    Method To Take Control of Cell Modem
    41 Posts 10 Posters 902 Views 14 Watching
      tlanier
      A new method has been added to the modem module. It is desirable to use the ICCID to determine which APN to set. One issue to deal with is apparently the ICCID is not valid until registration with the tower is done. The set_apn() method should be called right before doing the attach().
      To reduce the wear of writing to the non-volatile memory, I read the current value of the APN and skip the write if not necessary. I wonder if the modem does this type of checking internally? Ideally we could just set the APN once at program start, but we can't read the ICCID at that point for some reason. Even though the manual says when CFUN=4 or CFUN=1 access to the SIM is available, reading the ICCID does not work until after registration.
      To get some context as to how the modem module can be used, I've included example code for a modem_ready() method that uses the modem module.
      There is still work to be done with the basic at() and get_modem_response() methods. Unsolicited responses are causing problems in some cases. That will be my next area to concentrate on. There seems to be two paths to take when talking to a modem. Path #1 sends a command to the modem and then waits a period of time and assumes the modem has had time to respond completely. Path #2 sends a command to the modem and then watches the data being returned looking for (1) OK, or (2) ERROR anywhere in the response. The responses then must be filtered to only return the particular response line that is desired.
      #                           Set APN
      def set_apn():
          try:
              log("set APN")
              # ICCID is only valid after registration
              r = iccid()[0:5]
              if r == "89014":
                  apn = g.oIni.apn_89014   # Kore AT&T SIM
              elif r == "89012":
                  apn = g.oIni.apn_89012   # Kore T-Mobile SIM
              elif r == "89445":
                  apn = g.oIni.apn_89445   # Hologram SIM
              g.oIni.apn = apn
              log("APN: {0}".format(apn))
              # try to reduce wear of non-volatile memory
              a = at('AT+CGDCONT?')
              # response --> ['+CGDCONT: 1,"IP","10569.mcs",,,,0,0,0,0,0,0', ...]
              s = a[0]
              a = s.split(",")
              if (a[0] == '+CGDCONT: 1') and (a[1] == '"IP"') and (a[2] == '"'+apn+'"'):
                  return
              # apn needs setting
              a = at('AT+CGDCONT=1,"IP","{0}"'.format(apn))
              if a[0] != 'OK':
                  log("error setting APN")
          except Exception as ex:
              sys.print_exception(ex)
      #                           Modem Ready
      def modem_ready():
          try:
              log("** check for modem ready")
              # get modem signal strength
              g.oStatus.cell_signal = modem.signal_strength()
              # handle SMS messages
              r = modem.sms_read()
              if len(r) > 1:
                  modem.sms_process(r)
                  modem.sms_delete()
              # check modem registration
              r = modem.check_registration()
              if (r == 1) or (r == 5):
                  # wait until registered to set APN
                  modem.set_apn()
                  modem.attach()
                  if modem.isattached():
                      g.com_secs = 0
                      return True
              reset = False
              if g.com_secs > (10*60):
                  # unable to attach in 10 mins, try resetting modem
                  reset = True
              if modem.restarted():
                  # modem has crashed / restarted, try resetting modem
                  reset = True
              if reset:
                  modem.reset_modem()
                  modem.init_modem()
                  g.com_secs = 0
              return False
          return False
        jcaron @tlanier
        @tlanier you should probably create a GitHub or GitLab repo for your code...
          tlanier @jcaron
          @jcaron Thanks for the suggestion. I have been thinking about that. I would need to make the module more general purpose and less specific to my application. My first priority is to make our application more robust and error free.
          I've thought about creating a general purpose do nothing application that implements multi-threading, a timer interrupt service routine, and the modem module to show how everything fits together. Someone could take the template application and create a full application in no time.
          Including our method of program updates would also be useful I think.
            tlanier
            The new at(cmd, filter="") function is now improved such that unsolicited responses should have no affect. It also allows you to specify the response you are interested in getting back by setting the filter parameter. This simplifies the coding of the rest of the modem module.
            #                     Send AT Command To Modem
            def at(cmd, filterx=""):
                try:
                    if uart.any() > 0:
                        # get unsolicited modem response
                        a = at_response()
                        for s in a:
                            at_process(s)
                    log("  modem command: {}".format(cmd))
                    # send command to modem
                    n = uart.write(cmd + '\r')
                    if n != len(cmd) + 1:
                        log("error sending command to modem: n = {}".format(n))
                        return []
                    a = at_response(filterx)
                    return a
                    a = []
                return a    # return modem response lines in array
            #                     Filter Modem Response
            def at_filter(a, filterx):
                # a is passed as reference value
                if filterx == "":
                    return
                # filter response
                n = len(filterx)
                i = len(a)
                while i > 0:
                    i = i - 1
                    if a[i][0:n] != filterx:
                        # remove lines that do not start with filter value
                        at_process(a[i])
                        a.pop(i)
            #                     Process Unsolicited Response
            def at_process(s):
                if s == 'OK':
                    pass
                    log("unsolicited modem response: {}".format(s))
                return
            #                       Get AT Command Response
            def at_response(filterx=""):
                try:
                    t0 = ticks_ms()
                        if uart.any() > 0:
                            # insure entire response has been received
                            sleep_ms(50)
                            break
                        t1 = ticks_ms()
                        tx = ticks_diff(t1, t0)
                        if tx > 10000:
                            log("timeout error - no modem response after 10 secs")
                            return []
                        sleep_ms(100)
                    b = uart.read()
                    s = str(b, 'utf-8')
                    a = s.split('\r\n')
                    a = list(filter(None, a))
                    log("  modem response: {}".format(a))
                    a = []
              peterp @tlanier
              Hey @tlanier could you elaborate a bit on this point? How to reproduce this freezing?
              Task switching no longer freezes during modem communication.
                tlanier
                Here's some of the higher level code that uses the modem module.
                import globals as g
                import modem
                from poll import poll
                import sys
                import uos
                import util
                from util import log
                from utime import sleep_ms
                import wifi
                #                         Communication Task
                def com_task():
                    try:
                        sleep_ms(500)
                        log("com_task: started")
                        wifi.deinit()
                        modem.reset_modem()
                        modem.init_modem()
                        g.poll_host = True      # triggers poll at startup
                        try:
                            if modem_ready():
                                if ready_to_poll():
                                    modem.set_apn()
                                    transmit()
                            sleep_ms(2000)
                #                           Modem Ready
                def modem_ready():
                    try:
                            # registered
                            g.com_secs = 0
                            if len(r) > 1:
                                modem.sms_delete()
                            return True
                        reset = False
                            reset = True
                            reset = True
                        if reset:
                            modem.reset_modem()
                            modem.init_modem()
                            g.com_secs = 0
                        return False
                    return False
                  tlanier @peterp
                  @peterp Sorry to take so long to respond. I wanted to finish updating my posts showing the new code that seems to be working well. Soon I should be able to post the entire refined code. Maybe it will help others with the same problems we have had.
                  The reason I went down this development path was as described originally:
                  "I currently have a program working in production using Pycom MicroPython V1.20.0.rc13 on many units. When I try to run the same program on a newly purchased GPy running Pycom MicroPython 1.20.2.r3, the program crashes (20 sec watchdog timeout) when I do an AT command ('AT+CEREG?') after disconnecting from a successful transmission. How do I troubleshoot such a crash?"
                  Our original reason for picking Pycom and GPy was the thinking that all the modem complexity would be handled by the high level LTE module. It's only a guess but our thinking that since the crashes always happened during times communicating with the modem, the LTE module was the likely source of the problem.
                  The new method seems to be superior from the standpoint of interference with multiple tasks. Since we always call non-blocking uart commands, the code should never get hung in the C code for any period. A simple example of the LTE module code freezing multi-tasking is to do a simple modem reset. Reading and writing to the file storage also has a minor affect. The real reason for the development was to try to eliminate program crashes. Only longer term testing will show whether we have achieved that goal.
                  One concern I do have is whether I am properly initializing the cell modem. Any input from anybody out there that is more familiar with properly setting up the LTE modem would be appreciated. It seems to work fine at this point; however, I'm not sure whether it's working because the GPy I'm testing with has run the LTE initialization at some point in the past and that has possibly setup the non-volatile memory of the modem to the proper settings that are needed.
                  One drawback of using this method of transmission is it is not compatible with WIFI connections. That is not an issue for us at this time. Maybe later we can research how to do some form of communication that is compatible with both WIFI and direct AT commands. I assume that involves using the socket commands of the modem, but this is an area I'm not sure about at this time.
                  • K Offline
                    kjm @tlanier
                    @tlanier Admire your efforts squire. I've been struggling with lte for a year or so now. It's not perfect (the lte.isattached() gets confused sometimes) but I got it robust enough to be usable. I use the requests library for data transfer & my main complaint is that it can't be timed out. I modified it with machine.WDT so that I can abort in a timely manner but I'd like a better solution. Am I right in thinking your wait_rx(n, 10000) allows you to quit if http post/get times out after 10s?
                    T 3 Replies Last reply Reply Quote 0
                      tlanier @kjm
                      @kjm I think I remember having to modify urequests also. Here's what I currently use in my old version that is working.
                      import usocket
                      import util
                      class Response:
                          def __init__(self, f):
                              self.raw = f
                              self.encoding = "utf-8"
                              self._cached = None
                          def close(self):
                              if self.raw:
                                  self.raw.close()
                                  self.raw = None
                              self._cached = None
                          @property
                          def content(self):
                              if self._cached is None:
                                  try:
                                      self._cached = self.raw.read()
                                  finally:
                                      self.raw.close()
                                      self.raw = None
                              return self._cached
                          @property
                          def text(self):
                              return str(self.content, self.encoding)
                          def json(self):
                              import ujson
                              return ujson.loads(self.content)
                      def request(method, url, data=None, json=None, headers={}, stream=None):
                          try:
                              proto, dummy, host, path = url.split("/", 3)
                          except ValueError:
                              proto, dummy, host = url.split("/", 2)
                              path = ""
                          if proto == "http:":
                              port = 80
                          elif proto == "https:":
                              import ussl
                              port = 443
                              raise ValueError("Unsupported protocol: " + proto)
                          if ":" in host:
                              host, port = host.split(":", 1)
                              port = int(port)
                          # ai = usocket.getaddrinfo(host, port, 0, usocket.SOCK_STREAM)  # PATCH
                          ai = usocket.getaddrinfo(host, port)
                          ai = ai[0]
                          s = usocket.socket(ai[0], ai[1], ai[2])
                          try:
                              s.settimeout(20)
                              s.connect(ai[-1])
                                  s = ussl.wrap_socket(s, server_hostname=host)
                              s.write(b"%s /%s HTTP/1.0\r\n" % (method, path))
                              if not "Host" in headers:
                                  s.write(b"Host: %s\r\n" % host)
                              # Iterate over keys to avoid tuple alloc
                              for k in headers:
                                  s.write(k)
                                  s.write(b": ")
                                  s.write(headers[k])
                                  s.write(b"\r\n")
                              if json is not None:
                                  assert data is None
                                  import ujson
                                  data = ujson.dumps(json)
                                  s.write(b"Content-Type: application/json\r\n")
                              if data:
                                  s.write(b"Content-Length: %d\r\n" % len(data))
                              s.write(b"\r\n")
                              if data:
                                  s.write(data)
                              l = s.readline()
                              #print(l)
                              l = l.split(None, 2)
                              status = int(l[1])
                              reason = ""
                              if len(l) > 2:
                                  reason = l[2].rstrip()
                                  l = s.readline()
                                  if not l or l == b"\r\n":
                                      break
                                  #print(l)
                                  if l.startswith(b"Transfer-Encoding:"):
                                      if b"chunked" in l:
                                          raise ValueError("Unsupported " + l)
                                  elif l.startswith(b"Location:") and not 200 <= status <= 299:
                                      raise NotImplementedError("Redirects not yet supported")
                      #   except OSError:     # PATCH
                          except:
                              s.close()
                              raise
                          resp = Response(s)
                          resp.status_code = status
                          resp.reason = reason
                          return resp
                      def head(url, **kw):
                          return request("HEAD", url, **kw)
                      def get(url, **kw):
                          return request("GET", url, **kw)
                      def post(url, **kw):
                          return request("POST", url, **kw)
                      def put(url, **kw):
                          return request("PUT", url, **kw)
                      def patch(url, **kw):
                          return request("PATCH", url, **kw)
                      def delete(url, **kw):
                          return request("DELETE", url, **kw)
                        tlanier @kjm
                        @kjm Thanks for the comment. The intention of wait_rx(n, timeout=10000) is to be a non-blocking call that waits for N chars to come into the uart or to timeout after 10,000 msecs by default. N should be less than the buffer size of the uart which is currently set to 512 bytes.
                        In looking at my current code, I see a bug. I should have had a sleep command in the while loop to make multi-tasking more efficient. Here's the corrected code. Thanks again!
                        #                       Wait For N Received Chars
                        def wait_rx(n, timeout=10000):
                            # timeout in msecs
                            t0 = ticks_ms()
                                if uart.any() >= n:
                                    break
                                t1 = ticks_ms()
                                if tx > timeout:
                                    return False
                                sleep_ms(10)
                            return True
                          tlanier @kjm
                          @kjm What would really be neat is if we could learn how to put the modem in a mode that allowed the urequests/usockets libraries to work using just AT commands!
                          I suspect it has to do with the AT+CGDCONT parameter named PDP_type. The manual shows the following values:
                          X.25 ITU-T/CCITT X.25 layer 3 (Obsolete)
                          IP Internet Protocol (IETF STD 5 [103])
                          IPV6 Internet Protocol, version 6 (see RFC 2460 [106])
                          IPV4V6 Virtual <PDP_type> introduced to handle dual IP stack UE capability. (See
                          3GPP TS 24.301 [83])
                          OSPIH Internet Hosted Octect Stream Protocol (Obsolete)
                          PPP Point to Point Protocol (IETF STD 51 [104])
                          Non-IP Transfer of Non-IP data to external packet data network (see 3GPP TS 23.401
                          This is an area I'm unsure about. I would welcome comments from others about what would need to be done.
                            tlanier
                            Here's updated code that is now running on two units overnight with good success. The code handles unsolicited responses gracefully. The code is non-intrusive to other multi-tasking threads. The code has not crashed (more testing to be done for sure). The code is easy to understand; everything is there to see and improve (no hidden commands being sent to the modem).
                            # MODEM.PY Module
                            import globals as g
                            from machine import UART
                            import micropython
                            import sys
                            import util
                            from utime import sleep_ms, ticks_ms, ticks_diff
                            uart = None
                                try:
                                    if uart.any() > 0:
                                        a = at_response()
                                        for s in a:
                                            at_process(s)
                                        return []
                                    return a
                                    a = []
                                if filterx == "":
                                    return
                                # filter response
                                n = len(filterx)
                                i = len(a)
                                while i > 0:
                                    i = i - 1
                                        at_process(a[i])
                                        a.pop(i)
                            def at_process(s):
                                if s == 'OK':
                                    pass
                                return
                                try:
                                    t0 = ticks_ms()
                                        if uart.any() > 0:
                                            sleep_ms(50)
                                            break
                                        t1 = ticks_ms()
                                        if tx > 10000:
                                            return []
                                        sleep_ms(100)
                                    b = uart.read()
                                    s = str(b, 'utf-8')
                                    a = s.split('\r\n')
                                    a = []
                            #             Attach Cellular Modem To Packet Domain Service
                            def attach():
                                try:
                                    log("attach modem to packet domain service")
                                    a = at('AT+CGATT=1','OK')
                                    if len(a) == 0:
                                        log("error attaching modem")
                            #                       Check Registration
                            def check_registration():
                                # return 0-5, 99-unknown
                                # response: ['+CEREG: 2,4', 'OK']
                                # response: ['+CEREG: 2,1,"2C29","0B54400F",7', 'OK']
                                # 2,0 - not registered, not searching
                                # 2,1 - registered, home network
                                # 2,2 - not registered, searching
                                # 2,3 - registration denied
                                # 2,4 - unknown (out of coverage)
                                # 2,5 - registered, roaming
                                try:
                                        log("check registration")
                                        a = at('AT+CEREG?','+CEREG:')
                                        if len(a) == 0:
                                            break
                                        a = a[0].split(",")
                                        if (a[0] != "+CEREG: 2"):
                                            break
                                        reg = int(a[1])
                                        if reg == 1:
                                            log("registered - home network")
                                        elif reg == 5:
                                            log("registered - roaming")
                                            log("not registered")
                                        return reg
                                    log("check registration exception")
                                # unknown registration
                                log("error checking registration")
                                return 99
                            #             Detach Cellular Modem From Packet Domain Service
                            def detach():
                                # modem does not get SMS messages while the modem is detached
                                # old messages received while detached are only received when a new message is sent while attached
                                try:
                                    log("detach modem from packet domain service")
                                    a = at('AT+CGATT=0','OK')
                                    if len(a) == 0:
                                        log("error detaching modem")
                            #                       Disable LTE Modem
                            def disable_modem():
                                try:
                                    log("disable modem")
                                    a = at('AT+CFUN=0','OK')     # minimum functionality
                                    if len(a) == 0:
                                        log("error disabling modem")
                            #                       Enable Modem
                            def enable_modem():
                                try:
                                    log("enabling modem")
                                    a = at('AT+CFUN=1','OK')     # full functionality
                                    if len(a) == 0:
                                        log("error enabling modem")
                            #                Get CFUN - Modem Level of Functionality
                            def get_cfun():
                                # 0 - minimum functionality
                                # 1 - full functionality
                                # 4 - radios disabled but access to SIM allowed
                                # -1 - unknown
                                # note: if modem does +SHUTDOWN/+SYSSTART, CFUN will be reset to 0
                                try:
                                        a = at('AT+CFUN?','+CFUN:')
                                        # response: ['+CFUN: 1', 'OK']
                                        if len(a) == 0:
                                            break
                                        cfun = int(a[0][7])
                                        return cfun
                                return -1
                            #                           Get SMS Mode
                            def get_sms_mode():
                                # return 0-PDU mode or unknown, 1-text mode
                                try:
                                    log("get SMS mode")
                                    a = at('AT+CMGF?','+CMGF:')
                                    # response: ['+CMGF: 1', 'OK']
                                    if len(a) == 0:
                                        return 0    # mode unknown
                                    mode = int(a[0][7])
                                    return mode
                            #                            HTTP Post
                            def http_post(uri, header, tx_data):
                                # --> AT+SQNHTTPSND=<prof_id>,<command>,<resource>,<data_len>[,<post_param>[,<extra_header_line>]]
                                # xx> POST <uri> HTTP/1.1
                                # xx> <header>
                                # xx> Content-Length: <tx_size>
                                # xx> Content-Type: application/octet-stream
                                # xx> <blank line>
                                # --> <tx_data bytes>
                                # <-- OK
                                # <-- +SQNHTTPRING: <prof_id,<http_status_code>,<content_type>,<rx_size>
                                # --> AT+SQNHTTPRCV=1,0\r
                                # <-- /r/n<<<
                                # <-- <rx_data bytes>
                                # <-- OK
                                try:
                                    log("HTTP post")
                                        # note: init_modem() sets configuration "AT+SQNHTTPCFG=..." at startup
                                        tx_size = len(tx_data)
                                        # log("writing message: {0}".format(tx_data))
                                        log("tx_data length: {0}".format(tx_size))
                                        # AT+SQNHTTPSND=<prof_id>,<command>,<resource>,<data_len>[,<post_param>[,<extra_header_line>]]
                                        # prof_id=1, command=0 (POST), <uri>, <tx_size>, post_parm="2" (application/octet-stream), header="Host: <host_name>"
                                        a = at('AT+SQNHTTPSND=1,0,"{0}",{1},"2","{2}"'.format(uri, tx_size, header),'> ')
                                        if len(a) == 0:
                                            break   # error
                                        uart.write(tx_data)
                                        a = at_response('OK')
                                        if len(a) == 0:
                                            break   # error
                                        # modem responds with "+SQNHTTPRING: <prof_id,<http_status_code>,<content_type>,<data_size>"
                                        a = at_response("+SQNHTTPRING:")
                                        if len(a) == 0:
                                            break   # error
                                        a = a[0].split(",")
                                        http_status_code = int(a[1])
                                        if http_status_code != 200:
                                            break   # error
                                        rx_size = int(a[3])
                                        log("rx_data length: {0}".format(rx_size))
                                        # get response
                                        cmd = 'AT+SQNHTTPRCV=1,0\r'
                                        log("  modem command: {0}".format(cmd))
                                        uart.write(cmd)
                                        r = wait_rx(5, 10000)   # wait for b'\r\n<<<'
                                        if r == False:
                                            break   # error
                                        b = uart.read(5)
                                        # log(" modem response: {0}".format(b))
                                        if b[2:5] != b'<<<':
                                            break   # error
                                        t0 = ticks_ms()
                                        b = b''
                                        n = rx_size     # no. bytes remaining to be read
                                            if uart.any() > 0:
                                                log("attempt to read {0} bytes".format(n))
                                                bx = uart.read(n)
                                                log("bytes read: {0}".format(len(bx)))
                                                # log(" modem response: {0}".format(bx))
                                                b = b + bx
                                                if len(b) == rx_size:
                                                    break   # entire message received
                                                n = rx_size - len(b)
                                                t0 = ticks_ms()     # reset timeout
                                            t1 = ticks_ms()
                                            if tx > 10000:
                                                log("timeout error receiving response")
                                                return b''
                                            sleep_ms(400)
                                        log("total bytes read: {0}".format(len(b)))
                                        # log(" post response: {0}".format(b))
                                        if len(a) == 0:
                                            break   # error
                                        # log(b)
                                        return b
                                # error
                                return b''
                            #                     Get SIM Card ICCID Number
                            def iccid():
                                # CFUN must be 1 or 4
                                try:
                                    log("get SIM card ICCID")
                                    a = at('AT+SQNCCID?','+SQNCCID:')
                                    # example response: ['+SQNCCID: "89014103271203065543",""', 'OK']
                                    if len(a) == 0:
                                        return ''
                                    a = a[0].split(",")
                                    n = len(a[0])
                                    r = a[0][11:n-1]
                                    r = ''
                                log("ICCID = {0}".format(r))
                                return r    # ICCID as string
                            #                       Get Modem IMEI Number
                            def imei():
                                try:
                                    log("get modem IMEI number")
                                    a = at('AT+CGSN=1','+CGSN:')
                                    # example response: ['+CGSN: "354347094028575"', 'OK']
                                    if len(a) == 0:
                                        return ''
                                    n = len(a[0])
                                    r = a[0][8:n-1]
                                    r = ''
                                log("IMEI = {0}".format(r))
                                return r    # IMEI as string
                            #                       Initialize Modem
                            def init_modem():
                                try:
                                    log("initializing modem")
                                    if uart == None:
                                        init_uart()
                                    disable_modem()
                                    # set profile #1 parameters for HTTP connection
                                    # prof_id=1 (profile), ip, port, auth_type=0 (None), username="", password="",
                                    # ssl_enabled=0, timeout, cid=1 (PDN Context Identifier)
                                    server = g.oIni.host_ip     # note: host_name could also be used (auto DNS lookup)
                                    port = g.oIni.host_port
                                    timeout = 10    # secs to wait for response from server
                                    cmd = 'AT+SQNHTTPCFG=1,"{0}",{1},0,"","",0,{2},1'.format(server, port, timeout)
                                    a = at(cmd,'OK')
                                    if len(a) == 0:
                                        log("error initializing modem")
                                    set_sms_mode()
                                    enable_modem()
                            #               Initialize Uart Connected To LTE Modem
                            def init_uart():
                                global uart
                                # pins=(TXD, RXD, RTS, CTS)
                                # FiPy: pins=('P20', 'P18', 'P19', 'P17')
                                # GPy:  pins=('P5', 'P98', 'P7', 'P99')
                                log("initializing UART")
                                # rx_buffer_size: must be > 127, 200000 works, 250000 crashes, http_post seems to work with any size
                                uart = UART(1, baudrate=921600, bits=8, parity=None, stop=1, timeout_chars=2, pins=('P5', 'P98', 'P7', 'P99'), rx_buffer_size=512)
                            #           Is Cellular Modem Attached To Packet Domain Service
                            def isattached():
                                # returns: True/False
                                try:
                                    a = at('AT+CGATT?','+CGATT:')
                                    # example response: ['+CGATT: 0', 'OK']
                                    if len(a) == 0:
                                        return False
                                    if a[0][8] == '1':
                                        return True
                                return False
                            #                           Reset Modem
                            def reset_modem():
                                try:
                                    if uart == None:
                                        init_uart()
                                    log("reseting modem...")
                                    a = at('AT^RESET','+SHUTDOWN')
                                    # generates +SHUTDOWN ... +SYSSTART responses
                                    if len(a) == 0:
                                        log("error resetting modem - no +SHUTDOWN")
                                    a = at_response('+SYSSTART')
                                    if len(a) == 0:
                                        log("error resetting modem - no +SYSSTART")
                            #                  Check Modem For Restart/Crash
                            def restarted():
                                # return True if modem has crashed / restarted
                                try:
                                    # if CFUN != 1, modem has crashed / restarted
                                    cfun = get_cfun()
                                    if cfun != 1:
                                        return True
                                    # if SMS text mode is reset to zero, modem has crashed / restarted
                                    mode = get_sms_mode()
                                    if mode != 1:
                                        return True
                                    return False
                                return True
                            #                           Set APN
                            def set_apn():
                                try:
                                    log("set APN")
                                    r = iccid()[0:5]
                                    if r == "89014":
                                    elif r == "89012":
                                    elif r == "89445":
                                    g.oIni.apn = apn
                                    a = at('AT+CGDCONT?','+CGDCONT:')
                                    if len(a) > 0:
                                        a = a[0].split(",")
                                            return
                                    # apn needs setting
                                    cmd = 'AT+CGDCONT=1,"IP","{0}"'.format(apn)
                                    a = at(cmd,'OK')
                                    if len(a) == 0:
                            #                       Set SMS Mode To Text
                            def set_sms_mode():
                                try:
                                    log("set SMS mode to text")
                                    a = at('AT+CMGF=1','OK')     # set SMS mode to text
                                    if len(a) == 0:
                                        log("error setting SMS mode to text")
                            #                       Get Signal Strength
                            def signal_strength():
                                # 0-31, 99-unknown
                                try:
                                        log("check signal strength")
                                        a = at('AT+CSQ','+CSQ:')
                                        # example response: ['+CSQ: 18,99', 'OK'] where 18 is signal strength
                                        if len(a) == 0:
                                            break
                                        n = len(a[0])
                                        s = a[0][6:n-1]
                                        a = s.split(",")
                                        cell_signal = int(a[0])
                                        g.oStatus.cell_signal = cell_signal
                                        log("signal strength = {0}".format(cell_signal))
                                        return cell_signal
                                # unknown signal strength
                                g.oStatus.cell_signal = 99
                                log("signal strength unknown")
                                return 99
                            #             Delete Read, Sent, and Unsent SMS Messages
                            def sms_delete():
                                try:
                                    log("delete all READ, SENT, and UNSENT SMS messages")
                                    a = at('AT+CMGD=1,3','OK')
                                    if len(a) == 0:
                                        log("error trying to delete read, sent, and unsent SMS messages")
                            #                     Delete All SMS Messages
                            def sms_delete_all():
                                # doesn't work until some time after attach() is called
                                try:
                                    log("delete all SMS messages")
                                    a = at('AT+CMGD=1,4','OK')
                                    if len(a) == 0:
                                        log("error trying to delete all SMS messages")
                            #                     Process SMS Messages
                            def sms_process(r):
                                # example response:
                                # ['+CMGL: 1,"REC READ","+1xxxxxxxxxx",,"19/01/07,09:16:53-20"', 'Test3', '+CMGL: 2,"REC READ","+1xxxxxxxxxx",,"19/01/07,11:12:30-20"', 'Test4', 'OK']
                                try:
                                    for m in r:
                                        if (m[0:5] == "+CMGL"):
                                            continue
                                        a = m.split("=")
                                        cmd = a[0].upper()
                            #                      Read Unread SMS Messages
                            def sms_read():
                                # response example: ['+CMGL: 1,"REC UNREAD","+1xxxxxxxxxx",,"19/01/07,09:16:53-20"', 'Test3', 'OK']
                                log("read unread SMS messages")
                                a = at('AT+CMGL="REC UNREAD"')
                                return a
                            #                       Read All SMS Messages
                            def sms_read_all():
                                # response example:
                                log("read all SMS messages")
                                a = at('AT+CMGL="ALL"')
                                return a
                                # timeout in msecs
                                t0 = ticks_ms()
                                    if uart.any() >= n:
                                        break
                                    t1 = ticks_ms()
                                    if tx > timeout:
                                        return False
                                    sleep_ms(10)
                                return True
                            Here's the code being used. The code shown is incomplete since it is application dependent. I'm somewhat disappointed in the necessary placement of the modem.apn_set() call. This may change in the future.
                            # COM.PY Module
                            import globals as g
                            import modem
                            import sys
                            import uos
                            import util
                            import wifi
                            def com_task():
                                try:
                                    sleep_ms(500)
                                    wifi.deinit()
                                    modem.reset_modem()
                                    modem.init_modem()
                                    try:
                                        if modem_ready():
                                            if ready_to_poll():
                                                modem.set_apn()
                                                transmit()
                                        sleep_ms(2000)
                            #                           Modem Ready
                            def modem_ready():
                                try:
                                        # registered
                                        g.com_secs = 0
                                        if len(r) > 1:
                                            modem.sms_delete()
                                        return True
                                    reset = False
                                        reset = True
                                        reset = True
                                    if reset:
                                        modem.reset_modem()
                                        modem.init_modem()
                                        g.com_secs = 0
                                    return False
                                return False
                              tlanier
                              I seemed to have hit a major problem using the AT+SQNHTTPSND modem command. Although the manual does not state this, the maximum size of the data posted is apparently 1500 bytes.
                              If anyone has ideas of how to increase this, please let me know. Unfortunately my app requires posting messages over 3000 bytes.
                              Disappointed...
                                tlanier
                                I've now converted my code to use the Sequans modem socket commands in command mode (not on-line mode). I first tried to use the on-line mode, but ran into issues (no good way I could find to prevent overrunning tx buffer). This code resolves the 1500 byte limitation I ran into using the HTTP modem commands. There's still some cleanup to do to make the code more robust; however, it is working with large transmit and receive data blocks now.
                                During development while I had coding errors and the program would terminate abnormally, I did put the modem in a mode that I couldn't recover from without power cycling the GPy. The modem would not response to AT commands, Trying to do lte = LTE() would generate the following error (OSError: Couldn't connect to Modem (modem_state=disconnected)). Doing machine.reset() would not correct the problem.
                                Link to discussion of similar problem on Github
                                Hopefully whatever I did to cause the problem will not occur in debugged code. There needs to be a true hardware reset of the modem. It seems that a GPIO pin should be tied to a physical reset line going to the modem that we could pulse if needed. I'm also of the opinion that the watchdog timer in the GPy should have been a hardware circuit not dependent on software to work.
                                So far I have not seen any unexplained crashes while running the code.
                                This code has been added to my modem.py module.
                                #                       Socket Close
                                def socket_close():
                                    # socket close
                                    # connID = 1 --> socket connection identifier
                                    a = at('AT+SQNSH=1', 'OK')
                                    if len(a) == 0:
                                        log("error closing connection")
                                        return
                                #                       Socket Connect
                                def socket_connect(ip, port, timeout_secs=10):
                                    # returns: True if connection successful
                                    log("connecting to ip - {0}, port - {1}".format(ip, port))
                                    # make sure socket is closed
                                    socket_close()
                                    # socket configuration
                                    # cid = 1 --> PDP context identifier
                                    # pktSz = 1500 --> packet size
                                    # maxTo = 10 --> exchange timeout in secs
                                    # connTo = 600 --> connection timeout in msecs
                                    # txTo = 3 --> data sending timeout in hundreds of msecs
                                    # a = at('AT+SQNSCFG=1,1,1500,10,600,3', 'OK')
                                    a = at('AT+SQNSCFG=1,1,1500,{0},600,3'.format(timeout_secs), 'OK')
                                    if len(a) == 0:
                                        log("error connecting")
                                        return False
                                    # socket extended configuration
                                    # srMode = 1 --> SQNSRING URC data amount mode
                                    # recvDataMode = 1 --> data in hex
                                    # keepalive = 0 --> unused
                                    # listenAutoRsp = 0 --> deactivated
                                    # sendDataMode = 1 --> data in hex
                                    a = at('AT+SQNSCFGEXT=1,1,1,0,0,1', 'OK')
                                    if len(a) == 0:
                                        return False
                                    # socket dial
                                    # txProt = 0 --> TCP protocol
                                    # rPort = <port> --> remote host port to contact
                                    # IPaddr = <ip> --> address of remote host
                                    # closureType = 0 --> local host closes immediately when remote host has closed
                                    # lPort = 0 --> UDP port (not used)
                                    # connMode = 1 --> command mode connection
                                    # acceptAnyRemote = 0 --> disabled
                                    a = at('AT+SQNSD=1,0,{0},"{1}",0,0,1,0'.format(port,ip), 'OK')
                                    if len(a) == 0:
                                        return False
                                    log("** connection successful **")
                                    return True
                                #                       Socket Info
                                def socket_info():
                                    # modem response: ['+SQNSI: 1,0,0,0,0', 'OK']
                                    # connId: 1
                                    # sent: total bytes sent
                                    # received: total bytes received
                                    # buff_in: total bytes not yet read (buffered)
                                    # ack_waiting: total bytes sent but not yet acknowledged
                                    a = at('AT+SQNSI=1')
                                #                       Socket Receive Data
                                def socket_rx():
                                    # receives up to 1500 bytes maximum
                                    log("check for rx data")
                                    a = at('AT+SQNSRECV=1,1500')
                                    # no data ready --> modem response: ['+CME ERROR: operation not supported']
                                    # data ready --> modem response: ['+SQNSRECV: 1,3', '010203', 'OK']
                                    b = b''
                                    for i in range(len(a)):
                                        if a[i].startswith('+SQNSRECV:'):
                                            # next line is the data
                                            b = unhexlify(a[i+1])
                                    log("rx {0} bytes".format(len(b)))
                                    return b
                                #                       Socket Status
                                def socket_status():
                                    # modem response: ['+SQNSS: 1,0', '+SQNSS: 2,0', '+SQNSS: 3,0', '+SQNSS: 4,0', '+SQNSS: 5,0', '+SQNSS: 6,0', 'OK']
                                    # connID
                                    # state:
                                    #   0-socket closed
                                    #   1-socket with active data transfer connection
                                    #   2-socket suspended
                                    #   3-socket suspended with pending data
                                    #   4-socket listening
                                    #   5-socket with incoming connection
                                    #   6-socket in opening process
                                    a = at('AT+SQNSS?')
                                    return a
                                #                       Socket Transmit Data
                                def socket_tx(tx, n=0):
                                    # transmits up to 1500 bytes maximum
                                    # returns: True if successful
                                    if n == 0:
                                        n = len(tx)
                                    log("tx {0} bytes".format(n))
                                    a = at('AT+SQNSSENDEXT=1,{0}'.format(n), '> ')
                                    hex = hexlify(tx)
                                    uart.write(hex)
                                    if len(a) == 0:
                                        log("error transmitting data")
                                        return False
                                    return True
                                This code is in my http.py module.
                                import modem
                                import sys
                                import ubinascii
                                import uos
                                import ustruct
                                import util
                                BUFFER_SIZE = const(1500)
                                CR = const(0x0d)
                                LF = const(0x0a)
                                MAX_HEADER_SIZE = const(128)
                                MAX_TX_SIZE = const(1500)
                                HTTP_TIMEOUT_MSECS = const(15000)
                                # HTTP_TIMEOUT_MSECS = const(300000)  # TESTING
                                http_error = False      # HTTP communication error: True/False
                                http_size = 0           # HTTP POST message size
                                rx_cnt = 0              # no. bytes in rx_data buffer
                                rx_data = b''           # rx data buffer
                                rx_pt = 0               # pointer into rx data buffer
                                tx_cnt = 0              # no. bytes in tx_data buffer
                                tx_data = bytearray(MAX_TX_SIZE)    # tx data buffer
                                tx_flag = False         # controls tx_byte
                                #                       Close HTTP Socket
                                def close_http():
                                    modem.socket_close()
                                #                       Open HTTP Socket
                                def open_http(host_ip, host_port):
                                    global http_error, rx_cnt, rx_data, rx_pt, tx_cnt
                                    http_error = False
                                    rx_cnt = 0
                                    rx_data = b''
                                    rx_pt = 0
                                    tx_cnt = 0
                                    r = modem.socket_connect(host_ip, host_port)
                                    if r == False:
                                        log("TCP socket connect error")
                                        http_error = True
                                #                    Receive BLOCK From Response
                                def rx_block(cnt):
                                    b = bytearray(cnt)
                                    i = 0
                                    while i < cnt:
                                        b[i] = rx_byte()
                                        i = i + 1
                                    return b
                                #                    Receive BYTE From Response
                                def rx_byte():
                                    global http_error, http_size, rx_cnt, rx_data, rx_pt
                                    t0 = ticks_ms()
                                    while rx_cnt == 0:
                                        rx_data = modem.socket_rx()
                                        rx_cnt = len(rx_data)
                                        rx_pt = 0
                                        if rx_cnt > 0:
                                            break
                                        t1 = ticks_ms()
                                        if (tx > HTTP_TIMEOUT_MSECS):
                                            http_error = True
                                            return 0
                                        sleep_ms(200)
                                    b = rx_data[rx_pt]
                                    rx_cnt = rx_cnt - 1
                                    rx_pt = rx_pt + 1
                                    http_size = http_size - 1
                                    # print("rx byte: {0}".format(hex(b)))
                                    return b
                                #                    Receive DWORD From Response
                                def rx_dword():
                                    dw1 = rx_byte()
                                    dw2 = rx_byte()
                                    dw3 = rx_byte()
                                    dw4 = rx_byte()
                                    return (dw1 + (dw2<<8) + (dw3<<16) + (dw4<<24))
                                #                    Receive One HTTP Header
                                def rx_http_header():
                                    # returns header string
                                    global http_error
                                    n = 0
                                    header = bytearray(MAX_HEADER_SIZE)
                                    s = ""
                                        b = rx_byte()
                                        # print("byte = {0}".format(b))
                                        if http_error:
                                            return ""
                                        if b == CR:
                                            continue
                                        if b == LF:
                                            break
                                        header[n] = b
                                        n = n + 1
                                        if n >= MAX_HEADER_SIZE-1:
                                            http_error = True
                                            return ""
                                    if n > 0:
                                        # print("n = {0}, header = {1}".format(n,header))
                                        s = header[0:n].decode('utf-8')
                                    return s
                                #                    Receive HTTP Headers
                                # HTTP/1.1 200 OK
                                # <headers>
                                # Content-Length: nnn
                                # <headers>
                                # <crlf>
                                # Updates: http_size, http_error
                                def rx_http_headers():
                                    headers = []      # array of header lines
                                    http_size = 0
                                        s = rx_http_header()
                                        log("length = {0}, header = {1}".format(len(s), s))
                                        if http_error:
                                            return headers
                                        if s == "":
                                            break
                                        headers.append(s)
                                    if len(headers) < 2:
                                        http_error = True
                                        return headers
                                    a = headers[0].split(' ')
                                    if (a[1] != "200") or (a[2]) != "OK":
                                        http_error = True
                                        return headers
                                    for s in headers:
                                        if s.startswith("Content-Length:"):
                                            a = s.split(' ')
                                            http_size = int(a[1])
                                    return headers
                                #                    Receive String From Response
                                def rx_string(max_len):
                                    rx = bytearray(max_len)
                                    i = 0
                                    while i < max_len:
                                        b = rx_byte()
                                        if b == 0:
                                            break
                                        rx[i] = b
                                        i = i + 1
                                    if i == 0:
                                        return ""
                                    s = rx[0:i].decode('utf-8')
                                    return s
                                #                    Receive WORD From Response
                                def rx_word():
                                    dw1 = rx_byte()
                                    dw2 = rx_byte()
                                    return (dw1 + (dw2<<8))
                                #                       Transmit Block
                                def tx_block(b):
                                    for x in b:
                                        tx_byte(x)
                                #                       Transmit Byte
                                def tx_byte(b):
                                    global http_size, tx_cnt, tx_data, tx_flag
                                    if tx_flag == False:
                                        http_size = http_size + 1
                                        # print("tx byte: {0}, http size: {1}".format(hex(b), http_size))
                                        return
                                    # print("tx byte: {0}".format(hex(b)))
                                    tx_data[tx_cnt] = b
                                    tx_cnt = tx_cnt + 1
                                    if tx_cnt >= MAX_TX_SIZE:
                                        tx_flush()
                                #                       Transmit DWORD
                                def tx_dword(dw):
                                    tx_word(dw & 0xffff)
                                    tx_word((dw >> 16) & 0xffff)
                                #                       Transmit Flush
                                def tx_flush():
                                    global tx_cnt, tx_data
                                    if tx_cnt == 0:
                                        return
                                    r = modem.socket_tx(tx_data, tx_cnt)
                                    if not r:
                                        http_error = True
                                        return
                                    tx_cnt = 0
                                #                       Transmit HTTP Headers
                                def tx_http_headers(http_post, host_name, host_port):
                                    # example:
                                    # POST <http_post> HTTP/1.1
                                    # Host: <host_name>:<host_port>
                                    # Content-Length: <http_size>
                                    # Content-Type: application/octet-stream
                                    # <crlf>
                                    log("tx HTTP headers")
                                    if http_error:
                                        return
                                    s = "POST {0} HTTP/1.1\r\n".format(http_post)
                                    tx_string(s)
                                    if host_port != 80:
                                        s = "Host: {0}:{1}\r\n".format(host_name, host_port)
                                        s = "Host: {0}\r\n".format(host_name)
                                    tx_string(s)
                                    s = "Content-Length: {0}\r\n".format(http_size)
                                    tx_string(s)
                                    s = "Content-Type: application/octet-stream\r\n"
                                    tx_string(s)
                                    s = "\r\n"
                                    tx_string(s)
                                #                       Transmit String
                                def tx_string(s):
                                    b = s.encode('utf-8')
                                    for x in b:
                                        tx_byte(x)
                                #                       Transmit WORD
                                def tx_word(w):
                                    tx_byte(w & 0xff)
                                    tx_byte((w >> 8) & 0xff)
                                  tlanier
                                  We now have our program running completely independent of the LTE module. 26 units have been running for multiple days with no crashes. I now think we have found a reliable solution. The Sequans modem AT socket commands are used to do the HTTP posts. We reliably receive 90K files and transmit 1-5K of data with no issues. Pycom MicroPython V1.20.0.rc13 is the OS version we are using.
                                  Currently we are using whatever version of the modem firmware (41065, 43818, and 47510 have been seen) that comes with the GPy. The version of the OS we are using has the ability to "downgrade" the modem firmware to 41065 if we decide it is needed. Some newer versions of the OS do not have this ability.
                                  One note of importance is we did discover that in our case the default stack size was marginal when receiving large files. Yes, I did go back and check the old program and verified that the stack issue was not the cause of the original crash problems.
                                  #                          Initialize Tasks
                                  def init_tasks():
                                      n = 8192    # 4096 is marginal
                                      _thread.stack_size(n)
                                      log("initializing tasks with stack size: {}".format(n))
                                      _thread.start_new_thread(com.com_task, ())
                                      _thread.start_new_thread(cycle.cycle_task, ())
                                    ruok4t @tlanier
                                    @tlanier I really like the sound of what your doing here. I've been struggling with Pycom LTE module for months now. Really don't like the way it blocks other threads and randomly locks up for no apparent reason. Are you possibly in a position to share a complete "Hello LTE World" example. I'm sure I wouldn't be the only one around here who would be very interested. Hopefully someone from Pycom might also take an interest and finally admit they need to revise their code.
                                      tlanier @ruok4t
                                      @ruok4t Sorry I didn't see your request earlier.
                                      The software below is now working in production units. We ran about 20 units testing in house for two weeks with no crashes before beginning deployment with the new version. We are using MicroPython V1.20.0.rc13 with multiple versions of the modem firmware. It's a shame we had to resort to this, but it seems to work reliably.
                                      I've had to break the post up into 3 parts because of limitations of this forum.
                                      Part 1 of 3
                                      Here's the modem.py module:
                                      import globals as g
                                      import gpio
                                      import micropython
                                      import sys
                                      import util
                                      from ubinascii import hexlify, unhexlify
                                      from util import log, mem_info
                                      uart = None
                                          try:
                                              # util.mem_info("modem.at")
                                              if uart.any() > 0:
                                                  a = at_response()
                                                  for s in a:
                                                      at_process(s)
                                              if gpio.G():
                                                  if gpio.G():
                                                  return []
                                              return a
                                              a = []
                                          # filter response
                                          if filterx == "":
                                              return
                                          n = len(filterx)
                                          i = len(a)
                                          while i > 0:
                                              i = i - 1
                                              if not a[i].startswith(filterx):
                                                  at_process(a[i])
                                                  a.pop(i)
                                      def at_process(s):
                                          if s == 'OK':
                                              return
                                          if s.startswith("ERROR"):
                                              return
                                          if s.startswith("+CME ERROR:"):
                                              return
                                          # process unsolicited response here
                                          if gpio.G():
                                              log("  unsolicited modem response: {}".format(s))
                                          try:
                                              t0 = ticks_ms()
                                                  if uart.any() > 0:
                                                      sleep_ms(50)
                                                      break
                                                  t1 = ticks_ms()
                                                  if tx > 10000:
                                                      return []
                                                  sleep_ms(100)
                                              b = uart.read()
                                              s = str(b, 'utf-8')
                                              a = s.split('\r\n')
                                              if gpio.G():
                                              a = []
                                          try:
                                                  if len(a) == 0:
                                                      break
                                                  a = a[0].split(",")
                                                      break
                                                  reg = int(a[1])
                                                  if reg == 1:
                                                      log("*** registered - home network ***")
                                                  elif reg == 5:
                                                      log("*** registered - roaming ***")
                                                      log("*** NOT registered ***")
                                                  return reg
                                          return 99
                                      #                       Check SIM Status
                                      def check_sim_status():
                                          try:
                                              log("checking SIM card status")
                                              a = at('AT+CPIN?', '+CPIN: READY')
                                              if len(a) > 0:
                                                  return True
                                          log("error SIM card not ready")
                                          return False
                                      #                       Disable LTE Modem
                                          try:
                                              if len(a) == 0:
                                      #                       Enable Modem
                                      def enable_modem():
                                          try:
                                              if len(a) == 0:
                                      def get_cfun():
                                          # -1 - unknown
                                          try:
                                                  if len(a) == 0:
                                                      break
                                                  cfun = int(a[0][7])
                                                  return cfun
                                          return -1
                                      #                           Get SMS Mode
                                      def get_sms_mode():
                                          try:
                                              log("get SMS mode")
                                              if len(a) == 0:
                                              mode = int(a[0][7])
                                              return mode
                                      def iccid():
                                          # SIM status must be ready
                                          try:
                                              a = at('AT+SQNCCID?', '+SQNCCID:')
                                              if len(a) == 0:
                                                  return ''
                                              a = a[0].split(",")
                                              n = len(a[0])
                                              r = a[0][11:n-1]
                                              r = ''
                                      def imei():
                                          try:
                                              if len(a) == 0:
                                                  return ''
                                              n = len(a[0])
                                              r = a[0][8:n-1]
                                              r = ''
                                      #                   Modem Firmware Info
                                      def info():
                                          log("get modem firmware version")
                                          a = at('ATI1')
                                          return a
                                      #                       Initialize Modem
                                      def init_modem():
                                          try:
                                              if uart == None:
                                                  init_uart()
                                              info()
                                              set_sms_mode()
                                              # enable +CME ERROR: <err> result code and use verbose <err> values
                                              at('AT+CMEE=2')
                                              enable_modem()
                                              log("wait for SIM card ready")
                                              n = 0
                                                  if len(a) > 0:
                                                      break
                                                  n = n + 1
                                                  if n > 20:
                                                      util.reset(13, "No SIM card")
                                                  sleep_ms(200)
                                              set_apn()
                                      def init_uart():
                                          global uart
                                      def isattached():
                                          try:
                                              if len(a) == 0:
                                                  return False
                                              if a[0][8] == '1':
                                                  return True
                                          return False
                                      #                           Reset Modem
                                      def reset_modem():
                                          try:
                                              if uart == None:
                                                  init_uart()
                                              a = at('AT^RESET', '+SHUTDOWN')
                                              if len(a) == 0:
                                              if len(a) == 0:
                                      def restarted():
                                          try:
                                              cfun = get_cfun()
                                              if cfun != 1:
                                                  return True
                                              if mode != 1:
                                                  return True
                                              return False
                                          return True
                                      #                           Set APN
                                      def set_apn():
                                          try:
                                              log("set APN")
                                              # ICCID is only valid if SIM status is ready
                                              r = iccid()[0:5]
                                              if r == "89014":
                                              elif r == "89012":
                                              elif r == "89445":
                                              g.oIni.apn = apn
                                              a = at('AT+CGDCONT?', '+CGDCONT:')
                                              if len(a) > 0:
                                                  a = a[0].split(",")
                                                      return
                                              # apn needs setting
                                              a = at(cmd, 'OK')
                                              if len(a) == 0:
                                      def set_sms_mode():
                                          try:
                                              a = at('AT+CMGF=1', 'OK')     # set SMS mode to text
                                              if len(a) == 0:
                                          # 0-31, 99-unknown
                                          try:
                                                  a = at('AT+CSQ', '+CSQ:')
                                                  if len(a) == 0:
                                                      break
                                                  n = len(a[0])
                                                  s = a[0][6:n-1]
                                                  a = s.split(",")
                                                  return cell_signal
                                          return 99
                                      def sms_delete():
                                          try:
                                              a = at('AT+CMGD=1,3', 'OK')
                                              if len(a) == 0:
                                          try:
                                              a = at('AT+CMGD=1,4', 'OK')
                                              if len(a) == 0:
                                      def sms_process(r):
                                          # example response:
                                          try:
                                              for m in r:
                                                      continue
                                                  a = m.split("=")
                                                  cmd = a[0].upper()
                                      			# process message here
                                      def sms_read():
                                          return a
                                      def sms_read_all():
                                          # response example:
                                          return a
                                      #                       Socket Close
                                      def socket_close():
                                          # socket close
                                          log("closing socket")
                                          if len(a) == 0:
                                      #                       Socket Connect
                                          socket_close()
                                          if len(a) == 0:
                                              return False
                                          if len(a) == 0:
                                              return False
                                          # socket dial
                                          if len(a) == 0:
                                              return False
                                          return True
                                      #                       Socket Info
                                      def socket_info():
                                          # connId: 1
                                          log("socket info")
                                      def socket_rx():
                                          b = b''
                                          return b
                                      #                       Socket Status
                                          # connID
                                          # state:
                                          #   0-socket closed
                                          log("socket status")
                                          a = at('AT+SQNSS?')
                                          return a
                                          if n == 0:
                                              n = len(tx)
                                          b = hexlify(tx)
                                          uart.write(b)
                                          if len(a) == 0:
                                              return False
                                          return True
                                      T R 2 Replies Last reply Reply Quote 0
                                        tlanier @tlanier
                                        @tlanier
                                        Part 2 of 3
                                        Here's our com.py module. It is more application dependent but it may give you some ideas of how to use the modem module.
                                        import globals as g
                                        import modem
                                        import sys
                                        import uos
                                        import util
                                        import wifi
                                        _reset = True    # modem reset
                                        def com_task():
                                            global _reset
                                            try:
                                                sleep_ms(500)
                                                # this opens the door for continuous resets to cause high data usage
                                                util.set_ppp_errors(0)
                                                wifi.deinit()
                                                try:
                                                    _reset = False
                                                    g.modem_state = g.MS_RESET_MODEM
                                                    modem.reset_modem()
                                                    g.modem_state = g.MS_INIT_MODEM
                                                    modem.init_modem()
                                                    while _reset == False:
                                                        # util.mem_info("com_task")
                                                        if modem_ready():
                                                            g.modem_state = g.MS_REGISTERED
                                                            if ready_to_poll():
        transmit()
                                                            g.modem_state = g.MS_REGISTERING
                                                        sleep_ms(2000)
                                        #                           Modem Ready
                                        def modem_ready():
                                            global _reset
                                            try:
                                                    # registered
                                                    g.com_secs = 0
                                                    if len(r) > 1:
                                                        modem.sms_delete()
                                                    return True
                                                    _reset = True
                                                    _reset = True
                                                return False
                                            return False
                                        #                           Ready To Poll
                                        def ready_to_poll():
                                            # return: True/False
                                            try:
                                                log("--- time since last poll: {0} secs ---".format(g.oNvram.last_poll_secs))
                                                if (g.ppp_error_secs > 0):
                                                    log("*** poll throttling: {0} secs ***".format(g.ppp_error_secs))
                                                    return False
                                                if (g.oIni.intra_poll_secs > 0):
                                                    # contact server every <oIni.intra_poll_secs> seconds
                                                    if (g.oNvram.last_poll_secs > g.oIni.intra_poll_secs):
                                                        return True
                                                if (g.oSetup.intra_cycle_count > 0):
                                                    # contact server every <oSetup.intra_cycle_count> cycles
                                                    if (g.oNvram.cycle_count >= g.oSetup.intra_cycle_count):
                                                        return True
                                                # g.poll_host is set at startup and by SMS POLL_HOST message
                                                if (g.poll_host == True):
                                                    return True
                                            return False
                                        #                         Transmit
                                        def transmit():
                                            try:
                                                util.lcd("Transmitting", "")
                                                g.modem_state = g.MS_CONNECTING
                                                r = poll()
                                                g.modem_state = g.MS_DISCONNECT
                                                if (r == False):
                                                    util.lcd("Transmit failed", "")
                                                    sleep_ms(2500)
                                                    util.lcd("","")
                                                    return
                                                util.lcd("Successful", "")
                                                sleep_ms(2500)
                                                util.lcd("","")
                                                g.poll_host = False
                                                g.oNvram.last_poll_secs = 0
                                                g.poll_secs = 0
                                                if (g.update_flag == True):
                                                    # done after disconnect
                                                    try:
                                                        if util.file_exists("REMOTE.TAR"):
                                                            log("remove old REMOTE.TAR")
                                                            util.remove("REMOTE.TAR")
                                                        log("rename TEMP to REMOTE.TAR")
                                                        uos.rename("TEMP", "REMOTE.TAR")
                                                        # create file to signal boot.py that update is available
                                                        log("create UPDATE signal file")
                                                        with open("UPDATE", "w") as f:
                                                            f.write("UPDATE")
                                                        log("** New REMOTE.TAR ready to update")
                                                if (g.reboot_after_poll == True):
                                                    log("SMS message changed INI setting, rebooting")
                                                    util.reset(6, "INI changed")
                                                if (g.oHost.erase == True):
                                                    log("Erase command received, rebooting")
                                                    g.oNvram.erase()
                                                    util.reset(7, "Erase NVRAM")
                                                if (g.oHost.reset == True):
                                                    log("Reset command received, rebooting")
                                                    util.reset(8, "Reset command")
                                          tlanier @tlanier
                                          @tlanier
                                          Part 3 of 3
                                          Here's the http.py module:
                                          Note that the modem socket commands have a 1500 byte limitation. The HTTP module overcomes that by breaking longer messages up into smaller blocks.
                                          import modem
                                          import sys
                                          import ubinascii
                                          import uos
                                          import ustruct
                                          import util
                                          # note: HTTP errors raise exceptions
                                          CR = const(0x0d)
                                          LF = const(0x0a)
                                          #                       Close HTTP Socket
                                          def close_http():
                                          #                       Open HTTP Socket
                                              global rx_cnt, rx_data, rx_pt, tx_cnt
                                              rx_cnt = 0
                                              rx_data = b''
                                              rx_pt = 0
                                              tx_cnt = 0
                                              if r == False:
                                                  raise Exception("TCP socket connect error")
                                          def rx_block(cnt):
                                              b = bytearray(cnt)
                                              i = 0
                                              while i < cnt:
                                                  b[i] = rx_byte()
                                                  i = i + 1
                                              log("rx_block: {} bytes".format(len(b)))
                                              return b
                                          def rx_byte():
                                              global http_size, rx_cnt, rx_data, rx_pt
                                              t0 = ticks_ms()
                                              while rx_cnt == 0:
                                                  rx_pt = 0
                                                  if rx_cnt > 0:
                                                      break
                                                  t1 = ticks_ms()
                                                      raise Exception("HTTP timeout in rx_byte")
                                                  sleep_ms(200)
                                              b = rx_data[rx_pt]
                                              rx_cnt = rx_cnt - 1
                                              rx_pt = rx_pt + 1
                                              return b
                                          def rx_dword():
                                              dw1 = rx_byte()
                                              dw2 = rx_byte()
                                              dw3 = rx_byte()
                                              dw4 = rx_byte()
                                              n = 0
                                              s = ""
                                                  b = rx_byte()
                                                  if b == CR:
                                                      continue
                                                  if b == LF:
                                                      break
                                                  header[n] = b
                                                  n = n + 1
                                                      raise Exception("Maximum header size error in rx_http_header")
                                              if n > 0:
                                                  # older versions of MicroPython do not implement decode on bytearrays
                                                  a = bytes(header[0:n])
                                                  s = a.decode('utf-8')
                                                  log("header = {}".format(s))
                                              return s
                                          # HTTP/1.1 200 OK
                                          # <headers>
                                          # <headers>
                                          # <crlf>
                                              global http_size
                                              http_size = 0
                                                  # log("length = {0}, header = {1}".format(len(s), s))
                                                  if s == "":
                                                      break
                                                  headers.append(s)
                                                  raise Exception("Not enough headers received in rx_http_headers")
                                                  raise Exception("Invalid first header line: {0}".format(headers[0]))
                                              for s in headers:
                                                      a = s.split(' ')
                                              return headers
                                              i = 0
                                              while i < max_len:
                                                  b = rx_byte()
                                                  if b == 0:
                                                      break
                                                  rx[i] = b
                                                  i = i + 1
                                              if i == 0:
                                                  return ""
                                              a = bytes(rx[0:i])
                                              return s
                                          def rx_word():
                                              dw1 = rx_byte()
                                              dw2 = rx_byte()
                                          #                       Transmit Block
                                          def tx_block(b):
                                              for x in b:
                                                  tx_byte(x)
                                          #                       Transmit Byte
                                          def tx_byte(b):
                                                  return
                                              tx_data[tx_cnt] = b
                                              tx_cnt = tx_cnt + 1
                                                  tx_flush()
                                          #                       Transmit DWORD
                                          def tx_dword(dw):
                                          #                       Transmit Flush
                                          def tx_flush():
                                              if tx_cnt == 0:
                                                  return
                                              if not r:
                                                  raise Exception("Error transmitting in tx_flush")
                                              tx_cnt = 0
                                              # example:
                                              # <crlf>
                                              global http_size
                                              tx_string(s)
                                              if host_port != 80:
                                              tx_string(s)
                                              tx_string(s)
                                              tx_string(s)
                                              s = "\r\n"
                                              tx_string(s)
                                          #                       Transmit String
                                          def tx_string(s):
                                              for x in b:
                                                  tx_byte(x)
                                          #                       Transmit WORD
                                          def tx_word(w):
                                              tx_byte(w & 0xff)
                                            ruok4t @tlanier
                                            @tlanier Thanks, will download all parts and take a look.
                                            • 2 / 3
