    Method To Take Control of Cell Modem
    41 Posts 10 Posters 902 Views 14 Watching
      bitvijays @jcaron
      @jcaron Agreed. Also, just wanted to confirm about the MTU. Would the MTU for NB-IoT be 680 bits (85 bytes) DL and 1000 bits (125 bytes) UL. Referred Section 8.2 NB-IoT Deployment Guide
        tlanier
        A new method has been added to the modem module. It is desirable to use the ICCID to determine which APN to set. One issue to deal with is apparently the ICCID is not valid until registration with the tower is done. The set_apn() method should be called right before doing the attach().
        To reduce the wear of writing to the non-volatile memory, I read the current value of the APN and skip the write if not necessary. I wonder if the modem does this type of checking internally? Ideally we could just set the APN once at program start, but we can't read the ICCID at that point for some reason. Even though the manual says when CFUN=4 or CFUN=1 access to the SIM is available, reading the ICCID does not work until after registration.
        To get some context as to how the modem module can be used, I've included example code for a modem_ready() method that uses the modem module.
        There is still work to be done with the basic at() and get_modem_response() methods. Unsolicited responses are causing problems in some cases. That will be my next area to concentrate on. There seems to be two paths to take when talking to a modem. Path #1 sends a command to the modem and then waits a period of time and assumes the modem has had time to respond completely. Path #2 sends a command to the modem and then watches the data being returned looking for (1) OK, or (2) ERROR anywhere in the response. The responses then must be filtered to only return the particular response line that is desired.
        #                           Set APN
        def set_apn():
            try:
                log("set APN")
                # ICCID is only valid after registration
                r = iccid()[0:5]
                if r == "89014":
                    apn = g.oIni.apn_89014   # Kore AT&T SIM
                elif r == "89012":
                    apn = g.oIni.apn_89012   # Kore T-Mobile SIM
                elif r == "89445":
                    apn = g.oIni.apn_89445   # Hologram SIM
                g.oIni.apn = apn
                log("APN: {0}".format(apn))
                # try to reduce wear of non-volatile memory
                a = at('AT+CGDCONT?')
                # response --> ['+CGDCONT: 1,"IP","10569.mcs",,,,0,0,0,0,0,0', ...]
                s = a[0]
                a = s.split(",")
                if (a[0] == '+CGDCONT: 1') and (a[1] == '"IP"') and (a[2] == '"'+apn+'"'):
                    return
                # apn needs setting
                a = at('AT+CGDCONT=1,"IP","{0}"'.format(apn))
                if a[0] != 'OK':
                    log("error setting APN")
            except Exception as ex:
                sys.print_exception(ex)
        #                           Modem Ready
        def modem_ready():
            try:
                log("** check for modem ready")
                # get modem signal strength
                g.oStatus.cell_signal = modem.signal_strength()
                # handle SMS messages
                r = modem.sms_read()
                if len(r) > 1:
                    modem.sms_process(r)
                    modem.sms_delete()
                # check modem registration
                r = modem.check_registration()
                if (r == 1) or (r == 5):
                    # wait until registered to set APN
                    modem.set_apn()
                    modem.attach()
                    if modem.isattached():
                        g.com_secs = 0
                        return True
                reset = False
                if g.com_secs > (10*60):
                    # unable to attach in 10 mins, try resetting modem
                    reset = True
                if modem.restarted():
                    # modem has crashed / restarted, try resetting modem
                    reset = True
                if reset:
                    modem.reset_modem()
                    modem.init_modem()
                    g.com_secs = 0
                return False
            return False
          jcaron @tlanier
          @tlanier you should probably create a GitHub or GitLab repo for your code...
            tlanier @jcaron
            @jcaron Thanks for the suggestion. I have been thinking about that. I would need to make the module more general purpose and less specific to my application. My first priority is to make our application more robust and error free.
            I've thought about creating a general purpose do nothing application that implements multi-threading, a timer interrupt service routine, and the modem module to show how everything fits together. Someone could take the template application and create a full application in no time.
            Including our method of program updates would also be useful I think.
              tlanier
              The new at(cmd, filter="") function is now improved such that unsolicited responses should have no affect. It also allows you to specify the response you are interested in getting back by setting the filter parameter. This simplifies the coding of the rest of the modem module.
              #                     Send AT Command To Modem
              def at(cmd, filterx=""):
                  try:
                      if uart.any() > 0:
                          # get unsolicited modem response
                          a = at_response()
                          for s in a:
                              at_process(s)
                      log("  modem command: {}".format(cmd))
                      # send command to modem
                      n = uart.write(cmd + '\r')
                      if n != len(cmd) + 1:
                          log("error sending command to modem: n = {}".format(n))
                          return []
                      a = at_response(filterx)
                      return a
                      a = []
                  return a    # return modem response lines in array
              #                     Filter Modem Response
              def at_filter(a, filterx):
                  # a is passed as reference value
                  if filterx == "":
                      return
                  # filter response
                  n = len(filterx)
                  i = len(a)
                  while i > 0:
                      i = i - 1
                      if a[i][0:n] != filterx:
                          # remove lines that do not start with filter value
                          at_process(a[i])
                          a.pop(i)
              #                     Process Unsolicited Response
              def at_process(s):
                  if s == 'OK':
                      pass
                      log("unsolicited modem response: {}".format(s))
                  return
              #                       Get AT Command Response
              def at_response(filterx=""):
                  try:
                      t0 = ticks_ms()
                          if uart.any() > 0:
                              # insure entire response has been received
                              sleep_ms(50)
                              break
                          t1 = ticks_ms()
                          tx = ticks_diff(t1, t0)
                          if tx > 10000:
                              log("timeout error - no modem response after 10 secs")
                              return []
                          sleep_ms(100)
                      b = uart.read()
                      s = str(b, 'utf-8')
                      a = s.split('\r\n')
                      a = list(filter(None, a))
                      log("  modem response: {}".format(a))
                      a = []
                peterp @tlanier
                Hey @tlanier could you elaborate a bit on this point? How to reproduce this freezing?
                Task switching no longer freezes during modem communication.
                  tlanier
                  Here's some of the higher level code that uses the modem module.
                  import globals as g
                  import modem
                  from poll import poll
                  import sys
                  import uos
                  import util
                  from util import log
                  from utime import sleep_ms
                  import wifi
                  #                         Communication Task
                  def com_task():
                      try:
                          sleep_ms(500)
                          log("com_task: started")
                          wifi.deinit()
                          modem.reset_modem()
                          modem.init_modem()
                          g.poll_host = True      # triggers poll at startup
                          try:
                              if modem_ready():
                                  if ready_to_poll():
                                      modem.set_apn()
                                      transmit()
                              sleep_ms(2000)
                  #                           Modem Ready
                  def modem_ready():
                      try:
                              # registered
                              g.com_secs = 0
                              if len(r) > 1:
                                  modem.sms_delete()
                              return True
                          reset = False
                              reset = True
                              reset = True
                          if reset:
                              modem.reset_modem()
                              modem.init_modem()
                              g.com_secs = 0
                          return False
                      return False
                    tlanier @peterp
                    @peterp Sorry to take so long to respond. I wanted to finish updating my posts showing the new code that seems to be working well. Soon I should be able to post the entire refined code. Maybe it will help others with the same problems we have had.
                    The reason I went down this development path was as described originally:
                    "I currently have a program working in production using Pycom MicroPython V1.20.0.rc13 on many units. When I try to run the same program on a newly purchased GPy running Pycom MicroPython 1.20.2.r3, the program crashes (20 sec watchdog timeout) when I do an AT command ('AT+CEREG?') after disconnecting from a successful transmission. How do I troubleshoot such a crash?"
                    Our original reason for picking Pycom and GPy was the thinking that all the modem complexity would be handled by the high level LTE module. It's only a guess but our thinking that since the crashes always happened during times communicating with the modem, the LTE module was the likely source of the problem.
                    The new method seems to be superior from the standpoint of interference with multiple tasks. Since we always call non-blocking uart commands, the code should never get hung in the C code for any period. A simple example of the LTE module code freezing multi-tasking is to do a simple modem reset. Reading and writing to the file storage also has a minor affect. The real reason for the development was to try to eliminate program crashes. Only longer term testing will show whether we have achieved that goal.
                    One concern I do have is whether I am properly initializing the cell modem. Any input from anybody out there that is more familiar with properly setting up the LTE modem would be appreciated. It seems to work fine at this point; however, I'm not sure whether it's working because the GPy I'm testing with has run the LTE initialization at some point in the past and that has possibly setup the non-volatile memory of the modem to the proper settings that are needed.
                    One drawback of using this method of transmission is it is not compatible with WIFI connections. That is not an issue for us at this time. Maybe later we can research how to do some form of communication that is compatible with both WIFI and direct AT commands. I assume that involves using the socket commands of the modem, but this is an area I'm not sure about at this time.
                    • K Offline
                      kjm @tlanier
                      @tlanier Admire your efforts squire. I've been struggling with lte for a year or so now. It's not perfect (the lte.isattached() gets confused sometimes) but I got it robust enough to be usable. I use the requests library for data transfer & my main complaint is that it can't be timed out. I modified it with machine.WDT so that I can abort in a timely manner but I'd like a better solution. Am I right in thinking your wait_rx(n, 10000) allows you to quit if http post/get times out after 10s?
                      T 3 Replies Last reply Reply Quote 0
                        tlanier @kjm
                        @kjm I think I remember having to modify urequests also. Here's what I currently use in my old version that is working.
                        import usocket
                        import util
                        class Response:
                            def __init__(self, f):
                                self.raw = f
                                self.encoding = "utf-8"
                                self._cached = None
                            def close(self):
                                if self.raw:
                                    self.raw.close()
                                    self.raw = None
                                self._cached = None
                            @property
                            def content(self):
                                if self._cached is None:
                                    try:
                                        self._cached = self.raw.read()
                                    finally:
                                        self.raw.close()
                                        self.raw = None
                                return self._cached
                            @property
                            def text(self):
                                return str(self.content, self.encoding)
                            def json(self):
                                import ujson
                                return ujson.loads(self.content)
                        def request(method, url, data=None, json=None, headers={}, stream=None):
                            try:
                                proto, dummy, host, path = url.split("/", 3)
                            except ValueError:
                                proto, dummy, host = url.split("/", 2)
                                path = ""
                            if proto == "http:":
                                port = 80
                            elif proto == "https:":
                                import ussl
                                port = 443
                                raise ValueError("Unsupported protocol: " + proto)
                            if ":" in host:
                                host, port = host.split(":", 1)
                                port = int(port)
                            # ai = usocket.getaddrinfo(host, port, 0, usocket.SOCK_STREAM)  # PATCH
                            ai = usocket.getaddrinfo(host, port)
                            ai = ai[0]
                            s = usocket.socket(ai[0], ai[1], ai[2])
                            try:
                                s.settimeout(20)
                                s.connect(ai[-1])
                                    s = ussl.wrap_socket(s, server_hostname=host)
                                s.write(b"%s /%s HTTP/1.0\r\n" % (method, path))
                                if not "Host" in headers:
                                    s.write(b"Host: %s\r\n" % host)
                                # Iterate over keys to avoid tuple alloc
                                for k in headers:
                                    s.write(k)
                                    s.write(b": ")
                                    s.write(headers[k])
                                    s.write(b"\r\n")
                                if json is not None:
                                    assert data is None
                                    import ujson
                                    data = ujson.dumps(json)
                                    s.write(b"Content-Type: application/json\r\n")
                                if data:
                                    s.write(b"Content-Length: %d\r\n" % len(data))
                                s.write(b"\r\n")
                                if data:
                                    s.write(data)
                                l = s.readline()
                                #print(l)
                                l = l.split(None, 2)
                                status = int(l[1])
                                reason = ""
                                if len(l) > 2:
                                    reason = l[2].rstrip()
                                    l = s.readline()
                                    if not l or l == b"\r\n":
                                        break
                                    #print(l)
                                    if l.startswith(b"Transfer-Encoding:"):
                                        if b"chunked" in l:
                                            raise ValueError("Unsupported " + l)
                                    elif l.startswith(b"Location:") and not 200 <= status <= 299:
                                        raise NotImplementedError("Redirects not yet supported")
                        #   except OSError:     # PATCH
                            except:
                                s.close()
                                raise
                            resp = Response(s)
                            resp.status_code = status
                            resp.reason = reason
                            return resp
                        def head(url, **kw):
                            return request("HEAD", url, **kw)
                        def get(url, **kw):
                            return request("GET", url, **kw)
                        def post(url, **kw):
                            return request("POST", url, **kw)
                        def put(url, **kw):
                            return request("PUT", url, **kw)
                        def patch(url, **kw):
                            return request("PATCH", url, **kw)
                        def delete(url, **kw):
                            return request("DELETE", url, **kw)
                          tlanier @kjm
                          @kjm Thanks for the comment. The intention of wait_rx(n, timeout=10000) is to be a non-blocking call that waits for N chars to come into the uart or to timeout after 10,000 msecs by default. N should be less than the buffer size of the uart which is currently set to 512 bytes.
                          In looking at my current code, I see a bug. I should have had a sleep command in the while loop to make multi-tasking more efficient. Here's the corrected code. Thanks again!
                          #                       Wait For N Received Chars
                          def wait_rx(n, timeout=10000):
                              # timeout in msecs
                              t0 = ticks_ms()
                                  if uart.any() >= n:
                                      break
                                  t1 = ticks_ms()
                                  if tx > timeout:
                                      return False
                                  sleep_ms(10)
                              return True
                            tlanier @kjm
                            @kjm What would really be neat is if we could learn how to put the modem in a mode that allowed the urequests/usockets libraries to work using just AT commands!
                            I suspect it has to do with the AT+CGDCONT parameter named PDP_type. The manual shows the following values:
                            X.25 ITU-T/CCITT X.25 layer 3 (Obsolete)
                            IP Internet Protocol (IETF STD 5 [103])
                            IPV6 Internet Protocol, version 6 (see RFC 2460 [106])
                            IPV4V6 Virtual <PDP_type> introduced to handle dual IP stack UE capability. (See
                            3GPP TS 24.301 [83])
                            OSPIH Internet Hosted Octect Stream Protocol (Obsolete)
                            PPP Point to Point Protocol (IETF STD 51 [104])
                            Non-IP Transfer of Non-IP data to external packet data network (see 3GPP TS 23.401
                            This is an area I'm unsure about. I would welcome comments from others about what would need to be done.
                              tlanier
                              Here's updated code that is now running on two units overnight with good success. The code handles unsolicited responses gracefully. The code is non-intrusive to other multi-tasking threads. The code has not crashed (more testing to be done for sure). The code is easy to understand; everything is there to see and improve (no hidden commands being sent to the modem).
                              # MODEM.PY Module
                              import globals as g
                              from machine import UART
                              import micropython
                              import sys
                              import util
                              from utime import sleep_ms, ticks_ms, ticks_diff
                              uart = None
                                  try:
                                      if uart.any() > 0:
                                          a = at_response()
                                          for s in a:
                                              at_process(s)
                                          return []
                                      return a
                                      a = []
                                  if filterx == "":
                                      return
                                  # filter response
                                  n = len(filterx)
                                  i = len(a)
                                  while i > 0:
                                      i = i - 1
                                          at_process(a[i])
                                          a.pop(i)
                              def at_process(s):
                                  if s == 'OK':
                                      pass
                                  return
                                  try:
                                      t0 = ticks_ms()
                                          if uart.any() > 0:
                                              sleep_ms(50)
                                              break
                                          t1 = ticks_ms()
                                          if tx > 10000:
                                              return []
                                          sleep_ms(100)
                                      b = uart.read()
                                      s = str(b, 'utf-8')
                                      a = s.split('\r\n')
                                      a = []
                              #             Attach Cellular Modem To Packet Domain Service
                              def attach():
                                  try:
                                      log("attach modem to packet domain service")
                                      a = at('AT+CGATT=1','OK')
                                      if len(a) == 0:
                                          log("error attaching modem")
                              #                       Check Registration
                              def check_registration():
                                  # return 0-5, 99-unknown
                                  # response: ['+CEREG: 2,4', 'OK']
                                  # response: ['+CEREG: 2,1,"2C29","0B54400F",7', 'OK']
                                  # 2,0 - not registered, not searching
                                  # 2,1 - registered, home network
                                  # 2,2 - not registered, searching
                                  # 2,3 - registration denied
                                  # 2,4 - unknown (out of coverage)
                                  # 2,5 - registered, roaming
                                  try:
                                          log("check registration")
                                          a = at('AT+CEREG?','+CEREG:')
                                          if len(a) == 0:
                                              break
                                          a = a[0].split(",")
                                          if (a[0] != "+CEREG: 2"):
                                              break
                                          reg = int(a[1])
                                          if reg == 1:
                                              log("registered - home network")
                                          elif reg == 5:
                                              log("registered - roaming")
                                              log("not registered")
                                          return reg
                                      log("check registration exception")
                                  # unknown registration
                                  log("error checking registration")
                                  return 99
                              #             Detach Cellular Modem From Packet Domain Service
                              def detach():
                                  # modem does not get SMS messages while the modem is detached
                                  # old messages received while detached are only received when a new message is sent while attached
                                  try:
                                      log("detach modem from packet domain service")
                                      a = at('AT+CGATT=0','OK')
                                      if len(a) == 0:
                                          log("error detaching modem")
                              #                       Disable LTE Modem
                              def disable_modem():
                                  try:
                                      log("disable modem")
                                      a = at('AT+CFUN=0','OK')     # minimum functionality
                                      if len(a) == 0:
                                          log("error disabling modem")
                              #                       Enable Modem
                              def enable_modem():
                                  try:
                                      log("enabling modem")
                                      a = at('AT+CFUN=1','OK')     # full functionality
                                      if len(a) == 0:
                                          log("error enabling modem")
                              #                Get CFUN - Modem Level of Functionality
                              def get_cfun():
                                  # 0 - minimum functionality
                                  # 1 - full functionality
                                  # 4 - radios disabled but access to SIM allowed
                                  # -1 - unknown
                                  # note: if modem does +SHUTDOWN/+SYSSTART, CFUN will be reset to 0
                                  try:
                                          a = at('AT+CFUN?','+CFUN:')
                                          # response: ['+CFUN: 1', 'OK']
                                          if len(a) == 0:
                                              break
                                          cfun = int(a[0][7])
                                          return cfun
                                  return -1
                              #                           Get SMS Mode
                              def get_sms_mode():
                                  # return 0-PDU mode or unknown, 1-text mode
                                  try:
                                      log("get SMS mode")
                                      a = at('AT+CMGF?','+CMGF:')
                                      # response: ['+CMGF: 1', 'OK']
                                      if len(a) == 0:
                                          return 0    # mode unknown
                                      mode = int(a[0][7])
                                      return mode
                              #                            HTTP Post
                              def http_post(uri, header, tx_data):
                                  # --> AT+SQNHTTPSND=<prof_id>,<command>,<resource>,<data_len>[,<post_param>[,<extra_header_line>]]
                                  # xx> POST <uri> HTTP/1.1
                                  # xx> <header>
                                  # xx> Content-Length: <tx_size>
                                  # xx> Content-Type: application/octet-stream
                                  # xx> <blank line>
                                  # --> <tx_data bytes>
                                  # <-- OK
                                  # <-- +SQNHTTPRING: <prof_id,<http_status_code>,<content_type>,<rx_size>
                                  # --> AT+SQNHTTPRCV=1,0\r
                                  # <-- /r/n<<<
                                  # <-- <rx_data bytes>
                                  # <-- OK
                                  try:
                                      log("HTTP post")
                                          # note: init_modem() sets configuration "AT+SQNHTTPCFG=..." at startup
                                          tx_size = len(tx_data)
                                          # log("writing message: {0}".format(tx_data))
                                          log("tx_data length: {0}".format(tx_size))
                                          # AT+SQNHTTPSND=<prof_id>,<command>,<resource>,<data_len>[,<post_param>[,<extra_header_line>]]
                                          # prof_id=1, command=0 (POST), <uri>, <tx_size>, post_parm="2" (application/octet-stream), header="Host: <host_name>"
                                          a = at('AT+SQNHTTPSND=1,0,"{0}",{1},"2","{2}"'.format(uri, tx_size, header),'> ')
                                          if len(a) == 0:
                                              break   # error
                                          uart.write(tx_data)
                                          a = at_response('OK')
                                          if len(a) == 0:
                                              break   # error
                                          # modem responds with "+SQNHTTPRING: <prof_id,<http_status_code>,<content_type>,<data_size>"
                                          a = at_response("+SQNHTTPRING:")
                                          if len(a) == 0:
                                              break   # error
                                          a = a[0].split(",")
                                          http_status_code = int(a[1])
                                          if http_status_code != 200:
                                              break   # error
                                          rx_size = int(a[3])
                                          log("rx_data length: {0}".format(rx_size))
                                          # get response
                                          cmd = 'AT+SQNHTTPRCV=1,0\r'
                                          log("  modem command: {0}".format(cmd))
                                          uart.write(cmd)
                                          r = wait_rx(5, 10000)   # wait for b'\r\n<<<'
                                          if r == False:
                                              break   # error
                                          b = uart.read(5)
                                          # log(" modem response: {0}".format(b))
                                          if b[2:5] != b'<<<':
                                              break   # error
                                          t0 = ticks_ms()
                                          b = b''
                                          n = rx_size     # no. bytes remaining to be read
                                              if uart.any() > 0:
                                                  log("attempt to read {0} bytes".format(n))
                                                  bx = uart.read(n)
                                                  log("bytes read: {0}".format(len(bx)))
                                                  # log(" modem response: {0}".format(bx))
                                                  b = b + bx
                                                  if len(b) == rx_size:
                                                      break   # entire message received
                                                  n = rx_size - len(b)
                                                  t0 = ticks_ms()     # reset timeout
                                              t1 = ticks_ms()
                                              if tx > 10000:
                                                  log("timeout error receiving response")
                                                  return b''
                                              sleep_ms(400)
                                          log("total bytes read: {0}".format(len(b)))
                                          # log(" post response: {0}".format(b))
                                          if len(a) == 0:
                                              break   # error
                                          # log(b)
                                          return b
                                  # error
                                  return b''
                              #                     Get SIM Card ICCID Number
                              def iccid():
                                  # CFUN must be 1 or 4
                                  try:
                                      log("get SIM card ICCID")
                                      a = at('AT+SQNCCID?','+SQNCCID:')
                                      # example response: ['+SQNCCID: "89014103271203065543",""', 'OK']
                                      if len(a) == 0:
                                          return ''
                                      a = a[0].split(",")
                                      n = len(a[0])
                                      r = a[0][11:n-1]
                                      r = ''
                                  log("ICCID = {0}".format(r))
                                  return r    # ICCID as string
                              #                       Get Modem IMEI Number
                              def imei():
                                  try:
                                      log("get modem IMEI number")
                                      a = at('AT+CGSN=1','+CGSN:')
                                      # example response: ['+CGSN: "354347094028575"', 'OK']
                                      if len(a) == 0:
                                          return ''
                                      n = len(a[0])
                                      r = a[0][8:n-1]
                                      r = ''
                                  log("IMEI = {0}".format(r))
                                  return r    # IMEI as string
                              #                       Initialize Modem
                              def init_modem():
                                  try:
                                      log("initializing modem")
                                      if uart == None:
                                          init_uart()
                                      disable_modem()
                                      # set profile #1 parameters for HTTP connection
                                      # prof_id=1 (profile), ip, port, auth_type=0 (None), username="", password="",
                                      # ssl_enabled=0, timeout, cid=1 (PDN Context Identifier)
                                      server = g.oIni.host_ip     # note: host_name could also be used (auto DNS lookup)
                                      port = g.oIni.host_port
                                      timeout = 10    # secs to wait for response from server
                                      cmd = 'AT+SQNHTTPCFG=1,"{0}",{1},0,"","",0,{2},1'.format(server, port, timeout)
                                      a = at(cmd,'OK')
                                      if len(a) == 0:
                                          log("error initializing modem")
                                      set_sms_mode()
                                      enable_modem()
                              #               Initialize Uart Connected To LTE Modem
                              def init_uart():
                                  global uart
                                  # pins=(TXD, RXD, RTS, CTS)
                                  # FiPy: pins=('P20', 'P18', 'P19', 'P17')
                                  # GPy:  pins=('P5', 'P98', 'P7', 'P99')
                                  log("initializing UART")
                                  # rx_buffer_size: must be > 127, 200000 works, 250000 crashes, http_post seems to work with any size
                                  uart = UART(1, baudrate=921600, bits=8, parity=None, stop=1, timeout_chars=2, pins=('P5', 'P98', 'P7', 'P99'), rx_buffer_size=512)
                              #           Is Cellular Modem Attached To Packet Domain Service
                              def isattached():
                                  # returns: True/False
                                  try:
                                      a = at('AT+CGATT?','+CGATT:')
                                      # example response: ['+CGATT: 0', 'OK']
                                      if len(a) == 0:
                                          return False
                                      if a[0][8] == '1':
                                          return True
                                  return False
                              #                           Reset Modem
                              def reset_modem():
                                  try:
                                      if uart == None:
                                          init_uart()
                                      log("reseting modem...")
                                      a = at('AT^RESET','+SHUTDOWN')
                                      # generates +SHUTDOWN ... +SYSSTART responses
                                      if len(a) == 0:
                                          log("error resetting modem - no +SHUTDOWN")
                                      a = at_response('+SYSSTART')
                                      if len(a) == 0:
                                          log("error resetting modem - no +SYSSTART")
                              #                  Check Modem For Restart/Crash
                              def restarted():
                                  # return True if modem has crashed / restarted
                                  try:
                                      # if CFUN != 1, modem has crashed / restarted
                                      cfun = get_cfun()
                                      if cfun != 1:
                                          return True
                                      # if SMS text mode is reset to zero, modem has crashed / restarted
                                      mode = get_sms_mode()
                                      if mode != 1:
                                          return True
                                      return False
                                  return True
                              #                           Set APN
                              def set_apn():
                                  try:
                                      log("set APN")
                                      r = iccid()[0:5]
                                      if r == "89014":
                                      elif r == "89012":
                                      elif r == "89445":
                                      g.oIni.apn = apn
                                      a = at('AT+CGDCONT?','+CGDCONT:')
                                      if len(a) > 0:
                                          a = a[0].split(",")
                                              return
                                      # apn needs setting
                                      cmd = 'AT+CGDCONT=1,"IP","{0}"'.format(apn)
                                      a = at(cmd,'OK')
                                      if len(a) == 0:
                              #                       Set SMS Mode To Text
                              def set_sms_mode():
                                  try:
                                      log("set SMS mode to text")
                                      a = at('AT+CMGF=1','OK')     # set SMS mode to text
                                      if len(a) == 0:
                                          log("error setting SMS mode to text")
                              #                       Get Signal Strength
                              def signal_strength():
                                  # 0-31, 99-unknown
                                  try:
                                          log("check signal strength")
                                          a = at('AT+CSQ','+CSQ:')
                                          # example response: ['+CSQ: 18,99', 'OK'] where 18 is signal strength
                                          if len(a) == 0:
                                              break
                                          n = len(a[0])
                                          s = a[0][6:n-1]
                                          a = s.split(",")
                                          cell_signal = int(a[0])
                                          g.oStatus.cell_signal = cell_signal
                                          log("signal strength = {0}".format(cell_signal))
                                          return cell_signal
                                  # unknown signal strength
                                  g.oStatus.cell_signal = 99
                                  log("signal strength unknown")
                                  return 99
                              #             Delete Read, Sent, and Unsent SMS Messages
                              def sms_delete():
                                  try:
                                      log("delete all READ, SENT, and UNSENT SMS messages")
                                      a = at('AT+CMGD=1,3','OK')
                                      if len(a) == 0:
                                          log("error trying to delete read, sent, and unsent SMS messages")
                              #                     Delete All SMS Messages
                              def sms_delete_all():
                                  # doesn't work until some time after attach() is called
                                  try:
                                      log("delete all SMS messages")
                                      a = at('AT+CMGD=1,4','OK')
                                      if len(a) == 0:
                                          log("error trying to delete all SMS messages")
                              #                     Process SMS Messages
                              def sms_process(r):
                                  # example response:
                                  # ['+CMGL: 1,"REC READ","+1xxxxxxxxxx",,"19/01/07,09:16:53-20"', 'Test3', '+CMGL: 2,"REC READ","+1xxxxxxxxxx",,"19/01/07,11:12:30-20"', 'Test4', 'OK']
                                  try:
                                      for m in r:
                                          if (m[0:5] == "+CMGL"):
                                              continue
                                          a = m.split("=")
                                          cmd = a[0].upper()
                              #                      Read Unread SMS Messages
                              def sms_read():
                                  # response example: ['+CMGL: 1,"REC UNREAD","+1xxxxxxxxxx",,"19/01/07,09:16:53-20"', 'Test3', 'OK']
                                  log("read unread SMS messages")
                                  a = at('AT+CMGL="REC UNREAD"')
                                  return a
                              #                       Read All SMS Messages
                              def sms_read_all():
                                  # response example:
                                  log("read all SMS messages")
                                  a = at('AT+CMGL="ALL"')
                                  return a
                                  # timeout in msecs
                                  t0 = ticks_ms()
                                      if uart.any() >= n:
                                          break
                                      t1 = ticks_ms()
                                      if tx > timeout:
                                          return False
                                      sleep_ms(10)
                                  return True
                              Here's the code being used. The code shown is incomplete since it is application dependent. I'm somewhat disappointed in the necessary placement of the modem.apn_set() call. This may change in the future.
                              # COM.PY Module
                              import globals as g
                              import modem
                              import sys
                              import uos
                              import util
                              import wifi
                              def com_task():
                                  try:
                                      sleep_ms(500)
                                      wifi.deinit()
                                      modem.reset_modem()
                                      modem.init_modem()
                                      try:
                                          if modem_ready():
                                              if ready_to_poll():
                                                  modem.set_apn()
                                                  transmit()
                                          sleep_ms(2000)
                              #                           Modem Ready
                              def modem_ready():
                                  try:
                                          # registered
                                          g.com_secs = 0
                                          if len(r) > 1:
                                              modem.sms_delete()
                                          return True
                                      reset = False
                                          reset = True
                                          reset = True
                                      if reset:
                                          modem.reset_modem()
                                          modem.init_modem()
                                          g.com_secs = 0
                                      return False
                                  return False
                                tlanier
                                I seemed to have hit a major problem using the AT+SQNHTTPSND modem command. Although the manual does not state this, the maximum size of the data posted is apparently 1500 bytes.
                                If anyone has ideas of how to increase this, please let me know. Unfortunately my app requires posting messages over 3000 bytes.
                                Disappointed...
                                  tlanier
                                  I've now converted my code to use the Sequans modem socket commands in command mode (not on-line mode). I first tried to use the on-line mode, but ran into issues (no good way I could find to prevent overrunning tx buffer). This code resolves the 1500 byte limitation I ran into using the HTTP modem commands. There's still some cleanup to do to make the code more robust; however, it is working with large transmit and receive data blocks now.
                                  During development while I had coding errors and the program would terminate abnormally, I did put the modem in a mode that I couldn't recover from without power cycling the GPy. The modem would not response to AT commands, Trying to do lte = LTE() would generate the following error (OSError: Couldn't connect to Modem (modem_state=disconnected)). Doing machine.reset() would not correct the problem.
                                  Link to discussion of similar problem on Github
                                  Hopefully whatever I did to cause the problem will not occur in debugged code. There needs to be a true hardware reset of the modem. It seems that a GPIO pin should be tied to a physical reset line going to the modem that we could pulse if needed. I'm also of the opinion that the watchdog timer in the GPy should have been a hardware circuit not dependent on software to work.
                                  So far I have not seen any unexplained crashes while running the code.
                                  This code has been added to my modem.py module.
                                  #                       Socket Close
                                  def socket_close():
                                      # socket close
                                      # connID = 1 --> socket connection identifier
                                      a = at('AT+SQNSH=1', 'OK')
                                      if len(a) == 0:
                                          log("error closing connection")
                                          return
                                  #                       Socket Connect
                                  def socket_connect(ip, port, timeout_secs=10):
                                      # returns: True if connection successful
                                      log("connecting to ip - {0}, port - {1}".format(ip, port))
                                      # make sure socket is closed
                                      socket_close()
                                      # socket configuration
                                      # cid = 1 --> PDP context identifier
                                      # pktSz = 1500 --> packet size
                                      # maxTo = 10 --> exchange timeout in secs
                                      # connTo = 600 --> connection timeout in msecs
                                      # txTo = 3 --> data sending timeout in hundreds of msecs
                                      # a = at('AT+SQNSCFG=1,1,1500,10,600,3', 'OK')
                                      a = at('AT+SQNSCFG=1,1,1500,{0},600,3'.format(timeout_secs), 'OK')
                                      if len(a) == 0:
                                          log("error connecting")
                                          return False
                                      # socket extended configuration
                                      # srMode = 1 --> SQNSRING URC data amount mode
                                      # recvDataMode = 1 --> data in hex
                                      # keepalive = 0 --> unused
                                      # listenAutoRsp = 0 --> deactivated
                                      # sendDataMode = 1 --> data in hex
                                      a = at('AT+SQNSCFGEXT=1,1,1,0,0,1', 'OK')
                                      if len(a) == 0:
                                          return False
                                      # socket dial
                                      # txProt = 0 --> TCP protocol
                                      # rPort = <port> --> remote host port to contact
                                      # IPaddr = <ip> --> address of remote host
                                      # closureType = 0 --> local host closes immediately when remote host has closed
                                      # lPort = 0 --> UDP port (not used)
                                      # connMode = 1 --> command mode connection
                                      # acceptAnyRemote = 0 --> disabled
                                      a = at('AT+SQNSD=1,0,{0},"{1}",0,0,1,0'.format(port,ip), 'OK')
                                      if len(a) == 0:
                                          return False
                                      log("** connection successful **")
                                      return True
                                  #                       Socket Info
                                  def socket_info():
                                      # modem response: ['+SQNSI: 1,0,0,0,0', 'OK']
                                      # connId: 1
                                      # sent: total bytes sent
                                      # received: total bytes received
                                      # buff_in: total bytes not yet read (buffered)
                                      # ack_waiting: total bytes sent but not yet acknowledged
                                      a = at('AT+SQNSI=1')
                                  #                       Socket Receive Data
                                  def socket_rx():
                                      # receives up to 1500 bytes maximum
                                      log("check for rx data")
                                      a = at('AT+SQNSRECV=1,1500')
                                      # no data ready --> modem response: ['+CME ERROR: operation not supported']
                                      # data ready --> modem response: ['+SQNSRECV: 1,3', '010203', 'OK']
                                      b = b''
                                      for i in range(len(a)):
                                          if a[i].startswith('+SQNSRECV:'):
                                              # next line is the data
                                              b = unhexlify(a[i+1])
                                      log("rx {0} bytes".format(len(b)))
                                      return b
                                  #                       Socket Status
                                  def socket_status():
                                      # modem response: ['+SQNSS: 1,0', '+SQNSS: 2,0', '+SQNSS: 3,0', '+SQNSS: 4,0', '+SQNSS: 5,0', '+SQNSS: 6,0', 'OK']
                                      # connID
                                      # state:
                                      #   0-socket closed
                                      #   1-socket with active data transfer connection
                                      #   2-socket suspended
                                      #   3-socket suspended with pending data
                                      #   4-socket listening
                                      #   5-socket with incoming connection
                                      #   6-socket in opening process
                                      a = at('AT+SQNSS?')
                                      return a
                                  #                       Socket Transmit Data
                                  def socket_tx(tx, n=0):
                                      # transmits up to 1500 bytes maximum
                                      # returns: True if successful
                                      if n == 0:
                                          n = len(tx)
                                      log("tx {0} bytes".format(n))
                                      a = at('AT+SQNSSENDEXT=1,{0}'.format(n), '> ')
                                      hex = hexlify(tx)
                                      uart.write(hex)
                                      if len(a) == 0:
                                          log("error transmitting data")
                                          return False
                                      return True
                                  This code is in my http.py module.
                                  import modem
                                  import sys
                                  import ubinascii
                                  import uos
                                  import ustruct
                                  import util
                                  BUFFER_SIZE = const(1500)
                                  CR = const(0x0d)
                                  LF = const(0x0a)
                                  MAX_HEADER_SIZE = const(128)
                                  MAX_TX_SIZE = const(1500)
                                  HTTP_TIMEOUT_MSECS = const(15000)
                                  # HTTP_TIMEOUT_MSECS = const(300000)  # TESTING
                                  http_error = False      # HTTP communication error: True/False
                                  http_size = 0           # HTTP POST message size
                                  rx_cnt = 0              # no. bytes in rx_data buffer
                                  rx_data = b''           # rx data buffer
                                  rx_pt = 0               # pointer into rx data buffer
                                  tx_cnt = 0              # no. bytes in tx_data buffer
                                  tx_data = bytearray(MAX_TX_SIZE)    # tx data buffer
                                  tx_flag = False         # controls tx_byte
                                  #                       Close HTTP Socket
                                  def close_http():
                                      modem.socket_close()
                                  #                       Open HTTP Socket
                                  def open_http(host_ip, host_port):
                                      global http_error, rx_cnt, rx_data, rx_pt, tx_cnt
                                      http_error = False
                                      rx_cnt = 0
                                      rx_data = b''
                                      rx_pt = 0
                                      tx_cnt = 0
                                      r = modem.socket_connect(host_ip, host_port)
                                      if r == False:
                                          log("TCP socket connect error")
                                          http_error = True
                                  #                    Receive BLOCK From Response
                                  def rx_block(cnt):
                                      b = bytearray(cnt)
                                      i = 0
                                      while i < cnt:
                                          b[i] = rx_byte()
                                          i = i + 1
                                      return b
                                  #                    Receive BYTE From Response
                                  def rx_byte():
                                      global http_error, http_size, rx_cnt, rx_data, rx_pt
                                      t0 = ticks_ms()
                                      while rx_cnt == 0:
                                          rx_data = modem.socket_rx()
                                          rx_cnt = len(rx_data)
                                          rx_pt = 0
                                          if rx_cnt > 0:
                                              break
                                          t1 = ticks_ms()
                                          if (tx > HTTP_TIMEOUT_MSECS):
                                              http_error = True
                                              return 0
                                          sleep_ms(200)
                                      b = rx_data[rx_pt]
                                      rx_cnt = rx_cnt - 1
                                      rx_pt = rx_pt + 1
                                      http_size = http_size - 1
                                      # print("rx byte: {0}".format(hex(b)))
                                      return b
                                  #                    Receive DWORD From Response
                                  def rx_dword():
                                      dw1 = rx_byte()
                                      dw2 = rx_byte()
                                      dw3 = rx_byte()
                                      dw4 = rx_byte()
                                      return (dw1 + (dw2<<8) + (dw3<<16) + (dw4<<24))
                                  #                    Receive One HTTP Header
                                  def rx_http_header():
                                      # returns header string
                                      global http_error
                                      n = 0
                                      header = bytearray(MAX_HEADER_SIZE)
                                      s = ""
                                          b = rx_byte()
                                          # print("byte = {0}".format(b))
                                          if http_error:
                                              return ""
                                          if b == CR:
                                              continue
                                          if b == LF:
                                              break
                                          header[n] = b
                                          n = n + 1
                                          if n >= MAX_HEADER_SIZE-1:
                                              http_error = True
                                              return ""
                                      if n > 0:
                                          # print("n = {0}, header = {1}".format(n,header))
                                          s = header[0:n].decode('utf-8')
                                      return s
                                  #                    Receive HTTP Headers
                                  # HTTP/1.1 200 OK
                                  # <headers>
                                  # Content-Length: nnn
                                  # <headers>
                                  # <crlf>
                                  # Updates: http_size, http_error
                                  def rx_http_headers():
                                      headers = []      # array of header lines
                                      http_size = 0
                                          s = rx_http_header()
                                          log("length = {0}, header = {1}".format(len(s), s))
                                          if http_error:
                                              return headers
                                          if s == "":
                                              break
                                          headers.append(s)
                                      if len(headers) < 2:
                                          http_error = True
                                          return headers
                                      a = headers[0].split(' ')
                                      if (a[1] != "200") or (a[2]) != "OK":
                                          http_error = True
                                          return headers
                                      for s in headers:
                                          if s.startswith("Content-Length:"):
                                              a = s.split(' ')
                                              http_size = int(a[1])
                                      return headers
                                  #                    Receive String From Response
                                  def rx_string(max_len):
                                      rx = bytearray(max_len)
                                      i = 0
                                      while i < max_len:
                                          b = rx_byte()
                                          if b == 0:
                                              break
                                          rx[i] = b
                                          i = i + 1
                                      if i == 0:
                                          return ""
                                      s = rx[0:i].decode('utf-8')
                                      return s
                                  #                    Receive WORD From Response
                                  def rx_word():
                                      dw1 = rx_byte()
                                      dw2 = rx_byte()
                                      return (dw1 + (dw2<<8))
                                  #                       Transmit Block
                                  def tx_block(b):
                                      for x in b:
                                          tx_byte(x)
                                  #                       Transmit Byte
                                  def tx_byte(b):
                                      global http_size, tx_cnt, tx_data, tx_flag
                                      if tx_flag == False:
                                          http_size = http_size + 1
                                          # print("tx byte: {0}, http size: {1}".format(hex(b), http_size))
                                          return
                                      # print("tx byte: {0}".format(hex(b)))
                                      tx_data[tx_cnt] = b
                                      tx_cnt = tx_cnt + 1
                                      if tx_cnt >= MAX_TX_SIZE:
                                          tx_flush()
                                  #                       Transmit DWORD
                                  def tx_dword(dw):
                                      tx_word(dw & 0xffff)
                                      tx_word((dw >> 16) & 0xffff)
                                  #                       Transmit Flush
                                  def tx_flush():
                                      global tx_cnt, tx_data
                                      if tx_cnt == 0:
                                          return
                                      r = modem.socket_tx(tx_data, tx_cnt)
                                      if not r:
                                          http_error = True
                                          return
                                      tx_cnt = 0
                                  #                       Transmit HTTP Headers
                                  def tx_http_headers(http_post, host_name, host_port):
                                      # example:
                                      # POST <http_post> HTTP/1.1
                                      # Host: <host_name>:<host_port>
                                      # Content-Length: <http_size>
                                      # Content-Type: application/octet-stream
                                      # <crlf>
                                      log("tx HTTP headers")
                                      if http_error:
                                          return
                                      s = "POST {0} HTTP/1.1\r\n".format(http_post)
                                      tx_string(s)
                                      if host_port != 80:
                                          s = "Host: {0}:{1}\r\n".format(host_name, host_port)
                                          s = "Host: {0}\r\n".format(host_name)
                                      tx_string(s)
                                      s = "Content-Length: {0}\r\n".format(http_size)
                                      tx_string(s)
                                      s = "Content-Type: application/octet-stream\r\n"
                                      tx_string(s)
                                      s = "\r\n"
                                      tx_string(s)
                                  #                       Transmit String
                                  def tx_string(s):
                                      b = s.encode('utf-8')
                                      for x in b:
                                          tx_byte(x)
                                  #                       Transmit WORD
                                  def tx_word(w):
                                      tx_byte(w & 0xff)
                                      tx_byte((w >> 8) & 0xff)
                                    tlanier
                                    We now have our program running completely independent of the LTE module. 26 units have been running for multiple days with no crashes. I now think we have found a reliable solution. The Sequans modem AT socket commands are used to do the HTTP posts. We reliably receive 90K files and transmit 1-5K of data with no issues. Pycom MicroPython V1.20.0.rc13 is the OS version we are using.
                                    Currently we are using whatever version of the modem firmware (41065, 43818, and 47510 have been seen) that comes with the GPy. The version of the OS we are using has the ability to "downgrade" the modem firmware to 41065 if we decide it is needed. Some newer versions of the OS do not have this ability.
                                    One note of importance is we did discover that in our case the default stack size was marginal when receiving large files. Yes, I did go back and check the old program and verified that the stack issue was not the cause of the original crash problems.
                                    #                          Initialize Tasks
                                    def init_tasks():
                                        n = 8192    # 4096 is marginal
                                        _thread.stack_size(n)
                                        log("initializing tasks with stack size: {}".format(n))
                                        _thread.start_new_thread(com.com_task, ())
                                        _thread.start_new_thread(cycle.cycle_task, ())
                                      ruok4t @tlanier
                                      @tlanier I really like the sound of what your doing here. I've been struggling with Pycom LTE module for months now. Really don't like the way it blocks other threads and randomly locks up for no apparent reason. Are you possibly in a position to share a complete "Hello LTE World" example. I'm sure I wouldn't be the only one around here who would be very interested. Hopefully someone from Pycom might also take an interest and finally admit they need to revise their code.
                                        tlanier @ruok4t
                                        @ruok4t Sorry I didn't see your request earlier.
                                        The software below is now working in production units. We ran about 20 units testing in house for two weeks with no crashes before beginning deployment with the new version. We are using MicroPython V1.20.0.rc13 with multiple versions of the modem firmware. It's a shame we had to resort to this, but it seems to work reliably.
                                        I've had to break the post up into 3 parts because of limitations of this forum.
                                        Part 1 of 3
                                        Here's the modem.py module:
                                        import globals as g
                                        import gpio
                                        import micropython
                                        import sys
                                        import util
                                        from ubinascii import hexlify, unhexlify
                                        from util import log, mem_info
                                        uart = None
                                            try:
                                                # util.mem_info("modem.at")
                                                if uart.any() > 0:
                                                    a = at_response()
                                                    for s in a:
                                                        at_process(s)
                                                if gpio.G():
                                                    if gpio.G():
                                                    return []
                                                return a
                                                a = []
                                            # filter response
                                            if filterx == "":
                                                return
                                            n = len(filterx)
                                            i = len(a)
                                            while i > 0:
                                                i = i - 1
                                                if not a[i].startswith(filterx):
                                                    at_process(a[i])
                                                    a.pop(i)
                                        def at_process(s):
                                            if s == 'OK':
                                                return
                                            if s.startswith("ERROR"):
                                                return
                                            if s.startswith("+CME ERROR:"):
                                                return
                                            # process unsolicited response here
                                            if gpio.G():
                                                log("  unsolicited modem response: {}".format(s))
                                            try:
                                                t0 = ticks_ms()
                                                    if uart.any() > 0:
                                                        sleep_ms(50)
                                                        break
                                                    t1 = ticks_ms()
                                                    if tx > 10000:
                                                        return []
                                                    sleep_ms(100)
                                                b = uart.read()
                                                s = str(b, 'utf-8')
                                                a = s.split('\r\n')
                                                if gpio.G():
                                                a = []
                                            try:
                                                    if len(a) == 0:
                                                        break
                                                    a = a[0].split(",")
                                                        break
                                                    reg = int(a[1])
                                                    if reg == 1:
                                                        log("*** registered - home network ***")
                                                    elif reg == 5:
                                                        log("*** registered - roaming ***")
                                                        log("*** NOT registered ***")
                                                    return reg
                                            return 99
                                        #                       Check SIM Status
                                        def check_sim_status():
                                            try:
                                                log("checking SIM card status")
                                                a = at('AT+CPIN?', '+CPIN: READY')
                                                if len(a) > 0:
                                                    return True
                                            log("error SIM card not ready")
                                            return False
                                        #                       Disable LTE Modem
                                            try:
                                                if len(a) == 0:
                                        #                       Enable Modem
                                        def enable_modem():
                                            try:
                                                if len(a) == 0:
                                        def get_cfun():
                                            # -1 - unknown
                                            try:
                                                    if len(a) == 0:
                                                        break
                                                    cfun = int(a[0][7])
                                                    return cfun
                                            return -1
                                        #                           Get SMS Mode
                                        def get_sms_mode():
                                            try:
                                                log("get SMS mode")
                                                if len(a) == 0:
                                                mode = int(a[0][7])
                                                return mode
                                        def iccid():
                                            # SIM status must be ready
                                            try:
                                                a = at('AT+SQNCCID?', '+SQNCCID:')
                                                if len(a) == 0:
                                                    return ''
                                                a = a[0].split(",")
                                                n = len(a[0])
                                                r = a[0][11:n-1]
                                                r = ''
                                        def imei():
                                            try:
                                                if len(a) == 0:
                                                    return ''
                                                n = len(a[0])
                                                r = a[0][8:n-1]
                                                r = ''
                                        #                   Modem Firmware Info
                                        def info():
                                            log("get modem firmware version")
                                            a = at('ATI1')
                                            return a
                                        #                       Initialize Modem
                                        def init_modem():
                                            try:
                                                if uart == None:
                                                    init_uart()
                                                info()
                                                set_sms_mode()
                                                # enable +CME ERROR: <err> result code and use verbose <err> values
                                                at('AT+CMEE=2')
                                                enable_modem()
                                                log("wait for SIM card ready")
                                                n = 0
                                                    if len(a) > 0:
                                                        break
                                                    n = n + 1
                                                    if n > 20:
                                                        util.reset(13, "No SIM card")
                                                    sleep_ms(200)
                                                set_apn()
                                        def init_uart():
                                            global uart
                                        def isattached():
                                            try:
                                                if len(a) == 0:
                                                    return False
                                                if a[0][8] == '1':
                                                    return True
                                            return False
                                        #                           Reset Modem
                                        def reset_modem():
                                            try:
                                                if uart == None:
                                                    init_uart()
                                                a = at('AT^RESET', '+SHUTDOWN')
                                                if len(a) == 0:
                                                if len(a) == 0:
                                        def restarted():
                                            try:
                                                cfun = get_cfun()
                                                if cfun != 1:
                                                    return True
                                                if mode != 1:
                                                    return True
                                                return False
                                            return True
                                        #                           Set APN
                                        def set_apn():
                                            try:
                                                log("set APN")
                                                # ICCID is only valid if SIM status is ready
                                                r = iccid()[0:5]
                                                if r == "89014":
                                                elif r == "89012":
                                                elif r == "89445":
                                                g.oIni.apn = apn
                                                a = at('AT+CGDCONT?', '+CGDCONT:')
                                                if len(a) > 0:
                                                    a = a[0].split(",")
                                                        return
                                                # apn needs setting
                                                a = at(cmd, 'OK')
                                                if len(a) == 0:
                                        def set_sms_mode():
                                            try:
                                                a = at('AT+CMGF=1', 'OK')     # set SMS mode to text
                                                if len(a) == 0:
                                            # 0-31, 99-unknown
                                            try:
                                                    a = at('AT+CSQ', '+CSQ:')
                                                    if len(a) == 0:
                                                        break
                                                    n = len(a[0])
                                                    s = a[0][6:n-1]
                                                    a = s.split(",")
                                                    return cell_signal
                                            return 99
                                        def sms_delete():
                                            try:
                                                a = at('AT+CMGD=1,3', 'OK')
                                                if len(a) == 0:
                                            try:
                                                a = at('AT+CMGD=1,4', 'OK')
                                                if len(a) == 0:
                                        def sms_process(r):
                                            # example response:
                                            try:
                                                for m in r:
                                                        continue
                                                    a = m.split("=")
                                                    cmd = a[0].upper()
                                        			# process message here
                                        def sms_read():
                                            return a
                                        def sms_read_all():
                                            # response example:
                                            return a
                                        #                       Socket Close
                                        def socket_close():
                                            # socket close
                                            log("closing socket")
                                            if len(a) == 0:
                                        #                       Socket Connect
                                            socket_close()
                                            if len(a) == 0:
                                                return False
                                            if len(a) == 0:
                                                return False
                                            # socket dial
                                            if len(a) == 0:
                                                return False
                                            return True
                                        #                       Socket Info
                                        def socket_info():
                                            # connId: 1
                                            log("socket info")
                                        def socket_rx():
                                            b = b''
                                            return b
                                        #                       Socket Status
                                            # connID
                                            # state:
                                            #   0-socket closed
                                            log("socket status")
                                            a = at('AT+SQNSS?')
                                            return a
                                            if n == 0:
                                                n = len(tx)
                                            b = hexlify(tx)
                                            uart.write(b)
                                            if len(a) == 0:
                                                return False
                                            return True
                                        T R 2 Replies Last reply Reply Quote 0
                                          tlanier @tlanier
                                          @tlanier
                                          Part 2 of 3
                                          Here's our com.py module. It is more application dependent but it may give you some ideas of how to use the modem module.
                                          import globals as g
                                          import modem
                                          import sys
                                          import uos
                                          import util
                                          import wifi
                                          _reset = True    # modem reset
                                          def com_task():
                                              global _reset
                                              try:
                                                  sleep_ms(500)
                                                  # this opens the door for continuous resets to cause high data usage
                                                  util.set_ppp_errors(0)
                                                  wifi.deinit()
                                                  try:
                                                      _reset = False
                                                      g.modem_state = g.MS_RESET_MODEM
                                                      modem.reset_modem()
                                                      g.modem_state = g.MS_INIT_MODEM
                                                      modem.init_modem()
                                                      while _reset == False:
                                                          # util.mem_info("com_task")
                                                          if modem_ready():
                                                              g.modem_state = g.MS_REGISTERED
                                                              if ready_to_poll():
        transmit()
                                                              g.modem_state = g.MS_REGISTERING
                                                          sleep_ms(2000)
                                          #                           Modem Ready
                                          def modem_ready():
                                              global _reset
                                              try:
                                                      # registered
                                                      g.com_secs = 0
                                                      if len(r) > 1:
                                                          modem.sms_delete()
                                                      return True
                                                      _reset = True
                                                      _reset = True
                                                  return False
                                              return False
                                          #                           Ready To Poll
                                          def ready_to_poll():
                                              # return: True/False
                                              try:
                                                  log("--- time since last poll: {0} secs ---".format(g.oNvram.last_poll_secs))
                                                  if (g.ppp_error_secs > 0):
                                                      log("*** poll throttling: {0} secs ***".format(g.ppp_error_secs))
                                                      return False
                                                  if (g.oIni.intra_poll_secs > 0):
                                                      # contact server every <oIni.intra_poll_secs> seconds
                                                      if (g.oNvram.last_poll_secs > g.oIni.intra_poll_secs):
                                                          return True
                                                  if (g.oSetup.intra_cycle_count > 0):
                                                      # contact server every <oSetup.intra_cycle_count> cycles
                                                      if (g.oNvram.cycle_count >= g.oSetup.intra_cycle_count):
                                                          return True
                                                  # g.poll_host is set at startup and by SMS POLL_HOST message
                                                  if (g.poll_host == True):
                                                      return True
                                              return False
                                          #                         Transmit
                                          def transmit():
                                              try:
                                                  util.lcd("Transmitting", "")
                                                  g.modem_state = g.MS_CONNECTING
                                                  r = poll()
                                                  g.modem_state = g.MS_DISCONNECT
                                                  if (r == False):
                                                      util.lcd("Transmit failed", "")
                                                      sleep_ms(2500)
                                                      util.lcd("","")
                                                      return
                                                  util.lcd("Successful", "")
                                                  sleep_ms(2500)
                                                  util.lcd("","")
                                                  g.poll_host = False
                                                  g.oNvram.last_poll_secs = 0
                                                  g.poll_secs = 0
                                                  if (g.update_flag == True):
                                                      # done after disconnect
                                                      try:
                                                          if util.file_exists("REMOTE.TAR"):
                                                              log("remove old REMOTE.TAR")
                                                              util.remove("REMOTE.TAR")
                                                          log("rename TEMP to REMOTE.TAR")
                                                          uos.rename("TEMP", "REMOTE.TAR")
                                                          # create file to signal boot.py that update is available
                                                          log("create UPDATE signal file")
                                                          with open("UPDATE", "w") as f:
                                                              f.write("UPDATE")
                                                          log("** New REMOTE.TAR ready to update")
                                                  if (g.reboot_after_poll == True):
                                                      log("SMS message changed INI setting, rebooting")
                                                      util.reset(6, "INI changed")
                                                  if (g.oHost.erase == True):
                                                      log("Erase command received, rebooting")
                                                      g.oNvram.erase()
                                                      util.reset(7, "Erase NVRAM")
                                                  if (g.oHost.reset == True):
                                                      log("Reset command received, rebooting")
                                                      util.reset(8, "Reset command")
                                            tlanier @tlanier
                                            @tlanier
                                            Part 3 of 3
                                            Here's the http.py module:
                                            Note that the modem socket commands have a 1500 byte limitation. The HTTP module overcomes that by breaking longer messages up into smaller blocks.
                                            import modem
                                            import sys
                                            import ubinascii
                                            import uos
                                            import ustruct
                                            import util
                                            # note: HTTP errors raise exceptions
                                            CR = const(0x0d)
                                            LF = const(0x0a)
                                            #                       Close HTTP Socket
                                            def close_http():
                                            #                       Open HTTP Socket
                                                global rx_cnt, rx_data, rx_pt, tx_cnt
                                                rx_cnt = 0
                                                rx_data = b''
                                                rx_pt = 0
                                                tx_cnt = 0
                                                if r == False:
                                                    raise Exception("TCP socket connect error")
                                            def rx_block(cnt):
                                                b = bytearray(cnt)
                                                i = 0
                                                while i < cnt:
                                                    b[i] = rx_byte()
                                                    i = i + 1
                                                log("rx_block: {} bytes".format(len(b)))
                                                return b
                                            def rx_byte():
                                                global http_size, rx_cnt, rx_data, rx_pt
                                                t0 = ticks_ms()
                                                while rx_cnt == 0:
                                                    rx_pt = 0
                                                    if rx_cnt > 0:
                                                        break
                                                    t1 = ticks_ms()
                                                        raise Exception("HTTP timeout in rx_byte")
                                                    sleep_ms(200)
                                                b = rx_data[rx_pt]
                                                rx_cnt = rx_cnt - 1
                                                rx_pt = rx_pt + 1
                                                return b
                                            def rx_dword():
                                                dw1 = rx_byte()
                                                dw2 = rx_byte()
                                                dw3 = rx_byte()
                                                dw4 = rx_byte()
                                                n = 0
                                                s = ""
                                                    b = rx_byte()
                                                    if b == CR:
                                                        continue
                                                    if b == LF:
                                                        break
                                                    header[n] = b
                                                    n = n + 1
                                                        raise Exception("Maximum header size error in rx_http_header")
                                                if n > 0:
                                                    # older versions of MicroPython do not implement decode on bytearrays
                                                    a = bytes(header[0:n])
                                                    s = a.decode('utf-8')
                                                    log("header = {}".format(s))
                                                return s
                                            # HTTP/1.1 200 OK
                                            # <headers>
                                            # <headers>
                                            # <crlf>
                                                global http_size
                                                http_size = 0
                                                    # log("length = {0}, header = {1}".format(len(s), s))
                                                    if s == "":
                                                        break
                                                    headers.append(s)
                                                    raise Exception("Not enough headers received in rx_http_headers")
                                                    raise Exception("Invalid first header line: {0}".format(headers[0]))
                                                for s in headers:
                                                        a = s.split(' ')
                                                return headers
                                                i = 0
                                                while i < max_len:
                                                    b = rx_byte()
                                                    if b == 0:
                                                        break
                                                    rx[i] = b
                                                    i = i + 1
                                                if i == 0:
                                                    return ""
                                                a = bytes(rx[0:i])
                                                return s
                                            def rx_word():
                                                dw1 = rx_byte()
                                                dw2 = rx_byte()
                                            #                       Transmit Block
                                            def tx_block(b):
                                                for x in b:
                                                    tx_byte(x)
                                            #                       Transmit Byte
                                            def tx_byte(b):
                                                    return
                                                tx_data[tx_cnt] = b
                                                tx_cnt = tx_cnt + 1
                                                    tx_flush()
                                            #                       Transmit DWORD
                                            def tx_dword(dw):
                                            #                       Transmit Flush
                                            def tx_flush():
                                                if tx_cnt == 0:
                                                    return
                                                if not r:
                                                    raise Exception("Error transmitting in tx_flush")
                                                tx_cnt = 0
                                                # example:
                                                # <crlf>
                                                global http_size
                                                tx_string(s)
                                                if host_port != 80:
                                                tx_string(s)
                                                tx_string(s)
                                                tx_string(s)
                                                s = "\r\n"
                                                tx_string(s)
                                            #                       Transmit String
                                            def tx_string(s):
                                                for x in b:
                                                    tx_byte(x)
                                            #                       Transmit WORD
                                            def tx_word(w):
                                                tx_byte(w & 0xff)
                                            • 2 / 3
