gpy camera?
  • In my rpi days if I needed to grab the occasional still frame from a remote site it was as simple as plugging in a usb web cam, and uploading a 640x480 pic over 4G was no problem.
    Solutions for the gpy seem a bit scarce? https://forum.pycom.io/topic/5650/connecting-camera-to-fipy-new-findings-of-non-ee has opted for an idea that uses 2 different buses but that looks complicated. Is there an easy way to get a usb cam connected to a gpy via a usb-to-uart adapter or is the gpy uart not fast enough?
  • I am working with a Spinel 1.3MP WDR Serial JPEG Color Camera Module TTL/UART Output. I got most of photo working but I am not familiar with hex to jpg. I translate hex to the picture of my dog using https://codepen.io/abdhass/full/jdRNd.
    from machine import UART
    from machine import SD
    import gc
    import ubinascii
    is_sd_mounted = False
    uart = UART(1, baudrate=115200) #default baud of camera, this uses the UART_1 default pins for TXD and RXD (``P3`` and ``P4``)
    gc.collect()
    print(" ")
    print("Free Memory:")
    print(gc.mem_free())
    print(" ")
    LOG_PATH = '/sd'
    def mount_sd():
        global sd
        global is_sd_mounted
        try:    # try: again, we're preparing for a crash. If something goes wrong in the try: section, we'll jump to 'except Exception:' and do that instead of crashing.
            os.mount(sd, LOG_PATH)
            time.sleep(1)
            print("SD mounted OK")
            is_sd_mounted = True
        except Exception:   # Failed to mount SD
            print("ERROR: Can't mount SD card")
            sd = None
    def reset():
        uart.write(b'\x56\x00\x26\x00') #Send reset command
        time.sleep(4)
        recv=uart.read() # read up to 5 bytes
        print("Version:")
        print(recv)
        print(" ")
    def takephoto():
        uart.write(b'\x56\x00\x36\x01\x00') #Send take photo command
        time.sleep(4)
        print("Take Photo:")
        print(recv)
        print(" ")
    def changesize():
        uart.write(b'\x56\x00\x31\x05\x04\x01\x00\x19\x11') #Send take photo command
        time.sleep(4)
        print("Size:")
        print(recv)
        print(" ")
    def compress():
        uart.write(b'\x56\x00\x31\x05\x01\x01\x12\x04\x72') #Send take photo command
        time.sleep(4)
        print("Compression:")
        print(recv)
        print(" ")
    mount_sd()
    time.sleep(3)
    reset()
    changesize()
    compress()
    takephoto()
    uart.write(b'\x56\x00\x34\x01\x00') #Send get image length command
    time.sleep(2)
    print("READ IMAGE DATA LENGTH")
    print(recv)
    print("Image Size: "+str(int(ubinascii.hexlify(recv[5:9]),16)/1024)+" KB")
    print("READ IMAGE DATA")
    uart.write(b'\x56\x00\x32\x0C\x00\x0A\x00\x00\x00\x00')
    uart.write(recv[5:9])
    uart.write(b'\x00\xFF') #Send get image length command
    time.sleep(1)
    #count=0
    pic=ubinascii.hexlify(uart.read(500))
    time.sleep(2)
    while uart.any()>0:
        pic=pic+ubinascii.hexlify(uart.read(500))
        time.sleep(.01)
    #print(pic)
    #print(type(pic))
    uart.write(b'\x56\x00\x36\x01\x03') #STOP CAPTURE
    #print("uartany")
    #print(uart.any())
    pic=pic[10:-10]
    data = pic
    print(data)
    file='/sd/image122o23.txt'
    print(file)
    f = open(file, 'wb') # open for writing
    f.write(data)
    time.sleep(2)
    f.close()
    gc.collect()
    print(" ")
    if is_sd_mounted:
        try:
            os.unmount(LOG_PATH)
            print("SD unmounted")
        except Exception:
            print("Failed to unmount {}".format(LOG_PATH))
        print("Unmount SD not required")
  • @kjm Seeed’s VC0703-based serial cam has a protocol so simple that it shouldn’t take long to write a driver. Adafruit’s VC0706-based serial camera has CircuitPython drivers, I suppose that should be easy to port to micropython.
    I suspect performance may be quite lower than the other cams, though, and the cost higher.
    Remember that I2C and SPI can be shared (via addressing or chip select), though.
  • @grpatt I'm impressed and envious because the chances of me getting something that uses 2 busses to work are low. I don't understand why there isn't any uart based code for serial cams in micropython.
  • @kjm The most common camera for ESP32 projects and other MCUs seems to be the OV2640 mentioned in the link above. Note that the "raw" camera seems to have a pretty nasty interface, you probably want the Arducam SPI or some equivalent, which has SPI and I2C interfaces.
    There's a micropython driver for it, though it was targeted at the ESP8266 Arduino boards. I don't think it should be very difficult to adapt to a Pycom board. There's a long discussion here and it seems someone managed to get it to run on a GPy.
    Once you get things sorted it's just as simple as:
    import ov2640
    cam = ov2640.ov2640()
    nbytes = cam.capture_to_file("/image.jpg")
    From what I understand performance is pretty bad, but for a single picture it should work out OK I suppose.
  • @kjm
    No. I don't know if there is a standard for simple image download. Some serial cameras have features for private robotics or industrial usage. So they can detect/trace objects or QR codes and tell you their special data. So I guess you have to implement the download by your own.
    The adafruit and Pixy2 CMUCam5 have python examples. May be a start for you.
  • Do you know of a micropython lib that can tickle a serial webcam to regurgitate an image? I was hoping for something as easy as os.system('fswebcam -r 640x480 -S10 image.jpg') on the pi?
  • You can try to use an rs232 camera module.
1 out of 10
