Unable to provision Sigfox
I have recently acquired a Fipy and a expansion board 3.0. I have finally managed to provision the device using IOS Pybytes app.
After that, my device has no Sigfox ID:
(sysname='FiPy', nodename='FiPy', release='1.20.2.rc6', version='v1.11-01f49f7 on 2020-02-28', machine='FiPy with ESP32', lorawan='1.0.2', sigfox='1.0.1', pybytes='1.3.1') sigfox id: b'ffffffff' sigfox pac: b'ffffffffffffffff'I have tried to do the provision using Atom and I get the following message:
Wifi connection established... activating device! Unable to provision Sigfox! Please try again. Activation failed!I there something I should do in order to activate Sigfox?
Thanks in advance
I'm having the same issue and I have no clue what's going on.
Curious though what you get if you do the following:
- Add the device in Pybytes via USB and only enable WiFi.
- Connect the device to Pymakr, connect to the WiFi you specified in step 1 and set
pybytes_debugto 99 using following command:
import pycom pycom.nvs_set('pybytes_debug', 99)- Then trying to do the provisioning over wifi according to the instructions under "Activate your device with Pymakr plugin" in the provisioning tab?
I keep getting a response saying:
/v2/register-sigfox returned response: registerSigfoxDevice is missing some argumentsAre you able to update the firmware using Pycom Update-tool?
@amkrup said in Unable to provision Sigfox:
No. It said that it couldn’t connect with the device or something like that. I had to do it manually or with Pybytes IOS app.
At least I’m not alone.
@amkrup , any progress?
@juse I contacted PyCom today and had them escalate my ticket that I created last week. Will get back to you as soon as I have more info.
@amkrup Now it is working for me.
@juse Same here! Guess the folks at Pycom corrected the issue with the device registration.
