    Method To Take Control of Cell Modem
    41 Posts 10 Posters 902 Views 14 Watching
      tlanier @peterp
      @peterp Sorry to take so long to respond. I wanted to finish updating my posts showing the new code that seems to be working well. Soon I should be able to post the entire refined code. Maybe it will help others with the same problems we have had.
      The reason I went down this development path was as described originally:
      "I currently have a program working in production using Pycom MicroPython V1.20.0.rc13 on many units. When I try to run the same program on a newly purchased GPy running Pycom MicroPython 1.20.2.r3, the program crashes (20 sec watchdog timeout) when I do an AT command ('AT+CEREG?') after disconnecting from a successful transmission. How do I troubleshoot such a crash?"
      Our original reason for picking Pycom and GPy was the thinking that all the modem complexity would be handled by the high level LTE module. It's only a guess but our thinking that since the crashes always happened during times communicating with the modem, the LTE module was the likely source of the problem.
      The new method seems to be superior from the standpoint of interference with multiple tasks. Since we always call non-blocking uart commands, the code should never get hung in the C code for any period. A simple example of the LTE module code freezing multi-tasking is to do a simple modem reset. Reading and writing to the file storage also has a minor affect. The real reason for the development was to try to eliminate program crashes. Only longer term testing will show whether we have achieved that goal.
      One concern I do have is whether I am properly initializing the cell modem. Any input from anybody out there that is more familiar with properly setting up the LTE modem would be appreciated. It seems to work fine at this point; however, I'm not sure whether it's working because the GPy I'm testing with has run the LTE initialization at some point in the past and that has possibly setup the non-volatile memory of the modem to the proper settings that are needed.
      One drawback of using this method of transmission is it is not compatible with WIFI connections. That is not an issue for us at this time. Maybe later we can research how to do some form of communication that is compatible with both WIFI and direct AT commands. I assume that involves using the socket commands of the modem, but this is an area I'm not sure about at this time.
      • K Offline
        kjm @tlanier
        @tlanier Admire your efforts squire. I've been struggling with lte for a year or so now. It's not perfect (the lte.isattached() gets confused sometimes) but I got it robust enough to be usable. I use the requests library for data transfer & my main complaint is that it can't be timed out. I modified it with machine.WDT so that I can abort in a timely manner but I'd like a better solution. Am I right in thinking your wait_rx(n, 10000) allows you to quit if http post/get times out after 10s?
        T 3 Replies Last reply Reply Quote 0
          tlanier @kjm
          @kjm I think I remember having to modify urequests also. Here's what I currently use in my old version that is working.
          import usocket
          import util
          class Response:
              def __init__(self, f):
                  self.raw = f
                  self.encoding = "utf-8"
                  self._cached = None
              def close(self):
                  if self.raw:
                      self.raw.close()
                      self.raw = None
                  self._cached = None
              @property
              def content(self):
                  if self._cached is None:
                      try:
                          self._cached = self.raw.read()
                      finally:
                          self.raw.close()
                          self.raw = None
                  return self._cached
              @property
              def text(self):
                  return str(self.content, self.encoding)
              def json(self):
                  import ujson
                  return ujson.loads(self.content)
          def request(method, url, data=None, json=None, headers={}, stream=None):
              try:
                  proto, dummy, host, path = url.split("/", 3)
              except ValueError:
                  proto, dummy, host = url.split("/", 2)
                  path = ""
              if proto == "http:":
                  port = 80
              elif proto == "https:":
                  import ussl
                  port = 443
                  raise ValueError("Unsupported protocol: " + proto)
              if ":" in host:
                  host, port = host.split(":", 1)
                  port = int(port)
              # ai = usocket.getaddrinfo(host, port, 0, usocket.SOCK_STREAM)  # PATCH
              ai = usocket.getaddrinfo(host, port)
              ai = ai[0]
              s = usocket.socket(ai[0], ai[1], ai[2])
              try:
                  s.settimeout(20)
                  s.connect(ai[-1])
                      s = ussl.wrap_socket(s, server_hostname=host)
                  s.write(b"%s /%s HTTP/1.0\r\n" % (method, path))
                  if not "Host" in headers:
                      s.write(b"Host: %s\r\n" % host)
                  # Iterate over keys to avoid tuple alloc
                  for k in headers:
                      s.write(k)
                      s.write(b": ")
                      s.write(headers[k])
                      s.write(b"\r\n")
                  if json is not None:
                      assert data is None
                      import ujson
                      data = ujson.dumps(json)
                      s.write(b"Content-Type: application/json\r\n")
                  if data:
                      s.write(b"Content-Length: %d\r\n" % len(data))
                  s.write(b"\r\n")
                  if data:
                      s.write(data)
                  l = s.readline()
                  #print(l)
                  l = l.split(None, 2)
                  status = int(l[1])
                  reason = ""
                  if len(l) > 2:
                      reason = l[2].rstrip()
                      l = s.readline()
                      if not l or l == b"\r\n":
                          break
                      #print(l)
                      if l.startswith(b"Transfer-Encoding:"):
                          if b"chunked" in l:
                              raise ValueError("Unsupported " + l)
                      elif l.startswith(b"Location:") and not 200 <= status <= 299:
                          raise NotImplementedError("Redirects not yet supported")
          #   except OSError:     # PATCH
              except:
                  s.close()
                  raise
              resp = Response(s)
              resp.status_code = status
              resp.reason = reason
              return resp
          def head(url, **kw):
              return request("HEAD", url, **kw)
          def get(url, **kw):
              return request("GET", url, **kw)
          def post(url, **kw):
              return request("POST", url, **kw)
          def put(url, **kw):
              return request("PUT", url, **kw)
          def patch(url, **kw):
              return request("PATCH", url, **kw)
          def delete(url, **kw):
              return request("DELETE", url, **kw)
            tlanier @kjm
            @kjm Thanks for the comment. The intention of wait_rx(n, timeout=10000) is to be a non-blocking call that waits for N chars to come into the uart or to timeout after 10,000 msecs by default. N should be less than the buffer size of the uart which is currently set to 512 bytes.
            In looking at my current code, I see a bug. I should have had a sleep command in the while loop to make multi-tasking more efficient. Here's the corrected code. Thanks again!
            #                       Wait For N Received Chars
            def wait_rx(n, timeout=10000):
                # timeout in msecs
                t0 = ticks_ms()
                    if uart.any() >= n:
                        break
                    t1 = ticks_ms()
                    tx = ticks_diff(t1, t0)
                    if tx > timeout:
                        return False
                    sleep_ms(10)
                return True
              tlanier @kjm
              @kjm What would really be neat is if we could learn how to put the modem in a mode that allowed the urequests/usockets libraries to work using just AT commands!
              I suspect it has to do with the AT+CGDCONT parameter named PDP_type. The manual shows the following values:
              X.25 ITU-T/CCITT X.25 layer 3 (Obsolete)
              IP Internet Protocol (IETF STD 5 [103])
              IPV6 Internet Protocol, version 6 (see RFC 2460 [106])
              IPV4V6 Virtual <PDP_type> introduced to handle dual IP stack UE capability. (See
              3GPP TS 24.301 [83])
              OSPIH Internet Hosted Octect Stream Protocol (Obsolete)
              PPP Point to Point Protocol (IETF STD 51 [104])
              Non-IP Transfer of Non-IP data to external packet data network (see 3GPP TS 23.401
              This is an area I'm unsure about. I would welcome comments from others about what would need to be done.
                tlanier
                Here's updated code that is now running on two units overnight with good success. The code handles unsolicited responses gracefully. The code is non-intrusive to other multi-tasking threads. The code has not crashed (more testing to be done for sure). The code is easy to understand; everything is there to see and improve (no hidden commands being sent to the modem).
                # MODEM.PY Module
                import globals as g
                from machine import UART
                import micropython
                import sys
                import util
                from util import log
                from utime import sleep_ms, ticks_ms, ticks_diff
                uart = None
                #                     Send AT Command To Modem
                def at(cmd, filterx=""):
                    try:
                        if uart.any() > 0:
                            # get unsolicited modem response
                            a = at_response()
                            for s in a:
                                at_process(s)
                        log("  modem command: {}".format(cmd))
                        # send command to modem
                        n = uart.write(cmd + '\r')
                        if n != len(cmd) + 1:
                            log("error sending command to modem: n = {}".format(n))
                            return []
                        a = at_response(filterx)
                        return a
                    except Exception as ex:
                        sys.print_exception(ex)
                        a = []
                    return a    # return modem response lines in array
                #                     Filter Modem Response
                def at_filter(a, filterx):
                    # a is passed as reference value
                    if filterx == "":
                        return
                    # filter response
                    n = len(filterx)
                    i = len(a)
                    while i > 0:
                        i = i - 1
                        if a[i][0:n] != filterx:
                            # remove lines that do not start with filter value
                            at_process(a[i])
                            a.pop(i)
                #                     Process Unsolicited Response
                def at_process(s):
                    if s == 'OK':
                        pass
                        log("unsolicited modem response: {}".format(s))
                    return
                #                       Get AT Command Response
                def at_response(filterx=""):
                    try:
                        t0 = ticks_ms()
                            if uart.any() > 0:
                                # insure entire response has been received
                                sleep_ms(50)
                                break
                            t1 = ticks_ms()
                            if tx > 10000:
                                log("timeout error - no modem response after 10 secs")
                                return []
                            sleep_ms(100)
                        b = uart.read()
                        s = str(b, 'utf-8')
                        a = s.split('\r\n')
                        a = list(filter(None, a))
                        log("  modem response: {}".format(a))
                        a = []
                #             Attach Cellular Modem To Packet Domain Service
                def attach():
                    try:
                        log("attach modem to packet domain service")
                        a = at('AT+CGATT=1','OK')
                        if len(a) == 0:
                            log("error attaching modem")
                #                       Check Registration
                def check_registration():
                    # return 0-5, 99-unknown
                    # response: ['+CEREG: 2,4', 'OK']
                    # response: ['+CEREG: 2,1,"2C29","0B54400F",7', 'OK']
                    # 2,0 - not registered, not searching
                    # 2,1 - registered, home network
                    # 2,2 - not registered, searching
                    # 2,3 - registration denied
                    # 2,4 - unknown (out of coverage)
                    # 2,5 - registered, roaming
                    try:
                            log("check registration")
                            a = at('AT+CEREG?','+CEREG:')
                            if len(a) == 0:
                                break
                            a = a[0].split(",")
                            if (a[0] != "+CEREG: 2"):
                                break
                            reg = int(a[1])
                            if reg == 1:
                                log("registered - home network")
                            elif reg == 5:
                                log("registered - roaming")
                                log("not registered")
                            return reg
                        log("check registration exception")
                    # unknown registration
                    log("error checking registration")
                    return 99
                #             Detach Cellular Modem From Packet Domain Service
                def detach():
                    # modem does not get SMS messages while the modem is detached
                    # old messages received while detached are only received when a new message is sent while attached
                    try:
                        log("detach modem from packet domain service")
                        a = at('AT+CGATT=0','OK')
                        if len(a) == 0:
                            log("error detaching modem")
                #                       Disable LTE Modem
                def disable_modem():
                    try:
                        log("disable modem")
                        a = at('AT+CFUN=0','OK')     # minimum functionality
                        if len(a) == 0:
                            log("error disabling modem")
                #                       Enable Modem
                def enable_modem():
                    try:
                        log("enabling modem")
                        a = at('AT+CFUN=1','OK')     # full functionality
                        if len(a) == 0:
                            log("error enabling modem")
                #                Get CFUN - Modem Level of Functionality
                def get_cfun():
                    # 0 - minimum functionality
                    # 1 - full functionality
                    # 4 - radios disabled but access to SIM allowed
                    # -1 - unknown
                    # note: if modem does +SHUTDOWN/+SYSSTART, CFUN will be reset to 0
                    try:
                            a = at('AT+CFUN?','+CFUN:')
                            # response: ['+CFUN: 1', 'OK']
                            if len(a) == 0:
                                break
                            cfun = int(a[0][7])
                            return cfun
                    return -1
                #                           Get SMS Mode
                def get_sms_mode():
                    # return 0-PDU mode or unknown, 1-text mode
                    try:
                        log("get SMS mode")
                        a = at('AT+CMGF?','+CMGF:')
                        # response: ['+CMGF: 1', 'OK']
                        if len(a) == 0:
                            return 0    # mode unknown
                        mode = int(a[0][7])
                        return mode
                #                            HTTP Post
                def http_post(uri, header, tx_data):
                    # --> AT+SQNHTTPSND=<prof_id>,<command>,<resource>,<data_len>[,<post_param>[,<extra_header_line>]]
                    # xx> POST <uri> HTTP/1.1
                    # xx> <header>
                    # xx> Content-Length: <tx_size>
                    # xx> Content-Type: application/octet-stream
                    # xx> <blank line>
                    # --> <tx_data bytes>
                    # <-- OK
                    # <-- +SQNHTTPRING: <prof_id,<http_status_code>,<content_type>,<rx_size>
                    # --> AT+SQNHTTPRCV=1,0\r
                    # <-- /r/n<<<
                    # <-- <rx_data bytes>
                    # <-- OK
                    try:
                        log("HTTP post")
                            # note: init_modem() sets configuration "AT+SQNHTTPCFG=..." at startup
                            tx_size = len(tx_data)
                            # log("writing message: {0}".format(tx_data))
                            log("tx_data length: {0}".format(tx_size))
                            # AT+SQNHTTPSND=<prof_id>,<command>,<resource>,<data_len>[,<post_param>[,<extra_header_line>]]
                            # prof_id=1, command=0 (POST), <uri>, <tx_size>, post_parm="2" (application/octet-stream), header="Host: <host_name>"
                            a = at('AT+SQNHTTPSND=1,0,"{0}",{1},"2","{2}"'.format(uri, tx_size, header),'> ')
                            if len(a) == 0:
                                break   # error
                            uart.write(tx_data)
                            a = at_response('OK')
                            if len(a) == 0:
                                break   # error
                            # modem responds with "+SQNHTTPRING: <prof_id,<http_status_code>,<content_type>,<data_size>"
                            a = at_response("+SQNHTTPRING:")
                            if len(a) == 0:
                                break   # error
                            a = a[0].split(",")
                            http_status_code = int(a[1])
                            if http_status_code != 200:
                                break   # error
                            rx_size = int(a[3])
                            log("rx_data length: {0}".format(rx_size))
                            # get response
                            cmd = 'AT+SQNHTTPRCV=1,0\r'
                            log("  modem command: {0}".format(cmd))
                            uart.write(cmd)
                            r = wait_rx(5, 10000)   # wait for b'\r\n<<<'
                            if r == False:
                                break   # error
                            b = uart.read(5)
                            # log(" modem response: {0}".format(b))
                            if b[2:5] != b'<<<':
                                break   # error
                            t0 = ticks_ms()
                            b = b''
                            n = rx_size     # no. bytes remaining to be read
                                if uart.any() > 0:
                                    log("attempt to read {0} bytes".format(n))
                                    bx = uart.read(n)
                                    log("bytes read: {0}".format(len(bx)))
                                    # log(" modem response: {0}".format(bx))
                                    b = b + bx
                                    if len(b) == rx_size:
                                        break   # entire message received
                                    n = rx_size - len(b)
                                    t0 = ticks_ms()     # reset timeout
                                t1 = ticks_ms()
                                if tx > 10000:
                                    log("timeout error receiving response")
                                    return b''
                                sleep_ms(400)
                            log("total bytes read: {0}".format(len(b)))
                            # log(" post response: {0}".format(b))
                            if len(a) == 0:
                                break   # error
                            # log(b)
                            return b
                    # error
                    return b''
                #                     Get SIM Card ICCID Number
                def iccid():
                    # CFUN must be 1 or 4
                    try:
                        log("get SIM card ICCID")
                        a = at('AT+SQNCCID?','+SQNCCID:')
                        # example response: ['+SQNCCID: "89014103271203065543",""', 'OK']
                        if len(a) == 0:
                            return ''
                        a = a[0].split(",")
                        n = len(a[0])
                        r = a[0][11:n-1]
                        r = ''
                    log("ICCID = {0}".format(r))
                    return r    # ICCID as string
                #                       Get Modem IMEI Number
                def imei():
                    try:
                        log("get modem IMEI number")
                        a = at('AT+CGSN=1','+CGSN:')
                        # example response: ['+CGSN: "354347094028575"', 'OK']
                        if len(a) == 0:
                            return ''
                        n = len(a[0])
                        r = a[0][8:n-1]
                        r = ''
                    log("IMEI = {0}".format(r))
                    return r    # IMEI as string
                #                       Initialize Modem
                def init_modem():
                    try:
                        log("initializing modem")
                        if uart == None:
                            init_uart()
                        disable_modem()
                        # set profile #1 parameters for HTTP connection
                        # prof_id=1 (profile), ip, port, auth_type=0 (None), username="", password="",
                        # ssl_enabled=0, timeout, cid=1 (PDN Context Identifier)
                        server = g.oIni.host_ip     # note: host_name could also be used (auto DNS lookup)
                        port = g.oIni.host_port
                        timeout = 10    # secs to wait for response from server
                        cmd = 'AT+SQNHTTPCFG=1,"{0}",{1},0,"","",0,{2},1'.format(server, port, timeout)
                        a = at(cmd,'OK')
                        if len(a) == 0:
                            log("error initializing modem")
                        set_sms_mode()
                        enable_modem()
                #               Initialize Uart Connected To LTE Modem
                def init_uart():
                    global uart
                    # pins=(TXD, RXD, RTS, CTS)
                    # FiPy: pins=('P20', 'P18', 'P19', 'P17')
                    # GPy:  pins=('P5', 'P98', 'P7', 'P99')
                    log("initializing UART")
                    # rx_buffer_size: must be > 127, 200000 works, 250000 crashes, http_post seems to work with any size
                    uart = UART(1, baudrate=921600, bits=8, parity=None, stop=1, timeout_chars=2, pins=('P5', 'P98', 'P7', 'P99'), rx_buffer_size=512)
                #           Is Cellular Modem Attached To Packet Domain Service
                def isattached():
                    # returns: True/False
                    try:
                        a = at('AT+CGATT?','+CGATT:')
                        # example response: ['+CGATT: 0', 'OK']
                        if len(a) == 0:
                            return False
                        if a[0][8] == '1':
                            return True
                    return False
                #                           Reset Modem
                def reset_modem():
                    try:
                        if uart == None:
                            init_uart()
                        log("reseting modem...")
                        a = at('AT^RESET','+SHUTDOWN')
                        # generates +SHUTDOWN ... +SYSSTART responses
                        if len(a) == 0:
                            log("error resetting modem - no +SHUTDOWN")
                        a = at_response('+SYSSTART')
                        if len(a) == 0:
                            log("error resetting modem - no +SYSSTART")
                #                  Check Modem For Restart/Crash
                def restarted():
                    # return True if modem has crashed / restarted
                    try:
                        # if CFUN != 1, modem has crashed / restarted
                        cfun = get_cfun()
                        if cfun != 1:
                            return True
                        # if SMS text mode is reset to zero, modem has crashed / restarted
                        mode = get_sms_mode()
                        if mode != 1:
                            return True
                        return False
                    return True
                #                           Set APN
                def set_apn():
                    try:
                        log("set APN")
                        # ICCID is only valid after registration
                        r = iccid()[0:5]
                        if r == "89014":
                            apn = g.oIni.apn_89014   # Kore AT&T SIM
                        elif r == "89012":
                            apn = g.oIni.apn_89012   # Kore T-Mobile SIM
                        elif r == "89445":
                            apn = g.oIni.apn_89445   # Hologram SIM
                        g.oIni.apn = apn
                        log("APN: {0}".format(apn))
                        # try to reduce wear of non-volatile memory
                        a = at('AT+CGDCONT?','+CGDCONT:')
                        # response --> ['+CGDCONT: 1,"IP","10569.mcs",,,,0,0,0,0,0,0', ...]
                        if len(a) > 0:
                            a = a[0].split(",")
                            if (a[0] == '+CGDCONT: 1') and (a[1] == '"IP"') and (a[2] == '"'+apn+'"'):
                                return
                        # apn needs setting
                        cmd = 'AT+CGDCONT=1,"IP","{0}"'.format(apn)
                        a = at(cmd,'OK')
                        if len(a) == 0:
                            log("error setting APN")
                #                       Set SMS Mode To Text
                def set_sms_mode():
                    try:
                        log("set SMS mode to text")
                        a = at('AT+CMGF=1','OK')     # set SMS mode to text
                        if len(a) == 0:
                            log("error setting SMS mode to text")
                #                       Get Signal Strength
                def signal_strength():
                    # 0-31, 99-unknown
                    try:
                            log("check signal strength")
                            a = at('AT+CSQ','+CSQ:')
                            # example response: ['+CSQ: 18,99', 'OK'] where 18 is signal strength
                            if len(a) == 0:
                                break
                            n = len(a[0])
                            s = a[0][6:n-1]
                            a = s.split(",")
                            cell_signal = int(a[0])
                            g.oStatus.cell_signal = cell_signal
                            log("signal strength = {0}".format(cell_signal))
                            return cell_signal
                    # unknown signal strength
                    g.oStatus.cell_signal = 99
                    log("signal strength unknown")
                    return 99
                #             Delete Read, Sent, and Unsent SMS Messages
                def sms_delete():
                    try:
                        log("delete all READ, SENT, and UNSENT SMS messages")
                        a = at('AT+CMGD=1,3','OK')
                        if len(a) == 0:
                            log("error trying to delete read, sent, and unsent SMS messages")
                #                     Delete All SMS Messages
                def sms_delete_all():
                    # doesn't work until some time after attach() is called
                    try:
                        log("delete all SMS messages")
                        a = at('AT+CMGD=1,4','OK')
                        if len(a) == 0:
                            log("error trying to delete all SMS messages")
                #                     Process SMS Messages
                def sms_process(r):
                    # example response:
                    # ['+CMGL: 1,"REC READ","+1xxxxxxxxxx",,"19/01/07,09:16:53-20"', 'Test3', '+CMGL: 2,"REC READ","+1xxxxxxxxxx",,"19/01/07,11:12:30-20"', 'Test4', 'OK']
                    try:
                        for m in r:
                            if (m[0:5] == "+CMGL"):
                                continue
                            a = m.split("=")
                            cmd = a[0].upper()
                #                      Read Unread SMS Messages
                def sms_read():
                    # response example: ['+CMGL: 1,"REC UNREAD","+1xxxxxxxxxx",,"19/01/07,09:16:53-20"', 'Test3', 'OK']
                    log("read unread SMS messages")
                    a = at('AT+CMGL="REC UNREAD"')
                    return a
                #                       Read All SMS Messages
                def sms_read_all():
                    # response example:
                    log("read all SMS messages")
                    a = at('AT+CMGL="ALL"')
                    return a
                    # timeout in msecs
                    t0 = ticks_ms()
                        if uart.any() >= n:
                            break
                        t1 = ticks_ms()
                        if tx > timeout:
                            return False
                        sleep_ms(10)
                    return True
                Here's the code being used. The code shown is incomplete since it is application dependent. I'm somewhat disappointed in the necessary placement of the modem.apn_set() call. This may change in the future.
                # COM.PY Module
                import globals as g
                import modem
                from poll import poll
                import sys
                import uos
                import util
                import wifi
                #                         Communication Task
                def com_task():
                    try:
                        sleep_ms(500)
                        log("com_task: started")
                        wifi.deinit()
                        modem.reset_modem()
                        modem.init_modem()
                        g.poll_host = True      # triggers poll at startup
                        try:
                            if modem_ready():
                                if ready_to_poll():
                                    modem.set_apn()
                                    transmit()
                            sleep_ms(2000)
                #                           Modem Ready
                def modem_ready():
                    try:
                        log("** check for modem ready")
                        # get modem signal strength
                        g.oStatus.cell_signal = modem.signal_strength()
                        # check modem registration
                        r = modem.check_registration()
                        if (r == 1) or (r == 5):
                            # registered
                            g.com_secs = 0
                            # handle SMS messages
                            r = modem.sms_read()
                            if len(r) > 1:
                                modem.sms_process(r)
                                modem.sms_delete()
                            return True
                        reset = False
                        if g.com_secs > (10*60):
                            # unable to attach in 10 mins, try resetting modem
                            reset = True
                        if modem.restarted():
                            # modem has crashed / restarted, try resetting modem
                            reset = True
                        if reset:
                            modem.reset_modem()
                            modem.init_modem()
                            g.com_secs = 0
                        return False
                    return False
                  tlanier
                  I seemed to have hit a major problem using the AT+SQNHTTPSND modem command. Although the manual does not state this, the maximum size of the data posted is apparently 1500 bytes.
                  If anyone has ideas of how to increase this, please let me know. Unfortunately my app requires posting messages over 3000 bytes.
                  Disappointed...
                    tlanier
                    I've now converted my code to use the Sequans modem socket commands in command mode (not on-line mode). I first tried to use the on-line mode, but ran into issues (no good way I could find to prevent overrunning tx buffer). This code resolves the 1500 byte limitation I ran into using the HTTP modem commands. There's still some cleanup to do to make the code more robust; however, it is working with large transmit and receive data blocks now.
                    During development while I had coding errors and the program would terminate abnormally, I did put the modem in a mode that I couldn't recover from without power cycling the GPy. The modem would not response to AT commands, Trying to do lte = LTE() would generate the following error (OSError: Couldn't connect to Modem (modem_state=disconnected)). Doing machine.reset() would not correct the problem.
                    Link to discussion of similar problem on Github
                    Hopefully whatever I did to cause the problem will not occur in debugged code. There needs to be a true hardware reset of the modem. It seems that a GPIO pin should be tied to a physical reset line going to the modem that we could pulse if needed. I'm also of the opinion that the watchdog timer in the GPy should have been a hardware circuit not dependent on software to work.
                    So far I have not seen any unexplained crashes while running the code.
                    This code has been added to my modem.py module.
                    #                       Socket Close
                    def socket_close():
                        # socket close
                        # connID = 1 --> socket connection identifier
                        a = at('AT+SQNSH=1', 'OK')
                        if len(a) == 0:
                            log("error closing connection")
                            return
                    #                       Socket Connect
                    def socket_connect(ip, port, timeout_secs=10):
                        # returns: True if connection successful
                        log("connecting to ip - {0}, port - {1}".format(ip, port))
                        # make sure socket is closed
                        socket_close()
                        # socket configuration
                        # cid = 1 --> PDP context identifier
                        # pktSz = 1500 --> packet size
                        # maxTo = 10 --> exchange timeout in secs
                        # connTo = 600 --> connection timeout in msecs
                        # txTo = 3 --> data sending timeout in hundreds of msecs
                        # a = at('AT+SQNSCFG=1,1,1500,10,600,3', 'OK')
                        a = at('AT+SQNSCFG=1,1,1500,{0},600,3'.format(timeout_secs), 'OK')
                        if len(a) == 0:
                            log("error connecting")
                            return False
                        # socket extended configuration
                        # srMode = 1 --> SQNSRING URC data amount mode
                        # recvDataMode = 1 --> data in hex
                        # keepalive = 0 --> unused
                        # listenAutoRsp = 0 --> deactivated
                        # sendDataMode = 1 --> data in hex
                        a = at('AT+SQNSCFGEXT=1,1,1,0,0,1', 'OK')
                        if len(a) == 0:
                            return False
                        # socket dial
                        # txProt = 0 --> TCP protocol
                        # rPort = <port> --> remote host port to contact
                        # IPaddr = <ip> --> address of remote host
                        # closureType = 0 --> local host closes immediately when remote host has closed
                        # lPort = 0 --> UDP port (not used)
                        # connMode = 1 --> command mode connection
                        # acceptAnyRemote = 0 --> disabled
                        a = at('AT+SQNSD=1,0,{0},"{1}",0,0,1,0'.format(port,ip), 'OK')
                        if len(a) == 0:
                            return False
                        log("** connection successful **")
                        return True
                    #                       Socket Info
                    def socket_info():
                        # modem response: ['+SQNSI: 1,0,0,0,0', 'OK']
                        # connId: 1
                        # sent: total bytes sent
                        # received: total bytes received
                        # buff_in: total bytes not yet read (buffered)
                        # ack_waiting: total bytes sent but not yet acknowledged
                        a = at('AT+SQNSI=1')
                    #                       Socket Receive Data
                    def socket_rx():
                        # receives up to 1500 bytes maximum
                        log("check for rx data")
                        a = at('AT+SQNSRECV=1,1500')
                        # no data ready --> modem response: ['+CME ERROR: operation not supported']
                        # data ready --> modem response: ['+SQNSRECV: 1,3', '010203', 'OK']
                        b = b''
                        for i in range(len(a)):
                            if a[i].startswith('+SQNSRECV:'):
                                # next line is the data
                                b = unhexlify(a[i+1])
                        log("rx {0} bytes".format(len(b)))
                        return b
                    #                       Socket Status
                    def socket_status():
                        # modem response: ['+SQNSS: 1,0', '+SQNSS: 2,0', '+SQNSS: 3,0', '+SQNSS: 4,0', '+SQNSS: 5,0', '+SQNSS: 6,0', 'OK']
                        # connID
                        # state:
                        #   0-socket closed
                        #   1-socket with active data transfer connection
                        #   2-socket suspended
                        #   3-socket suspended with pending data
                        #   4-socket listening
                        #   5-socket with incoming connection
                        #   6-socket in opening process
                        a = at('AT+SQNSS?')
                        return a
                    #                       Socket Transmit Data
                    def socket_tx(tx, n=0):
                        # transmits up to 1500 bytes maximum
                        # returns: True if successful
                        if n == 0:
                            n = len(tx)
                        log("tx {0} bytes".format(n))
                        a = at('AT+SQNSSENDEXT=1,{0}'.format(n), '> ')
                        hex = hexlify(tx)
                        uart.write(hex)
                        if len(a) == 0:
                            log("error transmitting data")
                            return False
                        return True
                    This code is in my http.py module.
                    import modem
                    import sys
                    import ubinascii
                    import uos
                    import ustruct
                    import util
                    BUFFER_SIZE = const(1500)
                    CR = const(0x0d)
                    LF = const(0x0a)
                    MAX_HEADER_SIZE = const(128)
                    MAX_TX_SIZE = const(1500)
                    HTTP_TIMEOUT_MSECS = const(15000)
                    # HTTP_TIMEOUT_MSECS = const(300000)  # TESTING
                    http_error = False      # HTTP communication error: True/False
                    http_size = 0           # HTTP POST message size
                    rx_cnt = 0              # no. bytes in rx_data buffer
                    rx_data = b''           # rx data buffer
                    rx_pt = 0               # pointer into rx data buffer
                    tx_cnt = 0              # no. bytes in tx_data buffer
                    tx_data = bytearray(MAX_TX_SIZE)    # tx data buffer
                    tx_flag = False         # controls tx_byte
                    #                       Close HTTP Socket
                    def close_http():
                        modem.socket_close()
                    #                       Open HTTP Socket
                    def open_http(host_ip, host_port):
                        global http_error, rx_cnt, rx_data, rx_pt, tx_cnt
                        http_error = False
                        rx_cnt = 0
                        rx_data = b''
                        rx_pt = 0
                        tx_cnt = 0
                        r = modem.socket_connect(host_ip, host_port)
                        if r == False:
                            log("TCP socket connect error")
                            http_error = True
                    #                    Receive BLOCK From Response
                    def rx_block(cnt):
                        b = bytearray(cnt)
                        i = 0
                        while i < cnt:
                            b[i] = rx_byte()
                            i = i + 1
                        return b
                    #                    Receive BYTE From Response
                    def rx_byte():
                        global http_error, http_size, rx_cnt, rx_data, rx_pt
                        t0 = ticks_ms()
                        while rx_cnt == 0:
                            rx_data = modem.socket_rx()
                            rx_cnt = len(rx_data)
                            rx_pt = 0
                            if rx_cnt > 0:
                                break
                            t1 = ticks_ms()
                            if (tx > HTTP_TIMEOUT_MSECS):
                                http_error = True
                                return 0
                            sleep_ms(200)
                        b = rx_data[rx_pt]
                        rx_cnt = rx_cnt - 1
                        rx_pt = rx_pt + 1
                        http_size = http_size - 1
                        # print("rx byte: {0}".format(hex(b)))
                        return b
                    #                    Receive DWORD From Response
                    def rx_dword():
                        dw1 = rx_byte()
                        dw2 = rx_byte()
                        dw3 = rx_byte()
                        dw4 = rx_byte()
                        return (dw1 + (dw2<<8) + (dw3<<16) + (dw4<<24))
                    #                    Receive One HTTP Header
                    def rx_http_header():
                        # returns header string
                        global http_error
                        n = 0
                        header = bytearray(MAX_HEADER_SIZE)
                        s = ""
                            b = rx_byte()
                            # print("byte = {0}".format(b))
                            if http_error:
                                return ""
                            if b == CR:
                                continue
                            if b == LF:
                                break
                            header[n] = b
                            n = n + 1
                            if n >= MAX_HEADER_SIZE-1:
                                http_error = True
                                return ""
                        if n > 0:
                            # print("n = {0}, header = {1}".format(n,header))
                            s = header[0:n].decode('utf-8')
                        return s
                    #                    Receive HTTP Headers
                    # HTTP/1.1 200 OK
                    # <headers>
                    # Content-Length: nnn
                    # <headers>
                    # <crlf>
                    # Updates: http_size, http_error
                    def rx_http_headers():
                        headers = []      # array of header lines
                        http_size = 0
                            s = rx_http_header()
                            log("length = {0}, header = {1}".format(len(s), s))
                            if http_error:
                                return headers
                            if s == "":
                                break
                            headers.append(s)
                        if len(headers) < 2:
                            http_error = True
                            return headers
                        a = headers[0].split(' ')
                        if (a[1] != "200") or (a[2]) != "OK":
                            http_error = True
                            return headers
                        for s in headers:
                            if s.startswith("Content-Length:"):
                                a = s.split(' ')
                                http_size = int(a[1])
                        return headers
                    #                    Receive String From Response
                    def rx_string(max_len):
                        rx = bytearray(max_len)
                        i = 0
                        while i < max_len:
                            b = rx_byte()
                            if b == 0:
                                break
                            rx[i] = b
                            i = i + 1
                        if i == 0:
                            return ""
                        s = rx[0:i].decode('utf-8')
                        return s
                    #                    Receive WORD From Response
                    def rx_word():
                        dw1 = rx_byte()
                        dw2 = rx_byte()
                        return (dw1 + (dw2<<8))
                    #                       Transmit Block
                    def tx_block(b):
                        for x in b:
                            tx_byte(x)
                    #                       Transmit Byte
                    def tx_byte(b):
                        global http_size, tx_cnt, tx_data, tx_flag
                        if tx_flag == False:
                            http_size = http_size + 1
                            # print("tx byte: {0}, http size: {1}".format(hex(b), http_size))
                            return
                        # print("tx byte: {0}".format(hex(b)))
                        tx_data[tx_cnt] = b
                        tx_cnt = tx_cnt + 1
                        if tx_cnt >= MAX_TX_SIZE:
                            tx_flush()
                    #                       Transmit DWORD
                    def tx_dword(dw):
                        tx_word(dw & 0xffff)
                        tx_word((dw >> 16) & 0xffff)
                    #                       Transmit Flush
                    def tx_flush():
                        global tx_cnt, tx_data
                        if tx_cnt == 0:
                            return
                        r = modem.socket_tx(tx_data, tx_cnt)
                        if not r:
                            http_error = True
                            return
                        tx_cnt = 0
                    #                       Transmit HTTP Headers
                    def tx_http_headers(http_post, host_name, host_port):
                        # example:
                        # POST <http_post> HTTP/1.1
                        # Host: <host_name>:<host_port>
                        # Content-Length: <http_size>
                        # Content-Type: application/octet-stream
                        # <crlf>
                        log("tx HTTP headers")
                        if http_error:
                            return
                        s = "POST {0} HTTP/1.1\r\n".format(http_post)
                        tx_string(s)
                        if host_port != 80:
                            s = "Host: {0}:{1}\r\n".format(host_name, host_port)
                            s = "Host: {0}\r\n".format(host_name)
                        tx_string(s)
                        s = "Content-Length: {0}\r\n".format(http_size)
                        tx_string(s)
                        s = "Content-Type: application/octet-stream\r\n"
                        tx_string(s)
                        s = "\r\n"
                        tx_string(s)
                    #                       Transmit String
                    def tx_string(s):
                        b = s.encode('utf-8')
                        for x in b:
                            tx_byte(x)
                    #                       Transmit WORD
                    def tx_word(w):
                        tx_byte(w & 0xff)
                        tx_byte((w >> 8) & 0xff)
                      tlanier
                      We now have our program running completely independent of the LTE module. 26 units have been running for multiple days with no crashes. I now think we have found a reliable solution. The Sequans modem AT socket commands are used to do the HTTP posts. We reliably receive 90K files and transmit 1-5K of data with no issues. Pycom MicroPython V1.20.0.rc13 is the OS version we are using.
                      Currently we are using whatever version of the modem firmware (41065, 43818, and 47510 have been seen) that comes with the GPy. The version of the OS we are using has the ability to "downgrade" the modem firmware to 41065 if we decide it is needed. Some newer versions of the OS do not have this ability.
                      One note of importance is we did discover that in our case the default stack size was marginal when receiving large files. Yes, I did go back and check the old program and verified that the stack issue was not the cause of the original crash problems.
                      #                          Initialize Tasks
                      def init_tasks():
                          n = 8192    # 4096 is marginal
                          _thread.stack_size(n)
                          log("initializing tasks with stack size: {}".format(n))
                          _thread.start_new_thread(com.com_task, ())
                          _thread.start_new_thread(cycle.cycle_task, ())
                        ruok4t @tlanier
                        @tlanier I really like the sound of what your doing here. I've been struggling with Pycom LTE module for months now. Really don't like the way it blocks other threads and randomly locks up for no apparent reason. Are you possibly in a position to share a complete "Hello LTE World" example. I'm sure I wouldn't be the only one around here who would be very interested. Hopefully someone from Pycom might also take an interest and finally admit they need to revise their code.
                          tlanier @ruok4t
                          @ruok4t Sorry I didn't see your request earlier.
                          The software below is now working in production units. We ran about 20 units testing in house for two weeks with no crashes before beginning deployment with the new version. We are using MicroPython V1.20.0.rc13 with multiple versions of the modem firmware. It's a shame we had to resort to this, but it seems to work reliably.
                          I've had to break the post up into 3 parts because of limitations of this forum.
                          Part 1 of 3
                          Here's the modem.py module:
                          import globals as g
                          import gpio
                          import micropython
                          import sys
                          import util
                          from ubinascii import hexlify, unhexlify
                          from util import log, mem_info
                          uart = None
                              try:
                                  # util.mem_info("modem.at")
                                  if uart.any() > 0:
                                      a = at_response()
                                      for s in a:
                                          at_process(s)
                                  if gpio.G():
                                      if gpio.G():
                                      return []
                                  return a
                                  a = []
                              # filter response
                              if filterx == "":
                                  return
                              n = len(filterx)
                              i = len(a)
                              while i > 0:
                                  i = i - 1
                                  if not a[i].startswith(filterx):
                                      at_process(a[i])
                                      a.pop(i)
                          def at_process(s):
                              if s == 'OK':
                                  return
                              if s.startswith("ERROR"):
                                  return
                              if s.startswith("+CME ERROR:"):
                                  return
                              # process unsolicited response here
                              if gpio.G():
                                  log("  unsolicited modem response: {}".format(s))
                              try:
                                  t0 = ticks_ms()
                                      if uart.any() > 0:
                                          sleep_ms(50)
                                          break
                                      t1 = ticks_ms()
                                      if tx > 10000:
                                          return []
                                      sleep_ms(100)
                                  b = uart.read()
                                  s = str(b, 'utf-8')
                                  a = s.split('\r\n')
                                  if gpio.G():
                                  a = []
                              try:
                                      if len(a) == 0:
                                          break
                                      a = a[0].split(",")
                                          break
                                      reg = int(a[1])
                                      if reg == 1:
                                          log("*** registered - home network ***")
                                      elif reg == 5:
                                          log("*** registered - roaming ***")
                                          log("*** NOT registered ***")
                                      return reg
                              return 99
                          #                       Check SIM Status
                          def check_sim_status():
                              try:
                                  log("checking SIM card status")
                                  a = at('AT+CPIN?', '+CPIN: READY')
                                  if len(a) > 0:
                                      return True
                              log("error SIM card not ready")
                              return False
                          #                       Disable LTE Modem
                              try:
                                  if len(a) == 0:
                          #                       Enable Modem
                          def enable_modem():
                              try:
                                  if len(a) == 0:
                          def get_cfun():
                              # -1 - unknown
                              try:
                                      if len(a) == 0:
                                          break
                                      cfun = int(a[0][7])
                                      return cfun
                              return -1
                          #                           Get SMS Mode
                          def get_sms_mode():
                              try:
                                  log("get SMS mode")
                                  if len(a) == 0:
                                  mode = int(a[0][7])
                                  return mode
                          def iccid():
                              # SIM status must be ready
                              try:
                                  a = at('AT+SQNCCID?', '+SQNCCID:')
                                  if len(a) == 0:
                                      return ''
                                  a = a[0].split(",")
                                  n = len(a[0])
                                  r = a[0][11:n-1]
                                  r = ''
                          def imei():
                              try:
                                  if len(a) == 0:
                                      return ''
                                  n = len(a[0])
                                  r = a[0][8:n-1]
                                  r = ''
                          #                   Modem Firmware Info
                          def info():
                              log("get modem firmware version")
                              a = at('ATI1')
                              return a
                          #                       Initialize Modem
                          def init_modem():
                              try:
                                  if uart == None:
                                      init_uart()
                                  info()
                                  set_sms_mode()
                                  # enable +CME ERROR: <err> result code and use verbose <err> values
                                  at('AT+CMEE=2')
                                  enable_modem()
                                  log("wait for SIM card ready")
                                  n = 0
                                      if len(a) > 0:
                                          break
                                      n = n + 1
                                      if n > 20:
                                          util.reset(13, "No SIM card")
                                      sleep_ms(200)
                                  set_apn()
                          def init_uart():
                              global uart
                          def isattached():
                              try:
                                  if len(a) == 0:
                                      return False
                                  if a[0][8] == '1':
                                      return True
                              return False
                          #                           Reset Modem
                          def reset_modem():
                              try:
                                  if uart == None:
                                      init_uart()
                                  a = at('AT^RESET', '+SHUTDOWN')
                                  if len(a) == 0:
                                  if len(a) == 0:
                          def restarted():
                              try:
                                  cfun = get_cfun()
                                  if cfun != 1:
                                      return True
                                  if mode != 1:
                                      return True
                                  return False
                              return True
                          #                           Set APN
                          def set_apn():
                              try:
                                  log("set APN")
                                  # ICCID is only valid if SIM status is ready
                                  r = iccid()[0:5]
                                  if r == "89014":
                                  elif r == "89012":
                                  elif r == "89445":
                                  g.oIni.apn = apn
                                  a = at('AT+CGDCONT?', '+CGDCONT:')
                                  if len(a) > 0:
                                      a = a[0].split(",")
                                          return
                                  # apn needs setting
                                  a = at(cmd, 'OK')
                                  if len(a) == 0:
                          def set_sms_mode():
                              try:
                                  a = at('AT+CMGF=1', 'OK')     # set SMS mode to text
                                  if len(a) == 0:
                              # 0-31, 99-unknown
                              try:
                                      a = at('AT+CSQ', '+CSQ:')
                                      if len(a) == 0:
                                          break
                                      n = len(a[0])
                                      s = a[0][6:n-1]
                                      a = s.split(",")
                                      return cell_signal
                              return 99
                          def sms_delete():
                              try:
                                  a = at('AT+CMGD=1,3', 'OK')
                                  if len(a) == 0:
                              try:
                                  a = at('AT+CMGD=1,4', 'OK')
                                  if len(a) == 0:
                          def sms_process(r):
                              # example response:
                              try:
                                  for m in r:
                                          continue
                                      a = m.split("=")
                                      cmd = a[0].upper()
                          			# process message here
                          def sms_read():
                              return a
                          def sms_read_all():
                              # response example:
                              return a
                          #                       Socket Close
                          def socket_close():
                              # socket close
                              log("closing socket")
                              if len(a) == 0:
                          #                       Socket Connect
                              socket_close()
                              if len(a) == 0:
                                  return False
                              if len(a) == 0:
                                  return False
                              # socket dial
                              if len(a) == 0:
                                  return False
                              return True
                          #                       Socket Info
                          def socket_info():
                              # connId: 1
                              log("socket info")
                          def socket_rx():
                              b = b''
                              return b
                          #                       Socket Status
                              # connID
                              # state:
                              #   0-socket closed
                              log("socket status")
                              a = at('AT+SQNSS?')
                              return a
                              if n == 0:
                                  n = len(tx)
                              b = hexlify(tx)
                              uart.write(b)
                              if len(a) == 0:
                                  return False
                              return True
                          T R 2 Replies Last reply Reply Quote 0
                            tlanier @tlanier
                            @tlanier
                            Part 2 of 3
                            Here's our com.py module. It is more application dependent but it may give you some ideas of how to use the modem module.
                            import globals as g
                            import modem
                            import sys
                            import uos
                            import util
                            import wifi
                            _reset = True    # modem reset
                            def com_task():
                                global _reset
                                try:
                                    sleep_ms(500)
                                    # this opens the door for continuous resets to cause high data usage
                                    util.set_ppp_errors(0)
                                    wifi.deinit()
                                    try:
                                        _reset = False
                                        g.modem_state = g.MS_RESET_MODEM
                                        modem.reset_modem()
                                        g.modem_state = g.MS_INIT_MODEM
                                        modem.init_modem()
                                        while _reset == False:
                                            # util.mem_info("com_task")
                                            if modem_ready():
                                                g.modem_state = g.MS_REGISTERED
                                                if ready_to_poll():
                                                    transmit()
                                                g.modem_state = g.MS_REGISTERING
                                            sleep_ms(2000)
                            #                           Modem Ready
                            def modem_ready():
                                global _reset
                                try:
                                        # registered
                                        g.com_secs = 0
                                        if len(r) > 1:
                                            modem.sms_delete()
                                        return True
                                        _reset = True
                                        _reset = True
                                    return False
                                return False
                            #                           Ready To Poll
                            def ready_to_poll():
                                # return: True/False
                                try:
                                    log("--- time since last poll: {0} secs ---".format(g.oNvram.last_poll_secs))
                                    if (g.ppp_error_secs > 0):
                                        log("*** poll throttling: {0} secs ***".format(g.ppp_error_secs))
                                        return False
                                    if (g.oIni.intra_poll_secs > 0):
                                        # contact server every <oIni.intra_poll_secs> seconds
                                        if (g.oNvram.last_poll_secs > g.oIni.intra_poll_secs):
                                            return True
                                    if (g.oSetup.intra_cycle_count > 0):
                                        # contact server every <oSetup.intra_cycle_count> cycles
                                        if (g.oNvram.cycle_count >= g.oSetup.intra_cycle_count):
                                            return True
                                    # g.poll_host is set at startup and by SMS POLL_HOST message
                                    if (g.poll_host == True):
                                        return True
                                return False
                            #                         Transmit
                            def transmit():
                                try:
                                    util.lcd("Transmitting", "")
                                    g.modem_state = g.MS_CONNECTING
                                    r = poll()
                                    g.modem_state = g.MS_DISCONNECT
                                    if (r == False):
                                        util.lcd("Transmit failed", "")
                                        sleep_ms(2500)
                                        util.lcd("","")
                                        return
                                    util.lcd("Successful", "")
                                    sleep_ms(2500)
                                    util.lcd("","")
                                    g.poll_host = False
                                    g.oNvram.last_poll_secs = 0
                                    g.poll_secs = 0
                                    if (g.update_flag == True):
                                        # done after disconnect
                                        try:
                                            if util.file_exists("REMOTE.TAR"):
                                                log("remove old REMOTE.TAR")
                                                util.remove("REMOTE.TAR")
                                            log("rename TEMP to REMOTE.TAR")
                                            uos.rename("TEMP", "REMOTE.TAR")
                                            # create file to signal boot.py that update is available
                                            log("create UPDATE signal file")
                                            with open("UPDATE", "w") as f:
                                                f.write("UPDATE")
                                            log("** New REMOTE.TAR ready to update")
                                    if (g.reboot_after_poll == True):
                                        log("SMS message changed INI setting, rebooting")
                                        util.reset(6, "INI changed")
                                    if (g.oHost.erase == True):
                                        log("Erase command received, rebooting")
                                        g.oNvram.erase()
                                        util.reset(7, "Erase NVRAM")
                                    if (g.oHost.reset == True):
                                        log("Reset command received, rebooting")
                                        util.reset(8, "Reset command")
                              tlanier @tlanier
                              @tlanier
                              Part 3 of 3
                              Here's the http.py module:
                              Note that the modem socket commands have a 1500 byte limitation. The HTTP module overcomes that by breaking longer messages up into smaller blocks.
                              import modem
                              import sys
                              import ubinascii
                              import uos
                              import ustruct
                              import util
                              # note: HTTP errors raise exceptions
                              CR = const(0x0d)
                              LF = const(0x0a)
                              #                       Close HTTP Socket
                              def close_http():
                              #                       Open HTTP Socket
                                  global rx_cnt, rx_data, rx_pt, tx_cnt
                                  rx_cnt = 0
                                  rx_data = b''
                                  rx_pt = 0
                                  tx_cnt = 0
                                  if r == False:
                                      raise Exception("TCP socket connect error")
                              def rx_block(cnt):
                                  b = bytearray(cnt)
                                  i = 0
                                  while i < cnt:
                                      b[i] = rx_byte()
                                      i = i + 1
                                  log("rx_block: {} bytes".format(len(b)))
                                  return b
                              def rx_byte():
                                  global http_size, rx_cnt, rx_data, rx_pt
                                  t0 = ticks_ms()
                                  while rx_cnt == 0:
                                      rx_pt = 0
                                      if rx_cnt > 0:
                                          break
                                      t1 = ticks_ms()
                                          raise Exception("HTTP timeout in rx_byte")
                                      sleep_ms(200)
                                  b = rx_data[rx_pt]
                                  rx_cnt = rx_cnt - 1
                                  rx_pt = rx_pt + 1
                                  return b
                              def rx_dword():
                                  dw1 = rx_byte()
                                  dw2 = rx_byte()
                                  dw3 = rx_byte()
                                  dw4 = rx_byte()
                                  n = 0
                                  s = ""
                                      b = rx_byte()
                                      if b == CR:
                                          continue
                                      if b == LF:
                                          break
                                      header[n] = b
                                      n = n + 1
                                          raise Exception("Maximum header size error in rx_http_header")
                                  if n > 0:
                                      # older versions of MicroPython do not implement decode on bytearrays
                                      a = bytes(header[0:n])
                                      s = a.decode('utf-8')
                                      log("header = {}".format(s))
                                  return s
                              # HTTP/1.1 200 OK
                              # <headers>
                              # <headers>
                              # <crlf>
                                  global http_size
                                  http_size = 0
                                      # log("length = {0}, header = {1}".format(len(s), s))
                                      if s == "":
                                          break
                                      headers.append(s)
                                      raise Exception("Not enough headers received in rx_http_headers")
                                      raise Exception("Invalid first header line: {0}".format(headers[0]))
                                  for s in headers:
                                          a = s.split(' ')
                                  return headers
                                  i = 0
                                  while i < max_len:
                                      b = rx_byte()
                                      if b == 0:
                                          break
                                      rx[i] = b
                                      i = i + 1
                                  if i == 0:
                                      return ""
                                  a = bytes(rx[0:i])
                                  return s
                              def rx_word():
                                  dw1 = rx_byte()
                                  dw2 = rx_byte()
                              #                       Transmit Block
                              def tx_block(b):
                                  for x in b:
                                      tx_byte(x)
                              #                       Transmit Byte
                              def tx_byte(b):
                                      return
                                  tx_data[tx_cnt] = b
                                  tx_cnt = tx_cnt + 1
                                      tx_flush()
                              #                       Transmit DWORD
                              def tx_dword(dw):
                              #                       Transmit Flush
                              def tx_flush():
                                  if tx_cnt == 0:
                                      return
                                  if not r:
                                      raise Exception("Error transmitting in tx_flush")
                                  tx_cnt = 0
                                  # example:
                                  # <crlf>
                                  global http_size
                                  tx_string(s)
                                  if host_port != 80:
                                  tx_string(s)
                                  tx_string(s)
                                  tx_string(s)
                                  s = "\r\n"
                                  tx_string(s)
                              #                       Transmit String
                              def tx_string(s):
                                  for x in b:
                                      tx_byte(x)
                              #                       Transmit WORD
                              def tx_word(w):
                                  tx_byte(w & 0xff)
                                ruok4t @tlanier
                                @tlanier Thanks, will download all parts and take a look.
                                  SciWax
                                  @tlanier
                                  Thank you for compiling all this information for the community. I really appreciate it. It could become handy for my project.
                                    Scott Basgaard @tlanier
                                    @tlanier did you ever put this in a repo?
                                      tlanier @Scott Basgaard
                                      @Scott-Basgaard Sorry, I have not.
                                        Petteri Salo
                                        @tlanier Hey, I started looking into the three files you posted (http.py, com.py, modem.py) and it is looking very usefull! However, both com.py and modem.py have a line:
                                        "import globals as g"
                                        and I'm guessing it is a file you have, but I get an "ImportError: no module named 'globals'"
                                        Perhaps you could upload that file too? After a quick look throuh all "g.*" I could probably deduce most of it, but things like :
                                        would probably be usefull and save us some time.
                                        Anyway, Thanks for helping the community at large with your efforts!!
                                        Petteri
                                        S T 2 Replies Last reply Reply Quote 1
                                          Scott Basgaard @Petteri Salo
                                          @Petteri-Salo agree! Would be great @tlanier if you could share anything else here. Really struggling to get LTE working stable and any further insight for us others would be greatly appreciated. Digging into this more now and will let you know how far I get as well. Thanks for sharing!
                                            tlanier @Petteri Salo
                                            @Petteri-Salo The g.modem_state global variable is used in a timer interrupt routine to control the blinking and color of the LED on the GPY. This gives the user a visual indication of what state the modem is in. This variable is not critical to using the supplied code.
                                            Unfortunately the code I have published is just snippets of my production code. It was not designed to be a general purpose library (although I believe it comes close). Without publishing the entire application, there will be pieces that are missing.
                                            Your message has motivated me to add a few random notes.
                                            • We had production, shipping GPy based systems that were experiencing reliability issues. Upgrades to newer versions of the OS seemed to make the problems worse. There was considerable evidence that the problems were caused by the LTE module. For months I waited hoping that Pycom would make the existing product more robust. Instead they seemed to be going in all directions introducing new products but not improving the fundamental building blocks of the GPy. I was especially concerned when we purchased a new batch of chips and they came by default with a version of the OS which would not run our application for more than a few minutes without crashing. In addition Pycom seemed to be moving in a direction requiring our code in the future to be dependent on a cloud based system (Pybytes). This seemed to be making everything even more complex. We couldn't even get the simple things to work reliably.
                                            • In principle our application was not complex. We just needed to transmit a few packets of data to a web site periodically over the LTE network reliably without crashing the system. It was also desired that the communication would not interfere with the real time task of sampling data.
                                            • After looking at the C/C++ source code to the LTE module, it seemed way too complex. I had no good way to make changes, improvements, or bug fixes (assuming I could find the problem). If we moved the modem code to Python, we could bypass the usage of the LTE module and use the TCP/IP stack included in the Sequans modem. Maybe by pushing the communication load to the Sequans modem, the MicroPython would be more reliable and responsive to real time tasks. Maybe by publishing the code more people could observe and help to improve the code. We desperately needed a reliable method of communication.
                                            • Since converting our code to controlling the cell modem directly in Python code, I can now say the random crashes have been solved. The real time task is more responsive.
                                            • I hope that someday the LTE module will be improved so that it can be used again. Having a TCP/IP stack that is usable by both WIFI and LTE is certainly an advantage. Can it be made reliable? Can the ESP32 chip smoothly multitask while using LTE methods?
                                            • I wish I knew of a method to marry our higher level Python calls for modem management with the TCP/IP stack of MicroPython. I think such a technique could make the LTE module code simpler.
                                            • I think the dream of most application developers is to have simple reliable software methods to connect/disconnect to the network. The fact that we are connected using the cell network, WIFI, or whatever should be mostly transparent.
                                            • We all want Pycom to be successful. They have developed a good product. We did what we did because their priorities were not ours at the time.
                                            • 2 / 3
