    SigFox Error
    sipysigfox
    16 Posts 4 Posters 4.8k Views 4 Watching
      saprize
      os.uname()
      (sysname='SiPy', nodename='SiPy', release='1.0.0.b1', version='4fb4f54 on 2016-12-15', machine='SiPy with ESP32')
      I Cant get the Update to work. i only have a CP21xx Serial to USB converter und no exp Board. and the update always fails
        michal.zykov @saprize
        Hi @saprize,
        IMHO this is definitely firmware issue. You should upgrade to the most recent one.
        Is there anybody out there who could confirm it?
        Mike
          saprize
          when i run this code in the main
          main.py -- put your code here!
          from network import Sigfox
          import binascii
          initalise Sigfox for RCZ1 (You may need a different RCZ Region)
          sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ1)
          print Sigfox Device ID
          print(binascii.hexlify(sigfox.id()))
          print Sigfox PAC number
          print(binascii.hexlify(sigfox.pac()))
          i get this:
          File "main.py", line 9, in <module>
          AttributeError: 'Sigfox' object has no attribute 'id'
          MicroPython 4fb4f54 on 2016-12-15; SiPy with ESP32
          M J 2 Replies Last reply Reply Quote 0
            Hi @saprize,
            As I mentioned, this seems to be firmware issue. Check this out:
            • https://forum.pycom.io/topic/624/new-firmware-release-version-1-5-1-b1-supporting-the-sipy
            So, you should upgrade firmware to the most recent one to get your SiPy to the fully functional state.
            Mike
              jmarcelino @saprize
              @saprize
              You're running very old firmware when Sigfox wasn't even activated. Update your board first by following the "Firmware Update" links at https://www.pycom.io/resources/
                saprize
                This makes no sence. Ich can connect via Serialport. But when ich do the 23 to G thing an run the Updater it always fails. This cant be an Connection issue. pymkr works fine user my CP21xx serial device. ??
                  Hi @saprize,
                  Based on your information there are two issues.
                  Issue No .1
                  Sigfox library does not work properly because of your obsolete firmware.
                  Solution: Upgrade firmware to the most recent one.
                  Issue No. 2
                  You are not able to upgrade your firmware. OK - can we get any details? What is the error message? Can you take a print-screen?
                  Mike
                    saprize
                    There ist no Log or no futher info anywhere its just states ![0_1489673278628_Unbenannt.PNG](Uploading 100%) this.
                    ![0_1489673676801_Unbenannt.jpg](Uploading 100%)
                      Hi @saprize,
                      Thank yoU! How do you know that the firmware upgrade fails?
                      Mike
                        jmarcelino @saprize
                        @saprize
                        Did you reset/power cycle the board after connecting GND-23?
                        Have you closed other apps accessing the port, e.g Pymakr?
                          saprize
                            saprize @michal.zykov
                            @michal.zykov got to wait 600 sec. till ich can post again....
                              rskoniec
                              @saprize Check this:
                              @rskoniec said in Firmware upgrade Serial port to use unavailable:
                              @Migueloribe Did you look here? https://forum.pycom.io/topic/763/firmware-upgrade-troubleshooting-checklist-procedure
                              Do you see any change in a Device Manager when you're connecting/unconnecting USB cable with Expansion Board?
                              What version of Windows are you using?
                                saprize @jmarcelino
                                @jmarcelino There u go the WIFI Autoconnect was still on !!!!! Now it works. Thank you guys !!!!!!!
