Method To Take Control of Cell Modem
  • Is there a way to directly take control of the cell modem and talk to it directly with a raw serial interrupt driver (machine.UART)? In other words I do not want to use the LTE module other than possibly initializing the cell modem. I want to write all the modem interaction including the LTE.send_at_cmd() in 100% MicroPython using AT commands. I'll handle all the modem responses, timeouts, error checking, etc. No calls to the LTE module desired.
    Why would I want to do such a thing (call me crazy)?
    I want to try using the built-in Sequans "Specific HTTP Commands".
    Maybe this would improve the integrity of the GPy.
    I currently have a program working in production using Pycom MicroPython V1.20.0.rc13 on many units. When I try to run the same program on a newly purchased GPy running Pycom MicroPython 1.20.2.r3, the program crashes (20 sec watchdog timeout) when I do an AT command ('AT+CEREG?') after disconnecting from a successful transmission. How do I troubleshoot such a crash?
    Modem commands have always interfered with multi-threading and interrupt servicing. Maybe using just the MicroPython serial interrupt drivers would allow more smooth multi-threading and interrupt servicing. I could also have complete control over modem interaction, timeouts, retries, etc. without affecting the other tasks running on the system. Sending commands to a cell modem should not interfere with the servicing of an interrupt or the switching of threads in MicroPython.
    Looking at the C code for the LTE module shows a significant amount of complexity. Let's open up the cell communication software in Python so everyone can see and make improvements and changes. Let's create high level commands in Python that make cell communication reliable and transparent to the rest of the system.
    I've built embedded cell modem based systems using just AT commands that worked great. It shouldn't be that complicated.
    Another possibility is to run the ESP32 MicroPython on the GPy and bypass Pycom's implementation. Has anyone tried this before?
  • @Petteri-Salo The g.modem_state global variable is used in a timer interrupt routine to control the blinking and color of the LED on the GPY. This gives the user a visual indication of what state the modem is in. This variable is not critical to using the supplied code.
    Unfortunately the code I have published is just snippets of my production code. It was not designed to be a general purpose library (although I believe it comes close). Without publishing the entire application, there will be pieces that are missing.
    Your message has motivated me to add a few random notes.
    • We had production, shipping GPy based systems that were experiencing reliability issues. Upgrades to newer versions of the OS seemed to make the problems worse. There was considerable evidence that the problems were caused by the LTE module. For months I waited hoping that Pycom would make the existing product more robust. Instead they seemed to be going in all directions introducing new products but not improving the fundamental building blocks of the GPy. I was especially concerned when we purchased a new batch of chips and they came by default with a version of the OS which would not run our application for more than a few minutes without crashing. In addition Pycom seemed to be moving in a direction requiring our code in the future to be dependent on a cloud based system (Pybytes). This seemed to be making everything even more complex. We couldn't even get the simple things to work reliably.
    • In principle our application was not complex. We just needed to transmit a few packets of data to a web site periodically over the LTE network reliably without crashing the system. It was also desired that the communication would not interfere with the real time task of sampling data.
    • After looking at the C/C++ source code to the LTE module, it seemed way too complex. I had no good way to make changes, improvements, or bug fixes (assuming I could find the problem). If we moved the modem code to Python, we could bypass the usage of the LTE module and use the TCP/IP stack included in the Sequans modem. Maybe by pushing the communication load to the Sequans modem, the MicroPython would be more reliable and responsive to real time tasks. Maybe by publishing the code more people could observe and help to improve the code. We desperately needed a reliable method of communication.
    • Since converting our code to controlling the cell modem directly in Python code, I can now say the random crashes have been solved. The real time task is more responsive.
    • I hope that someday the LTE module will be improved so that it can be used again. Having a TCP/IP stack that is usable by both WIFI and LTE is certainly an advantage. Can it be made reliable? Can the ESP32 chip smoothly multitask while using LTE methods?
    • I wish I knew of a method to marry our higher level Python calls for modem management with the TCP/IP stack of MicroPython. I think such a technique could make the LTE module code simpler.
    • I think the dream of most application developers is to have simple reliable software methods to connect/disconnect to the network. The fact that we are connected using the cell network, WIFI, or whatever should be mostly transparent.
    • We all want Pycom to be successful. They have developed a good product. We did what we did because their priorities were not ours at the time.
  • @Petteri-Salo agree! Would be great @tlanier if you could share anything else here. Really struggling to get LTE working stable and any further insight for us others would be greatly appreciated. Digging into this more now and will let you know how far I get as well. Thanks for sharing!
  • @tlanier Hey, I started looking into the three files you posted (http.py, com.py, modem.py) and it is looking very usefull! However, both com.py and modem.py have a line:
    "import globals as g"
    and I'm guessing it is a file you have, but I get an "ImportError: no module named 'globals'"
    Perhaps you could upload that file too? After a quick look throuh all "g.*" I could probably deduce most of it, but things like :
    g.modem_state = g.MS_RESET_MODEM
    would probably be usefull and save us some time.
    Anyway, Thanks for helping the community at large with your efforts!!
    Petteri
  • @Scott-Basgaard Sorry, I have not.
  • @tlanier did you ever put this in a repo?
  • @tlanier
    Thank you for compiling all this information for the community. I really appreciate it. It could become handy for my project.
  • @tlanier Thanks, will download all parts and take a look.
  • @tlanier
    Part 3 of 3
    Here's the http.py module:
    Note that the modem socket commands have a 1500 byte limitation. The HTTP module overcomes that by breaking longer messages up into smaller blocks.
    import modem
    import sys
    import ubinascii
    import uos
    import ustruct
    import util
    from util import log
    from utime import sleep_ms, ticks_ms, ticks_diff
    # note: HTTP errors raise exceptions
    BUFFER_SIZE = const(1500)
    CR = const(0x0d)
    LF = const(0x0a)
    MAX_HEADER_SIZE = const(128)
    MAX_TX_SIZE = const(1500)
    HTTP_TIMEOUT_MSECS = const(15000)
    # HTTP_TIMEOUT_MSECS = const(300000)  # TESTING
    http_size = 0           # HTTP POST message size
    rx_cnt = 0              # no. bytes in rx_data buffer
    rx_data = b''           # rx data buffer
    rx_pt = 0               # pointer into rx data buffer
    tx_cnt = 0              # no. bytes in tx_data buffer
    tx_data = bytearray(MAX_TX_SIZE)    # tx data buffer
    tx_flag = False         # controls tx_byte
    #                       Close HTTP Socket
    def close_http():
        modem.socket_close()
    #                       Open HTTP Socket
    def open_http(host_ip, host_port):
        global rx_cnt, rx_data, rx_pt, tx_cnt
        rx_cnt = 0
        rx_data = b''
        rx_pt = 0
        tx_cnt = 0
        r = modem.socket_connect(host_ip, host_port)
        if r == False:
            raise Exception("TCP socket connect error")
    #                    Receive BLOCK From Response
    def rx_block(cnt):
        b = bytearray(cnt)
        i = 0
        while i < cnt:
            b[i] = rx_byte()
            i = i + 1
        log("rx_block: {} bytes".format(len(b)))
        return b
    #                    Receive BYTE From Response
    def rx_byte():
        global http_size, rx_cnt, rx_data, rx_pt
        t0 = ticks_ms()
        while rx_cnt == 0:
            rx_data = modem.socket_rx()
            rx_cnt = len(rx_data)
            rx_pt = 0
            if rx_cnt > 0:
                break
            t1 = ticks_ms()
            tx = ticks_diff(t1, t0)
            if (tx > HTTP_TIMEOUT_MSECS):
                raise Exception("HTTP timeout in rx_byte")
            sleep_ms(200)
        b = rx_data[rx_pt]
        rx_cnt = rx_cnt - 1
        rx_pt = rx_pt + 1
        http_size = http_size - 1
        # print("rx byte: {0}".format(hex(b)))
        return b
    #                    Receive DWORD From Response
    def rx_dword():
        dw1 = rx_byte()
        dw2 = rx_byte()
        dw3 = rx_byte()
        dw4 = rx_byte()
        return (dw1 + (dw2<<8) + (dw3<<16) + (dw4<<24))
    #                    Receive One HTTP Header
    def rx_http_header():
        # returns header string
        n = 0
        header = bytearray(MAX_HEADER_SIZE)
        s = ""
            b = rx_byte()
            # print("byte = {0}".format(b))
            if b == CR:
                continue
            if b == LF:
                break
            header[n] = b
            n = n + 1
            if n >= MAX_HEADER_SIZE-1:
                raise Exception("Maximum header size error in rx_http_header")
        if n > 0:
            # older versions of MicroPython do not implement decode on bytearrays
            a = bytes(header[0:n])
            s = a.decode('utf-8')
            log("header = {}".format(s))
        return s
    #                    Receive HTTP Headers
    # HTTP/1.1 200 OK
    # <headers>
    # Content-Length: nnn
    # <headers>
    # <crlf>
    # Updates: http_size
    def rx_http_headers():
        global http_size
        headers = []      # array of header lines
        http_size = 0
            s = rx_http_header()
            # log("length = {0}, header = {1}".format(len(s), s))
            if s == "":
                break
            headers.append(s)
        if len(headers) < 2:
            raise Exception("Not enough headers received in rx_http_headers")
        a = headers[0].split(' ')
        if (a[1] != "200") or (a[2]) != "OK":
            raise Exception("Invalid first header line: {0}".format(headers[0]))
        for s in headers:
            if s.startswith("Content-Length:"):
                a = s.split(' ')
                http_size = int(a[1])
        return headers
    #                    Receive String From Response
    def rx_string(max_len):
        rx = bytearray(max_len)
        i = 0
        while i < max_len:
            b = rx_byte()
            if b == 0:
                break
            rx[i] = b
            i = i + 1
        if i == 0:
            return ""
        a = bytes(rx[0:i])
        return s
    #                    Receive WORD From Response
    def rx_word():
        dw1 = rx_byte()
        dw2 = rx_byte()
        return (dw1 + (dw2<<8))
    #                       Transmit Block
    def tx_block(b):
        for x in b:
            tx_byte(x)
    #                       Transmit Byte
    def tx_byte(b):
        global http_size, tx_cnt, tx_data, tx_flag
        if tx_flag == False:
            http_size = http_size + 1
            # print("tx byte: {0}, http size: {1}".format(hex(b), http_size))
            return
        # print("tx byte: {0}".format(hex(b)))
        tx_data[tx_cnt] = b
        tx_cnt = tx_cnt + 1
        if tx_cnt >= MAX_TX_SIZE:
            tx_flush()
    #                       Transmit DWORD
    def tx_dword(dw):
        tx_word(dw & 0xffff)
        tx_word((dw >> 16) & 0xffff)
    #                       Transmit Flush
    def tx_flush():
        global tx_cnt, tx_data
        if tx_cnt == 0:
            return
        r = modem.socket_tx(tx_data, tx_cnt)
        if not r:
            raise Exception("Error transmitting in tx_flush")
        tx_cnt = 0
    #                       Transmit HTTP Headers
    def tx_http_headers(http_post, host_name, host_port):
        # example:
        # POST <http_post> HTTP/1.1
        # Host: <host_name>:<host_port>
        # Content-Length: <http_size>
        # Content-Type: application/octet-stream
        # <crlf>
        global http_size
        log("tx HTTP headers")
        s = "POST {0} HTTP/1.1\r\n".format(http_post)
        tx_string(s)
        if host_port != 80:
            s = "Host: {0}:{1}\r\n".format(host_name, host_port)
            s = "Host: {0}\r\n".format(host_name)
        tx_string(s)
        s = "Content-Length: {0}\r\n".format(http_size)
        tx_string(s)
        s = "Content-Type: application/octet-stream\r\n"
        tx_string(s)
        s = "\r\n"
        tx_string(s)
    #                       Transmit String
    def tx_string(s):
        b = s.encode('utf-8')
        for x in b:
            tx_byte(x)
    #                       Transmit WORD
    def tx_word(w):
        tx_byte(w & 0xff)
        tx_byte((w >> 8) & 0xff)
  • @tlanier
    Part 2 of 3
    Here's our com.py module. It is more application dependent but it may give you some ideas of how to use the modem module.
    import globals as g
    import modem
    from poll import poll
    import sys
    import uos
    import util
    import wifi
    _reset = True    # modem reset
    #                         Communication Task
    def com_task():
        global _reset
        try:
            sleep_ms(500)
            log("com_task: started")
            g.poll_host = True      # triggers poll at startup
            # this opens the door for continuous resets to cause high data usage
            util.set_ppp_errors(0)
            wifi.deinit()
        except Exception as ex:
            sys.print_exception(ex)
            try:
                _reset = False
                modem.reset_modem()
                g.modem_state = g.MS_INIT_MODEM
                modem.init_modem()
                while _reset == False:
                    # util.mem_info("com_task")
                    if modem_ready():
                        g.modem_state = g.MS_REGISTERED
                        if ready_to_poll():
                            transmit()
                        g.modem_state = g.MS_REGISTERING
                    sleep_ms(2000)
    #                           Modem Ready
    def modem_ready():
        global _reset
        try:
            log("** check for modem ready")
            # get modem signal strength
            g.oStatus.cell_signal = modem.signal_strength()
            # check modem registration
            r = modem.check_registration()
            if (r == 1) or (r == 5):
                # registered
                g.com_secs = 0
                # handle SMS messages
                r = modem.sms_read()
                if len(r) > 1:
                    modem.sms_process(r)
                    modem.sms_delete()
                return True
            if g.com_secs > (10*60):
                # unable to attach in 10 mins, try resetting modem
                _reset = True
            if modem.restarted():
                # modem has crashed / restarted, try resetting modem
                _reset = True
            return False
        return False
    #                           Ready To Poll
    def ready_to_poll():
        # return: True/False
        try:
            log("--- time since last poll: {0} secs ---".format(g.oNvram.last_poll_secs))
            if (g.ppp_error_secs > 0):
                log("*** poll throttling: {0} secs ***".format(g.ppp_error_secs))
                return False
            if (g.oIni.intra_poll_secs > 0):
                # contact server every <oIni.intra_poll_secs> seconds
                if (g.oNvram.last_poll_secs > g.oIni.intra_poll_secs):
                    return True
            if (g.oSetup.intra_cycle_count > 0):
                # contact server every <oSetup.intra_cycle_count> cycles
                if (g.oNvram.cycle_count >= g.oSetup.intra_cycle_count):
                    return True
            # g.poll_host is set at startup and by SMS POLL_HOST message
            if (g.poll_host == True):
                return True
        return False
    #                         Transmit
    def transmit():
        try:
            util.lcd("Transmitting", "")
            g.modem_state = g.MS_CONNECTING
            r = poll()
            g.modem_state = g.MS_DISCONNECT
            if (r == False):
                util.lcd("Transmit failed", "")
                sleep_ms(2500)
                util.lcd("","")
                return
            util.lcd("Successful", "")
            sleep_ms(2500)
            util.lcd("","")
            g.poll_host = False
            g.oNvram.last_poll_secs = 0
            g.poll_secs = 0
            if (g.update_flag == True):
                # done after disconnect
                try:
                    if util.file_exists("REMOTE.TAR"):
                        log("remove old REMOTE.TAR")
                        util.remove("REMOTE.TAR")
                    log("rename TEMP to REMOTE.TAR")
                    uos.rename("TEMP", "REMOTE.TAR")
                    # create file to signal boot.py that update is available
                    log("create UPDATE signal file")
                    with open("UPDATE", "w") as f:
                        f.write("UPDATE")
                    log("** New REMOTE.TAR ready to update")
            if (g.reboot_after_poll == True):
                log("SMS message changed INI setting, rebooting")
                util.reset(6, "INI changed")
            if (g.oHost.erase == True):
                log("Erase command received, rebooting")
                g.oNvram.erase()
                util.reset(7, "Erase NVRAM")
            if (g.oHost.reset == True):
                log("Reset command received, rebooting")
                util.reset(8, "Reset command")
  • @ruok4t Sorry I didn't see your request earlier.
    The software below is now working in production units. We ran about 20 units testing in house for two weeks with no crashes before beginning deployment with the new version. We are using MicroPython V1.20.0.rc13 with multiple versions of the modem firmware. It's a shame we had to resort to this, but it seems to work reliably.
    I've had to break the post up into 3 parts because of limitations of this forum.
    Part 1 of 3
    Here's the modem.py module:
    import globals as g
    import gpio
    from machine import UART
    import micropython
    import sys
    import util
    from ubinascii import hexlify, unhexlify
    from util import log, mem_info
    uart = None
    #                     Send AT Command To Modem
    def at(cmd, filterx=""):
        try:
            # util.mem_info("modem.at")
            if uart.any() > 0:
                # get unsolicited modem response
                a = at_response()
                for s in a:
                    at_process(s)
            if gpio.G():
                log("  modem command: {}".format(cmd))
            # send command to modem
            n = uart.write(cmd + '\r')
            if n != len(cmd) + 1:
                if gpio.G():
                    log("error sending command to modem: n = {}".format(n))
                return []
            a = at_response(filterx)
            return a
            a = []
        return a    # return modem response lines in array
    #                     Filter Modem Response
    def at_filter(a, filterx):
        # a is passed as reference value
        # filter response
        if filterx == "":
            return
        n = len(filterx)
        i = len(a)
        while i > 0:
            i = i - 1
            if not a[i].startswith(filterx):
                # remove lines that do not start with filter value
                at_process(a[i])
                a.pop(i)
    #                     Process Unsolicited Response
    def at_process(s):
        if s == 'OK':
            return
        if s.startswith("ERROR"):
            return
        if s.startswith("+CME ERROR:"):
            return
        # process unsolicited response here
        if gpio.G():
            log("  unsolicited modem response: {}".format(s))
    #                       Get AT Command Response
    def at_response(filterx=""):
        try:
            t0 = ticks_ms()
                if uart.any() > 0:
                    # insure entire response has been received
                    sleep_ms(50)
                    break
                t1 = ticks_ms()
                if tx > 10000:
                    log("timeout error - no modem response after 10 secs")
                    return []
                sleep_ms(100)
            b = uart.read()
            s = str(b, 'utf-8')
            a = s.split('\r\n')
            a = list(filter(None, a))
            if gpio.G():
                log("    modem response: {}".format(a))
            a = []
    #                       Check Registration
    def check_registration():
        # return 0-5, 99-unknown
        # response: ['+CEREG: 2,4', 'OK']
        # response: ['+CEREG: 2,1,"2C29","0B54400F",7', 'OK']
        # 2,0 - not registered, not searching
        # 2,1 - registered, home network
        # 2,2 - not registered, searching
        # 2,3 - registration denied
        # 2,4 - unknown (out of coverage)
        # 2,5 - registered, roaming
        try:
                log("check registration")
                a = at('AT+CEREG?','+CEREG:')
                if len(a) == 0:
                    break
                a = a[0].split(",")
                if (a[0] != "+CEREG: 2"):
                    break
                reg = int(a[1])
                if reg == 1:
                    log("*** registered - home network ***")
                elif reg == 5:
                    log("*** registered - roaming ***")
                    log("*** NOT registered ***")
                return reg
            log("check registration exception")
        # unknown registration
        log("error checking registration")
        return 99
    #                       Check SIM Status
    def check_sim_status():
        try:
            log("checking SIM card status")
            a = at('AT+CPIN?', '+CPIN: READY')
            if len(a) > 0:
                return True
        log("error SIM card not ready")
        return False
    #                       Disable LTE Modem
    def disable_modem():
        try:
            log("disable modem")
            a = at('AT+CFUN=0','OK')     # minimum functionality
            if len(a) == 0:
                log("error disabling modem")
    #                       Enable Modem
    def enable_modem():
        try:
            log("enabling modem")
            a = at('AT+CFUN=1','OK')     # full functionality
            if len(a) == 0:
                log("error enabling modem")
    #                Get CFUN - Modem Level of Functionality
    def get_cfun():
        # 0 - minimum functionality
        # 1 - full functionality
        # 4 - radios disabled but access to SIM allowed
        # -1 - unknown
        # note: if modem does +SHUTDOWN/+SYSSTART, CFUN will be reset to 0
        try:
                a = at('AT+CFUN?','+CFUN:')
                # response: ['+CFUN: 1', 'OK']
                if len(a) == 0:
                    break
                cfun = int(a[0][7])
                return cfun
        return -1
    #                           Get SMS Mode
    def get_sms_mode():
        # return 0-PDU mode or unknown, 1-text mode
        try:
            log("get SMS mode")
            a = at('AT+CMGF?','+CMGF:')
            # response: ['+CMGF: 1', 'OK']
            if len(a) == 0:
                return 0    # mode unknown
            mode = int(a[0][7])
            return mode
    #                     Get SIM Card ICCID Number
    def iccid():
        # CFUN must be 1 or 4
        # SIM status must be ready
        try:
            log("get SIM card ICCID")
            a = at('AT+SQNCCID?', '+SQNCCID:')
            # example response: ['+SQNCCID: "89014103271203065543",""', 'OK']
            if len(a) == 0:
                return ''
            a = a[0].split(",")
            n = len(a[0])
            r = a[0][11:n-1]
            r = ''
        log("ICCID = {0}".format(r))
        return r    # ICCID as string
    #                       Get Modem IMEI Number
    def imei():
        try:
            log("get modem IMEI number")
            a = at('AT+CGSN=1','+CGSN:')
            # example response: ['+CGSN: "354347094028575"', 'OK']
            if len(a) == 0:
                return ''
            n = len(a[0])
            r = a[0][8:n-1]
            r = ''
        log("IMEI = {0}".format(r))
        return r    # IMEI as string
    #                   Modem Firmware Info
    def info():
        log("get modem firmware version")
        a = at('ATI1')
        return a
    #                       Initialize Modem
    def init_modem():
        try:
            log("initializing modem")
            if uart == None:
                init_uart()
            info()
            set_sms_mode()
            # enable +CME ERROR: <err> result code and use verbose <err> values
            at('AT+CMEE=2')
            enable_modem()
            log("wait for SIM card ready")
            n = 0
                if len(a) > 0:
                    break
                n = n + 1
                if n > 20:
                    util.reset(13, "No SIM card")
                sleep_ms(200)
            set_apn()
    #               Initialize Uart Connected To LTE Modem
    def init_uart():
        global uart
        # pins=(TXD, RXD, RTS, CTS)
        # FiPy: pins=('P20', 'P18', 'P19', 'P17')
        # GPy:  pins=('P5', 'P98', 'P7', 'P99')
        log("initializing UART")
        # rx_buffer_size: must be > 127, 200000 works, 250000 crashes
        uart = UART(1, baudrate=921600, bits=8, parity=None, stop=1, timeout_chars=2, pins=('P5', 'P98', 'P7', 'P99'), rx_buffer_size=512)
    #           Is Cellular Modem Attached To Packet Domain Service
    def isattached():
        # returns: True/False
        try:
            a = at('AT+CGATT?','+CGATT:')
            # example response: ['+CGATT: 0', 'OK']
            if len(a) == 0:
                return False
            if a[0][8] == '1':
                return True
        return False
    #                           Reset Modem
    def reset_modem():
        try:
            if uart == None:
                init_uart()
            log("reseting modem...")
            a = at('AT^RESET', '+SHUTDOWN')
            # generates +SHUTDOWN ... +SYSSTART responses
            if len(a) == 0:
                log("error resetting modem - no +SHUTDOWN")
            a = at_response('+SYSSTART')
            if len(a) == 0:
                log("error resetting modem - no +SYSSTART")
    #                  Check Modem For Restart/Crash
    def restarted():
        # return True if modem has crashed / restarted
        try:
            # if CFUN != 1, modem has crashed / restarted
            cfun = get_cfun()
            if cfun != 1:
                return True
            # if SMS text mode is reset to zero, modem has crashed / restarted
            mode = get_sms_mode()
            if mode != 1:
                return True
            return False
        return True
    #                           Set APN
    def set_apn():
        try:
            log("set APN")
            # ICCID is only valid if SIM status is ready
            r = iccid()[0:5]
            if r == "89014":
                apn = g.oIni.apn_89014   # Kore AT&T SIM
            elif r == "89012":
                apn = g.oIni.apn_89012   # Kore T-Mobile SIM
            elif r == "89445":
                apn = g.oIni.apn_89445   # Hologram SIM
            g.oIni.apn = apn
            log("APN: {0}".format(apn))
            # try to reduce wear of non-volatile memory
            a = at('AT+CGDCONT?', '+CGDCONT:')
            # response --> ['+CGDCONT: 1,"IP","10569.mcs",,,,0,0,0,0,0,0', ...]
            if len(a) > 0:
                a = a[0].split(",")
                if (a[0] == '+CGDCONT: 1') and (a[1] == '"IP"') and (a[2] == '"'+apn+'"'):
                    return
            # apn needs setting
            cmd = 'AT+CGDCONT=1,"IP","{0}"'.format(apn)
            a = at(cmd, 'OK')
            if len(a) == 0:
                log("error setting APN")
    #                       Set SMS Mode To Text
    def set_sms_mode():
        try:
            log("set SMS mode to text")
            a = at('AT+CMGF=1', 'OK')     # set SMS mode to text
            if len(a) == 0:
                log("error setting SMS mode to text")
    #                       Get Signal Strength
    def signal_strength():
        # 0-31, 99-unknown
        try:
                log("check signal strength")
                a = at('AT+CSQ', '+CSQ:')
                # example response: ['+CSQ: 18,99', 'OK'] where 18 is signal strength
                if len(a) == 0:
                    break
                n = len(a[0])
                s = a[0][6:n-1]
                a = s.split(",")
                cell_signal = int(a[0])
                g.oStatus.cell_signal = cell_signal
                log("signal strength = {0}".format(cell_signal))
                return cell_signal
        # unknown signal strength
        g.oStatus.cell_signal = 99
        log("signal strength unknown")
        return 99
    #             Delete Read, Sent, and Unsent SMS Messages
    def sms_delete():
        try:
            log("delete all READ, SENT, and UNSENT SMS messages")
            a = at('AT+CMGD=1,3', 'OK')
            if len(a) == 0:
                log("error trying to delete read, sent, and unsent SMS messages")
    #                     Delete All SMS Messages
    def sms_delete_all():
        # doesn't work until some time after attach() is called
        try:
            log("delete all SMS messages")
            a = at('AT+CMGD=1,4', 'OK')
            if len(a) == 0:
                log("error trying to delete all SMS messages")
    #                     Process SMS Messages
    def sms_process(r):
        # example response:
        # ['+CMGL: 1,"REC READ","+1xxxxxxxxxx",,"19/01/07,09:16:53-20"', 'Test3', '+CMGL: 2,"REC READ","+1xxxxxxxxxx",,"19/01/07,11:12:30-20"', 'Test4', 'OK']
        try:
            for m in r:
                if (m[0:5] == "+CMGL"):
                    continue
                a = m.split("=")
                cmd = a[0].upper()
    			# process message here
    #                      Read Unread SMS Messages
    def sms_read():
        # response example: ['+CMGL: 1,"REC UNREAD","+1xxxxxxxxxx",,"19/01/07,09:16:53-20"', 'Test3', 'OK']
        log("read unread SMS messages")
        a = at('AT+CMGL="REC UNREAD"')
        return a
    #                       Read All SMS Messages
    def sms_read_all():
        # response example:
        log("read all SMS messages")
        a = at('AT+CMGL="ALL"')
        return a
    #                       Socket Close
    def socket_close():
        # socket close
        # connID = 1 --> socket connection identifier
        log("closing socket")
        a = at('AT+SQNSH=1', 'OK')
        if len(a) == 0:
            log("error closing connection")
    #                       Socket Connect
    def socket_connect(ip, port, timeout_secs=10):
        # returns: True if connection successful
        log("connecting to ip - {0}, port - {1}".format(ip, port))
        # make sure socket is closed
        socket_close()
        # socket configuration
        # cid = 1 --> PDP context identifier
        # pktSz = 1500 --> packet size
        # maxTo = 10 --> exchange timeout in secs
        # connTo = 600 --> connection timeout in msecs
        # txTo = 3 --> data sending timeout in hundreds of msecs
        # a = at('AT+SQNSCFG=1,1,1500,10,600,3', 'OK')
        a = at('AT+SQNSCFG=1,1,1500,{0},600,3'.format(timeout_secs), 'OK')
        if len(a) == 0:
            log("error connecting")
            return False
        # socket extended configuration
        # srMode = 1 --> SQNSRING URC data amount mode
        # recvDataMode = 1 --> data in hex
        # keepalive = 0 --> unused
        # listenAutoRsp = 0 --> deactivated
        # sendDataMode = 1 --> data in hex
        a = at('AT+SQNSCFGEXT=1,1,1,0,0,1', 'OK')
        if len(a) == 0:
            return False
        # socket dial
        # txProt = 0 --> TCP protocol
        # rPort = <port> --> remote host port to contact
        # IPaddr = <ip> --> address of remote host
        # closureType = 0 --> local host closes immediately when remote host has closed
        # lPort = 0 --> UDP port (not used)
        # connMode = 1 --> command mode connection
        # acceptAnyRemote = 0 --> disabled
        a = at('AT+SQNSD=1,0,{0},"{1}",0,0,1,0'.format(port,ip), 'OK')
        if len(a) == 0:
            return False
        log("** connection successful **")
        return True
    #                       Socket Info
    def socket_info():
        # modem response: ['+SQNSI: 1,0,0,0,0', 'OK']
        # connId: 1
        # sent: total bytes sent
        # received: total bytes received
        # buff_in: total bytes not yet read (buffered)
        # ack_waiting: total bytes sent but not yet acknowledged
        log("socket info")
        a = at('AT+SQNSI=1')
    #                       Socket Receive Data
    def socket_rx():
        # receives up to 1500 bytes maximum
        log("check for rx data")
        a = at('AT+SQNSRECV=1,1500')
        # no data ready --> modem response: ['+CME ERROR: operation not supported']
        # data ready --> modem response: ['+SQNSRECV: 1,3', '010203', 'OK']
        b = b''
        for i in range(len(a)):
            if a[i].startswith('+SQNSRECV:'):
                # next line is the data
                b = unhexlify(a[i+1])
        log("rx {0} bytes".format(len(b)))
        return b
    #                       Socket Status
    def socket_status():
        # modem response: ['+SQNSS: 1,0', '+SQNSS: 2,0', '+SQNSS: 3,0', '+SQNSS: 4,0', '+SQNSS: 5,0', '+SQNSS: 6,0', 'OK']
        # connID
        # state:
        #   0-socket closed
        #   1-socket with active data transfer connection
        #   2-socket suspended
        #   3-socket suspended with pending data
        #   4-socket listening
        #   5-socket with incoming connection
        #   6-socket in opening process
        log("socket status")
        a = at('AT+SQNSS?')
        return a
    #                       Socket Transmit Data
    def socket_tx(tx, n=0):
        # transmits up to 1500 bytes maximum
        # returns: True if successful
        if n == 0:
            n = len(tx)
        log("tx {0} bytes".format(n))
        a = at('AT+SQNSSENDEXT=1,{0}'.format(n), '> ')
        b = hexlify(tx)
        uart.write(b)
        a = at_response('OK')
        if len(a) == 0:
            log("error transmitting data")
            return False
        return True
  • @tlanier I really like the sound of what your doing here. I've been struggling with Pycom LTE module for months now. Really don't like the way it blocks other threads and randomly locks up for no apparent reason. Are you possibly in a position to share a complete "Hello LTE World" example. I'm sure I wouldn't be the only one around here who would be very interested. Hopefully someone from Pycom might also take an interest and finally admit they need to revise their code.
  • We now have our program running completely independent of the LTE module. 26 units have been running for multiple days with no crashes. I now think we have found a reliable solution. The Sequans modem AT socket commands are used to do the HTTP posts. We reliably receive 90K files and transmit 1-5K of data with no issues. Pycom MicroPython V1.20.0.rc13 is the OS version we are using.
    Currently we are using whatever version of the modem firmware (41065, 43818, and 47510 have been seen) that comes with the GPy. The version of the OS we are using has the ability to "downgrade" the modem firmware to 41065 if we decide it is needed. Some newer versions of the OS do not have this ability.
    One note of importance is we did discover that in our case the default stack size was marginal when receiving large files. Yes, I did go back and check the old program and verified that the stack issue was not the cause of the original crash problems.
    #                          Initialize Tasks
    def init_tasks():
        n = 8192    # 4096 is marginal
        _thread.stack_size(n)
        log("initializing tasks with stack size: {}".format(n))
        _thread.start_new_thread(com.com_task, ())
        _thread.start_new_thread(cycle.cycle_task, ())
  • I've now converted my code to use the Sequans modem socket commands in command mode (not on-line mode). I first tried to use the on-line mode, but ran into issues (no good way I could find to prevent overrunning tx buffer). This code resolves the 1500 byte limitation I ran into using the HTTP modem commands. There's still some cleanup to do to make the code more robust; however, it is working with large transmit and receive data blocks now.
    During development while I had coding errors and the program would terminate abnormally, I did put the modem in a mode that I couldn't recover from without power cycling the GPy. The modem would not response to AT commands, Trying to do lte = LTE() would generate the following error (OSError: Couldn't connect to Modem (modem_state=disconnected)). Doing machine.reset() would not correct the problem.
    Link to discussion of similar problem on Github
    Hopefully whatever I did to cause the problem will not occur in debugged code. There needs to be a true hardware reset of the modem. It seems that a GPIO pin should be tied to a physical reset line going to the modem that we could pulse if needed. I'm also of the opinion that the watchdog timer in the GPy should have been a hardware circuit not dependent on software to work.
    So far I have not seen any unexplained crashes while running the code.
    This code has been added to my modem.py module.
    #                       Socket Close
    def socket_close():
        # socket close
        if len(a) == 0:
            return
    #                       Socket Connect
        socket_close()
        if len(a) == 0:
            return False
        if len(a) == 0:
            return False
        # socket dial
        if len(a) == 0:
            return False
        return True
    #                       Socket Info
    def socket_info():
        # connId: 1
    def socket_rx():
        b = b''
        return b
    #                       Socket Status
        # connID
        # state:
        #   0-socket closed
        a = at('AT+SQNSS?')
        return a
        if n == 0:
            n = len(tx)
        hex = hexlify(tx)
        uart.write(hex)
        if len(a) == 0:
            return False
        return True
    This code is in my http.py module.
    import modem
    import sys
    import ubinascii
    import uos
    import ustruct
    import util
    CR = const(0x0d)
    LF = const(0x0a)
    http_error = False      # HTTP communication error: True/False
    #                       Close HTTP Socket
    def close_http():
    #                       Open HTTP Socket
        global http_error, rx_cnt, rx_data, rx_pt, tx_cnt
        http_error = False
        rx_cnt = 0
        rx_data = b''
        rx_pt = 0
        tx_cnt = 0
        if r == False:
            log("TCP socket connect error")
            http_error = True
    def rx_block(cnt):
        b = bytearray(cnt)
        i = 0
        while i < cnt:
            b[i] = rx_byte()
            i = i + 1
        return b
    def rx_byte():
        global http_error, http_size, rx_cnt, rx_data, rx_pt
        t0 = ticks_ms()
        while rx_cnt == 0:
            rx_pt = 0
            if rx_cnt > 0:
                break
            t1 = ticks_ms()
                http_error = True
                return 0
            sleep_ms(200)
        b = rx_data[rx_pt]
        rx_cnt = rx_cnt - 1
        rx_pt = rx_pt + 1
        return b
    def rx_dword():
        dw1 = rx_byte()
        dw2 = rx_byte()
        dw3 = rx_byte()
        dw4 = rx_byte()
        global http_error
        n = 0
        s = ""
            b = rx_byte()
            if http_error:
                return ""
            if b == CR:
                continue
            if b == LF:
                break
            header[n] = b
            n = n + 1
                http_error = True
                return ""
        if n > 0:
            # print("n = {0}, header = {1}".format(n,header))
            s = header[0:n].decode('utf-8')
        return s
    # HTTP/1.1 200 OK
    # <headers>
    # <headers>
    # <crlf>
    # Updates: http_size, http_error
        http_size = 0
            if http_error:
                return headers
            if s == "":
                break
            headers.append(s)
            http_error = True
            return headers
            http_error = True
            return headers
        for s in headers:
                a = s.split(' ')
        return headers
        i = 0
        while i < max_len:
            b = rx_byte()
            if b == 0:
                break
            rx[i] = b
            i = i + 1
        if i == 0:
            return ""
        s = rx[0:i].decode('utf-8')
        return s
    def rx_word():
        dw1 = rx_byte()
        dw2 = rx_byte()
    #                       Transmit Block
    def tx_block(b):
        for x in b:
            tx_byte(x)
    #                       Transmit Byte
    def tx_byte(b):
            return
        tx_data[tx_cnt] = b
        tx_cnt = tx_cnt + 1
            tx_flush()
    #                       Transmit DWORD
    def tx_dword(dw):
    #                       Transmit Flush
    def tx_flush():
        if tx_cnt == 0:
            return
        if not r:
            http_error = True
            return
        tx_cnt = 0
        # example:
        # <crlf>
        if http_error:
            return
        tx_string(s)
        if host_port != 80:
        tx_string(s)
        tx_string(s)
        tx_string(s)
        s = "\r\n"
        tx_string(s)
    #                       Transmit String
    def tx_string(s):
        for x in b:
            tx_byte(x)
    #                       Transmit WORD
    def tx_word(w):
        tx_byte(w & 0xff)
  • I seemed to have hit a major problem using the AT+SQNHTTPSND modem command. Although the manual does not state this, the maximum size of the data posted is apparently 1500 bytes.
    If anyone has ideas of how to increase this, please let me know. Unfortunately my app requires posting messages over 3000 bytes.
    Disappointed...
  • Here's updated code that is now running on two units overnight with good success. The code handles unsolicited responses gracefully. The code is non-intrusive to other multi-tasking threads. The code has not crashed (more testing to be done for sure). The code is easy to understand; everything is there to see and improve (no hidden commands being sent to the modem).
    # MODEM.PY Module
    import globals as g
    import micropython
    import sys
    import util
    uart = None
        try:
            if uart.any() > 0:
                a = at_response()
                for s in a:
                    at_process(s)
                return []
            return a
            a = []
        if filterx == "":
            return
        # filter response
        n = len(filterx)
        i = len(a)
        while i > 0:
            i = i - 1
            if a[i][0:n] != filterx:
                at_process(a[i])
                a.pop(i)
    def at_process(s):
        if s == 'OK':
            pass
            log("unsolicited modem response: {}".format(s))
        return
        try:
            t0 = ticks_ms()
                if uart.any() > 0:
                    sleep_ms(50)
                    break
                t1 = ticks_ms()
                if tx > 10000:
                    return []
                sleep_ms(100)
            b = uart.read()
            s = str(b, 'utf-8')
            a = s.split('\r\n')
            a = []
    #             Attach Cellular Modem To Packet Domain Service
    def attach():
        try:
            log("attach modem to packet domain service")
            a = at('AT+CGATT=1','OK')
            if len(a) == 0:
                log("error attaching modem")
        try:
                if len(a) == 0:
                    break
                a = a[0].split(",")
                    break
                reg = int(a[1])
                if reg == 1:
                    log("registered - home network")
                elif reg == 5:
                    log("registered - roaming")
                    log("not registered")
                return reg
        return 99
    #             Detach Cellular Modem From Packet Domain Service
    def detach():
        # modem does not get SMS messages while the modem is detached
        # old messages received while detached are only received when a new message is sent while attached
        try:
            log("detach modem from packet domain service")
            a = at('AT+CGATT=0','OK')
            if len(a) == 0:
                log("error detaching modem")
    #                       Disable LTE Modem
        try:
            if len(a) == 0:
    #                       Enable Modem
    def enable_modem():
        try:
            if len(a) == 0:
    def get_cfun():
        # -1 - unknown
        try:
                if len(a) == 0:
                    break
                cfun = int(a[0][7])
                return cfun
        return -1
    #                           Get SMS Mode
    def get_sms_mode():
        try:
            log("get SMS mode")
            if len(a) == 0:
            mode = int(a[0][7])
            return mode
    #                            HTTP Post
    def http_post(uri, header, tx_data):
        # --> AT+SQNHTTPSND=<prof_id>,<command>,<resource>,<data_len>[,<post_param>[,<extra_header_line>]]
        # xx> POST <uri> HTTP/1.1
        # xx> <header>
        # xx> Content-Length: <tx_size>
        # xx> Content-Type: application/octet-stream
        # xx> <blank line>
        # --> <tx_data bytes>
        # <-- OK
        # <-- +SQNHTTPRING: <prof_id,<http_status_code>,<content_type>,<rx_size>
        # --> AT+SQNHTTPRCV=1,0\r
        # <-- /r/n<<<
        # <-- <rx_data bytes>
        # <-- OK
        try:
            log("HTTP post")
                # note: init_modem() sets configuration "AT+SQNHTTPCFG=..." at startup
                tx_size = len(tx_data)
                # log("writing message: {0}".format(tx_data))
                log("tx_data length: {0}".format(tx_size))
                # AT+SQNHTTPSND=<prof_id>,<command>,<resource>,<data_len>[,<post_param>[,<extra_header_line>]]
                # prof_id=1, command=0 (POST), <uri>, <tx_size>, post_parm="2" (application/octet-stream), header="Host: <host_name>"
                a = at('AT+SQNHTTPSND=1,0,"{0}",{1},"2","{2}"'.format(uri, tx_size, header),'> ')
                if len(a) == 0:
                    break   # error
                uart.write(tx_data)
                if len(a) == 0:
                    break   # error
                # modem responds with "+SQNHTTPRING: <prof_id,<http_status_code>,<content_type>,<data_size>"
                a = at_response("+SQNHTTPRING:")
                if len(a) == 0:
                    break   # error
                a = a[0].split(",")
                http_status_code = int(a[1])
                if http_status_code != 200:
                    break   # error
                rx_size = int(a[3])
                log("rx_data length: {0}".format(rx_size))
                # get response
                cmd = 'AT+SQNHTTPRCV=1,0\r'
                log("  modem command: {0}".format(cmd))
                uart.write(cmd)
                r = wait_rx(5, 10000)   # wait for b'\r\n<<<'
                if r == False:
                    break   # error
                b = uart.read(5)
                # log(" modem response: {0}".format(b))
                if b[2:5] != b'<<<':
                    break   # error
                t0 = ticks_ms()
                b = b''
                n = rx_size     # no. bytes remaining to be read
                    if uart.any() > 0:
                        log("attempt to read {0} bytes".format(n))
                        bx = uart.read(n)
                        log("bytes read: {0}".format(len(bx)))
                        # log(" modem response: {0}".format(bx))
                        b = b + bx
                        if len(b) == rx_size:
                            break   # entire message received
                        n = rx_size - len(b)
                        t0 = ticks_ms()     # reset timeout
                    t1 = ticks_ms()
                    if tx > 10000:
                        log("timeout error receiving response")
                        return b''
                    sleep_ms(400)
                log("total bytes read: {0}".format(len(b)))
                # log(" post response: {0}".format(b))
                if len(a) == 0:
                    break   # error
                # log(b)
                return b
        # error
        return b''
    def iccid():
        try:
            a = at('AT+SQNCCID?','+SQNCCID:')
            if len(a) == 0:
                return ''
            a = a[0].split(",")
            n = len(a[0])
            r = a[0][11:n-1]
            r = ''
    def imei():
        try:
            if len(a) == 0:
                return ''
            n = len(a[0])
            r = a[0][8:n-1]
            r = ''
    #                       Initialize Modem
    def init_modem():
        try:
            if uart == None:
                init_uart()
            disable_modem()
            # set profile #1 parameters for HTTP connection
            # prof_id=1 (profile), ip, port, auth_type=0 (None), username="", password="",
            # ssl_enabled=0, timeout, cid=1 (PDN Context Identifier)
            server = g.oIni.host_ip     # note: host_name could also be used (auto DNS lookup)
            port = g.oIni.host_port
            timeout = 10    # secs to wait for response from server
            cmd = 'AT+SQNHTTPCFG=1,"{0}",{1},0,"","",0,{2},1'.format(server, port, timeout)
            a = at(cmd,'OK')
            if len(a) == 0:
                log("error initializing modem")
            set_sms_mode()
            enable_modem()
    def init_uart():
        global uart
        # rx_buffer_size: must be > 127, 200000 works, 250000 crashes, http_post seems to work with any size
    def isattached():
        try:
            if len(a) == 0:
                return False
            if a[0][8] == '1':
                return True
        return False
    #                           Reset Modem
    def reset_modem():
        try:
            if uart == None:
                init_uart()
            a = at('AT^RESET','+SHUTDOWN')
            if len(a) == 0:
            if len(a) == 0:
    def restarted():
        try:
            cfun = get_cfun()
            if cfun != 1:
                return True
            if mode != 1:
                return True
            return False
        return True
    #                           Set APN
    def set_apn():
        try:
            log("set APN")
            # ICCID is only valid after registration
            r = iccid()[0:5]
            if r == "89014":
            elif r == "89012":
            elif r == "89445":
            g.oIni.apn = apn
            a = at('AT+CGDCONT?','+CGDCONT:')
            if len(a) > 0:
                a = a[0].split(",")
                    return
            # apn needs setting
            a = at(cmd,'OK')
            if len(a) == 0:
    def set_sms_mode():
        try:
            a = at('AT+CMGF=1','OK')     # set SMS mode to text
            if len(a) == 0:
        # 0-31, 99-unknown
        try:
                a = at('AT+CSQ','+CSQ:')
                if len(a) == 0:
                    break
                n = len(a[0])
                s = a[0][6:n-1]
                a = s.split(",")
                return cell_signal
        return 99
    def sms_delete():
        try:
            a = at('AT+CMGD=1,3','OK')
            if len(a) == 0:
        try:
            a = at('AT+CMGD=1,4','OK')
            if len(a) == 0:
    def sms_process(r):
        # example response:
        try:
            for m in r:
                    continue
                a = m.split("=")
                cmd = a[0].upper()
    def sms_read():
        return a
    def sms_read_all():
        # response example:
        return a
    #                       Wait For N Received Chars
    def wait_rx(n, timeout=10000):
        # timeout in msecs
        t0 = ticks_ms()
            if uart.any() >= n:
                break
            t1 = ticks_ms()
            if tx > timeout:
                return False
            sleep_ms(10)
        return True
    Here's the code being used. The code shown is incomplete since it is application dependent. I'm somewhat disappointed in the necessary placement of the modem.apn_set() call. This may change in the future.
    # COM.PY Module
    import globals as g
    import modem
    import sys
    import uos
    import util
    import wifi
    def com_task():
        try:
            sleep_ms(500)
            wifi.deinit()
            modem.reset_modem()
            modem.init_modem()
            try:
                if modem_ready():
                    if ready_to_poll():
                        modem.set_apn()
                        transmit()
                sleep_ms(2000)
    #                           Modem Ready
    def modem_ready():
        try:
                # registered
                g.com_secs = 0
                if len(r) > 1:
                    modem.sms_delete()
                return True
            reset = False
                reset = True
                reset = True
            if reset:
                modem.reset_modem()
                modem.init_modem()
                g.com_secs = 0
            return False
        return False
  • @kjm What would really be neat is if we could learn how to put the modem in a mode that allowed the urequests/usockets libraries to work using just AT commands!
    I suspect it has to do with the AT+CGDCONT parameter named PDP_type. The manual shows the following values:
    X.25 ITU-T/CCITT X.25 layer 3 (Obsolete)
    IP Internet Protocol (IETF STD 5 [103])
    IPV6 Internet Protocol, version 6 (see RFC 2460 [106])
    IPV4V6 Virtual <PDP_type> introduced to handle dual IP stack UE capability. (See
    3GPP TS 24.301 [83])
    OSPIH Internet Hosted Octect Stream Protocol (Obsolete)
    PPP Point to Point Protocol (IETF STD 51 [104])
    Non-IP Transfer of Non-IP data to external packet data network (see 3GPP TS 23.401
    This is an area I'm unsure about. I would welcome comments from others about what would need to be done.
  • @kjm Thanks for the comment. The intention of wait_rx(n, timeout=10000) is to be a non-blocking call that waits for N chars to come into the uart or to timeout after 10,000 msecs by default. N should be less than the buffer size of the uart which is currently set to 512 bytes.
    In looking at my current code, I see a bug. I should have had a sleep command in the while loop to make multi-tasking more efficient. Here's the corrected code. Thanks again!
        # timeout in msecs
        t0 = ticks_ms()
            if uart.any() >= n:
                break
            t1 = ticks_ms()
            if tx > timeout:
                return False
            sleep_ms(10)
        return True
  • @kjm I think I remember having to modify urequests also. Here's what I currently use in my old version that is working.
    import usocket
    import util
    class Response:
        def __init__(self, f):
            self.raw = f
            self.encoding = "utf-8"
            self._cached = None
        def close(self):
            if self.raw:
                self.raw.close()
                self.raw = None
            self._cached = None
        @property
        def content(self):
            if self._cached is None:
                try:
                    self._cached = self.raw.read()
                finally:
                    self.raw.close()
                    self.raw = None
            return self._cached
        @property
        def text(self):
            return str(self.content, self.encoding)
        def json(self):
            import ujson
            return ujson.loads(self.content)
    def request(method, url, data=None, json=None, headers={}, stream=None):
        try:
            proto, dummy, host, path = url.split("/", 3)
        except ValueError:
            proto, dummy, host = url.split("/", 2)
            path = ""
        if proto == "http:":
            port = 80
        elif proto == "https:":
            import ussl
            port = 443
            raise ValueError("Unsupported protocol: " + proto)
        if ":" in host:
            host, port = host.split(":", 1)
            port = int(port)
        # ai = usocket.getaddrinfo(host, port, 0, usocket.SOCK_STREAM)  # PATCH
        ai = usocket.getaddrinfo(host, port)
        ai = ai[0]
        s = usocket.socket(ai[0], ai[1], ai[2])
        try:
            s.settimeout(20)
            s.connect(ai[-1])
                s = ussl.wrap_socket(s, server_hostname=host)
            s.write(b"%s /%s HTTP/1.0\r\n" % (method, path))
            if not "Host" in headers:
                s.write(b"Host: %s\r\n" % host)
            # Iterate over keys to avoid tuple alloc
            for k in headers:
                s.write(k)
                s.write(b": ")
                s.write(headers[k])
                s.write(b"\r\n")
            if json is not None:
                assert data is None
                import ujson
                data = ujson.dumps(json)
                s.write(b"Content-Type: application/json\r\n")
            if data:
                s.write(b"Content-Length: %d\r\n" % len(data))
            s.write(b"\r\n")
            if data:
                s.write(data)
            l = s.readline()
            #print(l)
            l = l.split(None, 2)
            status = int(l[1])
            reason = ""
            if len(l) > 2:
                reason = l[2].rstrip()
                l = s.readline()
                if not l or l == b"\r\n":
                    break
                #print(l)
                if l.startswith(b"Transfer-Encoding:"):
                    if b"chunked" in l:
                        raise ValueError("Unsupported " + l)
                elif l.startswith(b"Location:") and not 200 <= status <= 299:
                    raise NotImplementedError("Redirects not yet supported")
    #   except OSError:     # PATCH
        except:
            s.close()
            raise
        resp = Response(s)
        resp.status_code = status
        resp.reason = reason
        return resp
    def head(url, **kw):
        return request("HEAD", url, **kw)
    def get(url, **kw):
        return request("GET", url, **kw)
    def post(url, **kw):
        return request("POST", url, **kw)
    def put(url, **kw):
        return request("PUT", url, **kw)
    def patch(url, **kw):
        return request("PATCH", url, **kw)
    def delete(url, **kw):
        return request("DELETE", url, **kw)
  • @tlanier Admire your efforts squire. I've been struggling with lte for a year or so now. It's not perfect (the lte.isattached() gets confused sometimes) but I got it robust enough to be usable. I use the requests library for data transfer & my main complaint is that it can't be timed out. I modified it with machine.WDT so that I can abort in a timely manner but I'd like a better solution. Am I right in thinking your wait_rx(n, 10000) allows you to quit if http post/get times out after 10s?
6 out of 41
