    Firmware upgrade troubleshooting - checklist/procedure
    lopy
    24 Posts 13 Posters 16.8k Views 14 Watching
    • R Offline
      rskoniec
      I've noticed that problems with xPy's firmware upgrade is quite regular issue on the forum, so maybe this kind of checklist/procedure would be helpful:
      Checklist:
      0. Check whether your PC has access to the Internet, because the firmware image is retrieved on-the-fly during update procedure.
      1. Make sure you are using full communication USB cable (4-wire) not just charging USB cable (2-wire).
      2. Check if xPy board is fitting Expansion Board in right position. For example: LoPy RGB LED should be above Expansion Board microUSB port.
      3. What kind of G23-GND connection is used? Male-male breadboard connector or just ordinary wire? The first one is preffered, I've experienced problems with UTP wire connection (was unstable causing connection errors).
      4. It's a good habit that G23-GND cross-wire connection should be the only one on the Expansion Board. Without Expansion Board make sure you have nothing connected to the xPy board other than the serial, power and GND-G23 connection.
      5. Uncheck "fast connection" option in f/w updater tool is helpful.
      6. Have a look at the jumpers on the Expansion Board (especially RX/TX). Generally they should be all in place (EB+WiPy picture below - borrowed from @bucknall).
      Upgrade procedure:
      1. Unconnect (USB) xPy board from PC.
      2. Connect wire G23+GND.
      3. Connect the xPy board (USB) to PC by data USB cable.
      4. Use the RESET button on the xPy board. (issue confirmed for LoPy, not necessary for the WiPy2)
      5. Run the Update.
      6. After sucessfull update unconnect the xPy board (USB) from PC.
      7. Remove G23+GND wire.
      8. Connect the xPy board (USB) to PC.
      9. Check f/w release with os.uname() command.
      Linux Tips:
      1. From @Frida - Remember to update/place a file in: /etc/udev/rules.d
        I have these in my: 45-espruino.rules, then you don't have to use sudo su
      # To go in /etc/udev/rules.d/
      # Makes Espruino's serial port accessible to non-SU users, and stops the Modem Manager trying to enumerate it
      ATTRS{idProduct}=="5740", ATTRS{idVendor}=="0483", ENV{ID_MM_DEVICE_IGNORE}="1", MODE="0666", GROUP="plugdev"
      # Nordic kits
      ATTRS{idProduct}=="1015", ATTRS{idVendor}=="1366", ENV{ID_MM_DEVICE_IGNORE}="1", MODE="0666", GROUP="plugdev"
      # Microbit
      ATTRS{idProduct}=="0204", ATTRS{idVendor}=="0d28", ENV{ID_MM_DEVICE_IGNORE}="1", MODE="0666", GROUP="plugdev"
      # Propeller
      ATTRS{idProduct}=="6001", ATTRS{idVendor}=="0403", ENV{ID_MM_DEVICE_IGNORE}="1", MODE="0666", GROUP="plugdev"
      # Pycom
      ATTRS{idProduct}=="6015", ATTRS{idVendor}=="0403", ENV{ID_MM_DEVICE_IGNORE}="1", MODE="0666", GROUP="plugdev"
      Maybe I've missed something, so feel free to join in expanding this checklist and/or procedure. :o)
      M L M 3 Replies Last reply Reply Quote 5
        jmarcelino
        Great list! Thanks for making it, definitely should go into the documention.
        I'd add making sure you have nothing connected to the board other than the serial, power and GND-G23 connection.
        In particular disconnect anything on the strapping pins:
        G16 / P9 • MTDI/GPIO12: internal pull-down
        G15 / P8 • GPIO2: internal pull-down
        G24 / P3 • GPIO4: internal pull-down
        G11 / P4 • MTDO/GPIO15: internal pull-up
        G12 / P5 • GPIO5: internal pull-up
        Source: https://espressif.com/sites/default/files/documentation/esp32_datasheet_en.pdf#page16
        R B 2 Replies Last reply Reply Quote 2
        • R Offline
          rskoniec @jmarcelino
          @jmarcelino said in Firmware upgrade troubleshooting - checklist:
          Point 4 added. :)
          • M Offline
            mmarkvoort @rskoniec
            @rskoniec
            Very good list, certainly useful for beginners like me!
            I don't know if it is relevant but when i wanted to update/connect through USB I had to install the USB driver manually. Mine called FTDI driver where VCP or D2XX are types of drivers. With one of the two it said it was installed but still i coudn't update/connect.
            R 2 Replies Last reply Reply Quote 0
              livius @rskoniec
              @rskoniec
              you can somehow merge this post:
              https://forum.pycom.io/post/2655
              • R Offline
                rskoniec @livius
                @livius said in Firmware upgrade troubleshooting - checklist:
                @rskoniec
                Good tip! Done! :)
                • R Offline
                  rskoniec @mmarkvoort
                  @mmarkvoort said in Firmware upgrade troubleshooting - checklist:
                  But you were trying to update using Expansion Board USB or xPy board + USB2TTL serial converter?
                    dClaus
                    For Lopy "Connecting ......... Failure !"
                    see post https://forum.pycom.io/post/4518
                    between 3 and 4 : use the RESET buttom on the Lopy
                    • R Offline
                      rskoniec @dClaus
                      @dClaus One more time - thanx! It's already updated. :)
                      • M Offline
                        @rskoniec
                        Update using Expansion Board USB.
                        • B Offline
                          bucknall @jmarcelino
                          @jmarcelino This is going into Docs with the next update :)
                          Developer Evangelist - Pycom
                          R 1 Reply Last reply Reply Quote 3
                          • R Offline
                            rskoniec @bucknall
                            @bucknall said in Firmware upgrade troubleshooting - checklist:
                            Nice! :)
                            • R Offline
                              @rskoniec
                              OK. In a free time (I hope this weekend) I'll grab a fresh install Windows machine and try to investigate FTDI driver issue.
                              • FridaF Offline
                                Frida
                                On linux remember to update/place a file in: /etc/udev/rules.d
                                # Nordic kits
                                # Microbit
                                # Propeller
                                # Pycom
                                • R Offline
                                  rskoniec @Frida
                                  @Frida Thanx for sharing! Updated!
                                  • R Offline
                                    @mmarkvoort said in Firmware upgrade troubleshooting - checklist/procedure:
                                    OK, I took my notebook with Windows 10 Pro x64 with internet access and plug LoPy on Expansion Board to it for the very first time.
                                    Here is Device Manager just after connection:
                                    After about 30 seconds Windows Auto Update mechanism has done all the job:
                                    As you can see it is pretty straightforward - at least on Windows 10.
                                    What OS are you using?
                                    M 1 Reply Last reply Reply Quote 1
                                    • M Offline
                                      @rskoniec
                                      Aah thanks for the update. Really fast!!
                                      Now that u mention that windows installs the update automatic, I remember that I disabled windows update on my windows 10... that explans a lot! How stupid...
                                      Sorry for wasting your time, but thanks for the fast answer and for trying it out.
                                      • M Offline
                                        maamar @rskoniec
                                        @rskoniec thank you
                                        I did my updated
                                        • R Offline
                                          @mmarkvoort @maamar You welcome. :o)
                                          • Y Offline
                                            yunying
                                            Thank a lot.
                                            Reply just for feedback.
                                            Make sure your jumper at "TX"
                                            • 1
                                            • 2
                                            • 1 / 2
