    New firmware release, version 1.6.4.b1
    lopywipyfirmwaresipy
    26 Posts 9 Posters 10.8k Views 9 Watching
      lars
      I just updated my newly bought WiPy 2.0 to this firmware version with the Pycom updater. After reset I get a boot loop with the following messages via serial connection:[0_1488012601074_core_dump.txt](Uploading 100%)
      Resetting the firmware via safe mode does not work. Also trying to reinstall the firmware update leads to the same result. Any help?
        livius @lars
        @lars
        did you removed wire (G23-GND) after sucesfull upgrade?
          jmarcelino @zmrzli
          @zmrzli
          Your BLE advertising data is invalid according to the Bluetooth spec. The first octet is 1 so you're specifying you are sending one byte for that unit. That's exactly what you're getting :-)
          Let's move this discussion to your original post https://forum.pycom.io/topic/723/bluetooth-advertising-data
            lars @livius
            @livius yes I removed the G23-GND wire. I tried serveral disconnects to power and only 3v3 and GND plus plus P0,P1 for UART were connected. Even without uart there is no wifi AP available any more, as was before the update.
            For safe mode I tried 3v3-p12 for as long as the most rapid flashing of the orange led.
              jmarcelino @lars
              @lars
              could you post the serial connection messages again, either pasting here or somewhere like pastebin.com. It seems they didn't show on your other post
                lars @jmarcelino
                @jmarcelino You are right of course. There was a message, that I didn't have the rights to upload a file here. Here is the pastbin: http://pastebin.com/3RaMdeJ2
                  @lars it might be that there's a conflict with the NV storage area on your WiPy and the current firmware. I have just updated the firmware package online in order to erase that area before applying the new firmware. Could you please try the update again and let me know? Thanks!
                    Pete
                    By the way, I do want to thank whoever fixed the OSX GUI firmware updater so that it 1) shows some of the output from the underlying tools, and more importantly 2) knows about pycom.io's TLS certificate. That made my messing about above that little bit easier :-)
                    Pete
                      lars @daniel
                      @daniel although pycom does still report the same version number 1.6.4.b1 on update I hope, that I got the new version. The behavior is similar but the serial output is slightly different: http://pastebin.com/EN30c4Nk
                      Thank you all very much for your quick responses!
                        rdixey
                          livius @daniel
                          @daniel
                          I see that some timings/stability improved in pin.
                          Now i am able read samsung tv codes without any problem from python code without need of C function as previously :)
                          I tested this i suppose in many previous versions (last tested lower than 1.5) and it was not stable enought but now it work :)
                          • 2 / 2
