While I've had success porting the prior micropython bitbanging onewire code (it was mostly changing the IO mode to open drain, and replacing pyb with machine), I just managed to wake up the RMT peripheral. It could conceivably run onewire with extremely precise timing without requiring much CPU. It should only require two RMT channels (one input, one output) mapped on the same GPIO, set to open drain. 6µs should be no problem at all considering I did 0.05µs for the WS2812 :)
The micropython onewire example code is at https://github.com/micropython/micropython/tree/master/drivers/onewire and my initial RMT access code is at https://github.com/lonetech/LoPy
By the way, I suspect the issue with P19 was the bug when accessing GPIO>=31. P19 is GPIO 32.
@LoneTech Would you mind sharing your port of the MicroPython library on the Lopy?It's too bad that this library is not portable across different MicroPython board...
Once I've confirmed that my DS18B20 works fine on the Lopy, I'll try to use the RMT instead of this bitbanging library :) -
@JF002 Sure. The patch and modules are in http://donkey.vernier.se/~yann/onewire.zip - sorry for taking so long.
@LoneTech have you got a working example with the Lopy/Wipy?
When I try to get it working on a Lopy I get a 'OneWire pin didn't go high' error when I run this piece of coded=DS18X20(Pin('G5')) -
I got it working now.
from machine import Pin from ds18x20 import DS18X20 d=DS18X20(Pin('G17', mode=Pin.OUT)) result=d.read_temps() print(result) -
@LoneTech Thank you! I'll give it a try as soon as I have time :)
@michal The temperature output(2525 = 25.25 degrees celsius) is as 4 digits output. The strange fact is that If I read the same sensor with raspberry pi or on Arduino I got the value as 5 digits. (eq 25437)
@Colateral I checked the code an conv_temp function shall be changed as following
def convert_temp(self, rom0, data): """ Convert the raw temperature data into degrees celsius and return as a fixed point with 2 decimal places. """ temp_lsb = data[0] temp_msb = data[1] if rom0 == 0x10: if temp_msb != 0: # convert negative number temp_read = temp_lsb >> 1 | 0x80 # truncate bit 0 by shifting, fill high bit with 1. temp_read = -((~temp_read + 1) & 0xff) # now convert from two's complement else: temp_read = temp_lsb >> 1 # truncate bit 0 by shifting count_remain = data[6] count_per_c = data[7] temp = 100 * temp_read - 25 + (count_per_c - count_remain) // count_per_c return temp elif rom0 == 0x28: temp = (temp_msb << 8 | temp_lsb) / 16 if (temp_msb & 0xf8) == 0xf8 : # for negative temperature temp -= 0x1000 return temp * 1000 else: assert False -
@madsdk P23/G10 has SD_CLK (pulse clock) required for bit banging.
@iber how did you import the ds18x20 module? I am getting the error:
Traceback (most recent call last): File "<stdin>", line 2, in <module> ImportError: no module named 'ds18x20'I have pasted the ds18x20.py into the folder my other py files and project is in. Is that not where it goes?
onewire.py and ds18x20.py are in my lib directory (available here per @LoneTech: http://donkey.vernier.se/~yann/onewire.zip)
This works for me:
import time from machine import Pin from ds18x20 import DS18X20 while True: d=DS18X20(Pin('P23', mode=Pin.OUT)) result=(d.read_temps()) if result: val=str(result[0]*1.8+32) else: val="-1" print(val) time.sleep(5) -
@dchappel i cant get this to work, i get
# code block Running Traceback (most recent call last): File "<stdin>", line 7, in <module> File "ds18x20.py", line 47, in __init__ File "onewire.py", line 246, in scan File "onewire.py", line 269, in _search File "onewire.py", line 90, in reset OSError: OneWire pin didn't go high > MicroPython v1.8.6-464-g0f843911 on 2017-02-17; LoPy with ESP32 Type "help()" for more information.what firmware are you using?
(sysname='LoPy', nodename='LoPy', release='1.5.1.b1', version='v1.8.6-423-g18444a2 on 2017-02-07', machine='LoPy with ESP32', lorawan='1.0.0')The pin not going high message sounds more like a wiring issue? Are you sure your wiring is correct and the pullup resistor bridges +3.3V and data? I had same issue and realized that I had sensor wire colors mixed up...
@dchappel
I'm very new to this (and LoPy and python) : where is your lib directory ?(I'll adapt to my own config). -
@Guizmolux
I do not know if you ask for this
but fully working examlpe code you can find in official docs
https://docs.pycom.io/pycom_esp32/pycom_esp32/tutorial/includes/onewire.html -
@livius
I get that. Copied the code into a onewire.py file. Where should I put it?
I've tried to execute before the main.py file and I always get the "cannot import name OneWire" or "DS18X20".
is the const() a problem in class OneWire ? -
but do you have upgraded firmware?
current is1.6.12.b1
what is yours? you can check firmware version byos.uname()if it is really old then go to
https://www.pycom.io/resources/next, is this how your onewire looks like?
https://github.com/pycom/pycom-libraries/blob/master/lib/onewire/onewire.pyput it in the same place where you have main.py or in lib subfolder
and then you can simply use it
import time from machine import Pin from onewire import DS18X20 from onewire import OneWire #DS18B20 data line connected to pin P10 ow = OneWire(Pin('P10')) temp = DS18X20(ow) while True: print(temp.read_temp_async()) time.sleep(1) temp.start_convertion() time.sleep(1) -
@livius
it didn't seem to work with Pymakr. The Atom IDE with Pymakr pluggin solution that was updated as a tutorial last week definitely helped.
It seems to be good now.
Thank you! -
@livius said in DS18B20 temperature sensor:
When I do exactly as you state here, and connect the temperature sensor to 3.3v, and with the 4,7k resistor between sig and 3.3v - I get this error:
File "main.py", line 22, in <module>
File "/flash/lib/onewire.py", line 190, in read_temp_async
IndexError: list index out of rangeI have latest firmware and atom plugin
EDIT: after checking that I have latest onewire from here https://github.com/pycom/pycom-libraries/blob/master/lib/onewire/onewire.py this error was gone. I then had to correct your spelling mistake in "convertion" and now it's working, but despite everything being hooked up correctly - it prints out "None"...
- what you got from (you must change P10 to pin you use):
ow = OneWire(Pin('P10')) ow.romsif nothing then test(double ow)
ow.ow.scan()- which sensor do you have exactly? woterproof or some different?
