAAIQAGABYAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJcfvg==
                    5DYIQLBmCUAwAQYA/SwNgKBx+z9EQPw/AAAAAJBA/D8AAAAARED8PwAAAACwZgmA
                    gHH7PwAAAAD/////QN37PxxE/D/+AAAA/T4CAAAAAAAKAAAAAAAAAOBNCUD8TQlA
                    /////+Q4CEAcRPw/zIoJQLRV+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAKEaCICgcfs//Nz7P/9zq34AAAAA4HH7P5hA/D+gQPw/
                    AAAAAPO1AgBQLvs//T4CAP/////gcfs/AAAAAKBA/D/YBfw/AAAAACRw9D8AAAAA
                    AAAAABBy+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKBA/D/L5pYK
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHL7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                    rLH7P/Cg/T+Eov0/
                    8KD9PyCi/T/gAAAA9MP9P6xB/D+ssfs/pEH8PxQAAAD8TQlAAAAAAKyx+z8AAAAA
                    BQAAAIiS/T9TbWFydENvbmZpZwD//z8AAQAAAISi/T8AAAAAIQAGAAUAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAAAAA==
                    5DYIQPC/AEAwAAYAWnIJgLCh/T8AAAAAIwAGACAABgAAnfs/AwAAACMDBgD//z+z
                    q6sAAOzc+z8jAAYArLH7PwEAAAD+AAAAmAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                    AAAAAOQ4CEABAAAAzIoJQMSF+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACigwmAwKH9P0Dd+z8FAAAA
                    B3oOgOCh/T8BAAAAIET8P6yx+z8BAAAA/gAAACADBgAAAAAAAKL9PwAAAAAAAAAA
                    HET8P0Dd+z+QQfw/lEL8PwAAAAAgov0/AAAAAAAAAABET/w/AAAAAAAAAAAAAAAA
                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALKL9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                    Rebooting...
                    ets Jun  8 2016 00:22:57
                    rst:0xc (SW_CPU_RESET),boot:0x16 (SPI_FAST_FLASH_BOOT)
                    configsip: 0, SPIWP:0xee
                    mode:DIO, clock div:1
                    load:0x3fff8020,len:8
                    load:0x3fff8028,len:2176
                    load:0x4009fa00,len:19740
                    entry 0x400a05bc
                      andreas @sita
                      Thanks! Decoding this yields
                      ==================== CURRENT THREAD STACK =====================
                      #0  mp_execute_bytecode (code_state=0x3f94eef0, inject_exc=0x0) at ../py/vm.c:1306
                      #1  0x401024b3 in fun_bc_call (self_in=<optimized out>, n_args=<optimized out>, n_kw=0, args=0x3ffd8280) at ../py/objfun.c:287
                      #2  0x400fe7c4 in mp_call_function_n_kw (fun_in=0x3f94ed60, n_args=0, n_kw=0, args=0x0) at ../py/runtime.c:624
                      #3  0x400fe7f1 in mp_call_function_0 (fun=0x3f94ed60) at ../py/runtime.c:598
                      #4  0x400e2090 in parse_compile_execute (source=0x3f94eda6, input_kind=MP_PARSE_FILE_INPUT, exec_flags=32) at ../lib/utils/pyexec.c:103
                      #5  0x400e2320 in pyexec_file (filename=0x3f94eda6 <error: Cannot access memory at address 0x3f94eda6>) at ../lib/utils/pyexec.c:550
                      #6  0x400e0d84 in TASK_Micropython (pvParameters=<optimized out>) at mptask.c:320
                      ======================== THREADS INFO =========================
                        Id   Target Id         Frame
                        17   process 16        0x4000bff0 in ?? ()
                        16   process 15        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffc4044 <s_timer_semaphore_memory>, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                        15   process 14        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffb2e50, pvBuffer=0x3ffb42a0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                        14   process 13        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffb760c, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                        13   process 12        0x4000bff0 in ?? ()
                        12   process 11        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffbd338, pvBuffer=0x3ffd91d0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                        11   process 10        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffb7bd8, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                        10   process 9         0x400966b0 in xQueueGenericReceive (xQueue=0x3ffdb290, pvBuffer=0x3ffdeab0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                        9    process 8         0x4000bff0 in ?? ()
                        8    process 7         /builds/idf/crosstool-NG/.build/src/gdb-7.10/gdb/inline-frame.c:171: internal-error: inline_frame_this_id: Assertion `!frame_id_eq (*this_id, outer_frame_id)' failed.
                      So, the core dump seems to happen right away after system start while executing the Python file
                      I have never seen that before! The file might be corrupted somehow.
                      • Is this the core dump which is happening immediately after uploading the MicroPython file to the system?
                      • Can you get another core dump which is coming from the system after a short run time i.e. after hitting the reset button?
                      • Can you show your current MicroPython code again?
                      • You might also want to try yet another erase_all [1] / erase_flash procedure first.
                      [1] Please don't miss the corresponding installation notes when invoking erase_all on LoPy devices.
                      A S 2 Replies Last reply Reply Quote 0
                        andreas @andreas
                        @andreas said in Guru Meditation Error:
                        Regarding the MicroPython code, I would suggest trying to invoke your program without any interaction on the filesystem and see whether it still crashes.
                          sita @andreas
                          Hello @andreas,
                          I have attached the core dump which is observed after a short run.
                          Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
                          PC      : 0x40098fbb  PS      : 0x00060033  A0      : 0x80097e99  A1      : 0x3ffbf0c0
                          A2      : 0x3ffbb95c  A3      : 0x00060023  A4      : 0x3ffc45f4  A5      : 0x00000001
                          A6      : 0x000000fe  A7      : 0x3f95038a  A8      : 0x00000000  A9      : 0x3ffbb95c
                          A10     : 0x3ffbb95c  A11     : 0x00000000  A12     : 0x8010a802  A13     : 0x3ffd8260
                          A14     : 0x00000001  A15     : 0x00000000  SAR     : 0x00000003  EXCCAUSE: 0x0000001c
                          EXCVADDR: 0x00000004  LBEG    : 0x400ed8d0  LEND    : 0x400ed913  LCOUNT  : 0x00000000
                          Core 1 was running in ISR context:
                          EPC1    : 0x40098fbb  EPC2    : 0x00000000  EPC3    : 0x00000000  EPC4    : 0x00000000
                          Backtrace: 0x40098fbb:0x3ffbf0c0 0x40097e96:0x3ffbf0e0 0x4009656d:0x3ffbf100 0x400890bb:0x3ffbf120 0x40083949:0x3ffbf160 0x400e7009:0x3ffd81f0 0x401023ba:0x3ffd8220 0x400fe7c1:0x3ffd8240 0x400fe851:0x3ffd8260 0x4010a7ff:0x3ffd8280 0x401024b0:0x3ffd8320 0x400fe7c1:0x3ffd8350 0x400fe7ee:0x3ffd8370 0x400e208d:0x3ffd8390 0x400e231d:0x3ffd8430 0x400e0d81:0x3ffd8450
                          pDQAAAEAAAAQAAAAbAEAAA==
                          ZP39P6Ak/T+UJv0/
                          oCT9PzAm/T/I5AEAqEL8P6hC/D9k/f0/oEL8PxMAAAB8/f0/AAAAAGT9/T8AAAAA
                          BgAAAJgW/T9Mb1JhAAAAAAQAAAAAUFkAAQAAAJQm/T8AAAAAIQAGAAYAAAAAAAAA
                          AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADD+Pw==
                          5DYIQE53CUAwDQYAjDMRgGAl/T/I5AEAQN37Pxgh/j8AAAAAAAAAAAAAAABOdwmA
                          QCX9PwEAAADI5AEAZP39PwEAAAD+AAAAEAAAAA4AAADUCfo/AAAAAE4+CUBZPglA
                          GCH+PwAAAAAAAAAAAAAAAAAAAAAwJv0/AAAAAAAAAAAIAAAAAAAAAAAAAAABAAAA
                          AAAAAAAAAAAAAAAAAAAAAKUNQgcAAAAAAAAAAAAAAADMNkE/eAT8P1ia/D+W////
                          HLP7PyCx/T+Isv0/
                          ILH9PyCy/T/I5AEAlEL8P5RC/D8cs/s/jEL8PxQAAAAwOv4/MDr+Pxyz+z8AAAAA
                          5DYIQE53CUAwDQYAyA4OgOCx/T/I5AEAQN37PwsAAAAA/wAAAAD/AAAAAP9OdwmA
                          wLH9PwEAAADI5AEAHLP7PwEAAAD+AAAAIwAGAAAAAADEVg+AoLH9P+BNCUD8TQlA
                          QLn7PxC3+z84ufs/
                          ELf7P9C4+z9RFb1vvL77PzBC/D9Aufs/KEL8PxkAAABcufs/XLn7P0C5+z8AAAAA
                          AAAAADy1+z9JRExFMABWwAmj07v92E4AAAAAADi5+z8AAAAAIAcGAAAAAAAAAAAA
                          AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEX5Fw==
                          5DYIQLBmCUAwDwYApBQXgNC3+z/ktPs/AAAAADC1+z8AAAAA5LT7PwEAAACwZgmA
                          sLf7PwAAAAD/////QN37PxxE/D/+AAAAqQ28PwoAAADkNghAsl4hQNDYDkAT2Q5A
                          AAAAAOQ4CEAcRPw/zIoJQHSc+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                          AAAAAAAAAAAAAAAAAAAAAGC4+z8AAAAAAAAAAAAAAAAl2Q6AELj7PwEAAABAAAAA
                          AAAAAAPlAQAAAAAAAAAAAP////8AgAAA//8AgAoAAACguPs/AAAAANDYDkAT2Q5A
                          WEgPgEC4+z8AAAAAAQAAAHSc+D8Qkvw/AAAAAAAAAAAYAAAAAAAAAHTr/T8BAAAA
                          ZGgXgGC4+z/4kfw/AQAAAAAAAAAJAAAAAIAAAP//AIAseQmAgLj7PwAAAAABAAAA
                          AAAAALA//T8DAAAAIwAGAAAAAACguPs/AAAAALhB/D8AAAAAPPr8PxxE/D8AAAAA
                          tL77PxC9+z+svvs/
                          EL37P0C++z/MkOIQMEL8P0i5+z+0vvs/KEL8PxkAAACNMdnalEdm5bS++z8AAAAA
                          AAAAALC6+z9JRExFMQDrX/9+n4oQORUAAQAAAKy++z8AAAAAIwAGAAAAAAAAAAAA
                          5DYIQLZoIUAwCwYAdmgXgNC9+z8AAAAAMEL8PwtqCYDQsP0/AwAAACMABgAjAAYA
                          gLH9P+zc+z8gDwYA//8/s6urAAD+AAAAAAAAAAAAAAAQvvs/AAAAAAAAAAAAAAAA
                          AAAAAOQ4CECrqwAAzIoJQOSh+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                          AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAPPr8P8yKCUAseQmA8L37PyAAAAABAAAA
                          tJ/7P9Ct+z/Er/s/
                          0K37P2Cv+z805QEAHEL8PxxC/T+0n/s/FEL8PwcAAAAIn/s/CJ/7P7Sf+z8An/s/
                          cK77PwAAAABgAAAAQN37PxxE/D/+AAAAAAAAABAAAADkNghANDYYQPHrGED66xhA
                          AAAAANTkAQBkAAAAUDcYQGAAAACQrvs//gAAAAAAAABIOBiA4K77P7wMQj+YAJQ/
                          rwEYgACv+z88+/w/MK/7P68BGIAAr/s/PPv8PzCv+z9gAAAA/////9TkAQAAAAAA
                          FEL9PwBA/T8MQv0/
                          AED9P6BB/T8E5QEAvJ/7PxxC/D8UQv0/FEL8PxMAAAAFAAAAkEH8PxRC/T8AAAAA
                          5DYIQE53CUAwAQYAysofgMBA/T8E5QEAQN37PyD//T8AAAAAAAAAAAAAAABOdwmA
                          oED9PwAAAAAE5QEAFEL9PwEAAAD+AAAAIwAGABEAAABEJfo/AAAAAAAAAAAAAAAA
                          IMv7P8DJ+z8Yy/s/
                          CgAAABzB+z9UbXIgU3ZjAA4cTdTiG3QAAAAAABjL+z8AAAAAIQAGAAoAAAAAAAAA
                          AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMCU8g==
                          AAAAAAAAAAA=
                          7MP9P1DC/T/kw/0/
                          UML9P4DD/T/LQKlVCMr9P7Sx+z/sw/0/pEH8PxQAAABRiUhuVnTv3ezD/T8AAAAA
                          AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAACBBw==
                          5DYIQPC/AEAwAAYAWnIJgBDD/T8AAAAAIwAGACAABgCYzfs/VQAAAPCh/T///z+z
                          3moOgEDD/T8BAAAAIET8P+zD/T8BAAAA/gAAAICD/T8AAAAAYMP9PwAAAAAAAAAA
                          AMr9P1Dp/T9s6/0/
                          CwAAAHDL/T9JUlFzAAAAAAAAAAAASa4AAQAAAGzr/T8AAAAAIQAGAAsAAAAAAAAA
                          AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAArv6CA==
                          8On9PwEAAAD/////QN37PxxE/D/+AAAAAAAAAAAAAACkzvo/AAAAAAAAAAAAAAAA
                          AAAAAAAAAAAAAAAAAAAAAAAAAAAyAAAApaWlpaWlpaV8FA6AUOr9P4CS/D+w6v0/
                          AAAAAFQAAAClpaWlpaWlpf////9Q6v0/sJX8P7Dq/T8AAAAAAQAAAHSS/D8wAPw/
                          AAAAAAAAAAAAAAAA
                          MHz7P7Cc+z84nvs/
                          sJz7P9Cd+z8sSBnimNn7PwjK/T8wfPs/pEH8PwEAAAAEfPs/BHz7PzB8+z/8e/s/
                          GAAAADya+z9pcGMxAH1w+UnobXH5p5QAAQAAADie+z8AAAAAIQAGABgAAAAAAAAA
                          5DYIQLBmCUAwBQYAlDQIgHCd+z/Ye/s/AAAAACR8+z8AAAAA2Hv7PwAAAACwZgmA
                          UJ37PwEAAAD/////QN37PxxE/D/+AAAAIwAGABwAAACwnfs/OEH8PwAAAAAAAAAA
                          AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAAAAAAMyKCUAAAAAAsJ37PzhB/D8AAAAA
                          AAAAAGQEAAAAAAAAAAAAAP////8AAAAAOEH8PyRB/D8Advs/AAAAAAEAAAAAAAAA
                          AAAAAAAAAAA=
                          kNn7P9CQ/T+Akv0/
                          0JD9PyCS/T9w2fs/qDL9Pzh8+z+Q2fs/pEH8PwUAAABk0/s/ZNP7P5DZ+z9c0/s/
                          FAAAAISG/T9ldmVudFRhc2sA+z8AAAAAAAAAAICS/T8AAAAAIQAGABQAAAAAAAAA
                          AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHjBWQ==
                          AAAAALwEAAD+AAAAIAAGAP/////Qkf0/jPr8PwAAAACE0/s/AAAAAFzZ+z8BAAAA
                          AAAAACCS/T8AAAAAAAAAAA4AAADAQfs/AQEAAHzB/D8GAAAAogm8P///AABQBgAA
                          KHNBPzwAAAACAAAAGMf8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                          oDL9P9Aw/T+YMv0/
                          0DD9PzAy/T8AEAAAcHr7P5jZ+z+gMv0/pEH8PxEAAAB4Yvs/eGL7P6Ay/T9wYvs/
                          5DYIQPC/AEAwAAYAWnIJgJAx/T8AAAAAIwAGACAABgABAAAA/gAAACMABgD//z+z
                          q6sAAEDd+z////////8/s6urAAD+AAAAAABAAAAAAAAAAAAAkEH8PwAAAAAAAAAA
                          AAAAAOQ4CECrqwAAzIoJQNQV+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                          AAAAAAAAAAAAAAAAAAAAANQV+j8AAAAAAAAAAAAAAACnZgmAoDH9P5hi+z//////
                          AAAAAL8GAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAACYYvs/AAAAAKBi+z8AAAAA
                          aHr7P+B4+z9gevs/
                          4Hj7PwB6+z+XrzCfTEP7P6gy/T9oevs/pEH8PwEAAAA4dvs/OHb7P2h6+z8wdvs/
                          GAAAAGR2+z9pcGMwAPHWUYaKWUfbt7EAAAAAAGB6+z8AAAAAIQAGABgAAAAAAAAA
                          5DYIQLBmCUAwAQYAlDQIgKB5+z8Mdvs/AAAAAFh2+z8AAAAADHb7PwAAAACwZgmA
                          gHn7PwAAAAD/////QN37PxxE/D/+AAAAHEL9PwAAAAAAAAAAAQAAAAAAAAAAAAAA
                          AAAAADAKAAD+AAAAHEL9P//////gefs/NEH8PyRB/D8Advs/AAAAAAEAAAAAAAAA
                          REP7P3BB+z88Q/s/
                          cEH7P9BC+z8BIhymhHL7P3B6+z9EQ/s/pEH8PwIAAAB8Lvs/fC77P0RD+z90Lvs/
                          FwAAAEA1+z93aWZpADqbfer+shKU8Z4AAAAAADxD+z8AAAAAIQAGABcAAAABAAAA
                          AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANPmnQ==
                          EEL7PwAAAAD/////QN37PxxE/D/+AAAAAAAAABwAAAD1NBSAUEL7P+BNCUD8TQlA
                          AAAAAAAAAAAAAAAAAAAAAN9SFYBAQvs/AAAAAOiVCEAZeRWAcEL7P1Au+z+gQvs/
                          AAAAAPPkAQDwIgzAACAMAP////9wQvs/uL4AQAAAAABEQ/s/4Av8P+AL/D8BAAAA
                          AAAAAJBC+z/YBfw/dAv8P/////8AAAAAxAAAAHAL/D8AAAAA0EL7PwAAAAAAAAAA
                          AAAAAAAAAAAAAAAAAAAAAAsAAACUDbw/AAAAAAAAAAAAAAAAaOb8PxoAAABoCPw/
                          fHL7P+Bw+z90cvs/
                          4HD7PxBy+z8HlaRrrEH8P0xD+z98cvs/pEH8PwMAAABwQPw/cED8P3xy+z9oQPw/
                          FgAAAHhm+z9lc3BfdGltZXIA30u4hkQAAAAAAHRy+z8AAAAAIQAGABYAAAAAAAAA
                          AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJZbvA==
                          gHH7PwAAAAD/////QN37PxxE/D/+AAAAJLP7PwAAAAAKAAAAAAAAAOBNCUD8TQlA
                          AAAAAAAAAAAAAAAAAAAAAEDd+z8cRPw//gAAACSz+z8AAAAA4HH7P5hA/D+gQPw/
                          AAAAAPPkAQBQLvs/JLP7P//////gcfs/AAAAAKBA/D8AAAAAAAAAACRw9D8AAAAA
                          AAAAABBy+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKBA/D/6gGYH
                          rLH7P/Cg/T+Eov0/
                          8KD9PyCi/T/Gxsjt9MP9P6xB/D+ssfs/pEH8PxQAAAD7mJIwA0gB/6yx+z8AAAAA
                          BQAAAIiS/T9TbWFydENvbmZpZwBUAAAAAQAAAISi/T8AAAAAIQAGAAUAAAAAAAAA
                          5DYIQPC/AEAwAAYAWnIJgLCh/T8AAAAAIwAGACAABgDg8Ps/AwAAACMABgD//z+z
                          q6sAAOzc+z8jAAYArLH7PwEAAAD+AAAAAAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                          B3oOgOCh/T8BAAAAIET8P6yx+z8BAAAA/gAAACAAAAAAAAAAAKL9PwAAAAAAAAAA
                          Rebooting...
                          rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
                          entry 0x400a05bc
                            andreas @sita
                            Thanks @sita. This yields...
                            #0  0x4009774e in vTaskDelay (xTicksToDelay=<optimized out>) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/tasks.c:1484
                            #1  0x4011338c in TASK_LoRa (pvParameters=<optimized out>) at mods/modlora.c:804
                              andreas
                              Dear @sita,
                              @ps47 also experienced similar errors like you have been observing [1]. He is also using pure LoRa. Using the most recent 1.20.2.rc3 release seems to help here [2]. Thanks @husigeza and the whole Pycom team for mitigating this issue.
                              I tried the new build LoPy4-1.20.2.rc3-0.8.0-vanilla-squirrel.tar.gz and not any “bad00bad bad00bad bad00bad” Core Panic happened till now.
                              With kind regards,
                              Andreas.
                              [1] https://forum.pycom.io/topic/5514/random-core-panic-with-lora-socket-send-recv-device-doesnt-restart-try-with-config_esp32_panic_silent_reboot
                              [2] https://community.hiveeyes.org/t/investigating-core-panics-on-the-lopy4/2878/29
                                andreas
                                Dear @sita,
                                any news on your side about this issue?
                                With kind regards,
                                Andreas.
                                  sita @andreas
                                  Hello @andreas,
                                  I am tried all the ways (like removing SD card, changing the time ..etc) still same error is continuing :( :(
                                  Now i will test the device by sending data via TTN to check whether this error is coming in ad-hoc lora mode or not and let you know.
                                  Thanks for your support.
                                  Have a nice day
                                    peterp
                                    Which firmware are you using now? Or let me ask it differently, can you reproduce the error with v1.20.2.rc3?
                                      sita @peterp
                                      Hello @peterp,
                                      I am using latest firmware ( v1.20.2.rc3 ). I have tested the device different codes.
                                      If i send basic message then i didn't find any error, but if send GPS the error is still coming.
                                        andreas @sita
                                        Thanks for clarifying this. While I believe there has to be some protection for that case, might it be possible that the message is just getting too long?
                                        coord = l76.coordinates()
                                        gps_datetime = l76.get_datetime()
                                        lat,lon = coord
                                        timestamp =('20' + gps_datetime[4][4] + gps_datetime[4][5]+gps_datetime[4][2] + gps_datetime[4][3]+gps_datetime[4][0] + gps_datetime[4][1]+gps_datetime[2][0] + gps_datetime[2][1]+gps_datetime[2][2] + gps_datetime[2][3]+gps_datetime[2][4] + gps_datetime[2][5] )
                                        message = ''+str(lat)+','+str(lon)+','+str(timestamp)+','+str(value)
                                        s.send(message)
                                        a) Can you tell us about the final result of len(message) here?
                                        b) Can you make up another arbitrary message of the same length (e.g. by using message = 'X' * length) without reading the L76 in order to check if both things produce the error independently from each other?
                                          sita @andreas
                                          Hello @andreas,
                                          a) The length of message is 35
                                          b) With same length (35) message without L76 i tested the device, there is no error present.
                                            andreas @sita
                                            So, do you believe we can deduce from that that doing both things (reading the L76 and submitting data using LoRa) influence each other unfavourably?
                                            That might finally be a trace we could follow up here.
                                            • 2 / 3
