    pymakrplugincommunitydev rel
    68 Posts 31 Posters 45.1k Views 30 Watching
      bucknall @jomifo
      @jomifo Thanks for letting me know - would you mind dropping me a DM or email pointing to what is breaking with the new builds? I'll see if we can pinpoint the problem.
      Point noted about Vim, I'd definitely be interested in that too haha! I think unfortunately that will fall behind the four tools I highlight as we need to prioritise but I would also love to maybe one day see a Vim plugin!
      Developer Evangelist - Pycom
        jasonriedy
        As an Emacs user, file transfer and console access are fine. I'd rather have deep sleep on the LoPy...
          Pete @bucknall
          @bucknall said in Pymakr... Time of Death : 09/02... ;-):
          We aren't reallocating resources to put work on these plugins in front of developing the device firmware, it's simply moving the effort from Pymakr over to these new plugins.
          If the Pymakr developers don't have the right skill-set for the firmware, or if the nature of the firmware work or its development process means they'd just be tripping over each other with the existing folks, then fine. Otherwise, let's have 'em on @jasonriedy's DeepSleep, or whatever causes me to be kicked out the REPL when I try to inspect the WLAN config :-)
          Pete
            MaSePreetz Pybytes Beta
            @bucknall
            Hi Alex,
            in my opinion dropping PyMakr makes sense.
            But i would like to point out that the possibility to get the REPL on the console inside the IDE
            is very important.
            I am new to Python and am struggling with the syntax (doing Java and JavaScript for my living). The REPL
            gives me the opportunity to test my code while developing with direct feedback and print() debugging.
            This is really beneficial.
            In addition i witnessed that within our company we setup a LoPy within minutes for a simple demo
            by using PyMakr, your demo projects and feedback on the REPL loop.
            So this REPL integration is crucial (at least for starters, not so much for experts).
            The same applies for a simple file transfer/sync mechanism.
            I know that it is possible to achieve all this with several other tools in combination, but this is
            rather old-fashioned. (i worked with and appreciated emacs, telnet, the command line, but in
            my spare time i love integrated IDEs as a one-stop shop!)
            I am eager to see your plugins,
            Marc
              Pete @MaSePreetz
              @MaSePreetz said in Pymakr... Time of Death : 09/02... ;-):
              is very important.
              Having the REPL is great, and impressive on such a constrained device. But does it really make a difference to your dev workflow whether it's in the same window as your editor or in a terminal next to it?
              Or, if it must be in the same window, Atom at least has a few plugins that can do that:
              https://atom.io/packages/terminal-plus
              https://atom.io/packages/atom-terminal-panel
              and probably others.
              Pete
                mo-seph
                I'm looking at the LoPy for educational use, and having everything all together in Pymakr was quite useful - it becomes much harder if we have to support student's individual IDEs and strange setups. It's probably manageable though, if we come up with a single, cross platform supported solution.
                The thing that is really tricky, though, is the FTP uploads, as they need to be done over the LoPy's wifi, and in a room with 20 LoPys that becomes really challenging. Is anything planned for doing file uploads over the USB serial?
                  bucknall @mo-seph
                  @mo-seph What we will likely do is have a pre-packaged IDE (likely Atom) that already has everything installed after you download it. This way you can just direct your students to navigate towards our software page and download everything you need pre-installed.
                  We're working on file upload over USB Serial, this is on the roadmap. In addition to this, the SSID that each device broadcasts will be written on the sticker on top of the LoPy (as well as the other devices) for the next production run of devices.
                    mo-seph @bucknall
                    @bucknall Great! BTW - I have some feedback and suggestions for improvement on the boards. Where's the best place to send it?
                      bucknall @mo-seph
                      @mo-seph Is it specifically related to the hardware or firmware? I'm still working on streamlining the forum categories so might need a new one!
                      • E Offline
                        exquisitus
                        how come are these 4 the "most popular"? you gotta be kidding me...
                        eclipse and idea?
                          mo-seph @bucknall
                          @bucknall hardware.
                            bucknall @mo-seph
                            @mo-seph I created this just for you https://forum.pycom.io/category/30/hardware ;-) Hope we can help resolve this!
                            • H Offline
                              happyday
                              This is the way to go. I use PyDev within the Eclipse environment. Do you see a plug in developed for this? (Thank you).
                                Bajoja
                                When a beta?
                                Anxious for a beta because Pymakr does not work here.
                                  TravisT
                                  I tend to like to plug in my board when doing a lot of development. So my tools are Atom and rshell. This is partly because I write on multiple processors and USB is the simple common denominator.
                                  https://github.com/dhylands/rshell
                                    juriw
                                    Great news! We have had some problems with Pymakr and are looking forward to an Atom plugin! Where to look for the release of Atom plugin? Have tried to find the project on Github without any luck.
                                      bucknall @juriw
                                      Hi @juriw,
                                      It is still under development but should be coming in the next month or so! I'll make sure to keep you updated!
                                        juriw @bucknall
                                        @bucknall Sweet! :) Looking forward to working with it.
                                        • I Offline
                                          Innocenzo @bucknall
                                          @bucknall Very good news. There are some release dates?
                                          • F Offline
                                            fos @danielm
                                            @danielm
                                            Very interesting news. It is moving in a positive direction. Maybe you could update your "Getting Started" documentation.
                                            I am using the WiPy 2.0 via telnet and a simple editor.
                                            Are there any plans to support WingIDE?
                                            Thank you,
                                            v/r
                                            Jeff
                                            B P 2 Replies Last reply Reply Quote 0
                                            • 2 / 4
