    Method To Take Control of Cell Modem
    41 Posts 10 Posters 902 Views 14 Watching
      tlanier
      Here's updated code that is now running on two units overnight with good success. The code handles unsolicited responses gracefully. The code is non-intrusive to other multi-tasking threads. The code has not crashed (more testing to be done for sure). The code is easy to understand; everything is there to see and improve (no hidden commands being sent to the modem).
      # MODEM.PY Module
      import globals as g
      from machine import UART
      import micropython
      import sys
      import util
      from util import log
      from utime import sleep_ms, ticks_ms, ticks_diff
      uart = None
      #                     Send AT Command To Modem
      def at(cmd, filterx=""):
          try:
              if uart.any() > 0:
                  # get unsolicited modem response
                  a = at_response()
                  for s in a:
                      at_process(s)
              log("  modem command: {}".format(cmd))
              # send command to modem
              n = uart.write(cmd + '\r')
              if n != len(cmd) + 1:
                  log("error sending command to modem: n = {}".format(n))
                  return []
              a = at_response(filterx)
              return a
          except Exception as ex:
              sys.print_exception(ex)
              a = []
          return a    # return modem response lines in array
      #                     Filter Modem Response
      def at_filter(a, filterx):
          # a is passed as reference value
          if filterx == "":
              return
          # filter response
          n = len(filterx)
          i = len(a)
          while i > 0:
              i = i - 1
              if a[i][0:n] != filterx:
                  # remove lines that do not start with filter value
                  at_process(a[i])
                  a.pop(i)
      #                     Process Unsolicited Response
      def at_process(s):
          if s == 'OK':
              pass
              log("unsolicited modem response: {}".format(s))
          return
      #                       Get AT Command Response
      def at_response(filterx=""):
          try:
              t0 = ticks_ms()
                  if uart.any() > 0:
                      # insure entire response has been received
                      sleep_ms(50)
                      break
                  t1 = ticks_ms()
                  tx = ticks_diff(t1, t0)
                  if tx > 10000:
                      log("timeout error - no modem response after 10 secs")
                      return []
                  sleep_ms(100)
              b = uart.read()
              s = str(b, 'utf-8')
              a = s.split('\r\n')
              a = list(filter(None, a))
              log("  modem response: {}".format(a))
              a = []
      #             Attach Cellular Modem To Packet Domain Service
      def attach():
          try:
              log("attach modem to packet domain service")
              a = at('AT+CGATT=1','OK')
              if len(a) == 0:
                  log("error attaching modem")
      #                       Check Registration
      def check_registration():
          # return 0-5, 99-unknown
          # response: ['+CEREG: 2,4', 'OK']
          # response: ['+CEREG: 2,1,"2C29","0B54400F",7', 'OK']
          # 2,0 - not registered, not searching
          # 2,1 - registered, home network
          # 2,2 - not registered, searching
          # 2,3 - registration denied
          # 2,4 - unknown (out of coverage)
          # 2,5 - registered, roaming
          try:
                  log("check registration")
                  a = at('AT+CEREG?','+CEREG:')
                  if len(a) == 0:
                      break
                  a = a[0].split(",")
                  if (a[0] != "+CEREG: 2"):
                      break
                  reg = int(a[1])
                  if reg == 1:
                      log("registered - home network")
                  elif reg == 5:
                      log("registered - roaming")
                      log("not registered")
                  return reg
              log("check registration exception")
          # unknown registration
          log("error checking registration")
          return 99
      #             Detach Cellular Modem From Packet Domain Service
      def detach():
          # modem does not get SMS messages while the modem is detached
          # old messages received while detached are only received when a new message is sent while attached
          try:
              log("detach modem from packet domain service")
              a = at('AT+CGATT=0','OK')
              if len(a) == 0:
                  log("error detaching modem")
      #                       Disable LTE Modem
      def disable_modem():
          try:
              log("disable modem")
              a = at('AT+CFUN=0','OK')     # minimum functionality
              if len(a) == 0:
                  log("error disabling modem")
      #                       Enable Modem
      def enable_modem():
          try:
              log("enabling modem")
              a = at('AT+CFUN=1','OK')     # full functionality
              if len(a) == 0:
                  log("error enabling modem")
      #                Get CFUN - Modem Level of Functionality
      def get_cfun():
          # 0 - minimum functionality
          # 1 - full functionality
          # 4 - radios disabled but access to SIM allowed
          # -1 - unknown
          # note: if modem does +SHUTDOWN/+SYSSTART, CFUN will be reset to 0
          try:
                  a = at('AT+CFUN?','+CFUN:')
                  # response: ['+CFUN: 1', 'OK']
                  if len(a) == 0:
                      break
                  cfun = int(a[0][7])
                  return cfun
          return -1
      #                           Get SMS Mode
      def get_sms_mode():
          # return 0-PDU mode or unknown, 1-text mode
          try:
              log("get SMS mode")
              a = at('AT+CMGF?','+CMGF:')
              # response: ['+CMGF: 1', 'OK']
              if len(a) == 0:
                  return 0    # mode unknown
              mode = int(a[0][7])
              return mode
      #                            HTTP Post
      def http_post(uri, header, tx_data):
          # --> AT+SQNHTTPSND=<prof_id>,<command>,<resource>,<data_len>[,<post_param>[,<extra_header_line>]]
          # xx> POST <uri> HTTP/1.1
          # xx> <header>
          # xx> Content-Length: <tx_size>
          # xx> Content-Type: application/octet-stream
          # xx> <blank line>
          # --> <tx_data bytes>
          # <-- OK
          # <-- +SQNHTTPRING: <prof_id,<http_status_code>,<content_type>,<rx_size>
          # --> AT+SQNHTTPRCV=1,0\r
          # <-- /r/n<<<
          # <-- <rx_data bytes>
          # <-- OK
          try:
              log("HTTP post")
                  # note: init_modem() sets configuration "AT+SQNHTTPCFG=..." at startup
                  tx_size = len(tx_data)
                  # log("writing message: {0}".format(tx_data))
                  log("tx_data length: {0}".format(tx_size))
                  # AT+SQNHTTPSND=<prof_id>,<command>,<resource>,<data_len>[,<post_param>[,<extra_header_line>]]
                  # prof_id=1, command=0 (POST), <uri>, <tx_size>, post_parm="2" (application/octet-stream), header="Host: <host_name>"
                  a = at('AT+SQNHTTPSND=1,0,"{0}",{1},"2","{2}"'.format(uri, tx_size, header),'> ')
                  if len(a) == 0:
                      break   # error
                  uart.write(tx_data)
                  a = at_response('OK')
                  if len(a) == 0:
                      break   # error
                  # modem responds with "+SQNHTTPRING: <prof_id,<http_status_code>,<content_type>,<data_size>"
                  a = at_response("+SQNHTTPRING:")
                  if len(a) == 0:
                      break   # error
                  a = a[0].split(",")
                  http_status_code = int(a[1])
                  if http_status_code != 200:
                      break   # error
                  rx_size = int(a[3])
                  log("rx_data length: {0}".format(rx_size))
                  # get response
                  cmd = 'AT+SQNHTTPRCV=1,0\r'
                  log("  modem command: {0}".format(cmd))
                  uart.write(cmd)
                  r = wait_rx(5, 10000)   # wait for b'\r\n<<<'
                  if r == False:
                      break   # error
                  b = uart.read(5)
                  # log(" modem response: {0}".format(b))
                  if b[2:5] != b'<<<':
                      break   # error
                  t0 = ticks_ms()
                  b = b''
                  n = rx_size     # no. bytes remaining to be read
                      if uart.any() > 0:
                          log("attempt to read {0} bytes".format(n))
                          bx = uart.read(n)
                          log("bytes read: {0}".format(len(bx)))
                          # log(" modem response: {0}".format(bx))
                          b = b + bx
                          if len(b) == rx_size:
                              break   # entire message received
                          n = rx_size - len(b)
                          t0 = ticks_ms()     # reset timeout
                      t1 = ticks_ms()
                      if tx > 10000:
                          log("timeout error receiving response")
                          return b''
                      sleep_ms(400)
                  log("total bytes read: {0}".format(len(b)))
                  # log(" post response: {0}".format(b))
                  if len(a) == 0:
                      break   # error
                  # log(b)
                  return b
          # error
          return b''
      #                     Get SIM Card ICCID Number
      def iccid():
          # CFUN must be 1 or 4
          try:
              log("get SIM card ICCID")
              a = at('AT+SQNCCID?','+SQNCCID:')
              # example response: ['+SQNCCID: "89014103271203065543",""', 'OK']
              if len(a) == 0:
                  return ''
              a = a[0].split(",")
              n = len(a[0])
              r = a[0][11:n-1]
              r = ''
          log("ICCID = {0}".format(r))
          return r    # ICCID as string
      #                       Get Modem IMEI Number
      def imei():
          try:
              log("get modem IMEI number")
              a = at('AT+CGSN=1','+CGSN:')
              # example response: ['+CGSN: "354347094028575"', 'OK']
              if len(a) == 0:
                  return ''
              n = len(a[0])
              r = a[0][8:n-1]
              r = ''
          log("IMEI = {0}".format(r))
          return r    # IMEI as string
      #                       Initialize Modem
      def init_modem():
          try:
              log("initializing modem")
              if uart == None:
                  init_uart()
              disable_modem()
              # set profile #1 parameters for HTTP connection
              # prof_id=1 (profile), ip, port, auth_type=0 (None), username="", password="",
              # ssl_enabled=0, timeout, cid=1 (PDN Context Identifier)
              server = g.oIni.host_ip     # note: host_name could also be used (auto DNS lookup)
              port = g.oIni.host_port
              timeout = 10    # secs to wait for response from server
              cmd = 'AT+SQNHTTPCFG=1,"{0}",{1},0,"","",0,{2},1'.format(server, port, timeout)
              a = at(cmd,'OK')
              if len(a) == 0:
                  log("error initializing modem")
              set_sms_mode()
              enable_modem()
      #               Initialize Uart Connected To LTE Modem
      def init_uart():
          global uart
          # pins=(TXD, RXD, RTS, CTS)
          # FiPy: pins=('P20', 'P18', 'P19', 'P17')
          # GPy:  pins=('P5', 'P98', 'P7', 'P99')
          log("initializing UART")
          # rx_buffer_size: must be > 127, 200000 works, 250000 crashes, http_post seems to work with any size
          uart = UART(1, baudrate=921600, bits=8, parity=None, stop=1, timeout_chars=2, pins=('P5', 'P98', 'P7', 'P99'), rx_buffer_size=512)
      #           Is Cellular Modem Attached To Packet Domain Service
      def isattached():
          # returns: True/False
          try:
              a = at('AT+CGATT?','+CGATT:')
              # example response: ['+CGATT: 0', 'OK']
              if len(a) == 0:
                  return False
              if a[0][8] == '1':
                  return True
          return False
      #                           Reset Modem
      def reset_modem():
          try:
              if uart == None:
                  init_uart()
              log("reseting modem...")
              a = at('AT^RESET','+SHUTDOWN')
              # generates +SHUTDOWN ... +SYSSTART responses
              if len(a) == 0:
                  log("error resetting modem - no +SHUTDOWN")
              a = at_response('+SYSSTART')
              if len(a) == 0:
                  log("error resetting modem - no +SYSSTART")
      #                  Check Modem For Restart/Crash
      def restarted():
          # return True if modem has crashed / restarted
          try:
              # if CFUN != 1, modem has crashed / restarted
              cfun = get_cfun()
              if cfun != 1:
                  return True
              # if SMS text mode is reset to zero, modem has crashed / restarted
              mode = get_sms_mode()
              if mode != 1:
                  return True
              return False
          return True
      #                           Set APN
      def set_apn():
          try:
              log("set APN")
              # ICCID is only valid after registration
              r = iccid()[0:5]
              if r == "89014":
                  apn = g.oIni.apn_89014   # Kore AT&T SIM
              elif r == "89012":
                  apn = g.oIni.apn_89012   # Kore T-Mobile SIM
              elif r == "89445":
                  apn = g.oIni.apn_89445   # Hologram SIM
              g.oIni.apn = apn
              log("APN: {0}".format(apn))
              # try to reduce wear of non-volatile memory
              a = at('AT+CGDCONT?','+CGDCONT:')
              # response --> ['+CGDCONT: 1,"IP","10569.mcs",,,,0,0,0,0,0,0', ...]
              if len(a) > 0:
                  a = a[0].split(",")
                  if (a[0] == '+CGDCONT: 1') and (a[1] == '"IP"') and (a[2] == '"'+apn+'"'):
                      return
              # apn needs setting
              cmd = 'AT+CGDCONT=1,"IP","{0}"'.format(apn)
              a = at(cmd,'OK')
              if len(a) == 0:
                  log("error setting APN")
      #                       Set SMS Mode To Text
      def set_sms_mode():
          try:
              log("set SMS mode to text")
              a = at('AT+CMGF=1','OK')     # set SMS mode to text
              if len(a) == 0:
                  log("error setting SMS mode to text")
      #                       Get Signal Strength
      def signal_strength():
          # 0-31, 99-unknown
          try:
                  log("check signal strength")
                  a = at('AT+CSQ','+CSQ:')
                  # example response: ['+CSQ: 18,99', 'OK'] where 18 is signal strength
                  if len(a) == 0:
                      break
                  n = len(a[0])
                  s = a[0][6:n-1]
                  a = s.split(",")
                  cell_signal = int(a[0])
                  g.oStatus.cell_signal = cell_signal
                  log("signal strength = {0}".format(cell_signal))
                  return cell_signal
          # unknown signal strength
          g.oStatus.cell_signal = 99
          log("signal strength unknown")
          return 99
      #             Delete Read, Sent, and Unsent SMS Messages
      def sms_delete():
          try:
              log("delete all READ, SENT, and UNSENT SMS messages")
              a = at('AT+CMGD=1,3','OK')
              if len(a) == 0:
                  log("error trying to delete read, sent, and unsent SMS messages")
      #                     Delete All SMS Messages
      def sms_delete_all():
          # doesn't work until some time after attach() is called
          try:
              log("delete all SMS messages")
              a = at('AT+CMGD=1,4','OK')
              if len(a) == 0:
                  log("error trying to delete all SMS messages")
      #                     Process SMS Messages
      def sms_process(r):
          # example response:
          # ['+CMGL: 1,"REC READ","+1xxxxxxxxxx",,"19/01/07,09:16:53-20"', 'Test3', '+CMGL: 2,"REC READ","+1xxxxxxxxxx",,"19/01/07,11:12:30-20"', 'Test4', 'OK']
          try:
              for m in r:
                  if (m[0:5] == "+CMGL"):
                      continue
                  a = m.split("=")
                  cmd = a[0].upper()
      #                      Read Unread SMS Messages
      def sms_read():
          # response example: ['+CMGL: 1,"REC UNREAD","+1xxxxxxxxxx",,"19/01/07,09:16:53-20"', 'Test3', 'OK']
          log("read unread SMS messages")
          a = at('AT+CMGL="REC UNREAD"')
          return a
      #                       Read All SMS Messages
      def sms_read_all():
          # response example:
          log("read all SMS messages")
          a = at('AT+CMGL="ALL"')
          return a
      #                       Wait For N Received Chars
      def wait_rx(n, timeout=10000):
          # timeout in msecs
          t0 = ticks_ms()
              if uart.any() >= n:
                  break
              t1 = ticks_ms()
              if tx > timeout:
                  return False
              sleep_ms(10)
          return True
      Here's the code being used. The code shown is incomplete since it is application dependent. I'm somewhat disappointed in the necessary placement of the modem.apn_set() call. This may change in the future.
      # COM.PY Module
      import globals as g
      import modem
      from poll import poll
      import sys
      import uos
      import util
      import wifi
      #                         Communication Task
      def com_task():
          try:
              sleep_ms(500)
              log("com_task: started")
              wifi.deinit()
              modem.reset_modem()
              modem.init_modem()
              g.poll_host = True      # triggers poll at startup
              try:
                  if modem_ready():
                      if ready_to_poll():
                          modem.set_apn()
                          transmit()
                  sleep_ms(2000)
      #                           Modem Ready
      def modem_ready():
          try:
              log("** check for modem ready")
              # get modem signal strength
              g.oStatus.cell_signal = modem.signal_strength()
              # check modem registration
              r = modem.check_registration()
              if (r == 1) or (r == 5):
                  # registered
                  g.com_secs = 0
                  # handle SMS messages
                  r = modem.sms_read()
                  if len(r) > 1:
                      modem.sms_process(r)
                      modem.sms_delete()
                  return True
              reset = False
              if g.com_secs > (10*60):
                  # unable to attach in 10 mins, try resetting modem
                  reset = True
              if modem.restarted():
                  # modem has crashed / restarted, try resetting modem
                  reset = True
              if reset:
                  modem.reset_modem()
                  modem.init_modem()
                  g.com_secs = 0
              return False
          return False
        tlanier
        I seemed to have hit a major problem using the AT+SQNHTTPSND modem command. Although the manual does not state this, the maximum size of the data posted is apparently 1500 bytes.
        If anyone has ideas of how to increase this, please let me know. Unfortunately my app requires posting messages over 3000 bytes.
        Disappointed...
          tlanier
          I've now converted my code to use the Sequans modem socket commands in command mode (not on-line mode). I first tried to use the on-line mode, but ran into issues (no good way I could find to prevent overrunning tx buffer). This code resolves the 1500 byte limitation I ran into using the HTTP modem commands. There's still some cleanup to do to make the code more robust; however, it is working with large transmit and receive data blocks now.
          During development while I had coding errors and the program would terminate abnormally, I did put the modem in a mode that I couldn't recover from without power cycling the GPy. The modem would not response to AT commands, Trying to do lte = LTE() would generate the following error (OSError: Couldn't connect to Modem (modem_state=disconnected)). Doing machine.reset() would not correct the problem.
          Link to discussion of similar problem on Github
          Hopefully whatever I did to cause the problem will not occur in debugged code. There needs to be a true hardware reset of the modem. It seems that a GPIO pin should be tied to a physical reset line going to the modem that we could pulse if needed. I'm also of the opinion that the watchdog timer in the GPy should have been a hardware circuit not dependent on software to work.
          So far I have not seen any unexplained crashes while running the code.
          This code has been added to my modem.py module.
          #                       Socket Close
          def socket_close():
              # socket close
              # connID = 1 --> socket connection identifier
              a = at('AT+SQNSH=1', 'OK')
              if len(a) == 0:
                  log("error closing connection")
                  return
          #                       Socket Connect
          def socket_connect(ip, port, timeout_secs=10):
              # returns: True if connection successful
              log("connecting to ip - {0}, port - {1}".format(ip, port))
              # make sure socket is closed
              socket_close()
              # socket configuration
              # cid = 1 --> PDP context identifier
              # pktSz = 1500 --> packet size
              # maxTo = 10 --> exchange timeout in secs
              # connTo = 600 --> connection timeout in msecs
              # txTo = 3 --> data sending timeout in hundreds of msecs
              # a = at('AT+SQNSCFG=1,1,1500,10,600,3', 'OK')
              a = at('AT+SQNSCFG=1,1,1500,{0},600,3'.format(timeout_secs), 'OK')
              if len(a) == 0:
                  log("error connecting")
                  return False
              # socket extended configuration
              # srMode = 1 --> SQNSRING URC data amount mode
              # recvDataMode = 1 --> data in hex
              # keepalive = 0 --> unused
              # listenAutoRsp = 0 --> deactivated
              # sendDataMode = 1 --> data in hex
              a = at('AT+SQNSCFGEXT=1,1,1,0,0,1', 'OK')
              if len(a) == 0:
                  return False
              # socket dial
              # txProt = 0 --> TCP protocol
              # rPort = <port> --> remote host port to contact
              # IPaddr = <ip> --> address of remote host
              # closureType = 0 --> local host closes immediately when remote host has closed
              # lPort = 0 --> UDP port (not used)
              # connMode = 1 --> command mode connection
              # acceptAnyRemote = 0 --> disabled
              a = at('AT+SQNSD=1,0,{0},"{1}",0,0,1,0'.format(port,ip), 'OK')
              if len(a) == 0:
                  return False
              log("** connection successful **")
              return True
          #                       Socket Info
          def socket_info():
              # modem response: ['+SQNSI: 1,0,0,0,0', 'OK']
              # connId: 1
              # sent: total bytes sent
              # received: total bytes received
              # buff_in: total bytes not yet read (buffered)
              # ack_waiting: total bytes sent but not yet acknowledged
              a = at('AT+SQNSI=1')
          #                       Socket Receive Data
          def socket_rx():
              # receives up to 1500 bytes maximum
              log("check for rx data")
              a = at('AT+SQNSRECV=1,1500')
              # no data ready --> modem response: ['+CME ERROR: operation not supported']
              # data ready --> modem response: ['+SQNSRECV: 1,3', '010203', 'OK']
              b = b''
              for i in range(len(a)):
                  if a[i].startswith('+SQNSRECV:'):
                      # next line is the data
                      b = unhexlify(a[i+1])
              log("rx {0} bytes".format(len(b)))
              return b
          #                       Socket Status
          def socket_status():
              # modem response: ['+SQNSS: 1,0', '+SQNSS: 2,0', '+SQNSS: 3,0', '+SQNSS: 4,0', '+SQNSS: 5,0', '+SQNSS: 6,0', 'OK']
              # connID
              # state:
              #   0-socket closed
              #   1-socket with active data transfer connection
              #   2-socket suspended
              #   3-socket suspended with pending data
              #   4-socket listening
              #   5-socket with incoming connection
              #   6-socket in opening process
              a = at('AT+SQNSS?')
              return a
          #                       Socket Transmit Data
          def socket_tx(tx, n=0):
              # transmits up to 1500 bytes maximum
              # returns: True if successful
              if n == 0:
                  n = len(tx)
              log("tx {0} bytes".format(n))
              a = at('AT+SQNSSENDEXT=1,{0}'.format(n), '> ')
              hex = hexlify(tx)
              uart.write(hex)
              if len(a) == 0:
                  log("error transmitting data")
                  return False
              return True
          This code is in my http.py module.
          import modem
          import sys
          import ubinascii
          import uos
          import ustruct
          import util
          BUFFER_SIZE = const(1500)
          CR = const(0x0d)
          LF = const(0x0a)
          MAX_HEADER_SIZE = const(128)
          MAX_TX_SIZE = const(1500)
          HTTP_TIMEOUT_MSECS = const(15000)
          # HTTP_TIMEOUT_MSECS = const(300000)  # TESTING
          http_error = False      # HTTP communication error: True/False
          http_size = 0           # HTTP POST message size
          rx_cnt = 0              # no. bytes in rx_data buffer
          rx_data = b''           # rx data buffer
          rx_pt = 0               # pointer into rx data buffer
          tx_cnt = 0              # no. bytes in tx_data buffer
          tx_data = bytearray(MAX_TX_SIZE)    # tx data buffer
          tx_flag = False         # controls tx_byte
          #                       Close HTTP Socket
          def close_http():
              modem.socket_close()
          #                       Open HTTP Socket
          def open_http(host_ip, host_port):
              global http_error, rx_cnt, rx_data, rx_pt, tx_cnt
              http_error = False
              rx_cnt = 0
              rx_data = b''
              rx_pt = 0
              tx_cnt = 0
              r = modem.socket_connect(host_ip, host_port)
              if r == False:
                  log("TCP socket connect error")
                  http_error = True
          #                    Receive BLOCK From Response
          def rx_block(cnt):
              b = bytearray(cnt)
              i = 0
              while i < cnt:
                  b[i] = rx_byte()
                  i = i + 1
              return b
          #                    Receive BYTE From Response
          def rx_byte():
              global http_error, http_size, rx_cnt, rx_data, rx_pt
              t0 = ticks_ms()
              while rx_cnt == 0:
                  rx_data = modem.socket_rx()
                  rx_cnt = len(rx_data)
                  rx_pt = 0
                  if rx_cnt > 0:
                      break
                  t1 = ticks_ms()
                  if (tx > HTTP_TIMEOUT_MSECS):
                      http_error = True
                      return 0
                  sleep_ms(200)
              b = rx_data[rx_pt]
              rx_cnt = rx_cnt - 1
              rx_pt = rx_pt + 1
              http_size = http_size - 1
              # print("rx byte: {0}".format(hex(b)))
              return b
          #                    Receive DWORD From Response
          def rx_dword():
              dw1 = rx_byte()
              dw2 = rx_byte()
              dw3 = rx_byte()
              dw4 = rx_byte()
              return (dw1 + (dw2<<8) + (dw3<<16) + (dw4<<24))
          #                    Receive One HTTP Header
          def rx_http_header():
              # returns header string
              global http_error
              n = 0
              header = bytearray(MAX_HEADER_SIZE)
              s = ""
                  b = rx_byte()
                  # print("byte = {0}".format(b))
                  if http_error:
                      return ""
                  if b == CR:
                      continue
                  if b == LF:
                      break
                  header[n] = b
                  n = n + 1
                  if n >= MAX_HEADER_SIZE-1:
                      http_error = True
                      return ""
              if n > 0:
                  # print("n = {0}, header = {1}".format(n,header))
                  s = header[0:n].decode('utf-8')
              return s
          #                    Receive HTTP Headers
          # HTTP/1.1 200 OK
          # <headers>
          # Content-Length: nnn
          # <headers>
          # <crlf>
          # Updates: http_size, http_error
          def rx_http_headers():
              headers = []      # array of header lines
              http_size = 0
                  s = rx_http_header()
                  log("length = {0}, header = {1}".format(len(s), s))
                  if http_error:
                      return headers
                  if s == "":
                      break
                  headers.append(s)
              if len(headers) < 2:
                  http_error = True
                  return headers
              a = headers[0].split(' ')
              if (a[1] != "200") or (a[2]) != "OK":
                  http_error = True
                  return headers
              for s in headers:
                  if s.startswith("Content-Length:"):
                      a = s.split(' ')
                      http_size = int(a[1])
              return headers
          #                    Receive String From Response
          def rx_string(max_len):
              rx = bytearray(max_len)
              i = 0
              while i < max_len:
                  b = rx_byte()
                  if b == 0:
                      break
                  rx[i] = b
                  i = i + 1
              if i == 0:
                  return ""
              s = rx[0:i].decode('utf-8')
              return s
          #                    Receive WORD From Response
          def rx_word():
              dw1 = rx_byte()
              dw2 = rx_byte()
              return (dw1 + (dw2<<8))
          #                       Transmit Block
          def tx_block(b):
              for x in b:
                  tx_byte(x)
          #                       Transmit Byte
          def tx_byte(b):
              global http_size, tx_cnt, tx_data, tx_flag
              if tx_flag == False:
                  http_size = http_size + 1
                  # print("tx byte: {0}, http size: {1}".format(hex(b), http_size))
                  return
              # print("tx byte: {0}".format(hex(b)))
              tx_data[tx_cnt] = b
              tx_cnt = tx_cnt + 1
              if tx_cnt >= MAX_TX_SIZE:
                  tx_flush()
          #                       Transmit DWORD
          def tx_dword(dw):
              tx_word(dw & 0xffff)
              tx_word((dw >> 16) & 0xffff)
          #                       Transmit Flush
          def tx_flush():
              global tx_cnt, tx_data
              if tx_cnt == 0:
                  return
              r = modem.socket_tx(tx_data, tx_cnt)
              if not r:
                  http_error = True
                  return
              tx_cnt = 0
          #                       Transmit HTTP Headers
          def tx_http_headers(http_post, host_name, host_port):
              # example:
              # POST <http_post> HTTP/1.1
              # Host: <host_name>:<host_port>
              # Content-Length: <http_size>
              # Content-Type: application/octet-stream
              # <crlf>
              log("tx HTTP headers")
              if http_error:
                  return
              s = "POST {0} HTTP/1.1\r\n".format(http_post)
              tx_string(s)
              if host_port != 80:
                  s = "Host: {0}:{1}\r\n".format(host_name, host_port)
                  s = "Host: {0}\r\n".format(host_name)
              tx_string(s)
              s = "Content-Length: {0}\r\n".format(http_size)
              tx_string(s)
              s = "Content-Type: application/octet-stream\r\n"
              tx_string(s)
              s = "\r\n"
              tx_string(s)
          #                       Transmit String
          def tx_string(s):
              b = s.encode('utf-8')
              for x in b:
                  tx_byte(x)
          #                       Transmit WORD
          def tx_word(w):
              tx_byte(w & 0xff)
              tx_byte((w >> 8) & 0xff)
            tlanier
            We now have our program running completely independent of the LTE module. 26 units have been running for multiple days with no crashes. I now think we have found a reliable solution. The Sequans modem AT socket commands are used to do the HTTP posts. We reliably receive 90K files and transmit 1-5K of data with no issues. Pycom MicroPython V1.20.0.rc13 is the OS version we are using.
            Currently we are using whatever version of the modem firmware (41065, 43818, and 47510 have been seen) that comes with the GPy. The version of the OS we are using has the ability to "downgrade" the modem firmware to 41065 if we decide it is needed. Some newer versions of the OS do not have this ability.
            One note of importance is we did discover that in our case the default stack size was marginal when receiving large files. Yes, I did go back and check the old program and verified that the stack issue was not the cause of the original crash problems.
            #                          Initialize Tasks
            def init_tasks():
                n = 8192    # 4096 is marginal
                _thread.stack_size(n)
                log("initializing tasks with stack size: {}".format(n))
                _thread.start_new_thread(com.com_task, ())
                _thread.start_new_thread(cycle.cycle_task, ())
              ruok4t @tlanier
              @tlanier I really like the sound of what your doing here. I've been struggling with Pycom LTE module for months now. Really don't like the way it blocks other threads and randomly locks up for no apparent reason. Are you possibly in a position to share a complete "Hello LTE World" example. I'm sure I wouldn't be the only one around here who would be very interested. Hopefully someone from Pycom might also take an interest and finally admit they need to revise their code.
                tlanier @ruok4t
                @ruok4t Sorry I didn't see your request earlier.
                The software below is now working in production units. We ran about 20 units testing in house for two weeks with no crashes before beginning deployment with the new version. We are using MicroPython V1.20.0.rc13 with multiple versions of the modem firmware. It's a shame we had to resort to this, but it seems to work reliably.
                I've had to break the post up into 3 parts because of limitations of this forum.
                Part 1 of 3
                Here's the modem.py module:
                import globals as g
                import gpio
                import micropython
                import sys
                import util
                from ubinascii import hexlify, unhexlify
                from util import log, mem_info
                uart = None
                    try:
                        # util.mem_info("modem.at")
                        if uart.any() > 0:
                            a = at_response()
                            for s in a:
                                at_process(s)
                        if gpio.G():
                            if gpio.G():
                            return []
                        return a
                        a = []
                    # filter response
                    if filterx == "":
                        return
                    n = len(filterx)
                    i = len(a)
                    while i > 0:
                        i = i - 1
                        if not a[i].startswith(filterx):
                            at_process(a[i])
                            a.pop(i)
                def at_process(s):
                    if s == 'OK':
                        return
                    if s.startswith("ERROR"):
                        return
                    if s.startswith("+CME ERROR:"):
                        return
                    # process unsolicited response here
                    if gpio.G():
                        log("  unsolicited modem response: {}".format(s))
                    try:
                        t0 = ticks_ms()
                            if uart.any() > 0:
                                sleep_ms(50)
                                break
                            t1 = ticks_ms()
                            if tx > 10000:
                                return []
                            sleep_ms(100)
                        b = uart.read()
                        s = str(b, 'utf-8')
                        a = s.split('\r\n')
                        if gpio.G():
                        a = []
                    try:
                            if len(a) == 0:
                                break
                            a = a[0].split(",")
                                break
                            reg = int(a[1])
                            if reg == 1:
                                log("*** registered - home network ***")
                            elif reg == 5:
                                log("*** registered - roaming ***")
                                log("*** NOT registered ***")
                            return reg
                    return 99
                #                       Check SIM Status
                def check_sim_status():
                    try:
                        log("checking SIM card status")
                        a = at('AT+CPIN?', '+CPIN: READY')
                        if len(a) > 0:
                            return True
                    log("error SIM card not ready")
                    return False
                #                       Disable LTE Modem
                    try:
                        if len(a) == 0:
                #                       Enable Modem
                def enable_modem():
                    try:
                        if len(a) == 0:
                def get_cfun():
                    # -1 - unknown
                    try:
                            if len(a) == 0:
                                break
                            cfun = int(a[0][7])
                            return cfun
                    return -1
                #                           Get SMS Mode
                def get_sms_mode():
                    try:
                        log("get SMS mode")
                        if len(a) == 0:
                        mode = int(a[0][7])
                        return mode
                def iccid():
                    # SIM status must be ready
                    try:
                        a = at('AT+SQNCCID?', '+SQNCCID:')
                        if len(a) == 0:
                            return ''
                        a = a[0].split(",")
                        n = len(a[0])
                        r = a[0][11:n-1]
                        r = ''
                def imei():
                    try:
                        if len(a) == 0:
                            return ''
                        n = len(a[0])
                        r = a[0][8:n-1]
                        r = ''
                #                   Modem Firmware Info
                def info():
                    log("get modem firmware version")
                    a = at('ATI1')
                    return a
                #                       Initialize Modem
                def init_modem():
                    try:
                        if uart == None:
                            init_uart()
                        info()
                        set_sms_mode()
                        # enable +CME ERROR: <err> result code and use verbose <err> values
                        at('AT+CMEE=2')
                        enable_modem()
                        log("wait for SIM card ready")
                        n = 0
                            if len(a) > 0:
                                break
                            n = n + 1
                            if n > 20:
                                util.reset(13, "No SIM card")
                            sleep_ms(200)
                        set_apn()
                def init_uart():
                    global uart
                def isattached():
                    try:
                        if len(a) == 0:
                            return False
                        if a[0][8] == '1':
                            return True
                    return False
                #                           Reset Modem
                def reset_modem():
                    try:
                        if uart == None:
                            init_uart()
                        a = at('AT^RESET', '+SHUTDOWN')
                        if len(a) == 0:
                        if len(a) == 0:
                def restarted():
                    try:
                        cfun = get_cfun()
                        if cfun != 1:
                            return True
                        if mode != 1:
                            return True
                        return False
                    return True
                #                           Set APN
                def set_apn():
                    try:
                        log("set APN")
                        # ICCID is only valid if SIM status is ready
                        r = iccid()[0:5]
                        if r == "89014":
                        elif r == "89012":
                        elif r == "89445":
                        g.oIni.apn = apn
                        a = at('AT+CGDCONT?', '+CGDCONT:')
                        if len(a) > 0:
                            a = a[0].split(",")
                                return
                        # apn needs setting
                        a = at(cmd, 'OK')
                        if len(a) == 0:
                def set_sms_mode():
                    try:
                        a = at('AT+CMGF=1', 'OK')     # set SMS mode to text
                        if len(a) == 0:
                    # 0-31, 99-unknown
                    try:
                            a = at('AT+CSQ', '+CSQ:')
                            if len(a) == 0:
                                break
                            n = len(a[0])
                            s = a[0][6:n-1]
                            a = s.split(",")
                            return cell_signal
                    return 99
                def sms_delete():
                    try:
                        a = at('AT+CMGD=1,3', 'OK')
                        if len(a) == 0:
                    try:
                        a = at('AT+CMGD=1,4', 'OK')
                        if len(a) == 0:
                def sms_process(r):
                    # example response:
                    try:
                        for m in r:
                                continue
                            a = m.split("=")
                            cmd = a[0].upper()
                			# process message here
                def sms_read():
                    return a
                def sms_read_all():
                    # response example:
                    return a
                #                       Socket Close
                def socket_close():
                    # socket close
                    log("closing socket")
                    if len(a) == 0:
                #                       Socket Connect
                    socket_close()
                    if len(a) == 0:
                        return False
                    if len(a) == 0:
                        return False
                    # socket dial
                    if len(a) == 0:
                        return False
                    return True
                #                       Socket Info
                def socket_info():
                    # connId: 1
                    log("socket info")
                def socket_rx():
                    b = b''
                    return b
                #                       Socket Status
                    # connID
                    # state:
                    #   0-socket closed
                    log("socket status")
                    a = at('AT+SQNSS?')
                    return a
                    if n == 0:
                        n = len(tx)
                    b = hexlify(tx)
                    uart.write(b)
                    if len(a) == 0:
                        return False
                    return True
                T R 2 Replies Last reply Reply Quote 0
                  tlanier @tlanier
                  @tlanier
                  Part 2 of 3
                  Here's our com.py module. It is more application dependent but it may give you some ideas of how to use the modem module.
                  import globals as g
                  import modem
                  import sys
                  import uos
                  import util
                  import wifi
                  _reset = True    # modem reset
                  def com_task():
                      global _reset
                      try:
                          sleep_ms(500)
                          # this opens the door for continuous resets to cause high data usage
                          util.set_ppp_errors(0)
                          wifi.deinit()
                          try:
                              _reset = False
                              g.modem_state = g.MS_RESET_MODEM
                              modem.reset_modem()
                              g.modem_state = g.MS_INIT_MODEM
                              modem.init_modem()
                              while _reset == False:
                                  # util.mem_info("com_task")
                                  if modem_ready():
                                      g.modem_state = g.MS_REGISTERED
                                      if ready_to_poll():
                                          transmit()
                                      g.modem_state = g.MS_REGISTERING
                                  sleep_ms(2000)
                  #                           Modem Ready
                  def modem_ready():
                      global _reset
                      try:
                              # registered
                              g.com_secs = 0
                              if len(r) > 1:
                                  modem.sms_delete()
                              return True
                              _reset = True
                              _reset = True
                          return False
                      return False
                  #                           Ready To Poll
                  def ready_to_poll():
                      # return: True/False
                      try:
                          log("--- time since last poll: {0} secs ---".format(g.oNvram.last_poll_secs))
                          if (g.ppp_error_secs > 0):
                              log("*** poll throttling: {0} secs ***".format(g.ppp_error_secs))
                              return False
                          if (g.oIni.intra_poll_secs > 0):
                              # contact server every <oIni.intra_poll_secs> seconds
                              if (g.oNvram.last_poll_secs > g.oIni.intra_poll_secs):
                                  return True
                          if (g.oSetup.intra_cycle_count > 0):
                              # contact server every <oSetup.intra_cycle_count> cycles
                              if (g.oNvram.cycle_count >= g.oSetup.intra_cycle_count):
                                  return True
                          # g.poll_host is set at startup and by SMS POLL_HOST message
                          if (g.poll_host == True):
                              return True
                      return False
                  #                         Transmit
                  def transmit():
                      try:
                          util.lcd("Transmitting", "")
                          g.modem_state = g.MS_CONNECTING
                          r = poll()
                          g.modem_state = g.MS_DISCONNECT
                          if (r == False):
                              util.lcd("Transmit failed", "")
                              sleep_ms(2500)
                              util.lcd("","")
                              return
                          util.lcd("Successful", "")
                          sleep_ms(2500)
                          util.lcd("","")
                          g.poll_host = False
                          g.oNvram.last_poll_secs = 0
                          g.poll_secs = 0
                          if (g.update_flag == True):
                              # done after disconnect
                              try:
                                  if util.file_exists("REMOTE.TAR"):
                                      log("remove old REMOTE.TAR")
                                      util.remove("REMOTE.TAR")
                                  log("rename TEMP to REMOTE.TAR")
                                  uos.rename("TEMP", "REMOTE.TAR")
                                  # create file to signal boot.py that update is available
                                  log("create UPDATE signal file")
                                  with open("UPDATE", "w") as f:
                                      f.write("UPDATE")
                                  log("** New REMOTE.TAR ready to update")
                          if (g.reboot_after_poll == True):
                              log("SMS message changed INI setting, rebooting")
                              util.reset(6, "INI changed")
                          if (g.oHost.erase == True):
                              log("Erase command received, rebooting")
                              g.oNvram.erase()
                              util.reset(7, "Erase NVRAM")
                          if (g.oHost.reset == True):
                              log("Reset command received, rebooting")
                              util.reset(8, "Reset command")
                    tlanier @tlanier
                    @tlanier
                    Part 3 of 3
                    Here's the http.py module:
                    Note that the modem socket commands have a 1500 byte limitation. The HTTP module overcomes that by breaking longer messages up into smaller blocks.
                    import modem
                    import sys
                    import ubinascii
                    import uos
                    import ustruct
                    import util
                    # note: HTTP errors raise exceptions
                    CR = const(0x0d)
                    LF = const(0x0a)
                    #                       Close HTTP Socket
                    def close_http():
                    #                       Open HTTP Socket
                        global rx_cnt, rx_data, rx_pt, tx_cnt
                        rx_cnt = 0
                        rx_data = b''
                        rx_pt = 0
                        tx_cnt = 0
                        if r == False:
                            raise Exception("TCP socket connect error")
                    def rx_block(cnt):
                        b = bytearray(cnt)
                        i = 0
                        while i < cnt:
                            b[i] = rx_byte()
                            i = i + 1
                        log("rx_block: {} bytes".format(len(b)))
                        return b
                    def rx_byte():
                        global http_size, rx_cnt, rx_data, rx_pt
                        t0 = ticks_ms()
                        while rx_cnt == 0:
                            rx_pt = 0
                            if rx_cnt > 0:
                                break
                            t1 = ticks_ms()
                                raise Exception("HTTP timeout in rx_byte")
                            sleep_ms(200)
                        b = rx_data[rx_pt]
                        rx_cnt = rx_cnt - 1
                        rx_pt = rx_pt + 1
                        return b
                    def rx_dword():
                        dw1 = rx_byte()
                        dw2 = rx_byte()
                        dw3 = rx_byte()
                        dw4 = rx_byte()
                        n = 0
                        s = ""
                            b = rx_byte()
                            if b == CR:
                                continue
                            if b == LF:
                                break
                            header[n] = b
                            n = n + 1
                                raise Exception("Maximum header size error in rx_http_header")
                        if n > 0:
                            # older versions of MicroPython do not implement decode on bytearrays
                            a = bytes(header[0:n])
                            s = a.decode('utf-8')
                            log("header = {}".format(s))
                        return s
                    # HTTP/1.1 200 OK
                    # <headers>
                    # <headers>
                    # <crlf>
                        global http_size
                        http_size = 0
                            # log("length = {0}, header = {1}".format(len(s), s))
                            if s == "":
                                break
                            headers.append(s)
                            raise Exception("Not enough headers received in rx_http_headers")
                            raise Exception("Invalid first header line: {0}".format(headers[0]))
                        for s in headers:
                                a = s.split(' ')
                        return headers
                        i = 0
                        while i < max_len:
                            b = rx_byte()
                            if b == 0:
                                break
                            rx[i] = b
                            i = i + 1
                        if i == 0:
                            return ""
                        a = bytes(rx[0:i])
                        return s
                    def rx_word():
                        dw1 = rx_byte()
                        dw2 = rx_byte()
                    #                       Transmit Block
                    def tx_block(b):
                        for x in b:
                            tx_byte(x)
                    #                       Transmit Byte
                    def tx_byte(b):
                            return
                        tx_data[tx_cnt] = b
                        tx_cnt = tx_cnt + 1
                            tx_flush()
                    #                       Transmit DWORD
                    def tx_dword(dw):
                    #                       Transmit Flush
                    def tx_flush():
                        if tx_cnt == 0:
                            return
                        if not r:
                            raise Exception("Error transmitting in tx_flush")
                        tx_cnt = 0
                        # example:
                        # <crlf>
                        global http_size
                        tx_string(s)
                        if host_port != 80:
                        tx_string(s)
                        tx_string(s)
                        tx_string(s)
                        s = "\r\n"
                        tx_string(s)
                    #                       Transmit String
                    def tx_string(s):
                        for x in b:
                            tx_byte(x)
                    #                       Transmit WORD
                    def tx_word(w):
                        tx_byte(w & 0xff)
                      ruok4t @tlanier
                      @tlanier Thanks, will download all parts and take a look.
                        SciWax
                        @tlanier
                        Thank you for compiling all this information for the community. I really appreciate it. It could become handy for my project.
                          Scott Basgaard @tlanier
                          @tlanier did you ever put this in a repo?
                            tlanier @Scott Basgaard
                            @Scott-Basgaard Sorry, I have not.
                              Petteri Salo
                              @tlanier Hey, I started looking into the three files you posted (http.py, com.py, modem.py) and it is looking very usefull! However, both com.py and modem.py have a line:
                              "import globals as g"
                              and I'm guessing it is a file you have, but I get an "ImportError: no module named 'globals'"
                              Perhaps you could upload that file too? After a quick look throuh all "g.*" I could probably deduce most of it, but things like :
                              would probably be usefull and save us some time.
                              Anyway, Thanks for helping the community at large with your efforts!!
                              Petteri
                              S T 2 Replies Last reply Reply Quote 1
                                Scott Basgaard @Petteri Salo
                                @Petteri-Salo agree! Would be great @tlanier if you could share anything else here. Really struggling to get LTE working stable and any further insight for us others would be greatly appreciated. Digging into this more now and will let you know how far I get as well. Thanks for sharing!
                                  tlanier @Petteri Salo
                                  @Petteri-Salo The g.modem_state global variable is used in a timer interrupt routine to control the blinking and color of the LED on the GPY. This gives the user a visual indication of what state the modem is in. This variable is not critical to using the supplied code.
                                  Unfortunately the code I have published is just snippets of my production code. It was not designed to be a general purpose library (although I believe it comes close). Without publishing the entire application, there will be pieces that are missing.
                                  Your message has motivated me to add a few random notes.
                                  • We had production, shipping GPy based systems that were experiencing reliability issues. Upgrades to newer versions of the OS seemed to make the problems worse. There was considerable evidence that the problems were caused by the LTE module. For months I waited hoping that Pycom would make the existing product more robust. Instead they seemed to be going in all directions introducing new products but not improving the fundamental building blocks of the GPy. I was especially concerned when we purchased a new batch of chips and they came by default with a version of the OS which would not run our application for more than a few minutes without crashing. In addition Pycom seemed to be moving in a direction requiring our code in the future to be dependent on a cloud based system (Pybytes). This seemed to be making everything even more complex. We couldn't even get the simple things to work reliably.
                                  • In principle our application was not complex. We just needed to transmit a few packets of data to a web site periodically over the LTE network reliably without crashing the system. It was also desired that the communication would not interfere with the real time task of sampling data.
                                  • After looking at the C/C++ source code to the LTE module, it seemed way too complex. I had no good way to make changes, improvements, or bug fixes (assuming I could find the problem). If we moved the modem code to Python, we could bypass the usage of the LTE module and use the TCP/IP stack included in the Sequans modem. Maybe by pushing the communication load to the Sequans modem, the MicroPython would be more reliable and responsive to real time tasks. Maybe by publishing the code more people could observe and help to improve the code. We desperately needed a reliable method of communication.
                                  • Since converting our code to controlling the cell modem directly in Python code, I can now say the random crashes have been solved. The real time task is more responsive.
                                  • I hope that someday the LTE module will be improved so that it can be used again. Having a TCP/IP stack that is usable by both WIFI and LTE is certainly an advantage. Can it be made reliable? Can the ESP32 chip smoothly multitask while using LTE methods?
                                  • I wish I knew of a method to marry our higher level Python calls for modem management with the TCP/IP stack of MicroPython. I think such a technique could make the LTE module code simpler.
                                  • I think the dream of most application developers is to have simple reliable software methods to connect/disconnect to the network. The fact that we are connected using the cell network, WIFI, or whatever should be mostly transparent.
                                  • We all want Pycom to be successful. They have developed a good product. We did what we did because their priorities were not ours at the time.
                                  • 2 / 3
