    DS18B20 temperature sensor
    36 Posts 16 Posters 24.2k Views 15 Watching
      LoneTech @JF002
      @JF002 Sure. The patch and modules are in http://donkey.vernier.se/~yann/onewire.zip - sorry for taking so long.
      • I Offline
        iber
        @LoneTech have you got a working example with the Lopy/Wipy?
        When I try to get it working on a Lopy I get a 'OneWire pin didn't go high' error when I run this piece of code d=DS18X20(Pin('G5'))
        • I Offline
          iber
          I got it working now.
          from machine import Pin
          from ds18x20 import DS18X20
          d=DS18X20(Pin('G17', mode=Pin.OUT))
          result=d.read_temps()
          print(result)
            JF002 @LoneTech
            @LoneTech Thank you! I'll give it a try as soon as I have time :)
              Colateral @michal
              @michal The temperature output(2525 = 25.25 degrees celsius) is as 4 digits output. The strange fact is that If I read the same sensor with raspberry pi or on Arduino I got the value as 5 digits. (eq 25437)
                Colateral @Colateral
                @Colateral I checked the code an conv_temp function shall be changed as following
                def convert_temp(self, rom0, data):
                    Convert the raw temperature data into degrees celsius and return as a fixed point with 2 decimal places.
                    temp_lsb = data[0]
                    temp_msb = data[1]
                    if rom0 == 0x10:
                        if temp_msb != 0:
                            # convert negative number
                            temp_read = temp_lsb >> 1 | 0x80  # truncate bit 0 by shifting, fill high bit with 1.
                            temp_read = -((~temp_read + 1) & 0xff) # now convert from two's complement
                            temp_read = temp_lsb >> 1  # truncate bit 0 by shifting
                        count_remain = data[6]
                        count_per_c = data[7]
                        temp = 100 * temp_read - 25 + (count_per_c - count_remain) // count_per_c
                        return temp
                    elif rom0 == 0x28:
                        temp = (temp_msb << 8 | temp_lsb) / 16
                        if (temp_msb & 0xf8) == 0xf8 :  # for negative temperature
                           temp -= 0x1000
                        return temp * 1000
                        assert False
                  Colateral @madsdk
                  @madsdk P23/G10 has SD_CLK (pulse clock) required for bit banging.
                    sk @iber
                    @iber how did you import the ds18x20 module? I am getting the error:
                    File "<stdin>", line 2, in <module>
                    ImportError: no module named 'ds18x20'
                    I have pasted the ds18x20.py into the folder my other py files and project is in. Is that not where it goes?
                      dchappel @sk
                      @sk
                      onewire.py and ds18x20.py are in my lib directory (available here per @LoneTech: http://donkey.vernier.se/~yann/onewire.zip)
                      This works for me:
                          d=DS18X20(Pin('P23', mode=Pin.OUT))
                          result=(d.read_temps())
                          if result:
                              val=str(result[0]*1.8+32)
                              val="-1"
                          print(val)
                          time.sleep(5)
                      D G J 3 Replies Last reply Reply Quote 1
                        DonHugo @dchappel
                        @dchappel i cant get this to work, i get
                        # code block
                        Running
                          File "<stdin>", line 7, in <module>
                          File "ds18x20.py", line 47, in __init__
                          File "onewire.py", line 246, in scan
                          File "onewire.py", line 269, in _search
                          File "onewire.py", line 90, in reset
                        OSError: OneWire pin didn't go high
                        MicroPython v1.8.6-464-g0f843911 on 2017-02-17; LoPy with ESP32
                        what firmware are you using?
                          dchappel @DonHugo
                          @DonHugo
                          (sysname='LoPy', nodename='LoPy', release='1.5.1.b1', version='v1.8.6-423-g18444a2 on 2017-02-07', machine='LoPy with ESP32', lorawan='1.0.0')
                          The pin not going high message sounds more like a wiring issue? Are you sure your wiring is correct and the pullup resistor bridges +3.3V and data? I had same issue and realized that I had sensor wire colors mixed up...
                            Guizmolux @dchappel
                            @dchappel
                            I'm very new to this (and LoPy and python) : where is your lib directory ?(I'll adapt to my own config).
                              livius @Guizmolux
                              @Guizmolux
                              I do not know if you ask for this
                              but fully working examlpe code you can find in official docs
                              https://docs.pycom.io/pycom_esp32/pycom_esp32/tutorial/includes/onewire.html
                                Guizmolux @livius
                                @livius
                                I get that. Copied the code into a onewire.py file. Where should I put it?
                                I've tried to execute before the main.py file and I always get the "cannot import name OneWire" or "DS18X20".
                                is the const() a problem in class OneWire ?
                                  livius @Guizmolux
                                  @Guizmolux
                                  but do you have upgraded firmware?
                                  current is 1.6.12.b1
                                  what is yours? you can check firmware version by
                                  os.uname()
                                  if it is really old then go to
                                  https://www.pycom.io/resources/
                                  next, is this how your onewire looks like?
                                  https://github.com/pycom/pycom-libraries/blob/master/lib/onewire/onewire.py
                                  put it in the same place where you have main.py or in lib subfolder
                                  and then you can simply use it
                                  from onewire import DS18X20
                                  from onewire import OneWire
                                  #DS18B20 data line connected to pin P10
                                  ow = OneWire(Pin('P10'))
                                  temp = DS18X20(ow)
                                      print(temp.read_temp_async())
                                      time.sleep(1)
                                      temp.start_convertion()
                                      time.sleep(1)
                                  G sorenS 2 Replies Last reply Reply Quote 0
                                    Guizmolux @livius
                                    @livius
                                    it didn't seem to work with Pymakr. The Atom IDE with Pymakr pluggin solution that was updated as a tutorial last week definitely helped.
                                    It seems to be good now.
                                    Thank you!
                                    • sorenS Offline
                                      soren @livius
                                      @livius said in DS18B20 temperature sensor:
                                      When I do exactly as you state here, and connect the temperature sensor to 3.3v, and with the 4,7k resistor between sig and 3.3v - I get this error:
                                      File "main.py", line 22, in <module>
                                      File "/flash/lib/onewire.py", line 190, in read_temp_async
                                      IndexError: list index out of range
                                      I have latest firmware and atom plugin
                                      EDIT: after checking that I have latest onewire from here https://github.com/pycom/pycom-libraries/blob/master/lib/onewire/onewire.py this error was gone. I then had to correct your spelling mistake in "convertion" and now it's working, but despite everything being hooked up correctly - it prints out "None"...
                                        livius @soren
                                        @soren
                                        1. what you got from (you must change P10 to pin you use):
                                        ow.roms
                                        if nothing then test(double ow)
                                        ow.ow.scan()
                                        1. which sensor do you have exactly? woterproof or some different?
                                          jimpower @dchappel
                                          @dchappel I followed your main.py with both onewire.py and ds18x20.py in my lib, this works for the first temp reading, every following temp reading doesn't change from the first. I moved the sensor into the fridge and then freezer and the readings styed the same. Once I reset the device it will bring the new reading but only again for the first reading. Did you find this with yours?
                                            livius @jimpower
                                            @jimpower
                                            better look here
                                            https://github.com/pycom/pycom-libraries/tree/master/examples/DS18X20
                                            • 2 / 2
