    Guru Meditation Error
    58 Posts 7 Posters 2.9k Views 7 Watching
      andreas @sita
      Thanks. So, to make sure we are on the same page...
      • Invoking erase_all once before uploading a new firmware image is considered good practice. Thanks for letting me know.
      • After that, you are able to invoke your MicroPython program using the LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel firmware?
      • However, Guru Meditation errors still occur?
      Now, are you able to submit another core dump when running this firmware build? I have saved a local copy of lopy4-0.8.0-vanilla-squirrel.elf on my workstation in order to decode core dumps produced by this build.
        sita @andreas
        @andreas Now i got an issue with the atom editor :( :(
        i have updated the ATOM editor evening and now i it is not showing REPL console. I will check with this and send you the core dump (LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel).
          peterp
          @sita can you try again with 1.20.2.rc3
          @pigamonte same advice to you, but in case it doesn't solve it for you, I suggest to open your own thread. Otherwise we end up mixing different issues. Just because it shows a Guru Meditation Error, doesn't necessarily mean the issues are related.
            sita @peterp
            Hello @peterp,
            I have tried with new firmware version (1.20.2.rc3) but same error is coming again. I will open new thread to avoid mixing of different issues.
            Thanks & Have a nice day
              andreas @sita
              Dear @sita,
              @sita said in Guru Meditation Error:
              Either with the original Pycom's 1.20.2.rc3 and/or with the corresponding/updated LoPy4-1.20.2.rc3-0.8.0-vanilla-squirrel.tar.gz, I will be happy to receive respective core dumps. I have now kept the definitive .elf files around for decoding the core dumps appropriately.
              Thanks and with kind regards,
              Andreas.
                sita @andreas
                Hello @andreas ,
                This is the core dump of the updated LoPy4-1.20.2.rc3-0.8.0-vanilla-squirrel.tar.gz
                Guru Meditation Error: Core  1 panic'ed (IllegalInstruction). Exception was unhandled.
                Memory dump at 0x4010abc8: 10180108 00000044 00000000
                Core 1 register dump:
                PC      : 0x4010abcf  PS      : 0x00060130  A0      : 0x801024b3  A1      : 0x3ffd8280
                A2      : 0x3ffc93fc  A3      : 0x00000000  A4      : 0x3f94ef00  A5      : 0xffffff30
                A6      : 0x3f9502b3  A7      : 0x00007e00  A8      : 0x40109f79  A9      : 0x3ffd8260
                A10     : 0x3f40eed0  A11     : 0x00000000  A12     : 0x3f94ef04  A13     : 0x3f94ef08
                A14     : 0x00000048  A15     : 0x400ff4ea  SAR     : 0x0000001e  EXCCAUSE: 0x00000000
                EXCVADDR: 0x00000000  LBEG    : 0x40094de0  LEND    : 0x40094dfc  LCOUNT  : 0xffffffff
                Backtrace: 0x4010abcf:0x3ffd8280 0x401024b0:0x3ffd8320 0x400fe7c1:0x3ffd8350 0x400fe7ee:0x3ffd8370 0x400e208d:0x3ffd8390 0x400e231d:0x3ffd8430 0x400e0d81:0x3ffd8450
                0DgAAAEAAAARAAAAbAEAAA==
                9EX8P8CB/T98hv0/
                AIH9PxCG/T/ztQIADEP8PwxD/D/0Rfw/BEP8Pw4AAAC4N/4/uDf+P/RF/D8AAAAA
                CwAAAIBW/T9NaWNyb1B5AAAAAAAAAAAAAQAAAHyG/T8AAAAAIAsGAAsAAAABAAAA
                +DT7P/yT/D8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                l4dAPwAAAAD4WwlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAA==
                oCMQgM+rEEAwAQYAsyQQgICC/T/8k/w/AAAAAADvlD8w////swKVPwB+AAB5nxBA
                YIL9P9DuQD8AAAAABO+UPwjvlD9IAAAA6vQPQB4AAAAAAAAAAAAAAOBNCUD8TQlA
                /////wTvlD8I75Q/gDYIQLRp+j8AAAAAAAAAAAEAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAATvlD8I75Q/SAAAAOr0D0DE5w+AIIP9P1CU/D9QlPw/
                kIP9PwMAAACzJBCAgIL9PwgAAABQ75Q/TO+UP0TvlD8AAAAAEwAAACsBAAAgAAAA
                5DYIQFsjDkDE5w+AIIP9P1CU/D9QlPw/TpoQgMyKCUAIAAAARO+UPwAAAAATAAAA
                AAAAAPDulD9Q75Q/TO+UPwAAAAAAAAAAAAAAAAAAAAAE75Q/MP////cDlT8CAAAA
                8ecPgFCD/T9g7ZQ/AAAAAAAAAAAAAAAAAwAAACMABgDw7pQ/AAAAAEwAAAAgg/0/
                kCAOgHCD/T9g7ZQ/AAAAAAAAAAAAAAAAAQAAAAAAAAAgIw6AkIP9P2DtlD8gAAAA
                AAAAAAAAAAAAAAAAKPCUP4QNDoAwhP0/pu2UP2YDAAAAAAAAAAAAACAjDoCQg/0/
                DE/8PwAAAAAgAAAAEDNBPwgzQT8IAAAAsg0OgCCE/T+PM0E/ZgMAAIQNDoAwhP0/
                pu2UP2YDAAAMIA6AvACVP6D+lD8BAAAAZ0FJTgAIAAAIAAAAcDNBP3juAAABAAAA
                IAAAAKbtlD/D7gAAAQAAACAAAAAQM0E/CDNBPwgAAAAAAAAAUIT9PwYWAAABAAAA
                mDH+PwAAAAABAAAAAAAAAAAAAAAQhv0/AAAAAAAAAAABAAAApaWlpaWlpaWlpaWl
                AAAAAAAAAaXoAAAA6QAAAAEAAAAABAAA+P8f0AAAAAD//////////6WlpaWlpaWl
                AQAIAAAAAAClpaWlpaWlpaWlpaWlpaWlpaWlpQAAAADIXEA/paWlpaWlpaWlpaWl
                paWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWl
                5DYIQPQIDkAwAAUAAAAAABCG/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAAAAACQmxkA
                AAAAAP/////////////////////7O9mUAAAAAAAAAAAAAAAAAPAfAFCE/T8AAAAA
                AAAoAAAAAAAAAAAAAAAAAM0XQD+sR/w/AAAAAFUXQD8AAAAAAAAAAAAAAAAAAAAA
                AQAAAAAAAAAchv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAA
                ZP39P6Ak/T+UJv0/
                oCT9PzAm/T/ztQIAqEL8P6hC/D9k/f0/oEL8PxMAAAB8/f0/AAAAAGT9/T8AAAAA
                BgAAAJgW/T9Mb1JhAAAAAAAAAAAAUFkAAQAAAJQm/T8AAAAAIQAGAAYAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAP79Pw==
                5DYIQE53CUAwCwYAjDMRgGAl/T/ztQIAQN37Pxgh/j8AAAAAAAAAAAAAAABOdwmA
                QCX9PwEAAADztQIAZP39PwEAAAD+AAAAEAAAAA4AAACLAAYAq6sAAE4+CUBZPglA
                AAAAAOQ4CEABAAAAzIoJQNQJ+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAIBB/D8BAAAA/gAAAAEAAAAAAAAAgCX9P8SZ/D9Ymvw/
                3GL7P/////8AAAACzGL7PwAAAAAwJv0/AAAAAAAAAAAIAAAAAAAAAAAAAAABAAAA
                AAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAAAAAAMyKCUDUCfo/AAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAABKFhQoAAAAAAAAAAAAAAADMNkE/eAT8P1ia/D+V////
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPCb9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAA=
                HLP7PyCx/T+Isv0/
                ILH9PyCy/T/ztQIAlEL8P5RC/D8cs/s/jEL8PxQAAAAwOv4/MDr+Pxyz+z8AAAAA
                BQAAAIyi/T9TZXJ2ZXJzAAAAAAAAAAAAAQAAAIiy/T8AAAAAIQAGAAUAAAAAAAAA
                9H/7PwAAAAAAAAAAAAAAAAsAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
                5DYIQE53CUAwCwYAyA4OgOCx/T/ztQIAQN37PwsAAAAA/wAAAAD/AAAAAP9OdwmA
                wLH9PwEAAADztQIAHLP7PwEAAAD+AAAAIwAGAAAAAADEVg+AoLH9P+BNCUD8TQlA
                /////+Q4CEABAAAAzIoJQMSV+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAsv0/MPj7PwAAAAAAAAAAALL9PwAAAAAAAAAA
                AgAAAAD/AAAAAP8AAAAA/wAAAAAgsv0/AAAAAAAAAAAAAAAAAQAAAGpK/D8AAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALLL9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                QLn7P6C3+z84ufs/
                oLf7P9C4+z9Tlb0vvL77PzBC/D9Aufs/KEL8PxkAAAC8SVUVuUNvUUC5+z8AAAAA
                AAAAADy1+z9JRExFMABG0Bmj0zv92E4AAAAAADi5+z8AAAAAIwAGAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEXqHw==
                5DYIQLZoIUAwDwYAdmgXgGC4+z8AAAAAAAAAAAAAAACQt/s/AwAAACMABgD4kfw/
                AAAAAPyxAgAAAAAAAAAAAAkAAAAAgAAA//8AgAoAAACguPs/AAAAANDYDkAT2Q5A
                AAAAAOQ4CEAJAAAAzIoJQHSc+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAPPr8P8yKCUAseQmAgLj7PyAAAAABAAAA
                //8/swAAAAAAAAAAAAAAAAAAAACguPs/AAAAALhB/D8AAAAAPPr8PxxE/D8AAAAA
                AAAAANC4+z8AAAAAAAAAAEDd+z8AAAAAAAAAAAAAAAAAAAAAAQAAAAQAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3Lj7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                tL77PxC9+z+svvs/
                EL37P0C++z/MtOISMEL8P0i5+z+0vvs/KEL8PxkAAACFM0nahGdmZbS++z8AAAAA
                AAAAALC6+z9JRExFMQDLX/9qno4QORUAAQAAAKy++z8AAAAAIwAGAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAI8mOg==
                5DYIQLZoIUAwCQYAdmgXgNC9+z8AAAAAMEL8P4XGAgCoBfw/K6oCACMABgAjAAYA
                /////5BB/D8wQvw/6M8CAKgF/D81rwIAIwAGAAAAAADQvfs/AAAAAAAAAAAAAAAA
                AAAAAOQ4CECoBfw/zIoJQOSh+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAseQmA8L37PyAAAAABAAAA
                //8/swAAAAAAAAAAAAAAAAAAAAAQvvs/AAAAALhB/D8gAAAAPPr8PyBE/D8AAAAA
                AAAAAEC++z8AAAAAAAAAAEDd+z8AAAAAAAAAAAAAAAABAAAAAQAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAATL77PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                tJ/7P9Ct+z/Er/s/
                0K37P2Cv+z8xtgIAHEL8PxxC/T+0n/s/FEL8PwcAAAAIn/s/CJ/7P7Sf+z8An/s/
                EgAAAMih+z90aVQAcEH8P7x9+z/EffsAAAAAAMSv+z8AAAAAIQAGABIAAAAAAAAA
                5DYIQLBmCUAwDwYAaf8YgJCu+z/cnvs/MK/7Pyif+z8AAAAAMJ/7PwAAAACwZgmA
                cK77PwAAAABiAAAAQN37PxxE/D/+AAAAAAAAABAAAAABAAAA/gAAAPHrGED66xhA
                AAAAAOQ4CEAcRPw/zIoJQAST+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAEQ2GICgrvs/cAtCP6Cu+z//NxiA0K77P/////8wr/s/
                AAAAAM+1AgBkAAAAUDcYQGIAAACQrvs//gAAAAAAAABIOBiA4K77P7wMQj+YAJQ/
                rwEYgACv+z88+/w/MK/7P68BGIAAr/s/PPv8PzCv+z9iAAAA/////8+1AgAAAAAA
                AAAAADCv+z88ZxhAAAAAAFA3GEC8DEI/PGcYQAAAAACo//w/qP/8P6T//D+k//w/
                AAAAAGCv+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAbK/7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                FEL9PwBA/T8MQv0/
                AED9P6BB/T/0tQIAvJ/7PxxC/D8UQv0/FEL8PxMAAAAAAAAAAAAAABRC/T8AAAAA
                BgAAABA0/T9TaWdmb3gAQLDKH0AwAAUAAAAAAAxC/T8AAAAAIQAGAAYAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKWlpQ==
                5DYIQE53CUAwAQYAysofgMBA/T/0tQIAQN37PyD//T8AAAAAAAAAAAAAAABOdwmA
                oED9PwAAAAD0tQIAFEL9PwEAAAD+AAAAIwAGABEAAABEJfo/AAAAAAAAAAAAAAAA
                AAAAAOQ4CEABAAAAzIoJQEQl+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAA4ED9P9gU/T/UFP0/
                IP/9PwAAAAAAAAAAAAAAAAAAAACgQf0/AAAAAAAAAADkNghAsMofQDAABQAAAAAA
                oEH9PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                RCX6PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                FwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKxB/T8AAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
                IMv7P8DJ+z8Yy/s/
                wMn7P7DK+z8AAAAACEL8PwhC/D8gy/s/AEL8Pw8AAABQwPs/UMD7PyDL+z9IwPs/
                CgAAABzB+z9UbXIgU3ZjAA5cTdTiH3QAAAAAABjL+z8AAAAAIQAGAAoAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMCU9g==
                5DYIQGGICUAwAAYAAAAAAIDK+z8AAAAAAAAAAAAAAAAsRPw/JET8PwEAAABhiAmA
                YMr7PwAAAABA3fs/gEH8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAOQ4CEAAAAAAzIoJQFSu+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAFSu+D8AAAAAAAAAAAAAAAAAAAAAsMr7PwAAAAAAAAAA
                AAAAAAAAAAC8yvs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAA=
                7MP9P1DC/T/kw/0/
                UML9P4DD/T/JRKlVCMr9P7Sx+z/sw/0/pEH8PxQAAABziUhuF1Dt2OzD/T8AAAAA
                BQAAAOiz/T9Tb2NrZXQgT3BlcmF0aW8AAQAAAOTD/T8AAAAAIQAGAAUAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAACNJw==
                5DYIQPC/AEAwAAYAWnIJgBDD/T8AAAAAIwAGACAABgDQg/0/VQAAAPCh/T///z+z
                q6sAAOzc+z8jAAYA7MP9PwEAAAD+AAAAAAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                AAAAAOQ4CEABAAAAzIoJQCSn+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACigwmAIMP9P0Dd+z8GAAAA
                3moOgEDD/T8BAAAAIET8P+zD/T8BAAAA/gAAALCd+z8AAAAAYMP9PwAAAAAAAAAA
                HET8P0Dd+z+QQfw/lEL8PwAAAACAw/0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjMP9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                AMr9P1Dp/T9s6/0/
                UOn9PwDr/T8Ayv0/OHz7P/TD/T8Ayv0/pEH8Pw4AAAC8sv0/vLL9PwDK/T+0sv0/
                CwAAAHDL/T9JUlFzAAAAAAAAAAAASYIAAQAAAGzr/T8AAAAAIQAGAAsAAAAAAAAA
                AAAAAJzq/T8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApv6CQ==
                5DYIQLBmCUAwBQYASEsPgBDq/T+Qsv0/sOr9P9yy/T8AAAAA5LL9PwAAAACwZgmA
                8On9PwEAAAD/////QN37PxxE/D/+AAAAAAAAAAAAAABQ6v0/sJX8PwAAAAAAAAAA
                AAAAAOQ4CEAcRPw/zIoJQKTO+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAAQAAAMyKCUB8FA6AUOr9P4CS/D+w6v0/
                AAAAAFQAAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAAAAAAAAAQAAAHSS/D8wAPw/
                AAAAAODq/T90kvw/AAAAAADr/T8AAAAAAAAAAAAAAAAAAAAAdJL8PwAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACw6v0/
                ABwAAFCU/D9QlPw/AAAAAKTO+j8AAAAAAAAAAAAAAABQlPw/CgAAAJBB/D8MQ/w/
                AAAAAADr/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAM6/0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAA
                MHz7P7Cc+z84nvs/
                sJz7P9Cd+z8sCBnhmNn7PwjK/T8wfPs/pEH8PwEAAAAEfPs/BHz7PzB8+z/8e/s/
                GAAAADya+z9pcGMxAH0Q8VnobXH5p5QAAQAAADie+z8AAAAAIQAGABgAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKE5jA==
                5DYIQLBmCUAwBwYAlDQIgHCd+z/Ye/s/AAAAACR8+z8AAAAA2Hv7PwAAAACwZgmA
                UJ37PwEAAAD/////QN37PxxE/D/+AAAAIAMGABwAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAOQ4CEAcRPw/zIoJQHSB+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAADB8+z8BAAAA/gAAACMABgAAAAAAsJ37PzhB/D8AAAAA
                AAAAAGQEAAD+AAAAIAMGAP////8AAAAAOEH8PyRB/D8Advs/AAAAAAEAAAAAAAAA
                AAAAANCd+z8AAAAAAAAAALh+CEABAAAAAAAAAAAAAAB9FAiAgH3+PwABAADoDQBA
                AAAAAAAAAADcnfs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAA=
                kNn7P9CQ/T+Akv0/
                0JD9PyCS/T8L+VfXqDL9Pzh8+z+Q2fs/pEH8PwUAAABk0/s/ZNP7P5DZ+z9c0/s/
                FAAAAISG/T9ldmVudFRhc2sADM8yC4kAAAAAAICS/T8AAAAAIQAGABQAAAAAAAAA
                KDX7PwAAAAAAAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHiJeQ==
                5DYIQLBmCUAwAgYALGkXgJCR/T840/s/0JH9P4TT+z8AAAAAjNP7PwAAAACwZgmA
                cJH9PwAAAAD/////QN37PxxE/D/+AAAAIAAGAAAAAABwkf0/fJH9P+BNCUD8TQlA
                /////+Q4CEAcRPw/zIoJQMR1+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAMCoBAH///8AwKgEATxxv4cAAAAA0JH9P4z6/D8AAAAA
                AAAAAL0EAAD+AAAAIAAGAP/////Qkf0/jPr8PwAAAACE0/s/AAAAAFzZ+z8BAAAA
                AAAAACCS/T8AAAAAAAAAAA4AAAACAAAAfML8PwEAAAAIBvw//gAAAAEAAAAbchOA
                8EH7PwAAAAAAAAAAcQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAskv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                oDL9P9Aw/T+YMv0/
                0DD9PzAy/T8AAAAAcHr7P5jZ+z+gMv0/pEH8PxEAAAB4Yvs/eGL7P6Ay/T9wYvs/
                CAAAAJwm/T9Mb1JhX1RpbWVyX2NhbGwAAQAAAJgy/T8AAAAAIQAGAAgAAAAAAAAA
                5DYIQPC/AEAwAAYAWnIJgJAx/T8AAAAAIwAGACAABgABAAAA/gAAAAAAQAD//z+z
                q6sAAEDd+z//////IAoGAIDslD8AAP8AAAAA/wAAAAClpaWlpaWlpQAAAAAAAAAA
                AAAAAOQ4CECA7JQ/zIoJQNQV+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAP////+nZgmAoDH9P5hi+z//////
                mB4RgMAx/T9MYvs/ADL9P0Dd+z8cRPw//gAAACMABgAAAAAAADL9P4Cb/D8AAAAA
                AAAAAIAIAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAACYYvs/AAAAAKBi+z8AAAAA
                AAAAADAy/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPDL9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                aHr7P+B4+z9gevs/
                4Hj7PwB6+z+HrjGXTEP7P6gy/T9oevs/pEH8PwEAAAA4dvs/OHb7P2h6+z8wdvs/
                GAAAAGR2+z9pcGMwAPHSUYYL2UPLt7EAAAAAAGB6+z8AAAAAIQAGABgAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANj60g==
                5DYIQLBmCUAwBwYAlDQIgKB5+z8Mdvs/AAAAAFh2+z8AAAAADHb7PwAAAACwZgmA
                gHn7PwAAAAD/////QN37PxxE/D/+AAAAUQYAAAAAAAAAAAAAAQAAAAAAAAAAAAAA
                AAAAAOQ4CEAcRPw/zIoJQKRd+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAA4Hn7PzRB/D8AAAAA
                AAAAADQKAAD+AAAAUQYAAP/////gefs/NEH8PyRB/D8Advs/AAAAAAEAAAAAAAAA
                AAAAAAB6+z8AAAAAAAAAALh+CEAAAAAAAAAAAAAAAADpEwiAIDz+P4xB/D+PaUA/
                AAAAAAAAAAAMevs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                REP7P3BB+z88Q/s/
                cEH7P9BC+z8TIhymhHL7P3B6+z9EQ/s/pEH8PwIAAAB8Lvs/fC77P0RD+z90Lvs/
                FwAAAEA1+z93aWZpAL6bfa7+shKU8Z4AAAAAADxD+z8AAAAAIQAGABcAAAABAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANPm3Q==
                5DYIQLBmCUAwCQYArVwXgDBC+z9QLvs/oEL7P5wu+z8AAAAApC77PwAAAACwZgmA
                EEL7PwAAAAD/////QN37PxxE/D/+AAAAAAAAAB4AAAD1NBSAUEL7P+BNCUD8TQlA
                /////+Q4CEAcRPw/zIoJQHQm+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAB41/w/GwAAAAAAAAAZeRWAcEL7P1Au+z+gQvs/
                AAAAAPK1AgAAAAAAUPr9P/////9wQvs/AAAAABT6/T8JAAAA4Aj8P6AI/D8BAAAA
                AAAAAJBC+z/YBfw/dAv8P/////+AAAAAxAAAAHAL/D8AAAAA0EL7PwAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAaOb8PxoAAABoCPw/
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3EL7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                fHL7P+Bw+z90cvs/
                4HD7PxBy+z+XlaRrrEH8P0xD+z98cvs/pEH8PwMAAABwQPw/cED8P3xy+z9oQPw/
                FgAAAHhm+z9lc3BfdGltZXIA30u6hkQAAAAAAHRy+z8AAAAAIQAGABYAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJcfvg==
                5DYIQLBmCUAwAQYA/SwNgKBx+z9EQPw/AAAAAJBA/D8AAAAARED8PwAAAACwZgmA
                gHH7PwAAAAD/////QN37PxxE/D/+AAAA/T4CAAAAAAAKAAAAAAAAAOBNCUD8TQlA
                /////+Q4CEAcRPw/zIoJQLRV+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAKEaCICgcfs//Nz7P/9zq34AAAAA4HH7P5hA/D+gQPw/
                AAAAAPO1AgBQLvs//T4CAP/////gcfs/AAAAAKBA/D/YBfw/AAAAACRw9D8AAAAA
                AAAAABBy+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKBA/D/L5pYK
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHL7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                rLH7P/Cg/T+Eov0/
                8KD9PyCi/T/gAAAA9MP9P6xB/D+ssfs/pEH8PxQAAAD8TQlAAAAAAKyx+z8AAAAA
                BQAAAIiS/T9TbWFydENvbmZpZwD//z8AAQAAAISi/T8AAAAAIQAGAAUAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAAAAA==
                5DYIQPC/AEAwAAYAWnIJgLCh/T8AAAAAIwAGACAABgAAnfs/AwAAACMDBgD//z+z
                q6sAAOzc+z8jAAYArLH7PwEAAAD+AAAAmAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                AAAAAOQ4CEABAAAAzIoJQMSF+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACigwmAwKH9P0Dd+z8FAAAA
                B3oOgOCh/T8BAAAAIET8P6yx+z8BAAAA/gAAACADBgAAAAAAAKL9PwAAAAAAAAAA
                HET8P0Dd+z+QQfw/lEL8PwAAAAAgov0/AAAAAAAAAABET/w/AAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALKL9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                Rebooting...
                ets Jun  8 2016 00:22:57
                rst:0xc (SW_CPU_RESET),boot:0x16 (SPI_FAST_FLASH_BOOT)
                configsip: 0, SPIWP:0xee
                mode:DIO, clock div:1
                load:0x3fff8020,len:8
                load:0x3fff8028,len:2176
                load:0x4009fa00,len:19740
                entry 0x400a05bc
                  andreas @sita
                  Thanks! Decoding this yields
                  ==================== CURRENT THREAD STACK =====================
                  #0  mp_execute_bytecode (code_state=0x3f94eef0, inject_exc=0x0) at ../py/vm.c:1306
                  #1  0x401024b3 in fun_bc_call (self_in=<optimized out>, n_args=<optimized out>, n_kw=0, args=0x3ffd8280) at ../py/objfun.c:287
                  #2  0x400fe7c4 in mp_call_function_n_kw (fun_in=0x3f94ed60, n_args=0, n_kw=0, args=0x0) at ../py/runtime.c:624
                  #3  0x400fe7f1 in mp_call_function_0 (fun=0x3f94ed60) at ../py/runtime.c:598
                  #4  0x400e2090 in parse_compile_execute (source=0x3f94eda6, input_kind=MP_PARSE_FILE_INPUT, exec_flags=32) at ../lib/utils/pyexec.c:103
                  #5  0x400e2320 in pyexec_file (filename=0x3f94eda6 <error: Cannot access memory at address 0x3f94eda6>) at ../lib/utils/pyexec.c:550
                  #6  0x400e0d84 in TASK_Micropython (pvParameters=<optimized out>) at mptask.c:320
                  ======================== THREADS INFO =========================
                    Id   Target Id         Frame
                    17   process 16        0x4000bff0 in ?? ()
                    16   process 15        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffc4044 <s_timer_semaphore_memory>, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                    15   process 14        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffb2e50, pvBuffer=0x3ffb42a0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                    14   process 13        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffb760c, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                    13   process 12        0x4000bff0 in ?? ()
                    12   process 11        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffbd338, pvBuffer=0x3ffd91d0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                    11   process 10        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffb7bd8, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                    10   process 9         0x400966b0 in xQueueGenericReceive (xQueue=0x3ffdb290, pvBuffer=0x3ffdeab0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                    9    process 8         0x4000bff0 in ?? ()
                    8    process 7         /builds/idf/crosstool-NG/.build/src/gdb-7.10/gdb/inline-frame.c:171: internal-error: inline_frame_this_id: Assertion `!frame_id_eq (*this_id, outer_frame_id)' failed.
                  So, the core dump seems to happen right away after system start while executing the Python file
                  I have never seen that before! The file might be corrupted somehow.
                  • Is this the core dump which is happening immediately after uploading the MicroPython file to the system?
                  • Can you get another core dump which is coming from the system after a short run time i.e. after hitting the reset button?
                  • Can you show your current MicroPython code again?
                  • You might also want to try yet another erase_all [1] / erase_flash procedure first.
                  [1] Please don't miss the corresponding installation notes when invoking erase_all on LoPy devices.
                  A S 2 Replies Last reply Reply Quote 0
                    andreas @andreas
                    @andreas said in Guru Meditation Error:
                    Regarding the MicroPython code, I would suggest trying to invoke your program without any interaction on the filesystem and see whether it still crashes.
                      sita @andreas
                      Hello @andreas,
                      I have attached the core dump which is observed after a short run.
                      Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
                      PC      : 0x40098fbb  PS      : 0x00060033  A0      : 0x80097e99  A1      : 0x3ffbf0c0
                      A2      : 0x3ffbb95c  A3      : 0x00060023  A4      : 0x3ffc45f4  A5      : 0x00000001
                      A6      : 0x000000fe  A7      : 0x3f95038a  A8      : 0x00000000  A9      : 0x3ffbb95c
                      A10     : 0x3ffbb95c  A11     : 0x00000000  A12     : 0x8010a802  A13     : 0x3ffd8260
                      A14     : 0x00000001  A15     : 0x00000000  SAR     : 0x00000003  EXCCAUSE: 0x0000001c
                      EXCVADDR: 0x00000004  LBEG    : 0x400ed8d0  LEND    : 0x400ed913  LCOUNT  : 0x00000000
                      Core 1 was running in ISR context:
                      EPC1    : 0x40098fbb  EPC2    : 0x00000000  EPC3    : 0x00000000  EPC4    : 0x00000000
                      Backtrace: 0x40098fbb:0x3ffbf0c0 0x40097e96:0x3ffbf0e0 0x4009656d:0x3ffbf100 0x400890bb:0x3ffbf120 0x40083949:0x3ffbf160 0x400e7009:0x3ffd81f0 0x401023ba:0x3ffd8220 0x400fe7c1:0x3ffd8240 0x400fe851:0x3ffd8260 0x4010a7ff:0x3ffd8280 0x401024b0:0x3ffd8320 0x400fe7c1:0x3ffd8350 0x400fe7ee:0x3ffd8370 0x400e208d:0x3ffd8390 0x400e231d:0x3ffd8430 0x400e0d81:0x3ffd8450
                      pDQAAAEAAAAQAAAAbAEAAA==
                      ZP39P6Ak/T+UJv0/
                      oCT9PzAm/T/I5AEAqEL8P6hC/D9k/f0/oEL8PxMAAAB8/f0/AAAAAGT9/T8AAAAA
                      BgAAAJgW/T9Mb1JhAAAAAAQAAAAAUFkAAQAAAJQm/T8AAAAAIQAGAAYAAAAAAAAA
                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADD+Pw==
                      5DYIQE53CUAwDQYAjDMRgGAl/T/I5AEAQN37Pxgh/j8AAAAAAAAAAAAAAABOdwmA
                      QCX9PwEAAADI5AEAZP39PwEAAAD+AAAAEAAAAA4AAADUCfo/AAAAAE4+CUBZPglA
                      GCH+PwAAAAAAAAAAAAAAAAAAAAAwJv0/AAAAAAAAAAAIAAAAAAAAAAAAAAABAAAA
                      AAAAAAAAAAAAAAAAAAAAAKUNQgcAAAAAAAAAAAAAAADMNkE/eAT8P1ia/D+W////
                      HLP7PyCx/T+Isv0/
                      ILH9PyCy/T/I5AEAlEL8P5RC/D8cs/s/jEL8PxQAAAAwOv4/MDr+Pxyz+z8AAAAA
                      5DYIQE53CUAwDQYAyA4OgOCx/T/I5AEAQN37PwsAAAAA/wAAAAD/AAAAAP9OdwmA
                      wLH9PwEAAADI5AEAHLP7PwEAAAD+AAAAIwAGAAAAAADEVg+AoLH9P+BNCUD8TQlA
                      QLn7PxC3+z84ufs/
                      ELf7P9C4+z9RFb1vvL77PzBC/D9Aufs/KEL8PxkAAABcufs/XLn7P0C5+z8AAAAA
                      AAAAADy1+z9JRExFMABWwAmj07v92E4AAAAAADi5+z8AAAAAIAcGAAAAAAAAAAAA
                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEX5Fw==
                      5DYIQLBmCUAwDwYApBQXgNC3+z/ktPs/AAAAADC1+z8AAAAA5LT7PwEAAACwZgmA
                      sLf7PwAAAAD/////QN37PxxE/D/+AAAAqQ28PwoAAADkNghAsl4hQNDYDkAT2Q5A
                      AAAAAOQ4CEAcRPw/zIoJQHSc+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                      AAAAAAAAAAAAAAAAAAAAAGC4+z8AAAAAAAAAAAAAAAAl2Q6AELj7PwEAAABAAAAA
                      AAAAAAPlAQAAAAAAAAAAAP////8AgAAA//8AgAoAAACguPs/AAAAANDYDkAT2Q5A
                      WEgPgEC4+z8AAAAAAQAAAHSc+D8Qkvw/AAAAAAAAAAAYAAAAAAAAAHTr/T8BAAAA
                      ZGgXgGC4+z/4kfw/AQAAAAAAAAAJAAAAAIAAAP//AIAseQmAgLj7PwAAAAABAAAA
                      AAAAALA//T8DAAAAIwAGAAAAAACguPs/AAAAALhB/D8AAAAAPPr8PxxE/D8AAAAA
                      tL77PxC9+z+svvs/
                      EL37P0C++z/MkOIQMEL8P0i5+z+0vvs/KEL8PxkAAACNMdnalEdm5bS++z8AAAAA
                      AAAAALC6+z9JRExFMQDrX/9+n4oQORUAAQAAAKy++z8AAAAAIwAGAAAAAAAAAAAA
                      5DYIQLZoIUAwCwYAdmgXgNC9+z8AAAAAMEL8PwtqCYDQsP0/AwAAACMABgAjAAYA
                      gLH9P+zc+z8gDwYA//8/s6urAAD+AAAAAAAAAAAAAAAQvvs/AAAAAAAAAAAAAAAA
                      AAAAAOQ4CECrqwAAzIoJQOSh+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                      AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAPPr8P8yKCUAseQmA8L37PyAAAAABAAAA
                      tJ/7P9Ct+z/Er/s/
                      0K37P2Cv+z805QEAHEL8PxxC/T+0n/s/FEL8PwcAAAAIn/s/CJ/7P7Sf+z8An/s/
                      cK77PwAAAABgAAAAQN37PxxE/D/+AAAAAAAAABAAAADkNghANDYYQPHrGED66xhA
                      AAAAANTkAQBkAAAAUDcYQGAAAACQrvs//gAAAAAAAABIOBiA4K77P7wMQj+YAJQ/
                      rwEYgACv+z88+/w/MK/7P68BGIAAr/s/PPv8PzCv+z9gAAAA/////9TkAQAAAAAA
                      FEL9PwBA/T8MQv0/
                      AED9P6BB/T8E5QEAvJ/7PxxC/D8UQv0/FEL8PxMAAAAFAAAAkEH8PxRC/T8AAAAA
                      5DYIQE53CUAwAQYAysofgMBA/T8E5QEAQN37PyD//T8AAAAAAAAAAAAAAABOdwmA
                      oED9PwAAAAAE5QEAFEL9PwEAAAD+AAAAIwAGABEAAABEJfo/AAAAAAAAAAAAAAAA
                      IMv7P8DJ+z8Yy/s/
                      CgAAABzB+z9UbXIgU3ZjAA4cTdTiG3QAAAAAABjL+z8AAAAAIQAGAAoAAAAAAAAA
                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMCU8g==
                      AAAAAAAAAAA=
                      7MP9P1DC/T/kw/0/
                      UML9P4DD/T/LQKlVCMr9P7Sx+z/sw/0/pEH8PxQAAABRiUhuVnTv3ezD/T8AAAAA
                      AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAACBBw==
                      5DYIQPC/AEAwAAYAWnIJgBDD/T8AAAAAIwAGACAABgCYzfs/VQAAAPCh/T///z+z
                      3moOgEDD/T8BAAAAIET8P+zD/T8BAAAA/gAAAICD/T8AAAAAYMP9PwAAAAAAAAAA
                      AMr9P1Dp/T9s6/0/
                      CwAAAHDL/T9JUlFzAAAAAAAAAAAASa4AAQAAAGzr/T8AAAAAIQAGAAsAAAAAAAAA
                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAArv6CA==
                      8On9PwEAAAD/////QN37PxxE/D/+AAAAAAAAAAAAAACkzvo/AAAAAAAAAAAAAAAA
                      AAAAAAAAAAAAAAAAAAAAAAAAAAAyAAAApaWlpaWlpaV8FA6AUOr9P4CS/D+w6v0/
                      AAAAAFQAAAClpaWlpaWlpf////9Q6v0/sJX8P7Dq/T8AAAAAAQAAAHSS/D8wAPw/
                      AAAAAAAAAAAAAAAA
                      MHz7P7Cc+z84nvs/
                      sJz7P9Cd+z8sSBnimNn7PwjK/T8wfPs/pEH8PwEAAAAEfPs/BHz7PzB8+z/8e/s/
                      GAAAADya+z9pcGMxAH1w+UnobXH5p5QAAQAAADie+z8AAAAAIQAGABgAAAAAAAAA
                      5DYIQLBmCUAwBQYAlDQIgHCd+z/Ye/s/AAAAACR8+z8AAAAA2Hv7PwAAAACwZgmA
                      UJ37PwEAAAD/////QN37PxxE/D/+AAAAIwAGABwAAACwnfs/OEH8PwAAAAAAAAAA
                      AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAAAAAAMyKCUAAAAAAsJ37PzhB/D8AAAAA
                      AAAAAGQEAAAAAAAAAAAAAP////8AAAAAOEH8PyRB/D8Advs/AAAAAAEAAAAAAAAA
                      AAAAAAAAAAA=
                      kNn7P9CQ/T+Akv0/
                      0JD9PyCS/T9w2fs/qDL9Pzh8+z+Q2fs/pEH8PwUAAABk0/s/ZNP7P5DZ+z9c0/s/
                      FAAAAISG/T9ldmVudFRhc2sA+z8AAAAAAAAAAICS/T8AAAAAIQAGABQAAAAAAAAA
                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHjBWQ==
                      AAAAALwEAAD+AAAAIAAGAP/////Qkf0/jPr8PwAAAACE0/s/AAAAAFzZ+z8BAAAA
                      AAAAACCS/T8AAAAAAAAAAA4AAADAQfs/AQEAAHzB/D8GAAAAogm8P///AABQBgAA
                      KHNBPzwAAAACAAAAGMf8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                      oDL9P9Aw/T+YMv0/
                      0DD9PzAy/T8AEAAAcHr7P5jZ+z+gMv0/pEH8PxEAAAB4Yvs/eGL7P6Ay/T9wYvs/
                      5DYIQPC/AEAwAAYAWnIJgJAx/T8AAAAAIwAGACAABgABAAAA/gAAACMABgD//z+z
                      q6sAAEDd+z////////8/s6urAAD+AAAAAABAAAAAAAAAAAAAkEH8PwAAAAAAAAAA
                      AAAAAOQ4CECrqwAAzIoJQNQV+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                      AAAAAAAAAAAAAAAAAAAAANQV+j8AAAAAAAAAAAAAAACnZgmAoDH9P5hi+z//////
                      AAAAAL8GAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAACYYvs/AAAAAKBi+z8AAAAA
                      aHr7P+B4+z9gevs/
                      4Hj7PwB6+z+XrzCfTEP7P6gy/T9oevs/pEH8PwEAAAA4dvs/OHb7P2h6+z8wdvs/
                      GAAAAGR2+z9pcGMwAPHWUYaKWUfbt7EAAAAAAGB6+z8AAAAAIQAGABgAAAAAAAAA
                      5DYIQLBmCUAwAQYAlDQIgKB5+z8Mdvs/AAAAAFh2+z8AAAAADHb7PwAAAACwZgmA
                      gHn7PwAAAAD/////QN37PxxE/D/+AAAAHEL9PwAAAAAAAAAAAQAAAAAAAAAAAAAA
                      AAAAADAKAAD+AAAAHEL9P//////gefs/NEH8PyRB/D8Advs/AAAAAAEAAAAAAAAA
                      REP7P3BB+z88Q/s/
                      cEH7P9BC+z8BIhymhHL7P3B6+z9EQ/s/pEH8PwIAAAB8Lvs/fC77P0RD+z90Lvs/
                      FwAAAEA1+z93aWZpADqbfer+shKU8Z4AAAAAADxD+z8AAAAAIQAGABcAAAABAAAA
                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANPmnQ==
                      EEL7PwAAAAD/////QN37PxxE/D/+AAAAAAAAABwAAAD1NBSAUEL7P+BNCUD8TQlA
                      AAAAAAAAAAAAAAAAAAAAAN9SFYBAQvs/AAAAAOiVCEAZeRWAcEL7P1Au+z+gQvs/
                      AAAAAPPkAQDwIgzAACAMAP////9wQvs/uL4AQAAAAABEQ/s/4Av8P+AL/D8BAAAA
                      AAAAAJBC+z/YBfw/dAv8P/////8AAAAAxAAAAHAL/D8AAAAA0EL7PwAAAAAAAAAA
                      AAAAAAAAAAAAAAAAAAAAAAsAAACUDbw/AAAAAAAAAAAAAAAAaOb8PxoAAABoCPw/
                      fHL7P+Bw+z90cvs/
                      4HD7PxBy+z8HlaRrrEH8P0xD+z98cvs/pEH8PwMAAABwQPw/cED8P3xy+z9oQPw/
                      FgAAAHhm+z9lc3BfdGltZXIA30u4hkQAAAAAAHRy+z8AAAAAIQAGABYAAAAAAAAA
                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJZbvA==
                      gHH7PwAAAAD/////QN37PxxE/D/+AAAAJLP7PwAAAAAKAAAAAAAAAOBNCUD8TQlA
                      AAAAAAAAAAAAAAAAAAAAAEDd+z8cRPw//gAAACSz+z8AAAAA4HH7P5hA/D+gQPw/
                      AAAAAPPkAQBQLvs/JLP7P//////gcfs/AAAAAKBA/D8AAAAAAAAAACRw9D8AAAAA
                      AAAAABBy+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKBA/D/6gGYH
                      rLH7P/Cg/T+Eov0/
                      8KD9PyCi/T/Gxsjt9MP9P6xB/D+ssfs/pEH8PxQAAAD7mJIwA0gB/6yx+z8AAAAA
                      BQAAAIiS/T9TbWFydENvbmZpZwBUAAAAAQAAAISi/T8AAAAAIQAGAAUAAAAAAAAA
                      5DYIQPC/AEAwAAYAWnIJgLCh/T8AAAAAIwAGACAABgDg8Ps/AwAAACMABgD//z+z
                      q6sAAOzc+z8jAAYArLH7PwEAAAD+AAAAAAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                      B3oOgOCh/T8BAAAAIET8P6yx+z8BAAAA/gAAACAAAAAAAAAAAKL9PwAAAAAAAAAA
                      Rebooting...
                      rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
                      entry 0x400a05bc
                        andreas @sita
                        Thanks @sita. This yields...
                        #0  0x4009774e in vTaskDelay (xTicksToDelay=<optimized out>) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/tasks.c:1484
                        #1  0x4011338c in TASK_LoRa (pvParameters=<optimized out>) at mods/modlora.c:804
                          andreas
                          Dear @sita,
                          @ps47 also experienced similar errors like you have been observing [1]. He is also using pure LoRa. Using the most recent 1.20.2.rc3 release seems to help here [2]. Thanks @husigeza and the whole Pycom team for mitigating this issue.
                          I tried the new build LoPy4-1.20.2.rc3-0.8.0-vanilla-squirrel.tar.gz and not any “bad00bad bad00bad bad00bad” Core Panic happened till now.
                          With kind regards,
                          Andreas.
                          [1] https://forum.pycom.io/topic/5514/random-core-panic-with-lora-socket-send-recv-device-doesnt-restart-try-with-config_esp32_panic_silent_reboot
                          [2] https://community.hiveeyes.org/t/investigating-core-panics-on-the-lopy4/2878/29
                            andreas
                            Dear @sita,
                            any news on your side about this issue?
                            With kind regards,
                            Andreas.
                              sita @andreas
                              Hello @andreas,
                              I am tried all the ways (like removing SD card, changing the time ..etc) still same error is continuing :( :(
                              Now i will test the device by sending data via TTN to check whether this error is coming in ad-hoc lora mode or not and let you know.
                              Thanks for your support.
                              Have a nice day
                                peterp
                                Which firmware are you using now? Or let me ask it differently, can you reproduce the error with v1.20.2.rc3?
                                  sita @peterp
                                  Hello @peterp,
                                  I am using latest firmware ( v1.20.2.rc3 ). I have tested the device different codes.
                                  If i send basic message then i didn't find any error, but if send GPS the error is still coming.
                                    andreas @sita
                                    Thanks for clarifying this. While I believe there has to be some protection for that case, might it be possible that the message is just getting too long?
                                    coord = l76.coordinates()
                                    gps_datetime = l76.get_datetime()
                                    lat,lon = coord
                                    timestamp =('20' + gps_datetime[4][4] + gps_datetime[4][5]+gps_datetime[4][2] + gps_datetime[4][3]+gps_datetime[4][0] + gps_datetime[4][1]+gps_datetime[2][0] + gps_datetime[2][1]+gps_datetime[2][2] + gps_datetime[2][3]+gps_datetime[2][4] + gps_datetime[2][5] )
                                    message = ''+str(lat)+','+str(lon)+','+str(timestamp)+','+str(value)
                                    s.send(message)
                                    a) Can you tell us about the final result of len(message) here?
                                    b) Can you make up another arbitrary message of the same length (e.g. by using message = 'X' * length) without reading the L76 in order to check if both things produce the error independently from each other?
                                      sita @andreas
                                      Hello @andreas,
                                      a) The length of message is 35
                                      b) With same length (35) message without L76 i tested the device, there is no error present.
                                        andreas @sita
                                        So, do you believe we can deduce from that that doing both things (reading the L76 and submitting data using LoRa) influence each other unfavourably?
                                        That might finally be a trace we could follow up here.
                                          sita @andreas
                                          Hello @andreas,
                                          So as per my opinion, these things (reading the L76 and submitting data using LoRa) effecting the device.
                                            sita @andreas
                                            Hello @andreas,
                                            After transmitting the data 2 hours (without L76 lib and message length 35), just now i have observed Guru meditation error.
                                            • 3 / 3
