    Guru Meditation Error
    58 Posts 7 Posters 2.3k Views 7 Watching
      andreas @sita
      @sita said in Guru Meditation Error:
        f = open('/sd/A_3001SF8.txt', 'a+')
        f.write(message)
        f.write(' ')
        f.write('\n')
        f.close()
      Could you stop opening and closing the file within such a tight loop? You might want to time.sleep_ms() for at least some milliseconds between iterations. To be safe, try to use longer intervals first and get shorter if things might become more stable.
      When being at it, you might also want to think about optimizing things using a single write call like f.write(message + ' \n').
        sita @andreas
        Hello @andreas,
        Thanks for the information. I kept time.sleep_ms(10) in the loop and will change f.write as you said.I will do the the experiment again and let you know if i got same again.
        Thanks once again.
        Have a nice day
          sita @andreas
          Hello @andreas ,
          I have changed the firmware to LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel.tar.gz. I will do the experiment again and let you know if i got same issue again.
          Thanks once again & have a nice day
            sita @andreas
            Hello @andreas ,
            I have now flashed the latest firmware (LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel.tar.gz). I got a new problem.When i try to upload my project, it gets struck while uploading the additional library files required. I attached the screenshot below.
            As far i understood, it is trying to compress the library files before uploading and it gets struck with that. I haven't observed this phenomenon with earlier firmware versions. Please have a look
            Thanks & Best regards,
            Have a nice weekend
              sita @andreas
              Hello all,
              I got an issue regarding uploading the project and connecting the port after updating new firmware LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel.tar.gz, the respective problem screenshots shown in the below.
              My doubt is, Is it related to new firmware update or any change in ATOM editor settings ??
              Could anyone please suggest me how to resolve this problem ?
              Safe booting device... (see settings for more info)
              Safe boot failed, uploading anyway.
              Upload failed: timeout. Please reboot your device manually.
              Connecting to COM12...
              Connection error: Error: timeout
              Thanks in advance & Have a nice day
                andreas @sita
                Dear @sita,
                sorry to hear that this didn't work out well. While I have to admit I haven't tested the firmware on a LoPy4 device, I just compiled it like any other Dragonfly builds I have done before.
                I haven't seen the error you are observing anytime before.
                So, to be better safe than sorry, downgrading to any other former release from [1] might help. If it doesn't you might want to downgrade to a regular release from Pycom using the regular firmware installer.
                Sorry for the hassle!
                With kind regards,
                Andreas.
                [1] https://packages.hiveeyes.org/hiveeyes/foss/pycom/vanilla/
                  sita @andreas
                  Hello @andreas ,
                  I have tested my devices all the versions in the [1] but in every version i observed the Guru meditation error. Is there any permanent solution for this problem ? It would be very helpful if i know exact reason behind issue ,if you know the reason could you please let me know..
                  Thanks in advance & have a nice day
                    andreas @sita
                    Dear @sita,
                    just a short question: Have you been able to run your MicroPython program successfully with LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel until the Guru Meditation error happened again? I am asking because it looked like you had other problems with this the other day.
                    With kind regards,
                    Andreas.
                      sita @andreas
                      Hello @andreas,
                      The other problems are still there, for temporarily i am running [1] in cmd so that error not coming.
                      [1]pycom-fwtool-cli.exe --verbose --port COM12 erase_all
                        andreas @sita
                        Thanks. So, to make sure we are on the same page...
                        • Invoking erase_all once before uploading a new firmware image is considered good practice. Thanks for letting me know.
                        • After that, you are able to invoke your MicroPython program using the LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel firmware?
                        • However, Guru Meditation errors still occur?
                        Now, are you able to submit another core dump when running this firmware build? I have saved a local copy of lopy4-0.8.0-vanilla-squirrel.elf on my workstation in order to decode core dumps produced by this build.
                          sita @andreas
                          @andreas Now i got an issue with the atom editor :( :(
                          i have updated the ATOM editor evening and now i it is not showing REPL console. I will check with this and send you the core dump (LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel).
                            peterp
                            @sita can you try again with 1.20.2.rc3
                            @pigamonte same advice to you, but in case it doesn't solve it for you, I suggest to open your own thread. Otherwise we end up mixing different issues. Just because it shows a Guru Meditation Error, doesn't necessarily mean the issues are related.
                              sita @peterp
                              Hello @peterp,
                              I have tried with new firmware version (1.20.2.rc3) but same error is coming again. I will open new thread to avoid mixing of different issues.
                              Thanks & Have a nice day
                                andreas @sita
                                Dear @sita,
                                Either with the original Pycom's 1.20.2.rc3 and/or with the corresponding/updated LoPy4-1.20.2.rc3-0.8.0-vanilla-squirrel.tar.gz, I will be happy to receive respective core dumps. I have now kept the definitive .elf files around for decoding the core dumps appropriately.
                                Thanks and with kind regards,
                                Andreas.
                                  sita @andreas
                                  Hello @andreas ,
                                  This is the core dump of the updated LoPy4-1.20.2.rc3-0.8.0-vanilla-squirrel.tar.gz
                                  Guru Meditation Error: Core  1 panic'ed (IllegalInstruction). Exception was unhandled.
                                  Memory dump at 0x4010abc8: 10180108 00000044 00000000
                                  Core 1 register dump:
                                  PC      : 0x4010abcf  PS      : 0x00060130  A0      : 0x801024b3  A1      : 0x3ffd8280
                                  A2      : 0x3ffc93fc  A3      : 0x00000000  A4      : 0x3f94ef00  A5      : 0xffffff30
                                  A6      : 0x3f9502b3  A7      : 0x00007e00  A8      : 0x40109f79  A9      : 0x3ffd8260
                                  A10     : 0x3f40eed0  A11     : 0x00000000  A12     : 0x3f94ef04  A13     : 0x3f94ef08
                                  A14     : 0x00000048  A15     : 0x400ff4ea  SAR     : 0x0000001e  EXCCAUSE: 0x00000000
                                  EXCVADDR: 0x00000000  LBEG    : 0x40094de0  LEND    : 0x40094dfc  LCOUNT  : 0xffffffff
                                  Backtrace: 0x4010abcf:0x3ffd8280 0x401024b0:0x3ffd8320 0x400fe7c1:0x3ffd8350 0x400fe7ee:0x3ffd8370 0x400e208d:0x3ffd8390 0x400e231d:0x3ffd8430 0x400e0d81:0x3ffd8450
                                  0DgAAAEAAAARAAAAbAEAAA==
                                  9EX8P8CB/T98hv0/
                                  AIH9PxCG/T/ztQIADEP8PwxD/D/0Rfw/BEP8Pw4AAAC4N/4/uDf+P/RF/D8AAAAA
                                  CwAAAIBW/T9NaWNyb1B5AAAAAAAAAAAAAQAAAHyG/T8AAAAAIAsGAAsAAAABAAAA
                                  +DT7P/yT/D8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                                  l4dAPwAAAAD4WwlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAA==
                                  oCMQgM+rEEAwAQYAsyQQgICC/T/8k/w/AAAAAADvlD8w////swKVPwB+AAB5nxBA
                                  YIL9P9DuQD8AAAAABO+UPwjvlD9IAAAA6vQPQB4AAAAAAAAAAAAAAOBNCUD8TQlA
                                  /////wTvlD8I75Q/gDYIQLRp+j8AAAAAAAAAAAEAAAD//z+zAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAATvlD8I75Q/SAAAAOr0D0DE5w+AIIP9P1CU/D9QlPw/
                                  kIP9PwMAAACzJBCAgIL9PwgAAABQ75Q/TO+UP0TvlD8AAAAAEwAAACsBAAAgAAAA
                                  5DYIQFsjDkDE5w+AIIP9P1CU/D9QlPw/TpoQgMyKCUAIAAAARO+UPwAAAAATAAAA
                                  AAAAAPDulD9Q75Q/TO+UPwAAAAAAAAAAAAAAAAAAAAAE75Q/MP////cDlT8CAAAA
                                  8ecPgFCD/T9g7ZQ/AAAAAAAAAAAAAAAAAwAAACMABgDw7pQ/AAAAAEwAAAAgg/0/
                                  kCAOgHCD/T9g7ZQ/AAAAAAAAAAAAAAAAAQAAAAAAAAAgIw6AkIP9P2DtlD8gAAAA
                                  AAAAAAAAAAAAAAAAKPCUP4QNDoAwhP0/pu2UP2YDAAAAAAAAAAAAACAjDoCQg/0/
                                  DE/8PwAAAAAgAAAAEDNBPwgzQT8IAAAAsg0OgCCE/T+PM0E/ZgMAAIQNDoAwhP0/
                                  pu2UP2YDAAAMIA6AvACVP6D+lD8BAAAAZ0FJTgAIAAAIAAAAcDNBP3juAAABAAAA
                                  IAAAAKbtlD/D7gAAAQAAACAAAAAQM0E/CDNBPwgAAAAAAAAAUIT9PwYWAAABAAAA
                                  mDH+PwAAAAABAAAAAAAAAAAAAAAQhv0/AAAAAAAAAAABAAAApaWlpaWlpaWlpaWl
                                  AAAAAAAAAaXoAAAA6QAAAAEAAAAABAAA+P8f0AAAAAD//////////6WlpaWlpaWl
                                  AQAIAAAAAAClpaWlpaWlpaWlpaWlpaWlpaWlpQAAAADIXEA/paWlpaWlpaWlpaWl
                                  paWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWl
                                  5DYIQPQIDkAwAAUAAAAAABCG/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAAAAACQmxkA
                                  AAAAAP/////////////////////7O9mUAAAAAAAAAAAAAAAAAPAfAFCE/T8AAAAA
                                  AAAoAAAAAAAAAAAAAAAAAM0XQD+sR/w/AAAAAFUXQD8AAAAAAAAAAAAAAAAAAAAA
                                  AQAAAAAAAAAchv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAA
                                  ZP39P6Ak/T+UJv0/
                                  oCT9PzAm/T/ztQIAqEL8P6hC/D9k/f0/oEL8PxMAAAB8/f0/AAAAAGT9/T8AAAAA
                                  BgAAAJgW/T9Mb1JhAAAAAAAAAAAAUFkAAQAAAJQm/T8AAAAAIQAGAAYAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAP79Pw==
                                  5DYIQE53CUAwCwYAjDMRgGAl/T/ztQIAQN37Pxgh/j8AAAAAAAAAAAAAAABOdwmA
                                  QCX9PwEAAADztQIAZP39PwEAAAD+AAAAEAAAAA4AAACLAAYAq6sAAE4+CUBZPglA
                                  AAAAAOQ4CEABAAAAzIoJQNQJ+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAIBB/D8BAAAA/gAAAAEAAAAAAAAAgCX9P8SZ/D9Ymvw/
                                  3GL7P/////8AAAACzGL7PwAAAAAwJv0/AAAAAAAAAAAIAAAAAAAAAAAAAAABAAAA
                                  AAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAAAAAAMyKCUDUCfo/AAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAABKFhQoAAAAAAAAAAAAAAADMNkE/eAT8P1ia/D+V////
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPCb9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAA=
                                  HLP7PyCx/T+Isv0/
                                  ILH9PyCy/T/ztQIAlEL8P5RC/D8cs/s/jEL8PxQAAAAwOv4/MDr+Pxyz+z8AAAAA
                                  BQAAAIyi/T9TZXJ2ZXJzAAAAAAAAAAAAAQAAAIiy/T8AAAAAIQAGAAUAAAAAAAAA
                                  9H/7PwAAAAAAAAAAAAAAAAsAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
                                  5DYIQE53CUAwCwYAyA4OgOCx/T/ztQIAQN37PwsAAAAA/wAAAAD/AAAAAP9OdwmA
                                  wLH9PwEAAADztQIAHLP7PwEAAAD+AAAAIwAGAAAAAADEVg+AoLH9P+BNCUD8TQlA
                                  /////+Q4CEABAAAAzIoJQMSV+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAsv0/MPj7PwAAAAAAAAAAALL9PwAAAAAAAAAA
                                  AgAAAAD/AAAAAP8AAAAA/wAAAAAgsv0/AAAAAAAAAAAAAAAAAQAAAGpK/D8AAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALLL9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  QLn7P6C3+z84ufs/
                                  oLf7P9C4+z9Tlb0vvL77PzBC/D9Aufs/KEL8PxkAAAC8SVUVuUNvUUC5+z8AAAAA
                                  AAAAADy1+z9JRExFMABG0Bmj0zv92E4AAAAAADi5+z8AAAAAIwAGAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEXqHw==
                                  5DYIQLZoIUAwDwYAdmgXgGC4+z8AAAAAAAAAAAAAAACQt/s/AwAAACMABgD4kfw/
                                  AAAAAPyxAgAAAAAAAAAAAAkAAAAAgAAA//8AgAoAAACguPs/AAAAANDYDkAT2Q5A
                                  AAAAAOQ4CEAJAAAAzIoJQHSc+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAPPr8P8yKCUAseQmAgLj7PyAAAAABAAAA
                                  //8/swAAAAAAAAAAAAAAAAAAAACguPs/AAAAALhB/D8AAAAAPPr8PxxE/D8AAAAA
                                  AAAAANC4+z8AAAAAAAAAAEDd+z8AAAAAAAAAAAAAAAAAAAAAAQAAAAQAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3Lj7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  tL77PxC9+z+svvs/
                                  EL37P0C++z/MtOISMEL8P0i5+z+0vvs/KEL8PxkAAACFM0nahGdmZbS++z8AAAAA
                                  AAAAALC6+z9JRExFMQDLX/9qno4QORUAAQAAAKy++z8AAAAAIwAGAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAI8mOg==
                                  5DYIQLZoIUAwCQYAdmgXgNC9+z8AAAAAMEL8P4XGAgCoBfw/K6oCACMABgAjAAYA
                                  /////5BB/D8wQvw/6M8CAKgF/D81rwIAIwAGAAAAAADQvfs/AAAAAAAAAAAAAAAA
                                  AAAAAOQ4CECoBfw/zIoJQOSh+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAseQmA8L37PyAAAAABAAAA
                                  //8/swAAAAAAAAAAAAAAAAAAAAAQvvs/AAAAALhB/D8gAAAAPPr8PyBE/D8AAAAA
                                  AAAAAEC++z8AAAAAAAAAAEDd+z8AAAAAAAAAAAAAAAABAAAAAQAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAATL77PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  tJ/7P9Ct+z/Er/s/
                                  0K37P2Cv+z8xtgIAHEL8PxxC/T+0n/s/FEL8PwcAAAAIn/s/CJ/7P7Sf+z8An/s/
                                  EgAAAMih+z90aVQAcEH8P7x9+z/EffsAAAAAAMSv+z8AAAAAIQAGABIAAAAAAAAA
                                  5DYIQLBmCUAwDwYAaf8YgJCu+z/cnvs/MK/7Pyif+z8AAAAAMJ/7PwAAAACwZgmA
                                  cK77PwAAAABiAAAAQN37PxxE/D/+AAAAAAAAABAAAAABAAAA/gAAAPHrGED66xhA
                                  AAAAAOQ4CEAcRPw/zIoJQAST+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAEQ2GICgrvs/cAtCP6Cu+z//NxiA0K77P/////8wr/s/
                                  AAAAAM+1AgBkAAAAUDcYQGIAAACQrvs//gAAAAAAAABIOBiA4K77P7wMQj+YAJQ/
                                  rwEYgACv+z88+/w/MK/7P68BGIAAr/s/PPv8PzCv+z9iAAAA/////8+1AgAAAAAA
                                  AAAAADCv+z88ZxhAAAAAAFA3GEC8DEI/PGcYQAAAAACo//w/qP/8P6T//D+k//w/
                                  AAAAAGCv+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAbK/7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  FEL9PwBA/T8MQv0/
                                  AED9P6BB/T/0tQIAvJ/7PxxC/D8UQv0/FEL8PxMAAAAAAAAAAAAAABRC/T8AAAAA
                                  BgAAABA0/T9TaWdmb3gAQLDKH0AwAAUAAAAAAAxC/T8AAAAAIQAGAAYAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKWlpQ==
                                  5DYIQE53CUAwAQYAysofgMBA/T/0tQIAQN37PyD//T8AAAAAAAAAAAAAAABOdwmA
                                  oED9PwAAAAD0tQIAFEL9PwEAAAD+AAAAIwAGABEAAABEJfo/AAAAAAAAAAAAAAAA
                                  AAAAAOQ4CEABAAAAzIoJQEQl+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAA4ED9P9gU/T/UFP0/
                                  IP/9PwAAAAAAAAAAAAAAAAAAAACgQf0/AAAAAAAAAADkNghAsMofQDAABQAAAAAA
                                  oEH9PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  RCX6PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  FwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKxB/T8AAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
                                  IMv7P8DJ+z8Yy/s/
                                  wMn7P7DK+z8AAAAACEL8PwhC/D8gy/s/AEL8Pw8AAABQwPs/UMD7PyDL+z9IwPs/
                                  CgAAABzB+z9UbXIgU3ZjAA5cTdTiH3QAAAAAABjL+z8AAAAAIQAGAAoAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMCU9g==
                                  5DYIQGGICUAwAAYAAAAAAIDK+z8AAAAAAAAAAAAAAAAsRPw/JET8PwEAAABhiAmA
                                  YMr7PwAAAABA3fs/gEH8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  AAAAAOQ4CEAAAAAAzIoJQFSu+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAFSu+D8AAAAAAAAAAAAAAAAAAAAAsMr7PwAAAAAAAAAA
                                  AAAAAAAAAAC8yvs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAA=
                                  7MP9P1DC/T/kw/0/
                                  UML9P4DD/T/JRKlVCMr9P7Sx+z/sw/0/pEH8PxQAAABziUhuF1Dt2OzD/T8AAAAA
                                  BQAAAOiz/T9Tb2NrZXQgT3BlcmF0aW8AAQAAAOTD/T8AAAAAIQAGAAUAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAACNJw==
                                  5DYIQPC/AEAwAAYAWnIJgBDD/T8AAAAAIwAGACAABgDQg/0/VQAAAPCh/T///z+z
                                  q6sAAOzc+z8jAAYA7MP9PwEAAAD+AAAAAAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                                  AAAAAOQ4CEABAAAAzIoJQCSn+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACigwmAIMP9P0Dd+z8GAAAA
                                  3moOgEDD/T8BAAAAIET8P+zD/T8BAAAA/gAAALCd+z8AAAAAYMP9PwAAAAAAAAAA
                                  HET8P0Dd+z+QQfw/lEL8PwAAAACAw/0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjMP9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  AMr9P1Dp/T9s6/0/
                                  UOn9PwDr/T8Ayv0/OHz7P/TD/T8Ayv0/pEH8Pw4AAAC8sv0/vLL9PwDK/T+0sv0/
                                  CwAAAHDL/T9JUlFzAAAAAAAAAAAASYIAAQAAAGzr/T8AAAAAIQAGAAsAAAAAAAAA
                                  AAAAAJzq/T8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApv6CQ==
                                  5DYIQLBmCUAwBQYASEsPgBDq/T+Qsv0/sOr9P9yy/T8AAAAA5LL9PwAAAACwZgmA
                                  8On9PwEAAAD/////QN37PxxE/D/+AAAAAAAAAAAAAABQ6v0/sJX8PwAAAAAAAAAA
                                  AAAAAOQ4CEAcRPw/zIoJQKTO+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAAQAAAMyKCUB8FA6AUOr9P4CS/D+w6v0/
                                  AAAAAFQAAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAAAAAAAAAQAAAHSS/D8wAPw/
                                  AAAAAODq/T90kvw/AAAAAADr/T8AAAAAAAAAAAAAAAAAAAAAdJL8PwAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACw6v0/
                                  ABwAAFCU/D9QlPw/AAAAAKTO+j8AAAAAAAAAAAAAAABQlPw/CgAAAJBB/D8MQ/w/
                                  AAAAAADr/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAM6/0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAA
                                  MHz7P7Cc+z84nvs/
                                  sJz7P9Cd+z8sCBnhmNn7PwjK/T8wfPs/pEH8PwEAAAAEfPs/BHz7PzB8+z/8e/s/
                                  GAAAADya+z9pcGMxAH0Q8VnobXH5p5QAAQAAADie+z8AAAAAIQAGABgAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKE5jA==
                                  5DYIQLBmCUAwBwYAlDQIgHCd+z/Ye/s/AAAAACR8+z8AAAAA2Hv7PwAAAACwZgmA
                                  UJ37PwEAAAD/////QN37PxxE/D/+AAAAIAMGABwAAAD//z+zAAAAAAAAAAAAAAAA
                                  AAAAAOQ4CEAcRPw/zIoJQHSB+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAADB8+z8BAAAA/gAAACMABgAAAAAAsJ37PzhB/D8AAAAA
                                  AAAAAGQEAAD+AAAAIAMGAP////8AAAAAOEH8PyRB/D8Advs/AAAAAAEAAAAAAAAA
                                  AAAAANCd+z8AAAAAAAAAALh+CEABAAAAAAAAAAAAAAB9FAiAgH3+PwABAADoDQBA
                                  AAAAAAAAAADcnfs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAA=
                                  kNn7P9CQ/T+Akv0/
                                  0JD9PyCS/T8L+VfXqDL9Pzh8+z+Q2fs/pEH8PwUAAABk0/s/ZNP7P5DZ+z9c0/s/
                                  FAAAAISG/T9ldmVudFRhc2sADM8yC4kAAAAAAICS/T8AAAAAIQAGABQAAAAAAAAA
                                  KDX7PwAAAAAAAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHiJeQ==
                                  5DYIQLBmCUAwAgYALGkXgJCR/T840/s/0JH9P4TT+z8AAAAAjNP7PwAAAACwZgmA
                                  cJH9PwAAAAD/////QN37PxxE/D/+AAAAIAAGAAAAAABwkf0/fJH9P+BNCUD8TQlA
                                  /////+Q4CEAcRPw/zIoJQMR1+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAMCoBAH///8AwKgEATxxv4cAAAAA0JH9P4z6/D8AAAAA
                                  AAAAAL0EAAD+AAAAIAAGAP/////Qkf0/jPr8PwAAAACE0/s/AAAAAFzZ+z8BAAAA
                                  AAAAACCS/T8AAAAAAAAAAA4AAAACAAAAfML8PwEAAAAIBvw//gAAAAEAAAAbchOA
                                  8EH7PwAAAAAAAAAAcQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAskv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  oDL9P9Aw/T+YMv0/
                                  0DD9PzAy/T8AAAAAcHr7P5jZ+z+gMv0/pEH8PxEAAAB4Yvs/eGL7P6Ay/T9wYvs/
                                  CAAAAJwm/T9Mb1JhX1RpbWVyX2NhbGwAAQAAAJgy/T8AAAAAIQAGAAgAAAAAAAAA
                                  5DYIQPC/AEAwAAYAWnIJgJAx/T8AAAAAIwAGACAABgABAAAA/gAAAAAAQAD//z+z
                                  q6sAAEDd+z//////IAoGAIDslD8AAP8AAAAA/wAAAAClpaWlpaWlpQAAAAAAAAAA
                                  AAAAAOQ4CECA7JQ/zIoJQNQV+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAP////+nZgmAoDH9P5hi+z//////
                                  mB4RgMAx/T9MYvs/ADL9P0Dd+z8cRPw//gAAACMABgAAAAAAADL9P4Cb/D8AAAAA
                                  AAAAAIAIAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAACYYvs/AAAAAKBi+z8AAAAA
                                  AAAAADAy/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPDL9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  aHr7P+B4+z9gevs/
                                  4Hj7PwB6+z+HrjGXTEP7P6gy/T9oevs/pEH8PwEAAAA4dvs/OHb7P2h6+z8wdvs/
                                  GAAAAGR2+z9pcGMwAPHSUYYL2UPLt7EAAAAAAGB6+z8AAAAAIQAGABgAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANj60g==
                                  5DYIQLBmCUAwBwYAlDQIgKB5+z8Mdvs/AAAAAFh2+z8AAAAADHb7PwAAAACwZgmA
                                  gHn7PwAAAAD/////QN37PxxE/D/+AAAAUQYAAAAAAAAAAAAAAQAAAAAAAAAAAAAA
                                  AAAAAOQ4CEAcRPw/zIoJQKRd+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAA4Hn7PzRB/D8AAAAA
                                  AAAAADQKAAD+AAAAUQYAAP/////gefs/NEH8PyRB/D8Advs/AAAAAAEAAAAAAAAA
                                  AAAAAAB6+z8AAAAAAAAAALh+CEAAAAAAAAAAAAAAAADpEwiAIDz+P4xB/D+PaUA/
                                  AAAAAAAAAAAMevs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  REP7P3BB+z88Q/s/
                                  cEH7P9BC+z8TIhymhHL7P3B6+z9EQ/s/pEH8PwIAAAB8Lvs/fC77P0RD+z90Lvs/
                                  FwAAAEA1+z93aWZpAL6bfa7+shKU8Z4AAAAAADxD+z8AAAAAIQAGABcAAAABAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANPm3Q==
                                  5DYIQLBmCUAwCQYArVwXgDBC+z9QLvs/oEL7P5wu+z8AAAAApC77PwAAAACwZgmA
                                  EEL7PwAAAAD/////QN37PxxE/D/+AAAAAAAAAB4AAAD1NBSAUEL7P+BNCUD8TQlA
                                  /////+Q4CEAcRPw/zIoJQHQm+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAB41/w/GwAAAAAAAAAZeRWAcEL7P1Au+z+gQvs/
                                  AAAAAPK1AgAAAAAAUPr9P/////9wQvs/AAAAABT6/T8JAAAA4Aj8P6AI/D8BAAAA
                                  AAAAAJBC+z/YBfw/dAv8P/////+AAAAAxAAAAHAL/D8AAAAA0EL7PwAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAaOb8PxoAAABoCPw/
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3EL7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  fHL7P+Bw+z90cvs/
                                  4HD7PxBy+z+XlaRrrEH8P0xD+z98cvs/pEH8PwMAAABwQPw/cED8P3xy+z9oQPw/
                                  FgAAAHhm+z9lc3BfdGltZXIA30u6hkQAAAAAAHRy+z8AAAAAIQAGABYAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJcfvg==
                                  5DYIQLBmCUAwAQYA/SwNgKBx+z9EQPw/AAAAAJBA/D8AAAAARED8PwAAAACwZgmA
                                  gHH7PwAAAAD/////QN37PxxE/D/+AAAA/T4CAAAAAAAKAAAAAAAAAOBNCUD8TQlA
                                  /////+Q4CEAcRPw/zIoJQLRV+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAKEaCICgcfs//Nz7P/9zq34AAAAA4HH7P5hA/D+gQPw/
                                  AAAAAPO1AgBQLvs//T4CAP/////gcfs/AAAAAKBA/D/YBfw/AAAAACRw9D8AAAAA
                                  AAAAABBy+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKBA/D/L5pYK
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHL7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  rLH7P/Cg/T+Eov0/
                                  8KD9PyCi/T/gAAAA9MP9P6xB/D+ssfs/pEH8PxQAAAD8TQlAAAAAAKyx+z8AAAAA
                                  BQAAAIiS/T9TbWFydENvbmZpZwD//z8AAQAAAISi/T8AAAAAIQAGAAUAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAAAAA==
                                  5DYIQPC/AEAwAAYAWnIJgLCh/T8AAAAAIwAGACAABgAAnfs/AwAAACMDBgD//z+z
                                  q6sAAOzc+z8jAAYArLH7PwEAAAD+AAAAmAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                                  AAAAAOQ4CEABAAAAzIoJQMSF+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACigwmAwKH9P0Dd+z8FAAAA
                                  B3oOgOCh/T8BAAAAIET8P6yx+z8BAAAA/gAAACADBgAAAAAAAKL9PwAAAAAAAAAA
                                  HET8P0Dd+z+QQfw/lEL8PwAAAAAgov0/AAAAAAAAAABET/w/AAAAAAAAAAAAAAAA
                                  AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALKL9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                  Rebooting...
                                  ets Jun  8 2016 00:22:57
                                  rst:0xc (SW_CPU_RESET),boot:0x16 (SPI_FAST_FLASH_BOOT)
                                  configsip: 0, SPIWP:0xee
                                  mode:DIO, clock div:1
                                  load:0x3fff8020,len:8
                                  load:0x3fff8028,len:2176
                                  load:0x4009fa00,len:19740
                                  entry 0x400a05bc
                                    andreas @sita
                                    Thanks! Decoding this yields
                                    ==================== CURRENT THREAD STACK =====================
                                    #0  mp_execute_bytecode (code_state=0x3f94eef0, inject_exc=0x0) at ../py/vm.c:1306
                                    #1  0x401024b3 in fun_bc_call (self_in=<optimized out>, n_args=<optimized out>, n_kw=0, args=0x3ffd8280) at ../py/objfun.c:287
                                    #2  0x400fe7c4 in mp_call_function_n_kw (fun_in=0x3f94ed60, n_args=0, n_kw=0, args=0x0) at ../py/runtime.c:624
                                    #3  0x400fe7f1 in mp_call_function_0 (fun=0x3f94ed60) at ../py/runtime.c:598
                                    #4  0x400e2090 in parse_compile_execute (source=0x3f94eda6, input_kind=MP_PARSE_FILE_INPUT, exec_flags=32) at ../lib/utils/pyexec.c:103
                                    #5  0x400e2320 in pyexec_file (filename=0x3f94eda6 <error: Cannot access memory at address 0x3f94eda6>) at ../lib/utils/pyexec.c:550
                                    #6  0x400e0d84 in TASK_Micropython (pvParameters=<optimized out>) at mptask.c:320
                                    ======================== THREADS INFO =========================
                                      Id   Target Id         Frame
                                      17   process 16        0x4000bff0 in ?? ()
                                      16   process 15        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffc4044 <s_timer_semaphore_memory>, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                                      15   process 14        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffb2e50, pvBuffer=0x3ffb42a0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                                      14   process 13        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffb760c, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                                      13   process 12        0x4000bff0 in ?? ()
                                      12   process 11        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffbd338, pvBuffer=0x3ffd91d0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                                      11   process 10        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffb7bd8, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                                      10   process 9         0x400966b0 in xQueueGenericReceive (xQueue=0x3ffdb290, pvBuffer=0x3ffdeab0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                                      9    process 8         0x4000bff0 in ?? ()
                                      8    process 7         /builds/idf/crosstool-NG/.build/src/gdb-7.10/gdb/inline-frame.c:171: internal-error: inline_frame_this_id: Assertion `!frame_id_eq (*this_id, outer_frame_id)' failed.
                                    So, the core dump seems to happen right away after system start while executing the Python file
                                    I have never seen that before! The file might be corrupted somehow.
                                    • Is this the core dump which is happening immediately after uploading the MicroPython file to the system?
                                    • Can you get another core dump which is coming from the system after a short run time i.e. after hitting the reset button?
                                    • Can you show your current MicroPython code again?
                                    • You might also want to try yet another erase_all [1] / erase_flash procedure first.
                                    [1] Please don't miss the corresponding installation notes when invoking erase_all on LoPy devices.
                                    A S 2 Replies Last reply Reply Quote 0
                                      andreas @andreas
                                      @andreas said in Guru Meditation Error:
                                      Regarding the MicroPython code, I would suggest trying to invoke your program without any interaction on the filesystem and see whether it still crashes.
                                        sita @andreas
                                        Hello @andreas,
                                        I have attached the core dump which is observed after a short run.
                                        Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
                                        PC      : 0x40098fbb  PS      : 0x00060033  A0      : 0x80097e99  A1      : 0x3ffbf0c0
                                        A2      : 0x3ffbb95c  A3      : 0x00060023  A4      : 0x3ffc45f4  A5      : 0x00000001
                                        A6      : 0x000000fe  A7      : 0x3f95038a  A8      : 0x00000000  A9      : 0x3ffbb95c
                                        A10     : 0x3ffbb95c  A11     : 0x00000000  A12     : 0x8010a802  A13     : 0x3ffd8260
                                        A14     : 0x00000001  A15     : 0x00000000  SAR     : 0x00000003  EXCCAUSE: 0x0000001c
                                        EXCVADDR: 0x00000004  LBEG    : 0x400ed8d0  LEND    : 0x400ed913  LCOUNT  : 0x00000000
                                        Core 1 was running in ISR context:
                                        EPC1    : 0x40098fbb  EPC2    : 0x00000000  EPC3    : 0x00000000  EPC4    : 0x00000000
                                        Backtrace: 0x40098fbb:0x3ffbf0c0 0x40097e96:0x3ffbf0e0 0x4009656d:0x3ffbf100 0x400890bb:0x3ffbf120 0x40083949:0x3ffbf160 0x400e7009:0x3ffd81f0 0x401023ba:0x3ffd8220 0x400fe7c1:0x3ffd8240 0x400fe851:0x3ffd8260 0x4010a7ff:0x3ffd8280 0x401024b0:0x3ffd8320 0x400fe7c1:0x3ffd8350 0x400fe7ee:0x3ffd8370 0x400e208d:0x3ffd8390 0x400e231d:0x3ffd8430 0x400e0d81:0x3ffd8450
                                        pDQAAAEAAAAQAAAAbAEAAA==
                                        ZP39P6Ak/T+UJv0/
                                        oCT9PzAm/T/I5AEAqEL8P6hC/D9k/f0/oEL8PxMAAAB8/f0/AAAAAGT9/T8AAAAA
                                        BgAAAJgW/T9Mb1JhAAAAAAQAAAAAUFkAAQAAAJQm/T8AAAAAIQAGAAYAAAAAAAAA
                                        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADD+Pw==
                                        5DYIQE53CUAwDQYAjDMRgGAl/T/I5AEAQN37Pxgh/j8AAAAAAAAAAAAAAABOdwmA
                                        QCX9PwEAAADI5AEAZP39PwEAAAD+AAAAEAAAAA4AAADUCfo/AAAAAE4+CUBZPglA
                                        GCH+PwAAAAAAAAAAAAAAAAAAAAAwJv0/AAAAAAAAAAAIAAAAAAAAAAAAAAABAAAA
                                        AAAAAAAAAAAAAAAAAAAAAKUNQgcAAAAAAAAAAAAAAADMNkE/eAT8P1ia/D+W////
                                        HLP7PyCx/T+Isv0/
                                        ILH9PyCy/T/I5AEAlEL8P5RC/D8cs/s/jEL8PxQAAAAwOv4/MDr+Pxyz+z8AAAAA
                                        5DYIQE53CUAwDQYAyA4OgOCx/T/I5AEAQN37PwsAAAAA/wAAAAD/AAAAAP9OdwmA
                                        wLH9PwEAAADI5AEAHLP7PwEAAAD+AAAAIwAGAAAAAADEVg+AoLH9P+BNCUD8TQlA
                                        QLn7PxC3+z84ufs/
                                        ELf7P9C4+z9RFb1vvL77PzBC/D9Aufs/KEL8PxkAAABcufs/XLn7P0C5+z8AAAAA
                                        AAAAADy1+z9JRExFMABWwAmj07v92E4AAAAAADi5+z8AAAAAIAcGAAAAAAAAAAAA
                                        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEX5Fw==
                                        5DYIQLBmCUAwDwYApBQXgNC3+z/ktPs/AAAAADC1+z8AAAAA5LT7PwEAAACwZgmA
                                        sLf7PwAAAAD/////QN37PxxE/D/+AAAAqQ28PwoAAADkNghAsl4hQNDYDkAT2Q5A
                                        AAAAAOQ4CEAcRPw/zIoJQHSc+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                        AAAAAAAAAAAAAAAAAAAAAGC4+z8AAAAAAAAAAAAAAAAl2Q6AELj7PwEAAABAAAAA
                                        AAAAAAPlAQAAAAAAAAAAAP////8AgAAA//8AgAoAAACguPs/AAAAANDYDkAT2Q5A
                                        WEgPgEC4+z8AAAAAAQAAAHSc+D8Qkvw/AAAAAAAAAAAYAAAAAAAAAHTr/T8BAAAA
                                        ZGgXgGC4+z/4kfw/AQAAAAAAAAAJAAAAAIAAAP//AIAseQmAgLj7PwAAAAABAAAA
                                        AAAAALA//T8DAAAAIwAGAAAAAACguPs/AAAAALhB/D8AAAAAPPr8PxxE/D8AAAAA
                                        tL77PxC9+z+svvs/
                                        EL37P0C++z/MkOIQMEL8P0i5+z+0vvs/KEL8PxkAAACNMdnalEdm5bS++z8AAAAA
                                        AAAAALC6+z9JRExFMQDrX/9+n4oQORUAAQAAAKy++z8AAAAAIwAGAAAAAAAAAAAA
                                        5DYIQLZoIUAwCwYAdmgXgNC9+z8AAAAAMEL8PwtqCYDQsP0/AwAAACMABgAjAAYA
                                        gLH9P+zc+z8gDwYA//8/s6urAAD+AAAAAAAAAAAAAAAQvvs/AAAAAAAAAAAAAAAA
                                        AAAAAOQ4CECrqwAAzIoJQOSh+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                        AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAPPr8P8yKCUAseQmA8L37PyAAAAABAAAA
                                        tJ/7P9Ct+z/Er/s/
                                        0K37P2Cv+z805QEAHEL8PxxC/T+0n/s/FEL8PwcAAAAIn/s/CJ/7P7Sf+z8An/s/
                                        cK77PwAAAABgAAAAQN37PxxE/D/+AAAAAAAAABAAAADkNghANDYYQPHrGED66xhA
                                        AAAAANTkAQBkAAAAUDcYQGAAAACQrvs//gAAAAAAAABIOBiA4K77P7wMQj+YAJQ/
                                        rwEYgACv+z88+/w/MK/7P68BGIAAr/s/PPv8PzCv+z9gAAAA/////9TkAQAAAAAA
                                        FEL9PwBA/T8MQv0/
                                        AED9P6BB/T8E5QEAvJ/7PxxC/D8UQv0/FEL8PxMAAAAFAAAAkEH8PxRC/T8AAAAA
                                        5DYIQE53CUAwAQYAysofgMBA/T8E5QEAQN37PyD//T8AAAAAAAAAAAAAAABOdwmA
                                        oED9PwAAAAAE5QEAFEL9PwEAAAD+AAAAIwAGABEAAABEJfo/AAAAAAAAAAAAAAAA
                                        IMv7P8DJ+z8Yy/s/
                                        CgAAABzB+z9UbXIgU3ZjAA4cTdTiG3QAAAAAABjL+z8AAAAAIQAGAAoAAAAAAAAA
                                        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMCU8g==
                                        AAAAAAAAAAA=
                                        7MP9P1DC/T/kw/0/
                                        UML9P4DD/T/LQKlVCMr9P7Sx+z/sw/0/pEH8PxQAAABRiUhuVnTv3ezD/T8AAAAA
                                        AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAACBBw==
                                        5DYIQPC/AEAwAAYAWnIJgBDD/T8AAAAAIwAGACAABgCYzfs/VQAAAPCh/T///z+z
                                        3moOgEDD/T8BAAAAIET8P+zD/T8BAAAA/gAAAICD/T8AAAAAYMP9PwAAAAAAAAAA
                                        AMr9P1Dp/T9s6/0/
                                        CwAAAHDL/T9JUlFzAAAAAAAAAAAASa4AAQAAAGzr/T8AAAAAIQAGAAsAAAAAAAAA
                                        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAArv6CA==
                                        8On9PwEAAAD/////QN37PxxE/D/+AAAAAAAAAAAAAACkzvo/AAAAAAAAAAAAAAAA
                                        AAAAAAAAAAAAAAAAAAAAAAAAAAAyAAAApaWlpaWlpaV8FA6AUOr9P4CS/D+w6v0/
                                        AAAAAFQAAAClpaWlpaWlpf////9Q6v0/sJX8P7Dq/T8AAAAAAQAAAHSS/D8wAPw/
                                        AAAAAAAAAAAAAAAA
                                        MHz7P7Cc+z84nvs/
                                        sJz7P9Cd+z8sSBnimNn7PwjK/T8wfPs/pEH8PwEAAAAEfPs/BHz7PzB8+z/8e/s/
                                        GAAAADya+z9pcGMxAH1w+UnobXH5p5QAAQAAADie+z8AAAAAIQAGABgAAAAAAAAA
                                        5DYIQLBmCUAwBQYAlDQIgHCd+z/Ye/s/AAAAACR8+z8AAAAA2Hv7PwAAAACwZgmA
                                        UJ37PwEAAAD/////QN37PxxE/D/+AAAAIwAGABwAAACwnfs/OEH8PwAAAAAAAAAA
                                        AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAAAAAAMyKCUAAAAAAsJ37PzhB/D8AAAAA
                                        AAAAAGQEAAAAAAAAAAAAAP////8AAAAAOEH8PyRB/D8Advs/AAAAAAEAAAAAAAAA
                                        AAAAAAAAAAA=
                                        kNn7P9CQ/T+Akv0/
                                        0JD9PyCS/T9w2fs/qDL9Pzh8+z+Q2fs/pEH8PwUAAABk0/s/ZNP7P5DZ+z9c0/s/
                                        FAAAAISG/T9ldmVudFRhc2sA+z8AAAAAAAAAAICS/T8AAAAAIQAGABQAAAAAAAAA
                                        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHjBWQ==
                                        AAAAALwEAAD+AAAAIAAGAP/////Qkf0/jPr8PwAAAACE0/s/AAAAAFzZ+z8BAAAA
                                        AAAAACCS/T8AAAAAAAAAAA4AAADAQfs/AQEAAHzB/D8GAAAAogm8P///AABQBgAA
                                        KHNBPzwAAAACAAAAGMf8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                        oDL9P9Aw/T+YMv0/
                                        0DD9PzAy/T8AEAAAcHr7P5jZ+z+gMv0/pEH8PxEAAAB4Yvs/eGL7P6Ay/T9wYvs/
                                        5DYIQPC/AEAwAAYAWnIJgJAx/T8AAAAAIwAGACAABgABAAAA/gAAACMABgD//z+z
                                        q6sAAEDd+z////////8/s6urAAD+AAAAAABAAAAAAAAAAAAAkEH8PwAAAAAAAAAA
                                        AAAAAOQ4CECrqwAAzIoJQNQV+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                        AAAAAAAAAAAAAAAAAAAAANQV+j8AAAAAAAAAAAAAAACnZgmAoDH9P5hi+z//////
                                        AAAAAL8GAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAACYYvs/AAAAAKBi+z8AAAAA
                                        aHr7P+B4+z9gevs/
                                        4Hj7PwB6+z+XrzCfTEP7P6gy/T9oevs/pEH8PwEAAAA4dvs/OHb7P2h6+z8wdvs/
                                        GAAAAGR2+z9pcGMwAPHWUYaKWUfbt7EAAAAAAGB6+z8AAAAAIQAGABgAAAAAAAAA
                                        5DYIQLBmCUAwAQYAlDQIgKB5+z8Mdvs/AAAAAFh2+z8AAAAADHb7PwAAAACwZgmA
                                        gHn7PwAAAAD/////QN37PxxE/D/+AAAAHEL9PwAAAAAAAAAAAQAAAAAAAAAAAAAA
                                        AAAAADAKAAD+AAAAHEL9P//////gefs/NEH8PyRB/D8Advs/AAAAAAEAAAAAAAAA
                                        REP7P3BB+z88Q/s/
                                        cEH7P9BC+z8BIhymhHL7P3B6+z9EQ/s/pEH8PwIAAAB8Lvs/fC77P0RD+z90Lvs/
                                        FwAAAEA1+z93aWZpADqbfer+shKU8Z4AAAAAADxD+z8AAAAAIQAGABcAAAABAAAA
                                        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANPmnQ==
                                        EEL7PwAAAAD/////QN37PxxE/D/+AAAAAAAAABwAAAD1NBSAUEL7P+BNCUD8TQlA
                                        AAAAAAAAAAAAAAAAAAAAAN9SFYBAQvs/AAAAAOiVCEAZeRWAcEL7P1Au+z+gQvs/
                                        AAAAAPPkAQDwIgzAACAMAP////9wQvs/uL4AQAAAAABEQ/s/4Av8P+AL/D8BAAAA
                                        AAAAAJBC+z/YBfw/dAv8P/////8AAAAAxAAAAHAL/D8AAAAA0EL7PwAAAAAAAAAA
                                        AAAAAAAAAAAAAAAAAAAAAAsAAACUDbw/AAAAAAAAAAAAAAAAaOb8PxoAAABoCPw/
                                        fHL7P+Bw+z90cvs/
                                        4HD7PxBy+z8HlaRrrEH8P0xD+z98cvs/pEH8PwMAAABwQPw/cED8P3xy+z9oQPw/
                                        FgAAAHhm+z9lc3BfdGltZXIA30u4hkQAAAAAAHRy+z8AAAAAIQAGABYAAAAAAAAA
                                        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJZbvA==
                                        gHH7PwAAAAD/////QN37PxxE/D/+AAAAJLP7PwAAAAAKAAAAAAAAAOBNCUD8TQlA
                                        AAAAAAAAAAAAAAAAAAAAAEDd+z8cRPw//gAAACSz+z8AAAAA4HH7P5hA/D+gQPw/
                                        AAAAAPPkAQBQLvs/JLP7P//////gcfs/AAAAAKBA/D8AAAAAAAAAACRw9D8AAAAA
                                        AAAAABBy+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKBA/D/6gGYH
                                        rLH7P/Cg/T+Eov0/
                                        8KD9PyCi/T/Gxsjt9MP9P6xB/D+ssfs/pEH8PxQAAAD7mJIwA0gB/6yx+z8AAAAA
                                        BQAAAIiS/T9TbWFydENvbmZpZwBUAAAAAQAAAISi/T8AAAAAIQAGAAUAAAAAAAAA
                                        5DYIQPC/AEAwAAYAWnIJgLCh/T8AAAAAIwAGACAABgDg8Ps/AwAAACMABgD//z+z
                                        q6sAAOzc+z8jAAYArLH7PwEAAAD+AAAAAAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                                        B3oOgOCh/T8BAAAAIET8P6yx+z8BAAAA/gAAACAAAAAAAAAAAKL9PwAAAAAAAAAA
                                        Rebooting...
                                        rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
                                        entry 0x400a05bc
                                          andreas @sita
                                          Thanks @sita. This yields...
                                          #0  0x4009774e in vTaskDelay (xTicksToDelay=<optimized out>) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/tasks.c:1484
                                          #1  0x4011338c in TASK_LoRa (pvParameters=<optimized out>) at mods/modlora.c:804
                                            andreas
                                            Dear @sita,
                                            @ps47 also experienced similar errors like you have been observing [1]. He is also using pure LoRa. Using the most recent 1.20.2.rc3 release seems to help here [2]. Thanks @husigeza and the whole Pycom team for mitigating this issue.
                                            I tried the new build LoPy4-1.20.2.rc3-0.8.0-vanilla-squirrel.tar.gz and not any “bad00bad bad00bad bad00bad” Core Panic happened till now.
                                            With kind regards,
                                            Andreas.
                                            [1] https://forum.pycom.io/topic/5514/random-core-panic-with-lora-socket-send-recv-device-doesnt-restart-try-with-config_esp32_panic_silent_reboot
                                            [2] https://community.hiveeyes.org/t/investigating-core-panics-on-the-lopy4/2878/29
                                            • 2 / 3
