    pymakrplugincommunitydev rel
    68 Posts 31 Posters 44.0k Views 30 Watching
      MaSePreetz Pybytes Beta
      @bucknall
      Hi Alex,
      in my opinion dropping PyMakr makes sense.
      But i would like to point out that the possibility to get the REPL on the console inside the IDE
      is very important.
      I am new to Python and am struggling with the syntax (doing Java and JavaScript for my living). The REPL
      gives me the opportunity to test my code while developing with direct feedback and print() debugging.
      This is really beneficial.
      In addition i witnessed that within our company we setup a LoPy within minutes for a simple demo
      by using PyMakr, your demo projects and feedback on the REPL loop.
      So this REPL integration is crucial (at least for starters, not so much for experts).
      The same applies for a simple file transfer/sync mechanism.
      I know that it is possible to achieve all this with several other tools in combination, but this is
      rather old-fashioned. (i worked with and appreciated emacs, telnet, the command line, but in
      my spare time i love integrated IDEs as a one-stop shop!)
      I am eager to see your plugins,
      Marc
        Pete @MaSePreetz
        @MaSePreetz said in Pymakr... Time of Death : 09/02... ;-):
        is very important.
        Having the REPL is great, and impressive on such a constrained device. But does it really make a difference to your dev workflow whether it's in the same window as your editor or in a terminal next to it?
        Or, if it must be in the same window, Atom at least has a few plugins that can do that:
        https://atom.io/packages/terminal-plus
        https://atom.io/packages/atom-terminal-panel
        and probably others.
        Pete
          mo-seph
          I'm looking at the LoPy for educational use, and having everything all together in Pymakr was quite useful - it becomes much harder if we have to support student's individual IDEs and strange setups. It's probably manageable though, if we come up with a single, cross platform supported solution.
          The thing that is really tricky, though, is the FTP uploads, as they need to be done over the LoPy's wifi, and in a room with 20 LoPys that becomes really challenging. Is anything planned for doing file uploads over the USB serial?
            bucknall @mo-seph
            @mo-seph What we will likely do is have a pre-packaged IDE (likely Atom) that already has everything installed after you download it. This way you can just direct your students to navigate towards our software page and download everything you need pre-installed.
            We're working on file upload over USB Serial, this is on the roadmap. In addition to this, the SSID that each device broadcasts will be written on the sticker on top of the LoPy (as well as the other devices) for the next production run of devices.
            Developer Evangelist - Pycom
              mo-seph @bucknall
              @bucknall Great! BTW - I have some feedback and suggestions for improvement on the boards. Where's the best place to send it?
                bucknall @mo-seph
                @mo-seph Is it specifically related to the hardware or firmware? I'm still working on streamlining the forum categories so might need a new one!
                • E Offline
                  exquisitus
                  how come are these 4 the "most popular"? you gotta be kidding me...
                  eclipse and idea?
                    mo-seph @bucknall
                    @bucknall hardware.
                      bucknall @mo-seph
                      @mo-seph I created this just for you https://forum.pycom.io/category/30/hardware ;-) Hope we can help resolve this!
                      • H Offline
                        happyday
                        This is the way to go. I use PyDev within the Eclipse environment. Do you see a plug in developed for this? (Thank you).
                          Bajoja
                          When a beta?
                          Anxious for a beta because Pymakr does not work here.
                            TravisT
                            I tend to like to plug in my board when doing a lot of development. So my tools are Atom and rshell. This is partly because I write on multiple processors and USB is the simple common denominator.
                            https://github.com/dhylands/rshell
                              juriw
                              Great news! We have had some problems with Pymakr and are looking forward to an Atom plugin! Where to look for the release of Atom plugin? Have tried to find the project on Github without any luck.
                                bucknall @juriw
                                Hi @juriw,
                                It is still under development but should be coming in the next month or so! I'll make sure to keep you updated!
                                  juriw @bucknall
                                  @bucknall Sweet! :) Looking forward to working with it.
                                  • I Offline
                                    Innocenzo @bucknall
                                    @bucknall Very good news. There are some release dates?
                                    • F Offline
                                      fos @danielm
                                      @danielm
                                      Very interesting news. It is moving in a positive direction. Maybe you could update your "Getting Started" documentation.
                                      I am using the WiPy 2.0 via telnet and a simple editor.
                                      Are there any plans to support WingIDE?
                                      Thank you,
                                      v/r
                                      Jeff
                                      B P 2 Replies Last reply Reply Quote 0
                                        bucknall @fos
                                        Hi @fos,
                                        We're just waiting for the first builds of the new plugins to arrive - however, we will put up a notice about Pymakr in the documentation to reflect this!
                                        Right now we're looking to start with these 4 IDEs/Editors but we shall see going forward!
                                        Will keep you updated!
                                        Alex
                                        F 1 Reply Last reply Reply Quote 1
                                          juriw
                                          @bucknall Have you thought about talking with Zerynth (https://www.zerynth.com/) about them integrating your boards? I think their IDE and environment looks really sleek!
                                          • N Offline
                                            nextcloud
                                            Hi Alex,
                                            Do you plan to support for editors open source software? The editors mentioned are either proprietary closed source software or in case of Atom editor - raise significant privacy concerns. From Wikipedia: 'Atom reports usage information to Google Analytics, including a unique UUID v4 random identifier.'
                                            Thanks.
                                            B M 2 Replies Last reply Reply Quote 1
                                            • 2 / 4
