    Method To Take Control of Cell Modem
    41 Posts 10 Posters 902 Views 14 Watching
      tlanier
      Ok, I made a little more progress today.
      One of the problematic aspects of coding modem communication routines is knowing what to do when errors occur and how to reliably handle unsolicited modem responses. Currently I've decided against throwing exceptions in the functions. The calling program will need to decide what to do if errors occur.
      I've upgraded the at() function to look for unsolicited responses before transmitting the requested command. If anything is in the RX buffer, it is assumed to be an unsolicited response. There is always a remote chance that an unsolicited response will arrive during the transmission of the command. This will mess up the expected response received.
      I will later try to identify specific unsolicited responses the modem may emit. Currently I've noticed it emits a "+CEREG" on occassion. This can be turned off if we decide to later.
      from machine import UART
      from utime import sleep_ms, ticks_ms, ticks_diff
      uart = None
      #               Initialize Uart Connected To LTE Modem
      def init_uart():
          global uart
          # FiPy: pins=('P20', 'P18', 'P19', 'P17')
          # GPy:  pins=('P5', 'P98', 'P7', 'P99')
          uart = UART(1, baudrate=921600, pins=('P5', 'P98', 'P7', 'P99'), timeout_chars=2)
      #                     Send AT Command To Modem
      def at(cmd):
          try:
              if uart.any() > 0:
                  # get unsolicited modem response
                  a = get_modem_response()
                  if len(a) > 0:
                      print("unsolicited modem response: {}".format(a))
                  # process unsolicited results here
              print("modem command: {}".format(cmd))
              # send command to modem
              n = uart.write(cmd + '\r\n')
              if n != len(cmd) + 2:
                  print("error sending command to modem: n = {}".format(n))
                  return []
          except Exception as ex:
              sys.print_exception(ex)
              a = []
          return a    # return modem response
      #                     Get Modem Response
      def get_modem_response():
          try:
              t0 = ticks_ms()
                  if uart.any() > 0:
                      # insure entire response has been received
                      sleep_ms(1)
                      break
                  t1 = ticks_ms()
                  tx = ticks_diff(t1, t0)
                  if tx > 10000:
                      print("timeout error - no modem response after 10 secs")
                      return []
                  sleep_ms(100)
              r = uart.read()
              s = str(r, 'utf-8')
              a = s.split('\r\n')
              a = list(filter(None, a))
              print("modem response: {}".format(a))
              a = []
      #                       Test Modem Module
      def test():
          init_uart()
          r = at("ATZ")
          if (r[0] != 'OK'):
              print("error")
          r = at("AT+CEREG?")
          if (r[1] != 'OK'):
              print("error")
          s = iccid()
          print("ICCID: " + s)
          s = imei()
          print("IMEI: " + s)
          n = signal_strength()
          print("Signal Strength: " + str(n))
          print("End of test")
      #                     Get SIM Card ICCID Number
      def iccid():
          try:
              a = at("AT+SQNCCID?")
              # example response: ['+SQNCCID: "89014103271203065543",""', 'OK']
              if a[1] != 'OK':
                  return ''
              s = a[0]
              if s[0:10] != '+SQNCCID: ':
                  return ''
              a = s.split(",")
              n = len(a[0])
              r = a[0][11:n-1]
              r = ''
          return r
      #                       Get Modem IMEI Number
      def imei():
          try:
              a = at("AT+CGSN=1")
              # example response: ['+CGSN: "354347094028575"', 'OK']
              if a[1] != 'OK':
                  return ''
              s = a[0]
              if s[0:7] != '+CGSN: ':
                  return ''
              n = len(s)
              r = s[8:n-1]
              r = ''
          return r
      #                       Get Signal Strength
      def signal_strength():
          # 0-31, 99-unknown
          try:
                  a = at('AT+CSQ')
                  # example response: ['+CSQ: 18,99', 'OK'] where 18 is signal strength
                  if a[1] != 'OK':
                      break
                  s = a[0]
                  if (s[0:6] != "+CSQ: "):
                      break
                  n = len(s)
                  s = s[6:n-1]
                  a = s.split(",")
                  cell_signal = int(a[0])
                  return cell_signal
          # unknown signal strength
          return 99
        tlanier
        It Works!!!
        I have successfully eliminated the need to use the LTE module. All cell modem communication is done by talking directly to the Sequans modem using AT commands. Task switching no longer freezes during modem communication. Hopefully this will also be more reliable.
        Thanks go to "iot2020" and "jcaron" who showed how to initialize the uart to talk to the modem.
        Also, thanks go to the following github site for one of the only examples I found of using the HTTP AT commands for the Sequans modem.
        https://github.com/Avnet/sequans_python/blob/master/http_demo.py
        Here's the modem technical reference manual I used.
        https://docs.pycom.io/gitbook/assets/Monarch-LR5110-ATCmdRefMan-rev6_noConfidential.pdf
        Any comments or suggestions are welcome. All modem communication code is now in Python for everyone to see and improve. Below is a list of the currently implemented functions. Currently they have been written to work in my specific application. They could be rewritten to be more general purpose. For instance in my application I don't even need the HTTP Get function, but an example test is included. All my communication is done using the HTTP Post function.
        All printing is done by calling a utility log function that I have in my application. Here's a simple implementation.
        def log(m):
            print(m)
        List of Functions in Modem Module:
        def at(cmd)
        Attach Cellular Modem To Packet Domain Service
        def attach()
        Check Registration
        def check_registration()
        Detach Cellular Modem From Packet Domain Service
        def detach()
        Disable LTE Modem
        def disable_modem()
        Enable Modem
        def enable_modem()
        Get CFUN - Modem Level of Functionality
        def get_cfun()
        Get Modem Response
        Get SMS Mode
        def get_sms_mode()
        HTTP Post
        def http_post(uri, header, m)
        def iccid()
        def imei()
        Initialize Modem
        def init_modem()
        def init_uart()
        Is Cellular Modem Attached To Packet Domain Service
        def isattached()
        Reset Modem
        def reset_modem()
        Check Modem For Restart/Crash
        def restarted()
        Set SMS Mode To Text
        def set_sms_mode()
        Get Signal Strength
        Delete Read, Sent, and Unsent SMS Messages
        def sms_delete_all()
        Process SMS Messages
        def sms_process(r)
        Read Unread SMS Messages
        def sms_read()
        Read All SMS Messages
        def sms_read_all()
        Wait For N Received Chars
        def wait_rx(n, timeout=10000)
        Wait For Specific Modem Response
        def wait_response(response, msecs=10000)
        Test #1
        def test1()
        Example HTTP Get
        def test2()
        Example HTTP Post
        def test3()
        import globals as g
        import sys
        import util
        from util import log
        uart = None
        def at(cmd):
            try:
                if uart.any() > 0:
                    if len(a) > 0:
                        log("unsolicited modem response: {}".format(a))
                log("  modem command: {}".format(cmd))
                n = uart.write(cmd + '\r')
                if n != len(cmd) + 1:
                    log("error sending command to modem: n = {}".format(n))
                    return []
                a = []
            return a    # return modem response lines in array
        #             Attach Cellular Modem To Packet Domain Service
        def attach():
            try:
                log("attach modem to packet domain service")
                a = at('AT+CGATT=1')
                if a[0] != 'OK':
                    log("error attaching modem")
        #                       Check Registration
        def check_registration():
            # return 0-5, 99-unknown
            # response: ['+CEREG: 2,4', 'OK']
            # response: ['+CEREG: 2,1,"2C29","0B54400F",7', 'OK']
            # 2,0 - not registered, not searching
            # 2,1 - registered, home network
            # 2,2 - not registered, searching
            # 2,3 - registration denied
            # 2,4 - unknown (out of coverage)
            # 2,5 - registered, roaming
            try:
                    log("check registration")
                    a = at('AT+CEREG?')
                    if a[1] != 'OK':
                        break
                    s = a[0]
                    if (s[0:7] != "+CEREG:"):
                        break
                    a = s.split(",")
                    if (a[0] != "+CEREG: 2"):
                        break
                    reg = int(a[1])
                    if reg == 1:
                        log("registered - home network")
                    elif reg == 5:
                        log("registered - roaming")
                        log("not registered")
                    return reg
                log("check registration exception")
            # unknown registration
            log("error checking registration")
            return 99
        #             Detach Cellular Modem From Packet Domain Service
        def detach():
            try:
                log("detach modem from packet domain service")
                a = at('AT+CGATT=0')
                if a[0] != 'OK':
                    log("error detaching modem")
        #                       Disable LTE Modem
        def disable_modem():
            try:
                log("disable modem")
                at("AT+CFUN=4")     # disable both transmit and receive RF circuits
        #                       Enable Modem
        def enable_modem():
            try:
                log("enabling modem")
                a = at("AT+CFUN=1")     # full functionality
                if a[0] != 'OK':
                    log("error enabling modem")
        #                Get CFUN - Modem Level of Functionality
        def get_cfun():
            # 0 - minimum functionality
            # 1 - full functionality
            # 4 - radios disabled but access to SIM allowed
            # -1 - unknown
            # note: if modem does +SHUTDOWN/+SYSSTART, CFUN will be reset to 0
            try:
                    a = at('AT+CFUN?')
                    # response: ['+CFUN: 1', 'OK']
                    if a[1] != 'OK':
                        break
                    s = a[0]
                    if (s[0:6] != "+CFUN:"):
                        break
                    cfun = int(s[7])
                    return cfun
            return -1
            try:
                t0 = ticks_ms()
                    if uart.any() > 0:
                        sleep_ms(50)
                        break
                    t1 = ticks_ms()
                    if tx > 10000:
                        log("timeout error - no modem response after 10 secs")
                        return []
                    sleep_ms(100)
                b = uart.read()
                s = str(b, 'utf-8')
                a = s.split('\r\n')
                log("  modem response: {}".format(a))
                a = []
        #                           Get SMS Mode
        def get_sms_mode():
            # return 0-PDU mode or unknown, 1-text mode
            try:
                log("get SMS mode")
                a = at('AT+CMGF?')
                # response: ['+CMGF: 1', 'OK']
                if (len(a) < 2) or (a[1] != 'OK'):
                    return 0    # mode unknown
                s = a[0]
                if (s[0:6] != '+CMGF:'):
                    return 0    # state unknown
                mode = int(s[7])
                return mode
        #                            HTTP Post
        def http_post(uri, header, m):
            # POST <uri> HTTP/1.1
            # <header>
            # Content-Length: <len(m)>
            # Content-Type: application/octet-stream
            # <blank line>
            try:
                log("HTTP post")
                    # note: init_modem() is used to do "AT+SQNHTTPCFG=..."
                    n = len(m)
                    # log("writing message: {0}".format(m))
                    log("post message length: {0}".format(n))
                    # AT+SQNHTTPSND=<prof_id>,<command>,<resource>,<data_len>[,<post_param>[,<extra_header_line>]]
                    # prof_id=1, command=0 (POST), post_parm="2" (application/octet-stream), header="Host: <host_name>"
                    a = at('AT+SQNHTTPSND=1,0,"{0}",{1},"2","{2}"'.format(uri, n, header))
                    if a[0] != '> ':
                        break
                    uart.write(m)
                    if a[0] != 'OK':
                        break
                    # modem responds with "+SQNHTTPRING: <prof_id,<http_status_code>,<content_type>,<data_size>"
                    s = a[0]
                    if s[0:13] != "+SQNHTTPRING:":
                        break
                    a = s.split(",")
                    n = int(a[3])
                    log("response message length: {0}".format(n))
                    # get response
                    cmd = 'AT+SQNHTTPRCV=1,0\r'
                    log("  modem command: {0}".format(cmd))
                    uart.write(cmd)
                    wait_rx(5, 10000)   # wait for b'\r\n<<<'
                    b = uart.read(5)
                    # log(" modem response: {0}".format(b))
                    if b[2:5] != b'<<<':
                        break
                    wait_rx(n, 10000)   # wait for response
                    b = uart.read(n)
                    if a[0] != 'OK':
                        break
                    log(b)
                    return b
            # some type of error occurred
            return b''
        def iccid():
            # modem must be registered to network to get ICCID
            try:
                log("get SIM card ICCID")
                if a[1] != 'OK':
                    return ''
                s = a[0]
                if s[0:9] != '+SQNCCID:':
                    return ''
                a = s.split(",")
                n = len(a[0])
                r = a[0][11:n-1]
                r = ''
            log("ICCID = {0}".format(r))
            return r    # ICCID as string
        def imei():
            try:
                log("get modem IMEI number")
                a = at("AT+CGSN=1")
                if a[1] != 'OK':
                    return ''
                s = a[0]
                if s[0:6] != '+CGSN:':
                    return ''
                n = len(s)
                r = s[8:n-1]
                r = ''
            log("IMEI = {0}".format(r))
            return r    # IMEI as string
        #                       Initialize Modem
        def init_modem():
            try:
                log("initializing modem")
                if uart == None:
                    init_uart()
                enable_modem()
                # set profile #1 parameters for HTTP connection
                # prof_id=1 (profile), ip, port, auth_type=0 (None), username="", password="",
                # ssl_enabled=0, timeout, cid=1 (PDN Context Identifier)
                server = g.oIni.host_ip     # note: host_name could also be used (auto DNS lookup)
                port = g.oIni.host_port
                timeout = 10    # secs to wait for response from server
                cmd = 'AT+SQNHTTPCFG=1,"{0}",{1},0,"","",0,{2},1'.format(server, port, timeout)
                a = at(cmd)
                if a[0] != 'OK':
                    log("error initializing modem")
                set_sms_mode()
        def init_uart():
            global uart
            # pins=(TXD, RXD, RTS, CTS)
            log("initializing UART")
            # rx_buffer_size: must be > 127, 200000 works, 250000 crashes, http_post seems to work with any size
            uart = UART(1, baudrate=921600, bits=8, parity=None, stop=1, timeout_chars=2, pins=('P5', 'P98', 'P7', 'P99'), rx_buffer_size=512)
        #           Is Cellular Modem Attached To Packet Domain Service
        def isattached():
            # returns: True/False
            try:
                a = at('AT+CGATT?')
                if a[0][0:9] == '+CGATT: 1':
                    return True
            return False
        #                           Reset Modem
        def reset_modem():
            try:
                log("reseting modem...")
                a = at('AT^RESET')
                # generates +SHUTDOWN ... +SYSSTART responses
                if a[0] != 'OK':
                    log("error resetting modem")
                if a[1] != '+SHUTDOWN':
                if a[0] != '+SYSSTART':
        #                  Check Modem For Restart/Crash
        def restarted():
            # return True if modem has crashed / restarted
            try:
                # if CFUN != 1, modem has crashed / restarted
                r = get_cfun()
                if r != 1:
                    return True
                # if SMS text mode is reset to zero, modem has crashed / restarted
                mode = get_sms_mode()
                if mode != 1:
                    return True
                return False
            return True
        #                       Set SMS Mode To Text
        def set_sms_mode():
            try:
                log("set SMS mode to text")
                a = at('AT+CMGF=1')     # set SMS mode to text
                if a[0] != 'OK':
                    log("error setting SMS mode to text")
            # 0-31, 99-unknown
            try:
                    log("check signal strength")
                    a = at('AT+CSQ')
                    if a[1] != 'OK':
                        break
                    s = a[0]
                    if (s[0:5] != "+CSQ:"):
                        break
                    n = len(s)
                    s = s[6:n-1]
                    a = s.split(",")
                    g.oStatus.cell_signal = cell_signal
                    log("signal strength = {0}".format(cell_signal))
                    return cell_signal
            g.oStatus.cell_signal = 99
            log("signal strength unknown")
            return 99
        #             Delete Read, Sent, and Unsent SMS Messages
        def sms_delete():
            try:
                log("delete all READ, SENT, and UNSENT SMS messages")
                a = at('AT+CMGD=1,3')
                if a[0] != 'OK':
                    log("error trying to delete read, sent, and unsent SMS messages")
        #                     Delete All SMS Messages
        def sms_delete_all():
            # doesn't work until some time after lte.attach() is called
            try:
                log("delete all SMS messages")
                a = at('AT+CMGD=1,4')
                if a[0] != 'OK':
                    log("error trying to delete all SMS messages")
        #                     Process SMS Messages
        def sms_process(r):
            # example response:
            # ['+CMGL: 1,"REC READ","+19999999999",,"19/01/07,09:16:53-20"', 'Test3', '+CMGL: 2,"REC READ","+19999999999",,"19/01/07,11:12:30-20"', 'Test4', 'OK']
            try:
                for m in r:
                    if (m[0:5] == "+CMGL"):
                        continue
                    # process SMS messages
        #                      Read Unread SMS Messages
        def sms_read():
            # response example: ['+CMGL: 1,"REC UNREAD","+1999999999",,"19/01/07,09:16:53-20"', 'Test3', 'OK']
            a = at('AT+CMGL="REC UNREAD"')
            return a
        #                       Read All SMS Messages
        def sms_read_all():
            # response example:
            a = at('AT+CMGL="ALL"')
            return a
        #                       Wait For N Received Chars
        def wait_rx(n, timeout=10000):
            # timeout in msecs
            t0 = ticks_ms()
                if uart.any() >= n:
                    break
                t1 = ticks_ms()
                if tx > timeout:
                    return False
            return True
        #                    Wait For Specific Modem Response
        def wait_response(response, msecs=10000):
            log('wait up to {0} msecs for modem response: {1}'.format(msecs, response))
            t0 = ticks_ms()
                try:
                    a = at('AT')
                    for x in a:
                        if x == response:
                            log('****modem response found****: ' + response)
                            return True
                    t1 = ticks_ms()
                    log('{0} msecs'.format(tx))
                    if tx > msecs:
                        log('modem response not found: ' + response)
                        return False
                    sleep_ms(500)
        #                           Test #1
        def test1():
            try:
                log("test basic modem functions")
                if uart == None:
                    init_uart()
                    # reset_modem()
                    enable_modem()
                    set_sms_mode()
                    imei()
                    iccid()
                        r = check_registration()
                        if (r == 1) or (r == 5):
                            # modem registered
                            iccid()
                            attach()
                            return
                        if restarted():
                            print('MODEM crash/restart detected')
                            return
                        signal_strength()
                        sleep_ms(1000)
        #                         Example HTTP Get
        def test2():
            try:
                log("test HTTP get")
                at('AT+SQNHTTPCFG=1,"httpbin.org",80,0,"","",0,120,1')
                # some sites require "User-Agent" header
                #   ex: at('AT+SQNHTTPQRY=1,0,"/","User-Agent: Test1"')
                at('AT+SQNHTTPQRY=1,0,"/get"')
                at('AT+SQNHTTPRCV=1,0')
        #                         Example HTTP Post
        def test3(size=10):
            try:
                log("test HTTP post")
                    a = at('AT+SQNHTTPCFG=1,"httpbin.org",80,0,"","",0,120,1')
                    if a[0] != 'OK':
                        break
                    m = "X"*size
                    log("post message length: {0}".format(size))
                    a = at('AT+SQNHTTPSND=1,0,"/post",{0}'.format(size))
                    if a[0] != '> ':
                        break
                    uart.write(m)
                    if a[0] != 'OK':
                        break
                    s = a[0]
                        break
                    a = s.split(",")
                    n = int(a[3])
                    # get response
                    uart.write(cmd)
                    b = uart.read(5)
                        break
                    b = uart.read(n)
                    if a[0] != 'OK':
                        break
                    log(b)
                    return b
            return b''
        P 1 Reply Last reply Reply Quote 2
          tlanier
          Work Left To Be Done
          • I need to understand what AT commands are needed to properly initialize the modem and set the APN based on the SIM card. This is an area I'm currently fuzzy about. Do bands need to be set? This is stuff that is handled during the creation of the LTE module which I no longer want to use. The answers may come from studying the C code of the LTE module. Currently the code just sets CFUN=1 and everything magically works.
            tlanier
            Improved http_post() function
            This version can receive large files. Tested with file size > 128,000 bytes.
            #                            HTTP Post
            def http_post(uri, header, tx_data):
                # --> AT+SQNHTTPSND=<prof_id>,<command>,<resource>,<data_len>[,<post_param>[,<extra_header_line>]]
                # xx> POST <uri> HTTP/1.1
                # xx> <header>
                # xx> Content-Length: <tx_size>
                # xx> Content-Type: application/octet-stream
                # xx> <blank line>
                # --> <tx_data bytes>
                # <-- OK
                # <-- +SQNHTTPRING: <prof_id,<http_status_code>,<content_type>,<rx_size>
                # --> AT+SQNHTTPRCV=1,0\r
                # <-- /r/n<<<
                # <-- <rx_data bytes>
                # <-- OK
                try:
                    log("HTTP post")
                        # note: init_modem() sets configuration "AT+SQNHTTPCFG=..." at startup
                        tx_size = len(tx_data)
                        # log("writing message: {0}".format(tx_data))
                        log("tx_data length: {0}".format(tx_size))
                        # prof_id=1, command=0 (POST), <uri>, <tx_size>, post_parm="2" (application/octet-stream), header="Host: <host_name>"
                        a = at('AT+SQNHTTPSND=1,0,"{0}",{1},"2","{2}"'.format(uri, tx_size, header))
                        if a[0] != '> ':
                            break   # error
                        uart.write(tx_data)
                        if a[0] != 'OK':
                            break   # error
                        s = a[0]
                            break   # error
                        a = s.split(",")
                        http_status_code = int(a[1])
                        if http_status_code != 200:
                            break   # error
                        rx_size = int(a[3])
                        log("rx_data length: {0}".format(rx_size))
                        # get response
                        uart.write(cmd)
                        r = wait_rx(5, 10000)   # wait for b'\r\n<<<'
                        if r == False:
                            break   # error
                        b = uart.read(5)
                            break   # error
                        t0 = ticks_ms()
                        b = b''
                        n = rx_size     # no. bytes remaining to be read
                            if uart.any() > 0:
                                log("  attempt to read {0} bytes".format(n))
                                bx = uart.read(n)
                                log(" bytes read: {0}".format(len(bx)))
                                # log(" modem response: {0}".format(bx))
                                b = b + bx
                                if len(b) == rx_size:
                                    break   # entire message received
                                n = rx_size - len(b)
                                t0 = ticks_ms()     # reset timeout
                            t1 = ticks_ms()
                            if tx > 10000:
                                log("timeout error receiving response")
                                return b''
                            sleep_ms(400)
                        log(" total bytes read: {0}".format(len(b)))
                        # log(" post response: {0}".format(b))
                        if a[0] != 'OK':
                            break   # error
                        # log(b)
                        return b
                # error
                return b''
            • I Offline
              iot2020 @tlanier
              @tlanier said in Method To Take Control of Cell Modem:
              I use this for the first time initializing:
              send_cmd('AT+CGDCONT=1,"IP","cdp.iot.t-mobile.nl"') # set context 1 to ip and apn to cdp.iot.t-mobile.nl
              send_cmd("AT+SQNAUTOINTERNET=1") # maybe not needed for you use case?
              send_cmd('AT!="clearscanconfig"') # clear band scan config
              send_cmd('AT!="RRC:addScanBand band=8"') # scan for band 8
              send_cmd('AT+COPS=1,2,"20416"') # manually register to plmn 20416 (tmobile nl)
              #send_cmd('AT+COPS=0') # automatically choose plmn
                tlanier @iot2020
                @iot2020, thanks for the suggestions. It's interesting that when I search the Monarch-LR5110 manual neither of the AT!= commands are found.
                  bitvijays @tlanier
                  SQNHTTPSND
                  Hey @tlanier Hope you are doing well. Regarding "Tested with file size > 128,000 bytes" Just curious, how it is able to send such large payload at one go? Is it using fragmentation ? and divide the payload into multiple packets? and then send?
                  J T 2 Replies Last reply Reply Quote 0
                    jcaron @bitvijays
                    @bitvijays HTTP is based on TCP, so any HTTP payload would indeed be sent as multiple packets (the size and number of which depend on the path MTU). TCP normally makes use of windowing, so it would not even necessarily send all at once, it would wait for ACKs along the way and send more as the first ACKs are received.
                    It's interesting how this is all built into the modem itself...
                      tlanier @bitvijays
                      @bitvijays In my case the response to a HTTP Post is a large file (208K file used to update the program). The program hangs in a loop retrieving whatever is in the UART receive buffer until the correct number of bytes is received (or timeout occurs).
                        bitvijays @jcaron
                        @jcaron Agreed. Also, just wanted to confirm about the MTU. Would the MTU for NB-IoT be 680 bits (85 bytes) DL and 1000 bits (125 bytes) UL. Referred Section 8.2 NB-IoT Deployment Guide
                          tlanier
                          A new method has been added to the modem module. It is desirable to use the ICCID to determine which APN to set. One issue to deal with is apparently the ICCID is not valid until registration with the tower is done. The set_apn() method should be called right before doing the attach().
                          To reduce the wear of writing to the non-volatile memory, I read the current value of the APN and skip the write if not necessary. I wonder if the modem does this type of checking internally? Ideally we could just set the APN once at program start, but we can't read the ICCID at that point for some reason. Even though the manual says when CFUN=4 or CFUN=1 access to the SIM is available, reading the ICCID does not work until after registration.
                          To get some context as to how the modem module can be used, I've included example code for a modem_ready() method that uses the modem module.
                          There is still work to be done with the basic at() and get_modem_response() methods. Unsolicited responses are causing problems in some cases. That will be my next area to concentrate on. There seems to be two paths to take when talking to a modem. Path #1 sends a command to the modem and then waits a period of time and assumes the modem has had time to respond completely. Path #2 sends a command to the modem and then watches the data being returned looking for (1) OK, or (2) ERROR anywhere in the response. The responses then must be filtered to only return the particular response line that is desired.
                          #                           Set APN
                          def set_apn():
                              try:
                                  log("set APN")
                                  # ICCID is only valid after registration
                                  r = iccid()[0:5]
                                  if r == "89014":
                                      apn = g.oIni.apn_89014   # Kore AT&T SIM
                                  elif r == "89012":
                                      apn = g.oIni.apn_89012   # Kore T-Mobile SIM
                                  elif r == "89445":
                                      apn = g.oIni.apn_89445   # Hologram SIM
                                  g.oIni.apn = apn
                                  log("APN: {0}".format(apn))
                                  # try to reduce wear of non-volatile memory
                                  a = at('AT+CGDCONT?')
                                  # response --> ['+CGDCONT: 1,"IP","10569.mcs",,,,0,0,0,0,0,0', ...]
                                  s = a[0]
                                  a = s.split(",")
                                  if (a[0] == '+CGDCONT: 1') and (a[1] == '"IP"') and (a[2] == '"'+apn+'"'):
                                      return
                                  # apn needs setting
                                  a = at('AT+CGDCONT=1,"IP","{0}"'.format(apn))
                                  if a[0] != 'OK':
                                      log("error setting APN")
                          #                           Modem Ready
                          def modem_ready():
                              try:
                                  log("** check for modem ready")
                                  # get modem signal strength
                                  g.oStatus.cell_signal = modem.signal_strength()
                                  # handle SMS messages
                                  r = modem.sms_read()
                                  if len(r) > 1:
                                      modem.sms_process(r)
                                      modem.sms_delete()
                                  # check modem registration
                                  r = modem.check_registration()
                                      # wait until registered to set APN
                                      modem.set_apn()
                                      modem.attach()
                                      if modem.isattached():
                                          g.com_secs = 0
                                          return True
                                  reset = False
                                  if g.com_secs > (10*60):
                                      # unable to attach in 10 mins, try resetting modem
                                      reset = True
                                  if modem.restarted():
                                      # modem has crashed / restarted, try resetting modem
                                      reset = True
                                  if reset:
                                      modem.reset_modem()
                                      modem.init_modem()
                                      g.com_secs = 0
                                  return False
                              return False
                            jcaron @tlanier
                            @tlanier you should probably create a GitHub or GitLab repo for your code...
                              tlanier @jcaron
                              @jcaron Thanks for the suggestion. I have been thinking about that. I would need to make the module more general purpose and less specific to my application. My first priority is to make our application more robust and error free.
                              I've thought about creating a general purpose do nothing application that implements multi-threading, a timer interrupt service routine, and the modem module to show how everything fits together. Someone could take the template application and create a full application in no time.
                              Including our method of program updates would also be useful I think.
                                tlanier
                                The new at(cmd, filter="") function is now improved such that unsolicited responses should have no affect. It also allows you to specify the response you are interested in getting back by setting the filter parameter. This simplifies the coding of the rest of the modem module.
                                def at(cmd, filterx=""):
                                    try:
                                        if uart.any() > 0:
                                            a = at_response()
                                            for s in a:
                                                at_process(s)
                                            return []
                                        a = at_response(filterx)
                                        return a
                                        a = []
                                #                     Filter Modem Response
                                def at_filter(a, filterx):
                                    # a is passed as reference value
                                    if filterx == "":
                                        return
                                    # filter response
                                    n = len(filterx)
                                    i = len(a)
                                    while i > 0:
                                        i = i - 1
                                        if a[i][0:n] != filterx:
                                            # remove lines that do not start with filter value
                                            at_process(a[i])
                                            a.pop(i)
                                #                     Process Unsolicited Response
                                def at_process(s):
                                    if s == 'OK':
                                        pass
                                        log("unsolicited modem response: {}".format(s))
                                    return
                                #                       Get AT Command Response
                                def at_response(filterx=""):
                                    try:
                                        t0 = ticks_ms()
                                            if uart.any() > 0:
                                                sleep_ms(50)
                                                break
                                            t1 = ticks_ms()
                                            if tx > 10000:
                                                return []
                                            sleep_ms(100)
                                        b = uart.read()
                                        s = str(b, 'utf-8')
                                        a = s.split('\r\n')
                                        a = []
                                  peterp @tlanier
                                  Hey @tlanier could you elaborate a bit on this point? How to reproduce this freezing?
                                    tlanier
                                    Here's some of the higher level code that uses the modem module.
                                    import globals as g
                                    import modem
                                    from poll import poll
                                    import sys
                                    import uos
                                    import util
                                    import wifi
                                    #                         Communication Task
                                    def com_task():
                                        try:
                                            sleep_ms(500)
                                            log("com_task: started")
                                            wifi.deinit()
                                            modem.reset_modem()
                                            modem.init_modem()
                                            g.poll_host = True      # triggers poll at startup
                                            try:
                                                if modem_ready():
                                                    if ready_to_poll():
                                                        modem.set_apn()
                                                        transmit()
                                                sleep_ms(2000)
                                    #                           Modem Ready
                                    def modem_ready():
                                        try:
                                                # registered
                                                g.com_secs = 0
                                                if len(r) > 1:
                                                    modem.sms_delete()
                                                return True
                                            reset = False
                                                reset = True
                                                reset = True
                                            if reset:
                                                modem.reset_modem()
                                                modem.init_modem()
                                                g.com_secs = 0
                                            return False
                                        return False
                                      tlanier @peterp
                                      @peterp Sorry to take so long to respond. I wanted to finish updating my posts showing the new code that seems to be working well. Soon I should be able to post the entire refined code. Maybe it will help others with the same problems we have had.
                                      The reason I went down this development path was as described originally:
                                      "I currently have a program working in production using Pycom MicroPython V1.20.0.rc13 on many units. When I try to run the same program on a newly purchased GPy running Pycom MicroPython 1.20.2.r3, the program crashes (20 sec watchdog timeout) when I do an AT command ('AT+CEREG?') after disconnecting from a successful transmission. How do I troubleshoot such a crash?"
                                      Our original reason for picking Pycom and GPy was the thinking that all the modem complexity would be handled by the high level LTE module. It's only a guess but our thinking that since the crashes always happened during times communicating with the modem, the LTE module was the likely source of the problem.
                                      The new method seems to be superior from the standpoint of interference with multiple tasks. Since we always call non-blocking uart commands, the code should never get hung in the C code for any period. A simple example of the LTE module code freezing multi-tasking is to do a simple modem reset. Reading and writing to the file storage also has a minor affect. The real reason for the development was to try to eliminate program crashes. Only longer term testing will show whether we have achieved that goal.
                                      One concern I do have is whether I am properly initializing the cell modem. Any input from anybody out there that is more familiar with properly setting up the LTE modem would be appreciated. It seems to work fine at this point; however, I'm not sure whether it's working because the GPy I'm testing with has run the LTE initialization at some point in the past and that has possibly setup the non-volatile memory of the modem to the proper settings that are needed.
                                      One drawback of using this method of transmission is it is not compatible with WIFI connections. That is not an issue for us at this time. Maybe later we can research how to do some form of communication that is compatible with both WIFI and direct AT commands. I assume that involves using the socket commands of the modem, but this is an area I'm not sure about at this time.
                                      • K Offline
                                        kjm @tlanier
                                        @tlanier Admire your efforts squire. I've been struggling with lte for a year or so now. It's not perfect (the lte.isattached() gets confused sometimes) but I got it robust enough to be usable. I use the requests library for data transfer & my main complaint is that it can't be timed out. I modified it with machine.WDT so that I can abort in a timely manner but I'd like a better solution. Am I right in thinking your wait_rx(n, 10000) allows you to quit if http post/get times out after 10s?
                                        T 3 Replies Last reply Reply Quote 0
                                          tlanier @kjm
                                          @kjm I think I remember having to modify urequests also. Here's what I currently use in my old version that is working.
                                          import usocket
                                          import util
                                          class Response:
                                              def __init__(self, f):
                                                  self.raw = f
                                                  self.encoding = "utf-8"
                                                  self._cached = None
                                              def close(self):
                                                  if self.raw:
                                                      self.raw.close()
                                                      self.raw = None
                                                  self._cached = None
                                              @property
                                              def content(self):
                                                  if self._cached is None:
                                                      try:
                                                          self._cached = self.raw.read()
                                                      finally:
                                                          self.raw.close()
                                                          self.raw = None
                                                  return self._cached
                                              @property
                                              def text(self):
                                                  return str(self.content, self.encoding)
                                              def json(self):
                                                  import ujson
                                                  return ujson.loads(self.content)
                                          def request(method, url, data=None, json=None, headers={}, stream=None):
                                              try:
                                                  proto, dummy, host, path = url.split("/", 3)
                                              except ValueError:
                                                  proto, dummy, host = url.split("/", 2)
                                                  path = ""
                                              if proto == "http:":
                                                  port = 80
                                              elif proto == "https:":
                                                  import ussl
                                                  port = 443
                                                  raise ValueError("Unsupported protocol: " + proto)
                                              if ":" in host:
                                                  host, port = host.split(":", 1)
                                                  port = int(port)
                                              # ai = usocket.getaddrinfo(host, port, 0, usocket.SOCK_STREAM)  # PATCH
                                              ai = usocket.getaddrinfo(host, port)
                                              ai = ai[0]
                                              s = usocket.socket(ai[0], ai[1], ai[2])
                                              try:
                                                  s.settimeout(20)
                                                  s.connect(ai[-1])
                                                      s = ussl.wrap_socket(s, server_hostname=host)
                                                  s.write(b"%s /%s HTTP/1.0\r\n" % (method, path))
                                                  if not "Host" in headers:
                                                      s.write(b"Host: %s\r\n" % host)
                                                  # Iterate over keys to avoid tuple alloc
                                                  for k in headers:
                                                      s.write(k)
                                                      s.write(b": ")
                                                      s.write(headers[k])
                                                      s.write(b"\r\n")
                                                  if json is not None:
                                                      assert data is None
                                                      import ujson
                                                      data = ujson.dumps(json)
                                                      s.write(b"Content-Type: application/json\r\n")
                                                  if data:
                                                      s.write(b"Content-Length: %d\r\n" % len(data))
                                                  s.write(b"\r\n")
                                                  if data:
                                                      s.write(data)
                                                  l = s.readline()
                                                  #print(l)
                                                  l = l.split(None, 2)
                                                  status = int(l[1])
                                                  reason = ""
                                                  if len(l) > 2:
                                                      reason = l[2].rstrip()
                                                      l = s.readline()
                                                      if not l or l == b"\r\n":
                                                          break
                                                      #print(l)
                                                      if l.startswith(b"Transfer-Encoding:"):
                                                          if b"chunked" in l:
                                                              raise ValueError("Unsupported " + l)
                                                      elif l.startswith(b"Location:") and not 200 <= status <= 299:
                                                          raise NotImplementedError("Redirects not yet supported")
                                          #   except OSError:     # PATCH
                                              except:
                                                  s.close()
                                                  raise
                                              resp = Response(s)
                                              resp.status_code = status
                                              resp.reason = reason
                                              return resp
                                          def head(url, **kw):
                                              return request("HEAD", url, **kw)
                                          def get(url, **kw):
                                              return request("GET", url, **kw)
                                          def post(url, **kw):
                                              return request("POST", url, **kw)
                                          def put(url, **kw):
                                              return request("PUT", url, **kw)
                                          def patch(url, **kw):
                                              return request("PATCH", url, **kw)
                                          def delete(url, **kw):
                                              return request("DELETE", url, **kw)
                                            tlanier @kjm
                                            @kjm Thanks for the comment. The intention of wait_rx(n, timeout=10000) is to be a non-blocking call that waits for N chars to come into the uart or to timeout after 10,000 msecs by default. N should be less than the buffer size of the uart which is currently set to 512 bytes.
                                            In looking at my current code, I see a bug. I should have had a sleep command in the while loop to make multi-tasking more efficient. Here's the corrected code. Thanks again!
                                                # timeout in msecs
                                                t0 = ticks_ms()
                                                    if uart.any() >= n:
                                                        break
                                                    t1 = ticks_ms()
                                                    if tx > timeout:
                                                        return False
                                                    sleep_ms(10)
                                                return True
                                            • 1 / 3
