    [SOLVED] /v2/register-sigfox returning response: "registerSigfoxDevice is missing some arguments"
    Scheduled Pinned Locked Moved Pybytes IoT platform
    6 Posts 4 Posters 320 Views 4 Watching
      amkrup
      I've been trying to register my device so that I can use SigFox. Tried registering using Pycom Firmware Updater, PyBytes app and also tried to provision the device via USB running the pybytes.activate()-function.
      I although keep getting following error message when entering the activation token that I have in PyBytes:
      pybytes.activate("{MY_SUPERLONG_ACTIVATION_GOES_HERE}")
      Disconnecting current connection!
      self.__connection_status=0 | self.__network_type=None
      Already disconnected
      {'a': '{ID}', 'p': '{WLAN_PWD}', 's': '{WLAN_SSID}'}
      performing Wi-Fi activation
      Please wait while we try to connect to {WLAN_SSID}
      WLAN connected? True
      Wifi connection established... activating device!
      Activation response:
      {'mqttServiceAddress': 'mqtt.pybytes.pycom.io', 'userId': '{USER_ID}', 'network_preferences': 'wifi', 'wifi': {'ssid': '{WIFI_SSID}', 'password': '{WIFI_PWD'}, 'deviceToken': '{DEVICE_TOKEN}'}
      sigfox_registration: {'activationToken': '{ACTIVATION_TOKEN}', 'wmac': b'{WMAC}', 'smac': b'{SMAC}'}
      /v2/register-sigfox returned response: registerSigfoxDevice is missing some arguments
      PS. {}-field have real values in the real response.
      The /v2/register-sigfox -endpoint, is that a Pybyte/Pycom endpoint or SigFox? And what other arguments are supposed to be supplied?
      My FiPy device is currently running '1.20.2.rc3' but I've tried the same procedure after flashing FiPy-1.20.2.rc6.tar with the same result. Pycom Firmware updater only works using "Flash from local file" due to the update failing and showing an error message saying "Could not connect to the board" using following settings:
      Result:
        juse
        Exact same problem here with a FiPy
          jirkakrepl
          Hi, thanks for reporting this. We'll take a look
          software developer @ Pycom
            juse
            Now is working for me. I got a Sigfox ID and PAC
              amkrup @jirkakrepl
              @jirkakrepl Got my FiPy working now. Thanks!
                Louis CONVERT
                I'm trying to provision my new FiPy devices, and I get exactly the same error:
                [         70.320] [1073517588] /v2/register-sigfox returned response: registerSigfoxDevice is missing some arguments
                [         89.743] [1073517588] /v2/register-sigfox returned response: registerSigfoxDevice is missing some arguments
                [        109.000] [1073517588] /v2/register-sigfox returned response: registerSigfoxDevice is missing some arguments
                [        127.997] [1073517588] /v2/register-sigfox returned response: registerSigfoxDevice is missing some arguments
                [        147.543] [1073517588] /v2/register-sigfox returned response: registerSigfoxDevice is missing some arguments
                Unable to provision Sigfox! Please try again.
                Activation failed!
                I'm not using Sigfox nor Lora for the moment.
                Can you help me register correctly my devices on PyBytes?
                Thanks.
