gpy camera?
In my rpi days if I needed to grab the occasional still frame from a remote site it was as simple as plugging in a usb web cam, and uploading a 640x480 pic over 4G was no problem.
Solutions for the gpy seem a bit scarce? https://forum.pycom.io/topic/5650/connecting-camera-to-fipy-new-findings-of-non-ee has opted for an idea that uses 2 different buses but that looks complicated. Is there an easy way to get a usb cam connected to a gpy via a usb-to-uart adapter or is the gpy uart not fast enough?
https://forum.pycom.io/topic/6835/camera-uart-reading-pycom?_=1613190557153
I did get a better camera working.
I am working with a Spinel 1.3MP WDR Serial JPEG Color Camera Module TTL/UART Output. I got most of photo working but I am not familiar with hex to jpg. I translate hex to the picture of my dog using https://codepen.io/abdhass/full/jdRNd.
from machine import UART from machine import SD import os import time import gc import ubinascii is_sd_mounted = False uart = UART(1, baudrate=115200) #default baud of camera, this uses the UART_1 default pins for TXD and RXD (``P3`` and ``P4``) gc.collect() print(" ") print("Free Memory:") print(gc.mem_free()) print(" ") LOG_PATH = '/sd' def mount_sd(): global sd global is_sd_mounted try: # try: again, we're preparing for a crash. If something goes wrong in the try: section, we'll jump to 'except Exception:' and do that instead of crashing. os.mount(sd, LOG_PATH) time.sleep(1) print("SD mounted OK") is_sd_mounted = True except Exception: # Failed to mount SD print("ERROR: Can't mount SD card") sd = None def reset(): uart.write(b'\x56\x00\x26\x00') #Send reset command time.sleep(4) recv=uart.read() # read up to 5 bytes print("Version:") print(recv) print(" ") def takephoto(): uart.write(b'\x56\x00\x36\x01\x00') #Send take photo command time.sleep(4) recv=uart.read() # read up to 5 bytes print("Take Photo:") print(recv) print(" ") def changesize(): uart.write(b'\x56\x00\x31\x05\x04\x01\x00\x19\x11') #Send take photo command time.sleep(4) recv=uart.read() # read up to 5 bytes print("Size:") print(recv) print(" ") def compress(): uart.write(b'\x56\x00\x31\x05\x01\x01\x12\x04\x72') #Send take photo command time.sleep(4) recv=uart.read() # read up to 5 bytes print("Compression:") print(recv) print(" ") mount_sd() time.sleep(3) reset() changesize() compress() takephoto() uart.write(b'\x56\x00\x34\x01\x00') #Send get image length command time.sleep(2) print("READ IMAGE DATA LENGTH") recv=uart.read() # read up to 5 bytes print(recv) print("Image Size: "+str(int(ubinascii.hexlify(recv[5:9]),16)/1024)+" KB") print("READ IMAGE DATA") uart.write(b'\x56\x00\x32\x0C\x00\x0A\x00\x00\x00\x00') uart.write(recv[5:9]) uart.write(b'\x00\xFF') #Send get image length command time.sleep(1) #count=0 pic=ubinascii.hexlify(uart.read(500)) time.sleep(2) while uart.any()>0: pic=pic+ubinascii.hexlify(uart.read(500)) time.sleep(.01) #print(pic) #print(type(pic)) uart.write(b'\x56\x00\x36\x01\x03') #STOP CAPTURE #print("uartany") #print(uart.any()) pic=pic[10:-10] data = pic print(data) file='/sd/image122o23.txt' print(file) f = open(file, 'wb') # open for writing f.write(data) time.sleep(2) f.close() gc.collect() print(" ") print("Free Memory:") print(gc.mem_free()) if is_sd_mounted: try: os.unmount(LOG_PATH) print("SD unmounted") except Exception: print("Failed to unmount {}".format(LOG_PATH)) else: print("Unmount SD not required")
@kjm Seeed’s VC0703-based serial cam has a protocol so simple that it shouldn’t take long to write a driver. Adafruit’s VC0706-based serial camera has CircuitPython drivers, I suppose that should be easy to port to micropython.
I suspect performance may be quite lower than the other cams, though, and the cost higher.
Remember that I2C and SPI can be shared (via addressing or chip select), though.
@grpatt I'm impressed and envious because the chances of me getting something that uses 2 busses to work are low. I don't understand why there isn't any uart based code for serial cams in micropython.
I was able to get the Arducam working on the gpy.
https://github.com/grahamPatico/micropython-ov2640-Pycom?organization=grahamPatico&organization=grahamPatico
@kjm The most common camera for ESP32 projects and other MCUs seems to be the OV2640 mentioned in the link above. Note that the "raw" camera seems to have a pretty nasty interface, you probably want the Arducam SPI or some equivalent, which has SPI and I2C interfaces.
There's a micropython driver for it, though it was targeted at the ESP8266 Arduino boards. I don't think it should be very difficult to adapt to a Pycom board. There's a long discussion here and it seems someone managed to get it to run on a GPy.
Once you get things sorted it's just as simple as:
import ov2640 cam = ov2640.ov2640() nbytes = cam.capture_to_file("/image.jpg")
From what I understand performance is pretty bad, but for a single picture it should work out OK I suppose.
@kjm
No. I don't know if there is a standard for simple image download. Some serial cameras have features for private robotics or industrial usage. So they can detect/trace objects or QR codes and tell you their special data. So I guess you have to implement the download by your own.The adafruit and Pixy2 CMUCam5 have python examples. May be a start for you.
Do you know of a micropython lib that can tickle a serial webcam to regurgitate an image? I was hoping for something as easy as os.system('fswebcam -r 640x480 -S10 image.jpg') on the pi?
You can try to use an rs232 camera module.
