    Firmware upgrade troubleshooting - checklist/procedure
    lopy
    24 Posts 13 Posters 16.6k Views 14 Watching
      dClaus
      For Lopy "Connecting ......... Failure !"
      see post https://forum.pycom.io/post/4518
      between 3 and 4 : use the RESET buttom on the Lopy
        rskoniec @dClaus
        @dClaus One more time - thanx! It's already updated. :)
          mmarkvoort @rskoniec
          @rskoniec
          Update using Expansion Board USB.
            bucknall @jmarcelino
            @jmarcelino This is going into Docs with the next update :)
            Developer Evangelist - Pycom
            R 1 Reply Last reply Reply Quote 3
              rskoniec @bucknall
              @bucknall said in Firmware upgrade troubleshooting - checklist:
              Nice! :)
                rskoniec @mmarkvoort
                @mmarkvoort said in Firmware upgrade troubleshooting - checklist:
                @rskoniec
                OK. In a free time (I hope this weekend) I'll grab a fresh install Windows machine and try to investigate FTDI driver issue.
                • FridaF Offline
                  Frida
                  On linux remember to update/place a file in: /etc/udev/rules.d
                  I have these in my: 45-espruino.rules, then you don't have to use sudo su
                  # To go in /etc/udev/rules.d/
                  # Makes Espruino's serial port accessible to non-SU users, and stops the Modem Manager trying to enumerate it
                  ATTRS{idProduct}=="5740", ATTRS{idVendor}=="0483", ENV{ID_MM_DEVICE_IGNORE}="1", MODE="0666", GROUP="plugdev"
                  # Nordic kits
                  ATTRS{idProduct}=="1015", ATTRS{idVendor}=="1366", ENV{ID_MM_DEVICE_IGNORE}="1", MODE="0666", GROUP="plugdev"
                  # Microbit
                  ATTRS{idProduct}=="0204", ATTRS{idVendor}=="0d28", ENV{ID_MM_DEVICE_IGNORE}="1", MODE="0666", GROUP="plugdev"
                  # Propeller
                  ATTRS{idProduct}=="6001", ATTRS{idVendor}=="0403", ENV{ID_MM_DEVICE_IGNORE}="1", MODE="0666", GROUP="plugdev"
                  # Pycom
                  ATTRS{idProduct}=="6015", ATTRS{idVendor}=="0403", ENV{ID_MM_DEVICE_IGNORE}="1", MODE="0666", GROUP="plugdev"
                    rskoniec @Frida
                    @Frida Thanx for sharing! Updated!
                      @mmarkvoort said in Firmware upgrade troubleshooting - checklist/procedure:
                      I don't know if it is relevant but when i wanted to update/connect through USB I had to install the USB driver manually. Mine called FTDI driver where VCP or D2XX are types of drivers. With one of the two it said it was installed but still i coudn't update/connect.
                      OK, I took my notebook with Windows 10 Pro x64 with internet access and plug LoPy on Expansion Board to it for the very first time.
                      Here is Device Manager just after connection:
                      After about 30 seconds Windows Auto Update mechanism has done all the job:
                      As you can see it is pretty straightforward - at least on Windows 10.
                      What OS are you using?
                        @rskoniec
                        Aah thanks for the update. Really fast!!
                        Now that u mention that windows installs the update automatic, I remember that I disabled windows update on my windows 10... that explans a lot! How stupid...
                        Sorry for wasting your time, but thanks for the fast answer and for trying it out.
                          maamar @rskoniec
                          @rskoniec thank you
                          I did my updated
                            @mmarkvoort @maamar You welcome. :o)
                            • Y Offline
                              yunying
                              Thank a lot.
                              Reply just for feedback.
                              Make sure your jumper at "TX"
                                colinza
                                I had issues trying to update my wipy 2.0 with a standard TTL serial programmer I use for Arduino. For some reason the low baud rate update in the software selects 38400 but the WiPy sold with old broken firmware has it set to 115200 which isn't even an option through the firmware update tool.
                                To change this you can edit C:\Program Files (x86)\Pycom\Pycom Firmware Update\Upgrader\bin\updater.py and set "SLOW_BAUD_RATE=115200". Then the firmware updater works just fine.
                                  daniel 0
                                  One should also check that all of the jumpers have tight connections. I couldn't get communication to work with my expansion board until I replaced the jumpers provided with new ones as the originals were quite loose.
                                  • philwilkinsonP Offline
                                    philwilkinson
                                    I stress the need to reset LoPy boards after they have been connected to pc by data USB cable, and before you try to run the upgrade....
                                    • on4aaO Offline
                                      on4aa
                                      Unfortunately, this is currently not working for upgrading a module through either the Pysense or Pytrack boards using any GNU/Linux distribution.
